在平时的工作中,可能你也面遇到计算CRC16校验的问题。笔者曾经对接过MODBUS协议,就是使用了CRC16作为校验码。以下是笔者分享的,如何使用【余式表】计算CRC16的接口代码。
static const uint16_t crc_ta[256] = { /* CRC余式表 */
0x0000, 0x1021, 0x2042, 0x3063, 0x4084, 0x50a5, 0x60c6, 0x70e7,
0x8108, 0x9129, 0xa14a, 0xb16b, 0xc18c, 0xd1ad, 0xe1ce, 0xf1ef,
0x1231, 0x0210, 0x3273, 0x2252, 0x52b5, 0x4294, 0x72f7, 0x62d6,
0x9339, 0x8318, 0xb37b, 0xa35a, 0xd3bd, 0xc39c, 0xf3ff, 0xe3de,
0x2462, 0x3443, 0x0420, 0x1401, 0x64e6, 0x74c7, 0x44a4, 0x5485,
0xa56a, 0xb54b, 0x8528, 0x9509, 0xe5ee, 0xf5cf, 0xc5ac, 0xd58d,
0x3653, 0x2672, 0x1611, 0x0630, 0x76d7, 0x66f6, 0x5695, 0x46b4,
0xb75b, 0xa77a, 0x9719, 0x8738, 0xf7df, 0xe7fe, 0xd79d, 0xc7bc,
0x48c4, 0x58e5, 0x6886, 0x78a7, 0x0840, 0x1861, 0x2802, 0x3823,
0xc9cc, 0xd9ed, 0xe98e, 0xf9af, 0x8948, 0x9969, 0xa90a, 0xb92b,
0x5af5, 0x4ad4, 0x7ab7, 0x6a96, 0x1a71, 0x0a50, 0x3a33, 0x2a12,
0xdbfd, 0xcbdc, 0xfbbf, 0xeb9e, 0x9b79, 0x8b58, 0xbb3b, 0xab1a,
0x6ca6, 0x7c87, 0x4ce4, 0x5cc5, 0x2c22, 0x3c03, 0x0c60, 0x1c41,
0xedae, 0xfd8f, 0xcdec, 0xddcd, 0xad2a, 0xbd0b, 0x8d68, 0x9d49,
0x7e97, 0x6eb6, 0x5ed5, 0x4ef4, 0x3e13, 0x2e32, 0x1e51, 0x0e70,
0xff9f, 0xefbe, 0xdfdd, 0xcffc, 0xbf1b, 0xaf3a, 0x9f59, 0x8f78,
0x9188, 0x81a9, 0xb1ca, 0xa1eb, 0xd10c, 0xc12d, 0xf14e, 0xe16f,
0x1080, 0x00a1, 0x30c2, 0x20e3, 0x5004, 0x4025, 0x7046, 0x6067,
0x83b9, 0x9398, 0xa3fb, 0xb3da, 0xc33d, 0xd31c, 0xe37f, 0xf35e,
0x02b1, 0x1290, 0x22f3, 0x32d2, 0x4235, 0x5214, 0x6277, 0x7256,
0xb5ea, 0xa5cb, 0x95a8, 0x8589, 0xf56e, 0xe54f, 0xd52c, 0xc50d,
0x34e2, 0x24c3, 0x14a0, 0x0481, 0x7466, 0x6447, 0x5424, 0x4405,
0xa7db, 0xb7fa, 0x8799, 0x97b8, 0xe75f, 0xf77e, 0xc71d, 0xd73c,
0x26d3, 0x36f2, 0x0691, 0x16b0, 0x6657, 0x7676, 0x4615, 0x5634,
0xd94c, 0xc96d, 0xf90e, 0xe92f, 0x99c8, 0x89e9, 0xb98a, 0xa9ab,
0x5844, 0x4865, 0x7806, 0x6827, 0x18c0, 0x08e1, 0x3882, 0x28a3,
0xcb7d, 0xdb5c, 0xeb3f, 0xfb1e, 0x8bf9, 0x9bd8, 0xabbb, 0xbb9a,
0x4a75, 0x5a54, 0x6a37, 0x7a16, 0x0af1, 0x1ad0, 0x2ab3, 0x3a92,
0xfd2e, 0xed0f, 0xdd6c, 0xcd4d, 0xbdaa, 0xad8b, 0x9de8, 0x8dc9,
0x7c26, 0x6c07, 0x5c64, 0x4c45, 0x3ca2, 0x2c83, 0x1ce0, 0x0cc1,
0xef1f, 0xff3e, 0xcf5d, 0xdf7c, 0xaf9b, 0xbfba, 0x8fd9, 0x9ff8,
0x6e17, 0x7e36, 0x4e55, 0x5e74, 0x2e93, 0x3eb2, 0x0ed1, 0x1ef0
//入参:Buf : 输入数据串
//入参:Len : 输入数据长度
//入参:PreCrcValue : CRC预设值
//返回值: 16位CRC计算结果
uint16_t CRC16_calc(const void *buffer, uint32_t len, uint16_t pre_crc_value)
uint16_t crc;
uint8_t da;
uint8_t *pT = (typeof(pT))buffer;
if(buffer== NULL)
return(pre_crc_value);
crc = pre_crc_value;
while(len-- != 0)
da = (uint8_t)(crc/256); /* 以8位二进制数的形式暂存CRC的高8位 */
crc <<= 8; /* 左移8位,相当于CRC的低8位乘以 */
crc ^= crc_ta[da^*pT]; /* 高8位和当前字节相加后再查表求CRC ,再加上以前的CRC */
pT++;
return(crc);
因CRC16的计算方法多式多样,结果就留着读者来验证下?有问题请随时联系。@_@
审核编辑:汤梓红
举报投诉
MODBUS
28文章
1503浏览量
75927 -
C语言
180文章
7551浏览量
131837 -
CRC16
2浏览量
6721
用STM32L05x的CRC模块做modbus CRC16计算,结果不正确是为什么?
根据参考文档,CRC模块可以配置CRC多项式,应该可以做(Modbus)CRC16计算,自己试了一下,发现结果不正确,总是一个固定值,不知道
发表于 04-29 06:50
CRC16和CRC8校验计算,已经验证算法正确
用Labview2014做的CRC16和CRC8计算,已经验证,计算结果正确。
发表于 10-28 12:02
CRC16 XMODEM 校验程序,符合标准
CRC16的算法原理:1.根据CRC16的标准选择初值CRCIn的值。2.将数据的第一个字节与CRCIn高8位异或。3.判断最高位,若该位为 0 左移一位,若为 1 左移一位再与多项式Hex码异或
发表于 10-11 13:03
ADSP SHARC函数不能生成正确的CRC16
我发现下面的函数不能生成正确的CRC16结果,调试发现,虽然进行了强制类型转换unsigned char *code = (unsigned char *)data;但是对code++;仍旧对指针
发表于 03-01 14:33
ModBus CRC16校验码学习笔记(附手稿)精选资料分享
的意思是使用的Modbus CRC16校验的方式得来的。后面需要使用程序来计算,在百度之后了解了Modbus CRC16校验码的计算
发表于 08-30 06:28
CRYPTO中的CRC16计算结果有问题怎么解决
cubeMX只启用CRC功能,其余默认配置,编译没有任何问题。调用参考官方例程,CRC32的计算结果没问题,尝试CRC16、CRC8,
发表于 08-18 09:43
crc16几种标准校验算法及c语言代码
CRC16常见的标准有以下几种,被用在各个规范中,其算法原理基本一致,就是在数据的输入和输出有所差异,下边把这些标准的差异列出,并给出C语言的算法实现。
发表于 12-04 10:25
•3.8w次阅读
