处理以太网帧以及IP,UDP和ARP的模块
FPGA之家 来源:FPGA之家 作者:FPGA之家 2022-06-30 09:51 次阅读
基本介绍:
千兆位和10G数据包处理(8位和64位数据路径)的以太网相关组件的集合。包括用于处理以太网帧以及IP,UDP和ARP的模块,以及用于构建完整UDP/IP堆栈的组件。包括用于千兆位和10G的MAC模块,一个10G PCS/ PMA PHY模块以及一个10G组合MAC/PCS/PMA模块。还包括带有智能总线协同仿真端点的完整MyHDL测试平台。
仅对于IP和ARP支持,请使用ip_complete(1G)或ip_complete_64(10G)。
对于UDP,IP和ARP支持,请使用udp_complete(1G)或udp_complete_64(10G)。
顶层千兆和10G MAC模块是eth_mac_ *,具有各种接口,并且带有/不带有FIFO。顶层10G PCS/PMA PHY模块为eth_phy_10g。顶层10G MAC/ PCS/PMA组合模块为eth_mac_phy_10g。
通用信号:
    tdata   : Data (width generally DATA_WIDTH)
    tkeep   : Data word valid (width generally KEEP_WIDTH, present on _64 modules)
    tvalid  : Data valid
    tready  : Sink ready
    tlast   : End-of-frame
tuser : Bad frame (valid with tlast & tvalid)
文件如下:
    rtl/arp.v                       : ARP handling logic
    rtl/arp_64.v                    : ARP handling logic (64 bit)
    rtl/arp_cache.v                 : ARP LRU cache
    rtl/arp_eth_rx.v                : ARP frame receiver
    rtl/arp_eth_rx_64.v             : ARP frame receiver (64 bit)
    rtl/arp_eth_tx.v                : ARP frame transmitter
    rtl/arp_eth_tx_64.v             : ARP frame transmitter (64 bit)
    rtl/eth_arb_mux.py              : Ethernet frame arbitrated multiplexer generator
    rtl/axis_eth_fcs.v              : Ethernet FCS calculator
    rtl/axis_eth_fcs_64.v           : Ethernet FCS calculator (64 bit)
    rtl/axis_eth_fcs_insert.v       : Ethernet FCS inserter
    rtl/axis_eth_fcs_check.v        : Ethernet FCS checker
    rtl/axis_gmii_rx.v              : AXI stream GMII/MII receiver
    rtl/axis_gmii_tx.v              : AXI stream GMII/MII transmitter
    rtl/axis_xgmii_rx_32.v          : AXI stream XGMII receiver (32 bit)
    rtl/axis_xgmii_rx_64.v          : AXI stream XGMII receiver (64 bit)
    rtl/axis_xgmii_tx_32.v          : AXI stream XGMII transmitter (32 bit)
    rtl/axis_xgmii_tx_64.v          : AXI stream XGMII transmitter (64 bit)
    rtl/eth_arb_mux.v               : Ethernet frame arbitrated multiplexer
    rtl/eth_axis_rx.v               : Ethernet frame receiver
    rtl/eth_axis_rx_64.v            : Ethernet frame receiver (64 bit)
    rtl/eth_axis_tx.v               : Ethernet frame transmitter
    rtl/eth_axis_tx_64.v            : Ethernet frame transmitter (64 bit)
    rtl/eth_demux.v                 : Ethernet frame demultiplexer
    rtl/eth_mac_1g.v                : Gigabit Ethernet GMII MAC
    rtl/eth_mac_1g_fifo.v           : Gigabit Ethernet GMII MAC with FIFO
    rtl/eth_mac_1g_gmii.v           : Tri-mode Ethernet GMII/MII MAC
    rtl/eth_mac_1g_gmii_fifo.v      : Tri-mode Ethernet GMII/MII MAC with FIFO
    rtl/eth_mac_1g_rgmii.v          : Tri-mode Ethernet RGMII MAC
    rtl/eth_mac_1g_rgmii_fifo.v     : Tri-mode Ethernet RGMII MAC with FIFO
    rtl/eth_mac_10g.v               : 10G Ethernet XGMII MAC
    rtl/eth_mac_10g_fifo.v          : 10G Ethernet XGMII MAC with FIFO
    rtl/eth_mac_mii.v               : Ethernet MII MAC
    rtl/eth_mac_mii_fifo.v          : Ethernet MII MAC with FIFO
    rtl/eth_mac_phy_10g.v           : 10G Ethernet XGMII MAC/PHY
    rtl/eth_mac_phy_10g_fifo.v      : 10G Ethernet XGMII MAC/PHY with FIFO
    rtl/eth_mac_phy_10g_rx.v        : 10G Ethernet XGMII MAC/PHY RX with FIFO
    rtl/eth_mac_phy_10g_tx.v        : 10G Ethernet XGMII MAC/PHY TX with FIFO
    rtl/eth_mux.v                   : Ethernet frame multiplexer
    rtl/gmii_phy_if.v               : GMII PHY interface
    rtl/iddr.v                      : Generic DDR input register
    rtl/ip.v                        : IPv4 block
    rtl/ip_64.v                     : IPv4 block (64 bit)
    rtl/ip_arb_mux.v                : IP frame arbitrated multiplexer
    rtl/ip_complete.v               : IPv4 stack (IP-ARP integration)
    rtl/ip_complete_64.v            : IPv4 stack (IP-ARP integration) (64 bit)
    rtl/ip_demux.v                  : IP frame demultiplexer
    rtl/ip_eth_rx.v                 : IPv4 frame receiver
    rtl/ip_eth_rx_64.v              : IPv4 frame receiver (64 bit)
    rtl/ip_eth_tx.v                 : IPv4 frame transmitter
    rtl/ip_eth_tx_64.v              : IPv4 frame transmitter (64 bit)
    rtl/ip_mux.v                    : IP frame multiplexer
    rtl/lfsr.v                      : Generic LFSR/CRC module
    rtl/oddr.v                      : Generic DDR output register
    rtl/mii_phy_if.v                : MII PHY interface
    rtl/rgmii_phy_if.v              : RGMII PHY interface
    rtl/ssio_ddr_in.v               : Generic source synchronous IO DDR input module
    rtl/ssio_ddr_in_diff.v          : Generic source synchronous IO DDR differential input module
    rtl/ssio_ddr_out.v              : Generic source synchronous IO DDR output module
    rtl/ssio_ddr_out_diff.v         : Generic source synchronous IO DDR differential output module
    rtl/ssio_sdr_in.v               : Generic source synchronous IO SDR input module
    rtl/ssio_sdr_in_diff.v          : Generic source synchronous IO SDR differential input module
    rtl/ssio_sdr_out.v              : Generic source synchronous IO SDR output module
    rtl/ssio_sdr_out_diff.v         : Generic source synchronous IO SDR differential output module
    rtl/udp.v                       : UDP block
    rtl/udp_64.v                    : UDP block (64 bit)
    rtl/udp_arb_mux.v               : UDP frame arbitrated multiplexer
    rtl/udp_checksum_gen.v          : UDP checksum generator
    rtl/udp_checksum_gen_64.v       : UDP checksum generator (64 bit)
    rtl/udp_complete.v              : UDP stack (IP-ARP-UDP)
    rtl/udp_complete_64.v           : UDP stack (IP-ARP-UDP) (64 bit)
    rtl/udp_demux.v                 : UDP frame demultiplexer
    rtl/udp_ip_rx.v                 : UDP frame receiver
    rtl/udp_ip_rx_64.v              : UDP frame receiver (64 bit)
    rtl/udp_ip_tx.v                 : UDP frame transmitter
    rtl/udp_ip_tx_64.v              : UDP frame transmitter (64 bit)
    rtl/udp_mux.v                   : UDP frame multiplexer
    rtl/xgmii_baser_dec_64.v        : XGMII 10GBASE-R decoder
    rtl/xgmii_baser_enc_64.v        : XGMII 10GBASE-R encoder
    rtl/xgmii_deinterleave.v        : XGMII data/control de-interleaver
    rtl/xgmii_interleave.v          : XGMII data/control interleaver
AXI Stream 接口示例:
与标头数据一起传输
                  __    __    __    __    __    __    __
    clk        __/  \__/  \__/  \__/  \__/  \__/  \__/  \__
               ______________                   ___________
    hdr_ready                \_________________/
                        _____
    hdr_valid  ________/     \_____________________________
                        _____
    hdr_data   XXXXXXXXX_HDR_XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                        ___________ _____ _____
    tdata      XXXXXXXXX_A0________X_A1__X_A2__XXXXXXXXXXXX
    tkeep      XXXXXXXXX_K0________X_K1__X_K2__XXXXXXXXXXXX
    tvalid     ________/                       \___________
                              _________________
    tready     ______________/                 \___________
                                          _____
    tlast      __________________________/     \___________
    tuser      ____________________________________________
两个字节的传输,每个字节后都有接收器暂停
              __    __    __    __    __    __    __    __    __
    clk    __/  \__/  \__/  \__/  \__/  \__/  \__/  \__/  \__/  \__
                    _____ _________________
    tdata  XXXXXXXXX_D0__X_D1______________XXXXXXXXXXXXXXXXXXXXXXXX
    tkeep  XXXXXXXXX_K0__X_K1______________XXXXXXXXXXXXXXXXXXXXXXXX
    tvalid ________/                       \_______________________
           ______________             _____             ___________
    tready               \___________/     \___________/
                          _________________
    tlast  ______________/                 \_______________________
    tuser  ________________________________________________________
两个背对背数据包,无暂停
                    _____ _____ _____ _____ _____ _____
    tdata  XXXXXXXXX_A0__X_A1__X_A2__X_B0__X_B1__X_B2__XXXXXXXXXXXX
    tkeep  XXXXXXXXX_K0__X_K1__X_K2__X_K0__X_K1__X_K2__XXXXXXXXXXXX
    tready
                                _____             _____
    tlast  ____________________/     \___________/     \___________
测试文件:
    tb/arp_ep.py         : MyHDL ARP frame endpoints
    tb/axis_ep.py        : MyHDL AXI Stream endpoints
    tb/baser_serdes.py   : MyHDL 10GBASE-R SERDES endpoints
    tb/eth_ep.py         : MyHDL Ethernet frame endpoints
    tb/gmii_ep.py        : MyHDL GMII endpoints
    tb/ip_ep.py          : MyHDL IP frame endpoints
    tb/mii_ep.py         : MyHDL MII endpoints
    tb/rgmii_ep.py       : MyHDL RGMII endpoints
    tb/udp_ep.py         : MyHDL UDP frame endpoints
    tb/xgmii_ep.py       : MyHDL XGMII endpoints
测试:
运行包含的测试平台需要使用cocotb,cocotbext-axi,cocotbext-eth和Icarus Verilog。可以直接使用pytest(需要cocotb-test),通过tox或通过cocotb makefile进行pytest来运行测试平台。
审核编辑 :李倩
  • 以太网
  • Verilog
  • 数据包
原文标题:以太网IP核代码(verilog)
文章出处:【微信号:zhuyandz,微信公众号:FPGA之家】欢迎添加关注!文章转载请注明出处。
    ALINX发布100G以太网UDP/IP协议栈IP
    ALINX近日宣布,基于AMD 100G以太网MAC IP,成功开发出全新的100G以太网UDP/IP协议栈
    的头像 发表于 01-07 11:25 193次阅读
    以太网和TCP/IP的关系解析
    在现代计算机网络中,以太网和TCP/IP协议栈是构建网络通信的基础。以太网定义了局域(LAN)中的数据链路层和物理层的技术标准,而TCP/IP
    的头像 发表于 11-08 09:21 808次阅读
    以太网协议的种类和特点
    (DIX Ethernet) 定义 :以太网II是由DEC、Intel和Xerox(DIX)联合定义的,是最早的以太网标准。 特点 :使用MAC地址进行设备间的通信,结构简单,易于实现。 1.2
    的头像 发表于 11-08 09:10 1365次阅读
    以太网交换模式有哪几种
    以太网交换模式是指以太网交换机在数据传输过程中所采用的处理和转发数据的方式。以太网交换机作为局域
    的头像 发表于 10-08 10:12 1005次阅读
    以太网格式和功能详解
    以太网(Ethernet Frame)是以太网(Ethernet)协议用于在局域(LAN)中传输数据的基本单位。理解以太网
    的头像 发表于 10-08 10:03 2079次阅读
    以太网结构是怎样的
    的头像 发表于 10-08 10:00 1238次阅读
    解读工业以太网标准:Profinet与EtherNet/IP
    随着工业自动化技术的飞速发展,工业以太网标准作为连接各种自动化设备、控制系统和信息系统的重要桥梁,其重要性日益凸显。在众多工业以太网标准中,Profinet和EtherNet/IP凭借其各自的特点
    的头像 发表于 06-28 16:34 2080次阅读
    以太网无法连接外网IP,提示No route to host,为什么?
    调试以太网,创建socket后无法连接外网IP,提示错误No route to host。(用的示例protocolssocketstcp_client,以太网芯片选用的w5500) 自己做了实验
    发表于 06-21 06:43
    基于FPGA的千兆以太网设计
    今天给大侠带来基于FPGA的千兆以太网设计,话不多说,上货。 一、设计概述 由于设计比较复杂,本篇带来设计流程以及设计思路,仅供各位大侠参考。 本篇通过管理数据输入输出MDIO配置
    发表于 06-10 16:44
    STM32F429以太网UDP通讯异常的原因?怎么解决?
    专家好: 目前正在调试STM32F429的以太网,项目使用的是FreeRTOS+LWIP模式,创建工程使用的是cubemx,使用的开发板是nucleo-144,目前正在调试以太网部分。测试用程序
    发表于 04-29 08:29
    PLC以太网开放式通信概述
    以太网开放式通信概述:   1、以太网开放式通信,即就是通信协议是由用户自由定义的;   2、以太网开放式通信是基于TCP、UDP运输层的一种软件通信协议;   3、
    发表于 04-16 12:06 1111次阅读
    PLC<b class='flag-5'>以太网</b>开放式通信概述
    FPGA学习-以太网的原理介绍
    以太网链路上的数据包称作以太网以太网起始部分由前导码和开始符组成。后面紧跟着一个
    的头像 发表于 04-02 16:26 1725次阅读
    FPGA学习-<b class='flag-5'>以太网</b>的原理介绍
    以太网中的格式及不同端口速率下的quanta值介绍
    PAUSE以太网在全双工模式下,MAC控制子层发出的流量控制
    的头像 发表于 02-29 10:04 2513次阅读
    <b class='flag-5'>以太网</b>中的<b class='flag-5'>帧</b>格式及不同端口速率下的quanta值介绍
    FPGA通过UDP以太网传输JPEG压缩图片
    在 FPGA 上实现了 JPEG 压缩和 UDP 以太网传输。从摄像机的输入中获取单个灰度,使用 JPEG 标准对其进行压缩,然后通过UDP以太网
    的头像 发表于 01-26 09:30 922次阅读
    FPGA通过<b class='flag-5'>UDP</b><b class='flag-5'>以太网</b>传输JPEG压缩图片
    科普科普以太网的定义、种类以及晶振在以太网上的应用
    科普科普以太网的定义、种类以及晶振在以太网上的应用  以太网是一种用于局域网通信的传输技术,它是一种在计算机网络中常用的传输协议,用于将数据包从一个节点传输到另一个节点。本文将详细介绍
    的头像 发表于 01-24 16:11 1195次阅读
