type-c/DP转双路MIPI信号转换芯片LT7911D方案介绍
Description
The LT7911D is a high peRFormance DP1.2 to MIPI®DSI/CSI chip for VR/Smart phone/display application.
For DP1.2 input, LT7911D can be configured as 1,2,4 lane, also support lane swap function. Adaptive equalization makes it suitable for long cable application and the maximum bandwidth is up to 21.6Gbps.
For MIPI®DSI/CSI output, LT7911D features configurable single-port or dual-port or MIPI®DSI/CSI with 1 high-speed clock lane and 1~4 high-speed data lanes operating at maximum 1.5Gb/s/lane, which can support a total bandwidth of up to 12Gbps. LT7911D supports burst mode DSI video data transferring, also support flexible video data mapping path.
With sophisticated MCU and the EmbeddedFlash, LT7911D support EDID buffer, DP/eDP inputdetection and determine to enter into power saving mode automatically. When the receiver of LT7911D locks the input signal, MCU can read the recovered timing parameters by MSA registers to match the ASSR. The DPCD registers are accessible via system I2C when debugging the full link training. Once the fast link training used, system time will save at least 400ms.
2. Features
• Type-C
• DP/eDP Receiver
• Single/Dual-Port LVDS Transmitter
• Miscellaneous
3. Applications
• Mobile system
• VR
MIPI
11文章
373浏览量
51171 -
type-c
558文章
2062浏览量
278845
Type-C接口如何实现视频传输?
RK3588 Type-C一线通,DP显示输出实战指南
深入了解MAX14748 USB Type-C充电器:特性、应用与设计要点
AS7173+VL171设计TypeC转DP双向8K60/4K240转接线方案电路图
TUSB564:USB Type-C DP交替模式的高效解决方案
汽车电子利器:TPS25858-Q1和TPS25859-Q1双路3A USB Type-C充电端口转换器解析
汽车USB充电新选择:TPS2585x-Q1双路3A USB Type-C充电端口转换器解析
CS501 TYPE-C转DP1.4 8K@60HZ方案
GSV6155 Type-C/DP1.4 Retimer with MCU and PD
TUSB564 USB Type-C™ DP Alt Mode 线性重驱动交叉开关芯片技术文档总结
ASL原厂CS5266芯片特性概述 专为Type-C转HDMI拓展坞设计
type-c/DP转双路MIPI信号转换芯片LT7911D参数特性概述
