GitHub
作为全球最大的同性交友网站,GitHub可谓是又爱又恨,爱的是太多非常棒的开源项目了,有很大的参考价值,也方便我们自己托管项目,恨的是这个网站的访问实在是太不给力了,基本是随缘了,不同城市不同网络都各不相同,用宽带,手机流量也各不相同,大部分是不怎么好的。 最近发现一个叫做Fetch Github Hosts的项目,也许能帮到大家,这里只针对网络不好的同学哈,fetch-github-hosts是主要为解决研究及学习人员访问Github过慢或其他问题而提供的免费的Github hosts同步服务,项目开源,有写具体的使用方法,有需要的同学可以前往学习一下。简单粗暴的方法
手动添加hosts 访问https://hosts.gitcdn.top/hosts.txt这个网站,将网页的全部内容粘贴到你的hosts文件中。
Linux / MacOS hosts路径:/etc/hosts
Windows hosts路径:C:WindowsSystem32driversetchost
老宇哥这里也顺便贴出来,大家复制即可:
# fetch-github-hosts begin
140.82.112.26 alive.github.com
140.82.112.26 live.github.com
185.199.108.154 github.githubassets.com
140.82.112.21 central.github.com
185.199.111.133 desktop.githubusercontent.com
185.199.109.153 assets-cdn.github.com
185.199.108.133 camo.githubusercontent.com
185.199.108.133 github.map.fastly.net
146.75.113.194 github.global.ssl.fastly.net
52.192.72.89 gist.github.com
185.199.108.153 github.io
52.192.72.89 github.com
192.0.66.2 github.blog
52.69.239.207 api.github.com
185.199.109.133 raw.githubusercontent.com
185.199.109.133 user-images.githubusercontent.com
185.199.111.133 favicons.githubusercontent.com
185.199.109.133 avatars5.githubusercontent.com
185.199.109.133 avatars4.githubusercontent.com
185.199.109.133 avatars3.githubusercontent.com
185.199.108.133 avatars2.githubusercontent.com
185.199.109.133 avatars1.githubusercontent.com
185.199.111.133 avatars0.githubusercontent.com
185.199.111.133 avatars.githubusercontent.com
52.193.111.178 codeload.github.com
52.216.177.203 github-cloud.s3.amazonaws.com
52.216.177.203 github-com.s3.amazonaws.com
52.217.91.148 github-production-release-asset-2e65be.s3.amazonaws.com
52.217.91.148 github-production-user-asset-6210df.s3.amazonaws.com
52.217.91.148 github-production-repository-file-5c1aeb.s3.amazonaws.com
185.199.109.153 githubstatus.com
64.71.144.211 github.community
52.237.112.130 github.dev
140.82.112.21 collector.github.com
13.107.42.16 pipelines.actions.githubusercontent.com
185.199.108.133 media.githubusercontent.com
185.199.108.133 cloud.githubusercontent.com
185.199.108.133 objects.githubusercontent.com
# last fetch time: 2022-06-11T2302+08:00
# update url: https://hosts.gitcdn.top/hosts.txt
# fetch-github-hosts end
特别注意,在windows中,大家修改完hosts之后,直接保存不了,保存的时候先另存在桌面,再拖进去覆盖即可!
刷新生效:
Linux: /etc/init.d/network restart
Windows: ipconfig /flushdns
Macos: sudo killall -HUP mDNSResponder
试试访问效果
开源仓库:https://github.com/Licoy/fetch-github-hosts
GitHub镜像站或者使用Github镜像站,国内可以加速访问GitHub的网站(GitHub加速),使用起来和官网没啥区别,只是域名不同而已。
https://hub.おうか.tw
https://hub.連接.台灣
https://hub.fastgit.xyz
https://cdn.githubjs.cf
https://gitclone.com
举报投诉
开源
3文章
3333浏览量
42478 -
GitHub
3文章
470浏览量
16431
原文标题:提高访问GitHub速度方法
文章出处:【微信号:strongerHuang,微信公众号:strongerHuang】欢迎添加关注!文章转载请注明出处。
如何提高信噪比的有效方法
信噪比(SNR)是指信号与噪声的比例,是评价一个系统或设备性能的重要指标。提高信噪比可以通过多种方法实现,以下是一些有效的方法: 一、增加信号强度 提高发射功率 :在信号发射端,通过增
GitHub Copilot与Bitbucket、Jira、Confluence集成使用指南
如何将GitHub Copilot与Bitbucket、Jira和Confluence集成使用?实操指南有!
阅读了解如何在Bitbucket存储库中轻松使用GitHub Copilot,以及
内网通过公网地址访问内网服务器的设置方法
在一些场景下,内部网络中的服务器需要通过公网地址进行访问,尤其是在没有固定公网IP或需要在外部访问时。为了解决这一问题,可以使用以下几种方法实现内网穿透,方便地通过公网访问内网服务器。
Arm推出GitHub平台AI工具,简化开发者AI应用开发部署流程
专为 GitHub Copilot 设计的 Arm 扩展程序,可加速从云到边缘侧基于 Arm 平台的开发。
Arm 原生运行器为部署云原生、Windows on Arm 以及云到边缘侧的 AI
GitHub Copilot引入多模型支持
近日,据外媒报道,GitHub正在为其代码完成和编程工具Copilot引入多模型支持。这一举措将为开发者提供更加灵活和多样化的选择。 在近日举办的GitHub Universe大会上,GitHub
微软GitHub与Anthropic和谷歌合作
近日,微软旗下的GitHub宣布了一项重要合作,将Anthropic和谷歌的AI模型整合到其代码助理中,为数百万软件开发者提供新的AI模型选项。
上传本地项目代码到github
概述
GitHub是一个面向开源及私有软件项目的托管平台,因为只支持git 作为唯一的版本库格式进行托管,故名GitHub。本文主要讲解如何将本地代码上传至Github。
Git Bash的安装
发表于 09-11 16:33
GitHub推出GitHub Models服务,赋能开发者智能选择AI模型
8月2日,全球领先的代码托管平台GitHub宣布了一项重大创新——GitHub Models服务的正式推出。该服务被定位为AI时代的工程师助手,旨在帮助全球超过1亿的GitHub用户轻松找到并应用最适合其项目需求的AI模型。
esp32无法烧录github上的一个固件,为什么?
我准备用esp32-s2模组来做一个简易的激光雕刻机
代码是github上的https://github.com/bdring/FluidNC
在运行安装脚本的时候,提示我芯片是esp32-s2
发表于 06-17 08:00
【米尔-全志T113-i开发板试用】6、使用mDNS实现局域网域名访问
来访问设备呢?
可以的,要实现域名访问设备,有三种常见的方法:
在路由器上开启DNS域名解析服务(例如OpenWrt上常用的dnsmasq),并添加对应的域名和IP地址。这种方法对于D
发表于 02-23 18:46
提高电源整机效率的方法
电源整机效率是指电源将输入电能转换为输出电能的效率,通常用百分比表示。提高电源整机效率可以降低能源消耗,减少环境污染,提高设备的运行效率。以下是一些提高电源整机效率的方法: 1. 使用
ug内部错误,内存访问违例怎么解决
ug内部错误,内存访问违例怎么解决 内部错误和内存访问违例是编程中常见的问题,它们可能会导致应用程序崩溃、数据丢失或系统不稳定。在本文中,我将详细解释内部错误和内存访问违例的原因,如何解决这些
