cocotb中的基础语法
FPGA之家 来源:FPGA之家 作者:FPGA之家 2022-07-21 09:18 次阅读
cocotb的出现使得我们能够在做RTL仿真验证时依托Python来进行测试用例的构建,当我们习惯了用Verilog、SystemVerilog来构建测试用例时,切换到cocotb后最直观的方式便是我们能够建立cocotb中的基础语法与SystemVerilog中仿真常用的关键字又一个对应,能够使我们又一个初步的对照。本篇就cocotb中的基础语法与SystemVerilog中的常用语法做一个对照总结。
非阻塞赋值
在使用Systemverilog进行仿真时,对于接口信号,往往建议采用非阻塞赋值进行操作,其符号为“<=”.
在cocotb中,对于信号的赋值,其提供相应的非阻塞赋值方式,其符号也同样为“<=”。
在cocotb的手册里提到:
The syntaxsig<= new_value is a short form of sig.value = new_value. It not only resembles HDL syntax, but also has the same semantics: writes are not applied immediately, but delayed until the next write cycle.
因而我们可以在cocotb中这样来进行非阻塞赋值:
# Get a reference to the "clk" signal and assign a valueclk = dut.clkclk.value = 1
# Direct assignment through the hierarchydut.input_signal <= 12
# Assign a value to a memory deep in the hierarchydut.sub_block.memory.array[4] <= 2
阻塞赋值
针对阻塞赋值(立即生效),cocotb提供了相应的语法:
setimmediatevalue(value)
因而对于阻塞赋值,我们在cocotb中可以这样写:
dut.input_signal.setimmediatevalue(1)
信号值读取
对于信号的读取,我们在SystemVerilog中,可以直接读取信号值,而在cocotb中,其为接口变量提供了value方法属性用于获取信号值。
读取方式:sig.value
返回类型:BinaryValue
Accessing thevalueproperty of a handle object will return aBinaryValueobject. Any unresolved bits are preserved and can be accessed using thebinstrattribute, or a resolved integer value can be accessed using theintegerattribute.
信号的读取我们可以这么来写:
# Read a value back from the DUTcount=dut.counter.valueprint(count.binstr)1X1010# Resolve the value to an integer (X or Z treated as 0)print(count.integer)42# Show number of bits in a valueprint(count.n_bits)6
#Time
在仿真里延迟等待是经常遇到的,在cocotb里,我们通过Timer来实现延迟:
cocotb.triggers.Timer(time_ps,units=None)
Parameters
time_ps (numbers.Real or decimal.Decimal) – The time value. Note that despite the name this is not actually in picoseconds but depends on the units argument.
units (str or None, optional) – One of None, 'fs', 'ps', 'ns', 'us', 'ms', 'sec'. When no units is given (None) the timestep is determined by the simulator.
由于cocotb是基于协程的,而延迟函数的执行的时间长度是依赖于仿真器的,因此Timer延迟的执行需调用await:
await Timer(1, units='ns')
边沿检测
在SystemVerilog中我们常用posedge、negedge来检测上升沿和下降沿,在cocotb里,针对边沿检测,其提供了四个调用:
等待调变
class cocotb.triggers.Edge(*args, **kwargs)
Fires on any value change of signal.
等待上升沿
class cocotb.triggers.RisingEdge(*args, **kwargs)
Fires on the rising edge of signal, on a transition from 0 to 1.
等待下降沿
class cocotb.triggers.FallingEdge(*args, **kwargs)
Fires on the falling edge of signal, on a transition from 1 to 0.
检测等待指定到个数边沿
class cocotb.triggers.ClockCycles(signal,num_cycles,rising=True)
Fires after num_cycles transitions of signal from 0 to 1.
Parameters
signal – The signal to monitor.
num_cycles (int) – The number of cycles to count.
rising (bool, optional) – If True, the default, count rising edges. Otherwise, count falling edges.
我们在使用时,可以这么来写:
#等待信号signalA发生变化await cocotb.triggers.Edge(dut.signalA)#等待signalA从0变为1await cocotb.triggers.RisingEdge(dut.signalA)#等待signalA从1变为0await cocotb.triggers.FallingEdge(dut.signalA)#等待signalA从0变为1三次awaitcocotb.triggers.ClockCycles(dut.signalA,3,true)
fork-join_none
SystemVerilog中的fork-join_none用于发起一个线程但不等待线程的结束,在cocotb中,相应的语法为fork:
cocotb.fork()
Schedule a coroutine to be run concurrently
在写仿真代码时,我们可以这么写:
async def reset_dut(reset_n, duration_ns):    reset_n <= 0    await Timer(duration_ns, units='ns')    reset_n <= 1    reset_n._log.debug("Reset complete")reset_thread = cocotb.fork(reset_dut(reset_n, duration_ns=500))
这里值得注意的是,由于fork是起一个协程,因而resut_dut需添加async声明。
fork-join
与SystemVerilog中相对应的,cocotb等待一个协程的结束同样提供了join方法:
class cocotb.triggers.Join(*args, **kwargs)
Fires when a fork()ed coroutine completes.
The result of blocking on the trigger can be used to get the coroutine result:
使用方式:
async def coro_inner():    await Timer(1, units='ns')    return "Hello world"
task = cocotb.fork(coro_inner())result = await Join(task)assert result == "Hello world"
fork-any
相较于SystemVerilog中的join-any语法,cocotb并无专门的对应语法,但却有相似的方法供调用:
class cocotb.triggers.First(*triggers)
等待第一个协程结束即返回
t1 = Timer(10, units='ps')t2 = Timer(11, units='ps')t_ret = await First(t1, t2)
这里我们通过First等待t1、t2第一个返回的结果后await结束,并将第一个返回的协程的返回结果赋值给t_ret。
event
对于SystemVerilog中的event,在cocotb中同样提供类似的event:
class cocotb.triggers.Event(name=None)
用于两个协程间的同步
方法:
set(data=None):唤醒所有等待该事件的协程
wait(): 等待事件的出发(await),如果事件已经触发,立即返回
clear(): 清楚以触发的事件
is_set():判断事件是否触发
旗语
cocotb中提供了Lock操作用来实现与SystemVerilog中相似的操作,不过Lock不可声明旗语为多个:
class cocotb.triggers.Lock(name=None)
方法:
locked : True if the lock is held.
acquire():Produce a trigger which fires when the lock is acquired.
release(): Release the lock.
mailbox
SystemVerilog中的mailbox主要用于不同进程间的通信,在cocotb中,普通的Python的队列即可实现该功能(协程中无需没有进程间同步问题)。
审核编辑 :李倩
  • 代码
  • 语法
  • 非阻塞赋值
原文标题:cocotb—基础语法对照篇
文章出处:【微信号:zhuyandz,微信公众号:FPGA之家】欢迎添加关注!文章转载请注明出处。
    标准网络时钟系统:数字时代的通用语法
    特效与舞台灯光保持帧级对齐——这些突破物理界限的协作,都依赖着数字世界的基础语法:标准网络时钟系统。 数字世界的巴别塔解药       物联网设备每秒产生2.5亿个带时间戳的数据点,但若缺乏统一标准,就像全球机场使用不同时区:工业机
    的头像 发表于 03-03 10:08 142次阅读
    SSM开发的常见问题及解决方案
    在SSM(Spring + Spring MVC + MyBatis)框架的开发过程,开发者可能会遇到一些常见问题。以下是对这些问题的详细分析以及相应的解决方案: 一、配置文件问题 问题描述
    的头像 发表于 12-17 09:16 831次阅读
    SQL错误代码及解决方案
    在SQL数据库开发和管理,常见的错误代码及其解决方案可以归纳如下: 一、语法错误(Syntax Errors) 错误代码 :无特定代码,但通常会在错误消息明确指出是语法错误。 原因
    的头像 发表于 11-19 10:21 4630次阅读
    Lua语法基础教程(下篇)
    今天我们继续学习Lua语法基础教程,下篇。 九、函数 9.1 初识函数 函数是指一段在一起的、可以做某一件事儿的程序,也叫做子程序。 在前面的内容,我们已经接触过了函数的调用,这个函数就是前面用到
    的头像 发表于 10-26 11:41 441次阅读
    Lua<b class='flag-5'>语法</b>基础教程(下篇)
    Lua语法基础教程(中篇)
    今天我们继续学习Lua语法基础教程,中篇。 五、变量 5.1 number变量 变量,可以看作是一个桶,在里面装你想要装的内容。这些内容可以是Lua包含的所有合法类型。 例如:我想要新建一个桶,名叫
    的头像 发表于 10-26 11:39 440次阅读
    Lua<b class='flag-5'>语法</b>基础教程(中篇)
    Verilog语法运算符的用法
    verilog语法中使用以下两个运算符可以简化我们的位选择代码。
    的头像 发表于 10-25 15:17 1794次阅读
    Verilog<b class='flag-5'>语法</b><b class='flag-5'>中</b>运算符的用法
    Lua语法基础教程(上篇)
    今天我们来学习Lua语法基础教程。由于篇幅过长,将分为上中下三篇进行讲解,本篇为上篇。 一、初识Lua Lua 是一种轻量小巧的脚本语言,它用标准C语言编写并以源代码形式开放。这意味着什么呢?这
    的头像 发表于 10-24 07:17 453次阅读
    《DNK210使用指南 -CanMV版 V1.0》第七章 基于CanMV的MicroPython语法开发环境搭建
    第七章 基于CanMV的MicroPython语法开发环境搭建 前面章节已经介绍了如何编译CanMV固件,并将编译好的CanMV固件烧录至Kendryte K210,本章将介绍如何在Windows
    发表于 09-13 09:30
    嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-shell脚本编写之流程控制
    1、条件语句shell语句的流程控制与C语言不一样,流程控制不能为空。shellif语法如下,其中confition表示条件判断式,command为程序段落。if else语法
    发表于 09-05 09:06
    TestStand表达式中常用的语法规则和运算符使用
    TestStand也有自己的语言嘛?在回答这个问题之前大家可以想一下在使用TestStand时有一个和语言密切相关的属性。没错那就是表达式(Expressions),在这篇文章,小编将以Q&A的方式来带着大家来理解并熟悉TestStand表达式较为常用的一些
    的头像 发表于 08-15 18:10 2376次阅读
    TestStand表达式中常用的<b class='flag-5'>语法</b>规则和运算符使用
    TINA-TI导入spice模型失败,提示语法元素错误是哪里出了问题?
    在使用TINA-TI 导入器件的Spice模型时,提示错误语法元素错误,不能导入器件,其spice内容如下:烦请知道,非常感谢! * DRB501VM-40 D model * PKG: UMD2
    发表于 08-09 07:51
    用python写验证环境cocotb
    本文介绍了cocotb的安装、python tb文件的写法、用xrun仿真cocotb的脚本等,我们来看看体验如何。
    的头像 发表于 07-24 09:38 744次阅读
    用python写验证环境<b class='flag-5'>cocotb</b>
    HarmonyOS Next 原生应用开发-ArkTS语法适配背景说明
    规则基于上述设计考虑进行了明确定义,同时,SDK增加了在编译流程对.ets文件的ArkTS语法检查,通过编译告警或编译失败提示开发者适配新的ArkTS语法。 根据工程
    发表于 07-01 16:49
    FPGA学习笔记---基本语法
    Verilog语法是指硬件能够实现的语法。它的子集很小。常用的RTL语法结构如下: 1、模块声明:module ... end module 2、端口声明:input, output, inout
    发表于 06-23 14:58
    直流可编程电子负载IT8500系列编程与语法指南
    电子发烧友网站提供《直流可编程电子负载IT8500系列编程与语法指南.pdf》资料免费下载
    发表于 04-14 09:56 3次下载
