MicroBlaze大内部存储器(AXI BRAM)设计
石飞鹏 来源:CZM陈先生123 作者:CZM陈先生123 2022-08-02 10:09 次阅读
MicroBlaze可以使用AXI BRAM存放数据和指令。有些客户软件很大,需要把AXI BRAM的空间做到最大。AXI BRAM底层是Block RAM或者Ultra RAM。器件的Block RAM或者Ultra RAM个数,决定了AXI BRAM的大小。
在ZCU106单板上,有312个Block RAM,有96个Ultra RAM。客户需要1MB存储空间。实现MicroBlaze时,也使用Block RAM实现Cache,和Local Memory。剩下的个Block RAM不够做1MB的AXI BRAM。为了实现1MB空间,可以用Block RAM实现512KB AXI BRAM、256KB AXI BRAM;再使用Ultra RAM实现256KB AXI BRAM。为这三个AXI BRAM分配连续的地址空间,从而使软件感觉到这是一个存储器。其中,Block RAM和Ultra RAM还可以根据实际情况调整,比如用Block RAM实现512KB AXI BRAM;用Ultra RAM实现512KB AXI BRAM,两个存储器也可以实现1MB存储空间。
Vivado的Block设计
Vivado的地址分配
Vivado的器件资源使用情况
下面是Vivado IP Integrator的TCL脚本。
# This is a generated script based on design: design_1
# Though there are limitations about the generated script,
# the main purpose of this utility is to make learning
# IP Integrator Tcl commands easier.
namespace eval _tcl {
proc get_script_folder {} {
set script_path [file normalize [info script]]
set script_folder [file dirname $script_path]
return $script_folder
variable script_folder
set script_folder [_tcl::get_script_folder]
# Check if script is running in correct Vivado version.
set scripts_vivado_version 2018.3
set current_vivado_version [version -short]
if { [string first $scripts_vivado_version $current_vivado_version] == -1 } {
puts ""
common::send_msg_id "BD_TCL-1002" "WARNING" "This script was generated using Vivado <$scripts_vivado_version> without IP versions in the create_bd_cell commands, but is now being run in <$current_vivado_version> of Vivado. There may have been major IP version changes between Vivado <$scripts_vivado_version> and <$current_vivado_version>, which could impact the parameter settings of the IPs."
# START
# To test this script, run the following commands from Vivado Tcl console:
# source design_1_script.tcl
# If there is no project opened, this script will create a
# project, but make sure you do not have an existing project
# <./myproj/project_1.xpr> in the current working folder.
set list_projs [get_projects -quiet]
if { $list_projs eq "" } {
create_project project_1 myproj -part xczu7ev-ffvc1156-2-e
set_property BOARD_PART xilinx.com:zcu106:part0:2.3 [current_project]
# CHANGE DESIGN NAME HERE
variable design_name
set design_name design_1
# If you do not already have an existing IP Integrator design open,
# you can create a design using the following command:
# create_bd_design $design_name
# Creating design if needed
set errMsg ""
set nRet 0
set cur_design [current_bd_design -quiet]
set list_cells [get_bd_cells -quiet]
if { ${design_name} eq "" } {
# USE CASES:
# 1) Design_name not set
set errMsg "Please set the variable  to a non-empty value."
set nRet 1
} elseif { ${cur_design} ne "" && ${list_cells} eq "" } {
# USE CASES:
# 2): Current design opened AND is empty AND names same.
# 3): Current design opened AND is empty AND names diff; design_name NOT in project.
# 4): Current design opened AND is empty AND names diff; design_name exists in project.
if { $cur_design ne $design_name } {
common::send_msg_id "BD_TCL-001" "INFO" "Changing value of  from <$design_name> to <$cur_design> since current design is empty."
set design_name [get_property NAME $cur_design]
common::send_msg_id "BD_TCL-002" "INFO" "Constructing design in IPI design <$cur_design>..."
} elseif { ${cur_design} ne "" && $list_cells ne "" && $cur_design eq $design_name } {
# USE CASES:
# 5) Current design opened AND has components AND same names.
set errMsg "Design <$design_name> already exists in your project, please set the variable  to another value."
set nRet 1
} elseif { [get_files -quiet ${design_name}.bd] ne "" } {
# USE CASES:
# 6) Current opened design, has components, but diff names, design_name exists in project.
# 7) No opened design, design_name exists in project.
set nRet 2
} else {
# USE CASES:
# 8) No opened design, design_name not in project.
# 9) Current opened design, has components, but diff names, design_name not in project.
common::send_msg_id "BD_TCL-003" "INFO" "Currently there is no design <$design_name> in project, so creating one..."
common::send_msg_id "BD_TCL-004" "INFO" "Making design <$design_name> as current_bd_design."
current_bd_design $design_name
common::send_msg_id "BD_TCL-005" "INFO" "Currently the variable  is equal to "$design_name"."
if { $nRet != 0 } {
catch {common::send_msg_id "BD_TCL-114" "ERROR" $errMsg}
return $nRet
set bCheckIPsPassed 1
# CHECK IPs
set bCheckIPs 1
if { $bCheckIPs == 1 } {
set list_check_ips "\
xilinx.com:ip:axi_bram_ctrl:*\
xilinx.com:ip:blk_mem_gen:*\
xilinx.com:ip:axi_timer:*\
xilinx.com:ip:clk_wiz:*\
xilinx.com:ip:mdm:*\
xilinx.com:ip:microblaze:*\
xilinx.com:ip:axi_intc:*\
xilinx.com:ip:xlconcat:*\
xilinx.com:ip:proc_sys_reset:*\
xilinx.com:ip:lmb_bram_if_cntlr:*\
xilinx.com:ip:lmb_v10:*\
set list_ips_missing ""
common::send_msg_id "BD_TCL-006" "INFO" "Checking if the following IPs exist in the project's IP catalog: $list_check_ips ."
foreach ip_vlnv $list_check_ips {
set ip_obj [get_ipdefs -all $ip_vlnv]
if { $ip_obj eq "" } {
lappend list_ips_missing $ip_vlnv
if { $list_ips_missing ne "" } {
catch {common::send_msg_id "BD_TCL-115" "ERROR" "The following IPs are not found in the IP Catalog:\n $list_ips_missing\n\nResolution: Please add the repository containing the IP(s) to the project." }
set bCheckIPsPassed 0
if { $bCheckIPsPassed != 1 } {
common::send_msg_id "BD_TCL-1003" "WARNING" "Will not continue with creation of design due to the error(s) above."
return 3
# DESIGN PROCs
# Hierarchical cell: microblaze_0_local_memory
proc create_hier_cell_microblaze_0_local_memory { parentCell nameHier } {
if { $parentCell eq "" || $nameHier eq "" } {
catch {common::send_msg_id "BD_TCL-102" "ERROR" "create_hier_cell_microblaze_0_local_memory() - Empty argument(s)!"}
return
# Get object for parentCell
set parentObj [get_bd_cells $parentCell]
if { $parentObj == "" } {
catch {common::send_msg_id "BD_TCL-100" "ERROR" "Unable to find parent cell <$parentCell>!"}
return
# Make sure parentObj is hier blk
set parentType [get_property TYPE $parentObj]
if { $parentType ne "hier" } {
catch {common::send_msg_id "BD_TCL-101" "ERROR" "Parent <$parentObj> has TYPE = <$parentType>. Expected to be ."}
return
# Save current instance; Restore later
set oldCurInst [current_bd_instance .]
# Set parent object as current
current_bd_instance $parentObj
# Create cell and set as current instance
set hier_obj [create_bd_cell -type hier $nameHier]
current_bd_instance $hier_obj
# Create interface pins
create_bd_intf_pin -mode MirroredMaster -vlnv xilinx.com:interface:lmb_rtl:1.0 DLMB
create_bd_intf_pin -mode MirroredMaster -vlnv xilinx.com:interface:lmb_rtl:1.0 ILMB
# Create pins
create_bd_pin -dir I -type clk LMB_Clk
create_bd_pin -dir I -type rst SYS_Rst
# Create instance: dlmb_bram_if_cntlr, and set properties
set dlmb_bram_if_cntlr [ create_bd_cell -type ip -vlnv xilinx.com:ip:lmb_bram_if_cntlr dlmb_bram_if_cntlr ]
set_property -dict [ list \
CONFIG.C_ECC {1} \
] $dlmb_bram_if_cntlr
# Create instance: dlmb_v10, and set properties
set dlmb_v10 [ create_bd_cell -type ip -vlnv xilinx.com:ip:lmb_v10 dlmb_v10 ]
# Create instance: ilmb_bram_if_cntlr, and set properties
set ilmb_bram_if_cntlr [ create_bd_cell -type ip -vlnv xilinx.com:ip:lmb_bram_if_cntlr ilmb_bram_if_cntlr ]
CONFIG.C_ECC {1} \
] $ilmb_bram_if_cntlr
# Create instance: ilmb_v10, and set properties
set ilmb_v10 [ create_bd_cell -type ip -vlnv xilinx.com:ip:lmb_v10 ilmb_v10 ]
# Create instance: lmb_bram, and set properties
set lmb_bram [ create_bd_cell -type ip -vlnv xilinx.com:ip:blk_mem_gen lmb_bram ]
CONFIG.Memory_Type {True_Dual_Port_RAM} \
CONFIG.use_bram_block {BRAM_Controller} \
] $lmb_bram
# Create interface connections
connect_bd_intf_net -intf_net microblaze_0_dlmb [get_bd_intf_pins DLMB] [get_bd_intf_pins dlmb_v10/LMB_M]
connect_bd_intf_net -intf_net microblaze_0_dlmb_bus [get_bd_intf_pins dlmb_bram_if_cntlr/SLMB] [get_bd_intf_pins dlmb_v10/LMB_Sl_0]
connect_bd_intf_net -intf_net microblaze_0_dlmb_cntlr [get_bd_intf_pins dlmb_bram_if_cntlr/BRAM_PORT] [get_bd_intf_pins lmb_bram/BRAM_PORTA]
connect_bd_intf_net -intf_net microblaze_0_ilmb [get_bd_intf_pins ILMB] [get_bd_intf_pins ilmb_v10/LMB_M]
connect_bd_intf_net -intf_net microblaze_0_ilmb_bus [get_bd_intf_pins ilmb_bram_if_cntlr/SLMB] [get_bd_intf_pins ilmb_v10/LMB_Sl_0]
connect_bd_intf_net -intf_net microblaze_0_ilmb_cntlr [get_bd_intf_pins ilmb_bram_if_cntlr/BRAM_PORT] [get_bd_intf_pins lmb_bram/BRAM_PORTB]
# Create port connections
connect_bd_net -net SYS_Rst_1 [get_bd_pins SYS_Rst] [get_bd_pins dlmb_bram_if_cntlr/LMB_Rst] [get_bd_pins dlmb_v10/SYS_Rst] [get_bd_pins ilmb_bram_if_cntlr/LMB_Rst] [get_bd_pins ilmb_v10/SYS_Rst]
connect_bd_net -net microblaze_0_Clk [get_bd_pins LMB_Clk] [get_bd_pins dlmb_bram_if_cntlr/LMB_Clk] [get_bd_pins dlmb_v10/LMB_Clk] [get_bd_pins ilmb_bram_if_cntlr/LMB_Clk] [get_bd_pins ilmb_v10/LMB_Clk]
# Restore current instance
current_bd_instance $oldCurInst
# Procedure to create entire design; Provide argument to make
# procedure reusable. If parentCell is "", will use root.
proc create_root_design { parentCell } {
if { $parentCell eq "" } {
set parentCell [get_bd_cells /]
catch {common::send_msg_id "BD_TCL-100" "ERROR" "Unable to find parent cell < $parentCell>!"}
return
return
# Create interface ports
set user_si570_sysclk [ create_bd_intf_port -mode Slave -vlnv xilinx.com:interface:diff_clock_rtl:1.0 user_si570_sysclk ]
CONFIG.FREQ_HZ {300000000} \
] $user_si570_sysclk
# Create ports
set reset [ create_bd_port -dir I -type rst reset ]
CONFIG.POLARITY {ACTIVE_HIGH} \
] $reset
# Create instance: axi_bram_ctrl_0, and set properties
set axi_bram_ctrl_0 [ create_bd_cell -type ip -vlnv xilinx.com:ip:axi_bram_ctrl axi_bram_ctrl_0 ]
# Create instance: axi_bram_ctrl_0_bram, and set properties
set axi_bram_ctrl_0_bram [ create_bd_cell -type ip -vlnv xilinx.com:ip:blk_mem_gen axi_bram_ctrl_0_bram ]
] $axi_bram_ctrl_0_bram
# Create instance: axi_timer_0, and set properties
set axi_timer_0 [ create_bd_cell -type ip -vlnv xilinx.com:ip:axi_timer axi_timer_0 ]
# Create instance: clk_wiz_1, and set properties
set clk_wiz_1 [ create_bd_cell -type ip -vlnv xilinx.com:ip:clk_wiz clk_wiz_1 ]
CONFIG.CLK_IN1_BOARD_INTERFACE {user_si570_sysclk} \
CONFIG.PRIM_SOURCE {Differential_clock_capable_pin} \
CONFIG.RESET_BOARD_INTERFACE {reset} \
CONFIG.USE_BOARD_FLOW {true} \
] $clk_wiz_1
# Create instance: mdm_1, and set properties
set mdm_1 [ create_bd_cell -type ip -vlnv xilinx.com:ip:mdm mdm_1 ]
CONFIG.C_ADDR_SIZE {32} \
CONFIG.C_M_AXI_ADDR_WIDTH {32} \
CONFIG.C_USE_UART {1} \
] $mdm_1
# Create instance: microblaze_0, and set properties
set microblaze_0 [ create_bd_cell -type ip -vlnv xilinx.com:ip:microblaze microblaze_0 ]
CONFIG.C_DEBUG_ENABLED {1} \
CONFIG.C_D_AXI {1} \
CONFIG.C_D_LMB {1} \
CONFIG.C_I_LMB {1} \
CONFIG.G_TEMPLATE_LIST {10} \
] $microblaze_0
# Create instance: microblaze_0_axi_intc, and set properties
set microblaze_0_axi_intc [ create_bd_cell -type ip -vlnv xilinx.com:ip:axi_intc microblaze_0_axi_intc ]
CONFIG.C_HAS_FAST {1} \
] $microblaze_0_axi_intc
# Create instance: microblaze_0_axi_periph, and set properties
set microblaze_0_axi_periph [ create_bd_cell -type ip -vlnv xilinx.com:ip:axi_interconnect microblaze_0_axi_periph ]
CONFIG.NUM_MI {3} \
CONFIG.NUM_SI {1} \
] $microblaze_0_axi_periph
# Create instance: microblaze_0_axi_periph1, and set properties
set microblaze_0_axi_periph1 [ create_bd_cell -type ip -vlnv xilinx.com:ip:axi_interconnect microblaze_0_axi_periph1 ]
CONFIG.NUM_MI {1} \
CONFIG.NUM_SI {2} \
] $microblaze_0_axi_periph1
# Create instance: microblaze_0_local_memory
create_hier_cell_microblaze_0_local_memory [current_bd_instance .] microblaze_0_local_memory
# Create instance: microblaze_0_xlconcat, and set properties
set microblaze_0_xlconcat [ create_bd_cell -type ip -vlnv xilinx.com:ip:xlconcat microblaze_0_xlconcat ]
# Create instance: rst_clk_wiz_1_100M, and set properties
set rst_clk_wiz_1_100M [ create_bd_cell -type ip -vlnv xilinx.com:ip:proc_sys_reset rst_clk_wiz_1_100M ]
] $rst_clk_wiz_1_100M
connect_bd_intf_net -intf_net axi_bram_ctrl_0_BRAM_PORTA [get_bd_intf_pins axi_bram_ctrl_0/BRAM_PORTA] [get_bd_intf_pins axi_bram_ctrl_0_bram/BRAM_PORTA]
connect_bd_intf_net -intf_net axi_bram_ctrl_0_BRAM_PORTB [get_bd_intf_pins axi_bram_ctrl_0/BRAM_PORTB] [get_bd_intf_pins axi_bram_ctrl_0_bram/BRAM_PORTB]
connect_bd_intf_net -intf_net microblaze_0_M_AXI_DC [get_bd_intf_pins microblaze_0/M_AXI_DC] [get_bd_intf_pins microblaze_0_axi_periph1/S00_AXI]
connect_bd_intf_net -intf_net microblaze_0_M_AXI_IC [get_bd_intf_pins microblaze_0/M_AXI_IC] [get_bd_intf_pins microblaze_0_axi_periph1/S01_AXI]
connect_bd_intf_net -intf_net microblaze_0_axi_dp [get_bd_intf_pins microblaze_0/M_AXI_DP] [get_bd_intf_pins microblaze_0_axi_periph/S00_AXI]
connect_bd_intf_net -intf_net microblaze_0_axi_periph1_M00_AXI [get_bd_intf_pins axi_bram_ctrl_0/S_AXI] [get_bd_intf_pins microblaze_0_axi_periph1/M00_AXI]
connect_bd_intf_net -intf_net microblaze_0_axi_periph_M02_AXI [get_bd_intf_pins axi_timer_0/S_AXI] [get_bd_intf_pins microblaze_0_axi_periph/M02_AXI]
connect_bd_intf_net -intf_net microblaze_0_debug [get_bd_intf_pins mdm_1/MBDEBUG_0] [get_bd_intf_pins microblaze_0/DEBUG]
connect_bd_intf_net -intf_net microblaze_0_dlmb_1 [get_bd_intf_pins microblaze_0/DLMB] [get_bd_intf_pins microblaze_0_local_memory/DLMB]
connect_bd_intf_net -intf_net microblaze_0_ilmb_1 [get_bd_intf_pins microblaze_0/ILMB] [get_bd_intf_pins microblaze_0_local_memory/ILMB]
connect_bd_intf_net -intf_net microblaze_0_intc_axi [get_bd_intf_pins microblaze_0_axi_intc/s_axi] [get_bd_intf_pins microblaze_0_axi_periph/M00_AXI]
connect_bd_intf_net -intf_net microblaze_0_interrupt [get_bd_intf_pins microblaze_0/INTERRUPT] [get_bd_intf_pins microblaze_0_axi_intc/interrupt]
connect_bd_intf_net -intf_net microblaze_0_mdm_axi [get_bd_intf_pins mdm_1/S_AXI] [get_bd_intf_pins microblaze_0_axi_periph/M01_AXI]
connect_bd_intf_net -intf_net user_si570_sysclk_1 [get_bd_intf_ports user_si570_sysclk] [get_bd_intf_pins clk_wiz_1/CLK_IN1_D]
connect_bd_net -net ARESETN_1 [get_bd_pins microblaze_0_axi_periph/ARESETN] [get_bd_pins microblaze_0_axi_periph1/ARESETN] [get_bd_pins rst_clk_wiz_1_100M/interconnect_aresetn]
connect_bd_net -net axi_timer_0_interrupt [get_bd_pins axi_timer_0/interrupt] [get_bd_pins microblaze_0_xlconcat/In0]
connect_bd_net -net clk_wiz_1_locked [get_bd_pins clk_wiz_1/locked] [get_bd_pins rst_clk_wiz_1_100M/dcm_locked]
connect_bd_net -net mdm_1_debug_sys_rst [get_bd_pins mdm_1/Debug_SYS_Rst] [get_bd_pins rst_clk_wiz_1_100M/mb_debug_sys_rst]
connect_bd_net -net microblaze_0_Clk [get_bd_pins axi_bram_ctrl_0/s_axi_aclk] [get_bd_pins axi_timer_0/s_axi_aclk] [get_bd_pins clk_wiz_1/clk_out1] [get_bd_pins mdm_1/S_AXI_ACLK] [get_bd_pins microblaze_0/Clk] [get_bd_pins microblaze_0_axi_intc/processor_clk] [get_bd_pins microblaze_0_axi_intc/s_axi_aclk] [get_bd_pins microblaze_0_axi_periph/ACLK] [get_bd_pins microblaze_0_axi_periph/M00_ACLK] [get_bd_pins microblaze_0_axi_periph/M01_ACLK] [get_bd_pins microblaze_0_axi_periph/M02_ACLK] [get_bd_pins microblaze_0_axi_periph/S00_ACLK] [get_bd_pins microblaze_0_axi_periph1/ACLK] [get_bd_pins microblaze_0_axi_periph1/M00_ACLK] [get_bd_pins microblaze_0_axi_periph1/S00_ACLK] [get_bd_pins microblaze_0_axi_periph1/S01_ACLK] [get_bd_pins microblaze_0_local_memory/LMB_Clk] [get_bd_pins rst_clk_wiz_1_100M/slowest_sync_clk]
connect_bd_net -net microblaze_0_intr [get_bd_pins microblaze_0_axi_intc/intr] [get_bd_pins microblaze_0_xlconcat/dout]
connect_bd_net -net reset_1 [get_bd_ports reset] [get_bd_pins clk_wiz_1/reset] [get_bd_pins rst_clk_wiz_1_100M/ext_reset_in]
connect_bd_net -net rst_clk_wiz_1_100M_bus_struct_reset [get_bd_pins microblaze_0_local_memory/SYS_Rst] [get_bd_pins rst_clk_wiz_1_100M/bus_struct_reset]
connect_bd_net -net rst_clk_wiz_1_100M_mb_reset [get_bd_pins microblaze_0/Reset] [get_bd_pins microblaze_0_axi_intc/processor_rst] [get_bd_pins rst_clk_wiz_1_100M/mb_reset]
connect_bd_net -net rst_clk_wiz_1_100M_peripheral_aresetn [get_bd_pins axi_bram_ctrl_0/s_axi_aresetn] [get_bd_pins axi_timer_0/s_axi_aresetn] [get_bd_pins mdm_1/S_AXI_ARESETN] [get_bd_pins microblaze_0_axi_intc/s_axi_aresetn] [get_bd_pins microblaze_0_axi_periph/M00_ARESETN] [get_bd_pins microblaze_0_axi_periph/M01_ARESETN] [get_bd_pins microblaze_0_axi_periph/M02_ARESETN] [get_bd_pins microblaze_0_axi_periph/S00_ARESETN] [get_bd_pins microblaze_0_axi_periph1/M00_ARESETN] [get_bd_pins microblaze_0_axi_periph1/S00_ARESETN] [get_bd_pins microblaze_0_axi_periph1/S01_ARESETN] [get_bd_pins rst_clk_wiz_1_100M/peripheral_aresetn]
# Create address segments
create_bd_addr_seg -range 0x00080000 -offset 0x80000000 [get_bd_addr_spaces microblaze_0/Data] [get_bd_addr_segs axi_bram_ctrl_0/S_AXI/Mem0] SEG_axi_bram_ctrl_0_Mem0
create_bd_addr_seg -range 0x00080000 -offset 0x80000000 [get_bd_addr_spaces microblaze_0/Instruction] [get_bd_addr_segs axi_bram_ctrl_0/S_AXI/Mem0] SEG_axi_bram_ctrl_0_Mem0
create_bd_addr_seg -range 0x00010000 -offset 0x41C00000 [get_bd_addr_spaces microblaze_0/Data] [get_bd_addr_segs axi_timer_0/S_AXI/Reg] SEG_axi_timer_0_Reg
create_bd_addr_seg -range 0x00010000 -offset 0x00000000 [get_bd_addr_spaces microblaze_0/Data] [get_bd_addr_segs microblaze_0_local_memory/dlmb_bram_if_cntlr/SLMB/Mem] SEG_dlmb_bram_if_cntlr_Mem
create_bd_addr_seg -range 0x00010000 -offset 0x00000000 [get_bd_addr_spaces microblaze_0/Instruction] [get_bd_addr_segs microblaze_0_local_memory/ilmb_bram_if_cntlr/SLMB/Mem] SEG_ilmb_bram_if_cntlr_Mem
create_bd_addr_seg -range 0x00001000 -offset 0x41400000 [get_bd_addr_spaces microblaze_0/Data] [get_bd_addr_segs mdm_1/S_AXI/Reg] SEG_mdm_1_Reg
create_bd_addr_seg -range 0x00010000 -offset 0x41200000 [get_bd_addr_spaces microblaze_0/Data] [get_bd_addr_segs microblaze_0_axi_intc/S_AXI/Reg] SEG_microblaze_0_axi_intc_Reg
validate_bd_design
save_bd_design
# End of create_root_design()
# MAIN FLOW
create_root_design ""
软件测试过程
xsct% connect
attempting to launch hw_server
****** Xilinx hw_server v2018.3
  **** Build date : Dec  7 2018-00:40:27
    ** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
target
  1* PS TAP
     2  PMU
     3  PL
       13  MicroBlaze Debug Module at USER2
          14  MicroBlaze #0 (Running)
xsct% target 14
xsct% rst -proc
Info: MicroBlaze #0 (target 14) Stopped at 0x10 (Stop)
xsct% target
  1  PS TAP
     2  PMU
     3  PL
          14* MicroBlaze #0 (Stop)
xsct% rrd
 r0: 00000000   r1: 00000000   r2: 00000000   r3: 00000000   r4: 00000000
 r5: 00000000   r6: 00000000   r7: 00000000   r8: 00000000   r9: 00000000
r10: 00000000  r11: 00000000  r12: 00000000  r13: 00000000  r14: 00000000
r15: 00000000  r16: 00000000  r17: 00000000  r18: 00000000  r19: 00000000
r20: 00000000  r21: 00000000  r22: 00000000  r23: 00000000  r24: 00000000
r25: 00000000  r26: 00000000  r27: 00000000  r28: 00000000  r29: 00000000
r30: 00000000  r31: 00000000   pc: 00000010  msr: 00000400  ear: 00000000
esr: 00000000  fsr: 00000000  btr: 00000000  pvr            mmu
dcr: 00000009  dsr: 21010001
xsct% mrd 0x80000000 0x10
80000000:   00000000
80000004:   00000000
80000008:   00000000
8000000C:   00000000
80000010:   00000000
80000014:   00000000
80000018:   00000000
8000001C:   00000000
80000020:   00000000
80000024:   00000000
80000028:   00000000
8000002C:   00000000
80000030:   00000000
80000034:   00000000
80000038:   00000000
8000003C:   00000000
xsct% mwr 0x80000000 0x12345678
80000000:   12345678
80000004:   00000000
80000008:   00000000
8000000C:   00000000
80000010:   00000000
80000014:   00000000
80000018:   00000000
8000001C:   00000000
80000020:   00000000
80000024:   00000000
80000028:   00000000
8000002C:   00000000
80000030:   00000000
80000034:   00000000
80000038:   00000000
8000003C:   00000000
审核编辑:汤梓红
  • 存储器
  • MicroBlaze
  • BRAM
    MicroBlaze串口设计
    本系统中,Basys3的MicroBlaze模块调用基于AXI协议的UART IP核,通过AXI总线实现MicroBlaze-UART之间的通信,完成串口打印。
    发表于 08-02 09:32 1692次阅读
    <b class='flag-5'>MicroBlaze</b>串口设计
    XUPV2P和MicroblazeBRAM太少了
    知道是否有办法将指令存储在XUPV2P的另一个存储器中(例如ACE闪存或ROM)?我已经阅读了一些帖子,但他们总是谈论像uClinux这样的内核的引导加载,而这不是我的情况。我从来没有遇到过这样
    发表于 09-30 11:08
    怎么从VHDL更新Microblaze BRAM
    我有一个带有64kb BRAMMicroblaze,带有指令和数据空间(一个端口上的标准I和另一个端口上的D)。我有另一个64kb只在一个端口上连接到Microblaze并且只包含数据。第二个端口
    发表于 03-04 12:09
    如何在不使用DDR内存控制的情况下设计FPGA BRAM大容量存储单元?
    你好如何在不使用DDR内存控制的情况下设计FPGA BRAM(或任何其他内存模块_SD,DDR以外的本地等)大容量存储单元?当我通过示例设计“VC707_bist”替换DRAM控制
    发表于 04-04 15:10
    怎么使用AXI CDMA从OCM/DDR写入BRAM
    提交一个事务,并将我提交的缓冲区中的数据写入块存储器生成器创建的BRAM中。据我所知,我上面描述的设置应该允许这样做。在我的地址编辑中,在sys_ps7下,有一个AXI_CDMA_0
    发表于 04-19 07:50
    请问如何通过MicroBlaze访问BRAM
    如何阅读存储BRAM中的数据吗?项目设置:使用AXI BRAM控制AXI互连将
    发表于 05-20 08:38
    请问microblaze如何通过串口读写FPGA内部axi4总线上的寄存
    microblaze通过串口读写FPGA内部axi4总线上的寄存
    发表于 12-23 06:16
    AXI FIFO和AXI virtual FIFO这两个IP的使用方法
    问题。FIFO 的挑战之一是存储大量数据需要 FPGA 内的大量资源。当然,这在较小的 FPGA 中可能是一个问题,因为 BRAM 资源是有限的。但在许多情况下,较小的 FPGA 可能会连接外部存储器,如
    发表于 11-04 11:03
    AXI内部存储器接口的功能
    库的慢-慢工艺点对块进行合成,以200 MHz的目标速度确认时序特性。 接口存储器端口上的信号符合RAM编译为TSMC CL013G工艺技术生产的单端口同步存储器组件所要求的时序要求
    发表于 08-21 06:55
    基于AXI总线的MicroBlaze双核SoPC系统设计
    目的是利用嵌入在Xilinx FPGA中的MicroBlaze核实现基于AXI总线的双核嵌入式系统设计以及共享实现LED灯的时控.
    发表于 03-09 14:17 91次下载
    基于<b class='flag-5'>AXI</b>总线的<b class='flag-5'>MicroBlaze</b>双核SoPC系统设计
    发表于 10-31 08:54 8次下载
    如何利用MicroBlaze实现大内部存储器设计
    RAM或者Ultra RAM个数,决定了AXI BRAM的大小。 在ZCU106单板上,有312个Block RAM,有96个Ultra RAM。客户需要1MB存储空间。实现MicroBla
    的头像 发表于 09-29 11:29 5189次阅读
    如何利用<b class='flag-5'>MicroBlaze</b>实现<b class='flag-5'>大内部</b><b class='flag-5'>存储器</b>设计
    如何使用MicroBlaze调用AXI IP核详细解析
    在一个项目中,当你使用microblaze作为控制来进行系统调度的时候,一般是建议将所有模块封装成AXI形式的IP核,这样好管理,也容易调试。
    的头像 发表于 04-27 11:17 7097次阅读
    如何使用<b class='flag-5'>MicroBlaze</b>调用<b class='flag-5'>AXI</b> IP核详细解析
    微控制内部存储器有哪些
    微控制(MCU)内部存储器是微控制系统的重要组成部分,它负责存储程序代码、数据以及控制逻辑等信息。这些
    的头像 发表于 08-22 10:41 997次阅读
    内部存储器有哪些
    内部存储器,也称为内存(Memory),是计算机系统中用于暂时存储程序和数据的重要组件。它直接与CPU相连,是CPU处理数据的主要来源。内部存储器
    的头像 发表于 09-05 10:42 2486次阅读
