怎么定义特种光纤?
工程师邓生 来源:光电读书 作者:光电读书 2022-08-30 09:45 次阅读
衣食住行,处处离不开纤维,光导纤维就是其中一类可以传输光信号的纤维。如今光纤也不仅仅用于通讯技术,利用纤维状的特征以及材料选择的灵活度,光纤在传感、能量、医疗等等领域都崭露头角。
怎么定义特种光纤?根据“RP Photonics Encyclopedia”介绍,就是“具有特殊设计或材料的光纤”。
Definition: optical fibers with special designs or materials
定义:具有特殊设计或材料的光纤
More specific terms:fluoride fibers,phosphatefibers,active fibers,polarizationmaintaining fibers,tapered fibers,photonic crystal fibers
更具体的术语:氟化物纤维,磷酸盐纤维,主动纤维,保偏纤维,锥形纤维,光子晶体纤维
Author(作者):Dr. Rüdiger Paschotta
Specialty optical fibersare usually understood as optical fibers that have at least one special property, distinguishing them fromstandard fibers. However, there is no universally accepted definition of the termstandard fiber. One may regard a standard fiber as a simplestep-index fiber, made with standardmaterial(in case of glass fibers:silica) and with common values of parameters like thecoresize andnumerical aperture.
特种光纤通常被理解为具有至少一种特殊特性的光纤,将其与标准光纤区分开。但是,现在也并没有标准纤维的普遍接受定义。我们一般可以将标准纤维视为简单的阶跃折射率纤维,它是由标准材料(在玻璃纤维的情况下为二氧化硅)制成,并具有诸如纤芯尺寸和数值孔径之类的参数的通用值。
Specialty fibers can then belong to various groups:
特种纤维可以属于下列分类:
Some fibers use non-standard materials. For example, there arefluoride fibersthat can transmit in longer(infrared) wavelength regions (mid- infrared fibers). Also, there arephosphate glassfibers, which can be morehighly doped with laser-active rare earth ions. Radiation-resistant fibers are made from materials that are less affected by radiation and used for example in space applications. Some fibers are made from monocrystalline material; they are calledsingle - crystal fibers. Single - crystal fibers are suitable for far higher power levels, particularly in the domain ofultrashort pulseamplification. But it istentatively more difficult to obtain a high outputbeam qualitydue to the inherent multimodenature. There are even liquid core fibers, offering widebandinfrared transmission. Special materials may also be used for fiber coatings and jackets.
有些纤维使用非标准材料。例如,有氟化物纤维、硫系玻璃纤维,重金属氧化物纤维等可以在更长(红外)波长范围内传输(近、中红外纤维)。
此外,还有磷酸盐玻璃纤维,可以易于进行更高程度的活性稀土离子掺杂。耐辐射纤维由受辐射影响较小的材料制成,例如用于太空应用。一些纤维是由单晶材料制成的。它们被称为单晶纤维。单晶纤维适用于高功率激光器,特别是在超短脉冲放大器应用领域有突出性能。但是由于固有的多模特质,难以获得较好输出光束质量。另外,还有液芯光纤,可提供宽带红外传输。更重要的是,特殊材料也可用于纤维的涂层。
Active fibers, being doped with laser-active ions(generally withrare-earth ions), are often generally regarded as specialty fibers.Double-clad fibers, having an additional larger waveguide structure for pump light, are even more special.
掺有激光活性离子(通常掺有稀土离子)的主动纤维通常被视为特种材料纤维。双包层光纤具有更大波导结构用于泵浦光。
Some fibers exhibit extreme or specially tailored parameters, such as an unusually largefiber corediameter or a very highnumerical aperture. Also, there arelarge mode area fibers, exhibiting particularly large-fibermodes.Dispersion-shifted fibershave tailoredchromatic dispersionproperties. Indispersion - decreasing fibers, the chromatic dispersion even varies over the length.
有些光纤表现出极端的定制参数,例如异常大的纤芯直径、方形纤芯、或很高的数值孔径。大模面积的光纤表现出特别大的模式。色散位移光纤具有定制的色散特性。在色散缓变光纤中,色散甚至会随着长度而变化。
There are fibers where thewaveguidefunction is not obtained simply with a somewhat increasedrefractive indexin the core (step-index fibers), but in some other way. For example, there arephotonic crystal fibers, containing air holes and therefore also being calledholey fibers.
有些光纤不能简单地通过纤芯中的折射率略有增加而获得波导功能(阶跃折射率光纤),而是通过其他方式获得。例如,包含空气孔的光子晶体纤维,也称为孔状光纤或微结构光纤。
Polarization - maintaining fibersof different designs can be used to maintain a linear polarization state over arbitrarily long propagation distances.Single - polarization fibersguide only light with a certain polarization direction.
保偏光纤的结构类型灵活,可用于在任意长度传播距离上保持线性偏振的状态。单偏振光纤仅传导具有特定偏振方向的光。
Tapered fibershave been stretched to obtain reduced fiber diameter, which usually changes along the length. They can be used, for example, for mode field adapters.
锥形纤维被拉伸以获得较小的纤维直径,该直径通常沿长度变化。它们可以用于类似模式适配器等器件。
As there can be so different special properties, it is preferable to use a more specific term thanspecialty fibers, particularly in scientific publications.
这些特种工光纤由于具备种类繁多的特殊性能,因此在专门的应用领域一般会使用比“特种纤维”更具体的术语,尤其是在科学出版物中。
个人觉得 “RP Photonics Encyclopedia”中对特种光纤的定义还是非常准确的。最后一句话很重要,特种光纤在很多应用领域都起到了关键作用,领域之间的跨界很大,甚至没有交集(比如石油、和医疗),所以涉及到某一个行业,还是利用该行业内公允的术语来命名某一种光纤更为方便。
审核编辑:刘清
原文标题:特种纤维 Specialty Optical Fibres
文章出处:【微信号:光电读书,微信公众号:光电读书】欢迎添加关注!文章转载请注明出处。
    LP光纤模式计算器
    的 Bessel 和用于渐变折射率光纤的 Laguerre。 此用例展示了如何使用计算器以及如何配置模式的采样参数。 配置光纤结构:Step-Index Fiber(阶跃折射率光纤光纤
    发表于 12-18 13:36
    aoc线缆和普通光纤区别
    AOC线缆(Active Optical Cable,有源光学电缆)和普通光纤在多个方面存在显著差异。以下是对两者的详细比较: 一、定义与构成 AOC线缆 定义:AOC线缆是一种集成了光电转换技术
    的头像 发表于 11-13 10:26 491次阅读
    特种电源发展走向浅析
    特种电源是为满足科研、军事、工程等领域特殊负载或特殊应用需求设计研发的电源,其特殊之处在于或输出电压、功率、纹波系数等技术参数要求高,或要求能够适应高低温、辐射、强电磁、强振动等特殊环境。特种电源
    发表于 11-05 18:03
    特种光纤指的是什么
    特种光纤是指在特定的波长上使用,为了实现某特种功能而设计制造的光纤。它是光纤的一种,但与常规通信光纤
    的头像 发表于 11-01 10:00 203次阅读
    sc光纤是什么意思
    SC光纤指的是采用SC(Subscriber Connector)接口的光纤连接器,它是一种广泛应用于光纤通信系统中的标准连接器类型。以下是对SC光纤的详细解释: 一、
    的头像 发表于 10-17 10:40 615次阅读
    光纤耦合器的定义、应用及参数
    光纤耦合器和光纤适配器,是光纤连接器中的两个大类,虽然在外观上看上去相似,但是在实际使用中,仍然是有部分差别的。本期我们将单独介绍光纤耦合器,从细节入手,更好提升使用体验。
    的头像 发表于 09-09 15:02 482次阅读
    隐形光纤和普通光纤区别
    隐形光纤和普通光纤在多个方面存在显著差异,以下是它们之间的主要区别: 一、定义与特点 隐形光纤定义:隐形
    的头像 发表于 08-08 10:04 1943次阅读
    光纤配线架进线和出线的区别
    光纤线路的集中管理和维护。在光纤配线架中,进线和出线是两个非常重要的概念,它们之间存在着明显的区别。 定义 1.1 进线(Inbound Line) 进线是指从外部光纤网络或
    的头像 发表于 08-02 11:03 1374次阅读
    sfp光纤接口怎么接光纤
    SFP(Small Form-factor Pluggable)光纤接口是一种小型化的光纤接口模块,广泛应用于网络通信设备中。 一、SFP光纤接口的定义 SFP(Small Form-
    的头像 发表于 07-10 10:23 1425次阅读
    odf架和光纤配线架区别
    ODF架和光纤配线架在光纤通信系统中都扮演着重要的角色,但它们在定义、功能、用途和结构上存在一些区别。以下是它们之间的详细比较: 定义: ODF架:ODF(Optical Distri
    的头像 发表于 06-19 10:03 973次阅读
    单模mpo/apc-mpo/apc光纤跳线定义
    单模MPO/APC-MPO/APC光纤跳线是一种高密度的光纤传输跳线,主要用于高速数据传输。以下是关于这种光纤跳线的详细解释和相关信息: 定义与结构 MPO
    的头像 发表于 06-17 10:35 1154次阅读
    光纤转换器的定义和使用方法
    光纤转换器,也称为光纤收发器或光纤交换机,是一种将电信号转换为光信号或将光信号转换回电信号的设备。
    的头像 发表于 05-23 16:28 2378次阅读
    一文轻松掌握光纤耦合器的定义、作用及应用
    光纤耦合器,也称为光纤分路器、光纤合路器或光纤分配器,是一种将光信号在两根或多根光纤之间进行分配的无源光器件。
    的头像 发表于 05-23 15:32 4037次阅读
    理工光科光栅阵列特种传感光纤拉丝塔在武汉投产运行! 院士姜德生出席仪式
    1月26日,历时近两年建设的理工光科(300557)光栅阵列特种传感光纤拉丝塔在武汉正式投产运行。理工光科光栅阵列特种传感光纤拉丝塔,是新一代大容量分布式
    的头像 发表于 02-20 08:41 523次阅读
    理工光科光栅阵列<b class='flag-5'>特种</b>传感<b class='flag-5'>光纤</b>拉丝塔在武汉投产运行! 院士姜德生出席仪式
    特种机器人的定义与分类
    相对于一般的工业机器人及家用服务机器人,特种机器人的工作环境和作业条件更为复杂,对机器人结构和功能也提出了更高的要求。因此,未来特种机器人领域将呈现出更多的创新和发展。
    发表于 01-04 11:42 1623次阅读
    <b class='flag-5'>特种</b>机器人的<b class='flag-5'>定义</b>与分类
