一、概述
Apache ZooKeeper
是一个集中式服务,用于维护配置信息、命名、提供分布式同步和提供组服务,ZooKeeper 致力于开发和维护一个开源服务器,以实现高度可靠的分布式协调,其实也可以认为就是一个分布式数据库,只是结构比较特殊,是树状结构。官网文档:
![febc62a8-3821-11ed-ba43-dac502259ad0.png](https://file1.elecfans.com//web2/M00/96/AA/wKgZomTnIoWAPBYtAACiCmFrl3M843.png)
![fec6e552-3821-11ed-ba43-dac502259ad0.png](https://file1.elecfans.com//web2/M00/96/AB/wKgZomTnIoWALWrPAAE_EcKQ2rg740.png)
二、Zookeeper on k8s 部署
![002bb7d8-3822-11ed-ba43-dac502259ad0.png](https://file1.elecfans.com//web2/M00/96/AB/wKgZomTnIoWAZAocAADEsfPfxmA192.png)
1)添加源
部署包地址:
helmrepoaddbitnamihttps://charts.bitnami.com/bitnami
helmpullbitnami/zookeeper
tar-xfzookeeper-10.2.1.tgz
2)修改配置
修改
zookeeper/values.yaml
image:
registry:myharbor.com
repository:bigdata/zookeeper
tag:3.8.0-debian-11-r36
replicaCount:3
service:
type:NodePort
nodePorts:
#NodePort默认范围是30000-32767
client:"32181"
tls:"32182"
persistence:
storageClass:"zookeeper-local-storage"
#目录需要提前在宿主机上创建
local:
-name:zookeeper-0
host:"local-168-182-110"
path:"/opt/bigdata/servers/zookeeper/data/data1"
-name:zookeeper-1
host:"local-168-182-111"
-name:zookeeper-2
host:"local-168-182-112"
#EnablePrometheustoaccessZooKeepermetricsendpoint
metrics:
enabled:true
添加
zookeeper/templates/pv.yaml
{{-range.Values.persistence.local}}
apiVersion:v1
kind:PersistentVolume
metadata:
labels:
spec:
storageClassName:{{$.Values.persistence.storageClass}}
capacity:
storage:{{$.Values.persistence.size}}
accessModes:
-ReadWriteOnce
local:
path:{{.path}}
nodeAffinity:
required:
nodeSelectorTerms:
-matchExpressions:
-key:kubernetes.io/hostname
operator:In
values:
-{{.host}}
{{-end}}
添加
zookeeper/templates/storage-class.yaml
kind:StorageClass
apiVersion:storage.k8s.io/v1
metadata:
provisioner:kubernetes.io/no-provisioner
3)开始安装
#先准备好镜像
dockerpulldocker.io/bitnami/zookeeper:3.8.0-debian-11-r36
dockertagdocker.io/bitnami/zookeeper:3.8.0-debian-11-r36myharbor.com/bigdata/zookeeper:3.8.0-debian-11-r36
dockerpushmyharbor.com/bigdata/zookeeper:3.8.0-debian-11-r36
#开始安装
helminstallzookeeper./zookeeper-nzookeeper--create-namespace
NOTES
LASTDEPLOYED:SunSep1818032022
NAMESPACE:zookeeper
STATUS:deployed
REVISION:1
TESTSUITE:None
NOTES:
CHARTNAME:zookeeper
CHARTVERSION:10.2.1
APPVERSION:3.8.0
**Pleasebepatientwhilethechartisbeingdeployed**
ZooKeepercanbeaccessedviaport2181onthefollowingDNSnamefromwithinyourcluster:
zookeeper.zookeeper.svc.cluster.local
ToconnecttoyourZooKeeperserverrunthefollowingcommands:
exportPOD_NAME=$(kubectlgetpods--namespacezookeeper-l"app.kubernetes.io/name=zookeeper,app.kubernetes.io/instance=zookeeper,app.kubernetes.io/component=zookeeper"-ojsonpath="{.items[0].metadata.name}")
kubectlexec-it$POD_NAME--zkCli.sh
ToconnecttoyourZooKeeperserverfromoutsidetheclusterexecutethefollowingcommands:
exportNODE_IP=$(kubectlgetnodes--namespacezookeeper-ojsonpath="{.items[0].status.addresses[0].address}")
exportNODE_PORT=$(kubectlget--namespacezookeeper-ojsonpath="{.spec.ports[0].nodePort}"serviceszookeeper)
zkCli.sh$NODE_IP:$NODE_PORT
查看 pod 状态
kubectlgetpods,svc-nzookeeper-owide
![0062232c-3822-11ed-ba43-dac502259ad0.png](https://file1.elecfans.com//web2/M00/96/AB/wKgZomTnIoaAQHobAAI5omYfUAE191.png)
4)测试验证
#登录zookeeperpod
kubectlexec-itzookeeper-0-nzookeeper--zkServer.shstatus
kubectlexec-itzookeeper-1-nzookeeper--zkServer.shstatus
kubectlexec-itzookeeper-2-nzookeeper--zkServer.shstatus
kubectlexec-itzookeeper-0-nzookeeper--bash
![00798e5e-3822-11ed-ba43-dac502259ad0.png](https://file1.elecfans.com//web2/M00/96/AB/wKgZomTnIoaAUd_EAARiT1bA6ug517.png)
5)Prometheus 监控
Prometheus:https://prometheus.k8s.local/targets?search=zookeeper
可以通过命令查看采集数据
kubectlget--rawhttp://10.244.0.52:9141/metrics
kubectlget--rawhttp://10.244.1.101:9141/metrics
kubectlget--rawhttp://10.244.2.137:9141/metrics
Grafana:https://grafana.k8s.local/
账号:admin
,密码通过下面命令获取
kubectlgetsecret--namespacegrafanagrafana-ojsonpath="{.data.admin-password}"|base64--decode;echo
导入 grafana 模板,集群资源监控:10465
官方模块下载地址:
![00a29880-3822-11ed-ba43-dac502259ad0.png](https://file1.elecfans.com//web2/M00/96/AB/wKgZomTnIoaAV13jAAFm4Yq6GgU228.png)
6)卸载
helmuninstallzookeeper-nzookeeper
kubectldeletepod-nzookeeper`kubectlgetpod-nzookeeper|awk'NR>1{print$1}'`--force
kubectlpatchnszookeeper-p'{"metadata":{"finalizers":null}}'
kubectldeletenszookeeper--force
三、Kafka on k8s 部署
1)添加源
部署包地址:
helmpullbitnami/kafka
tar-xfkafka-18.4.2.tgz
2)修改配置
修改
kafka/values.yaml
image:
repository:bigdata/kafka
tag:3.2.1-debian-11-r16
replicaCount:3
service:
type:NodePort
nodePorts:
client:"30092"
external:"30094"
externalAccess
enabled:true
service:
type:NodePort
nodePorts:
-30001
-30002
-30003
useHostIPs:true
persistence:
storageClass:"kafka-local-storage"
#目录需要提前在宿主机上创建
local:
-name:kafka-0
path:"/opt/bigdata/servers/kafka/data/data1"
-name:kafka-1
-name:kafka-2
metrics:
kafka:
enabled:true
image:
repository:bigdata/kafka-exporter
tag:1.6.0-debian-11-r8
jmx:
enabled:true
image:
repository:bigdata/jmx-exporter
tag:0.17.1-debian-11-r1
annotations:
prometheus.io/path:"/metrics"
zookeeper:
enabled:false
externalZookeeper
servers:
-zookeeper-0.zookeeper-headless.zookeeper
-zookeeper-1.zookeeper-headless.zookeeper
-zookeeper-2.zookeeper-headless.zookeeper
添加
kafka/templates/pv.yaml
apiVersion:v1
metadata:
labels:
spec:
capacity:
accessModes:
-ReadWriteOnce
local:
path:{{.path}}
nodeAffinity:
required:
nodeSelectorTerms:
-matchExpressions:
operator:In
values:
-{{.host}}
{{-end}}
添加
kafka/templates/storage-class.yaml
kind:StorageClass
metadata:
3)开始安装
#先准备好镜像
dockerpulldocker.io/bitnami/kafka:3.2.1-debian-11-r16
dockertagdocker.io/bitnami/kafka:3.2.1-debian-11-r16myharbor.com/bigdata/kafka:3.2.1-debian-11-r16
dockerpushmyharbor.com/bigdata/kafka:3.2.1-debian-11-r16
#node-export
dockerpulldocker.io/bitnami/kafka-exporter:1.6.0-debian-11-r8
dockertagdocker.io/bitnami/kafka-exporter:1.6.0-debian-11-r8myharbor.com/bigdata/kafka-exporter:1.6.0-debian-11-r8
dockerpushmyharbor.com/bigdata/kafka-exporter:1.6.0-debian-11-r8
#JXM
docker.io/bitnami/jmx-exporter:0.17.1-debian-11-r1
dockertagdocker.io/bitnami/jmx-exporter:0.17.1-debian-11-r1myharbor.com/bigdata/jmx-exporter:0.17.1-debian-11-r1
dockerpushmyharbor.com/bigdata/jmx-exporter:0.17.1-debian-11-r1
#开始安装
helminstallkafka./kafka-nkafka--create-namespace
LASTDEPLOYED:SunSep1820022022
NAMESPACE:kafka
STATUS:deployed
REVISION:1
TESTSUITE:None
NOTES:
CHARTNAME:kafka
CHARTVERSION:18.4.2
APPVERSION:3.2.1
WARNING
Byspecifying"serviceType=LoadBalancer"andnotconfiguringtheauthentication
youhavemostlikelyexposedtheKafkaserviceexternallywithoutany
authenticationmechanism.
Forsecurityreasons,westronglysuggestthatyouswitchto"ClusterIP"or
"NodePort".Asalternative,youcanalsoconfiguretheKafkaauthentication.
Kafkacanbeaccessedbyconsumersviaport9092onthefollowingDNSnamefromwithinyourcluster:
kafka.kafka.svc.cluster.local
EachKafkabrokercanbeaccessedbyproducersviaport9092onthefollowingDNSname(s)fromwithinyourcluster:
kafka-0.kafka-headless.kafka.svc.cluster.local:9092
kafka-1.kafka-headless.kafka.svc.cluster.local:9092
kafka-2.kafka-headless.kafka.svc.cluster.local:9092
TocreateapodthatyoucanuseasaKafkaclientrunthefollowingcommands:
kubectlrunkafka-client--restart='Never'--imagedocker.io/bitnami/kafka:3.2.1-debian-11-r16--namespacekafka--command--sleepinfinity
kubectlexec--tty-ikafka-client--namespacekafka--bash
PRODUCER:
kafka-console-producer.sh
--broker-listkafka-0.kafka-headless.kafka.svc.cluster.local:9092,kafka-1.kafka-headless.kafka.svc.cluster.local:9092,kafka-2.kafka-headless.kafka.svc.cluster.local:9092
--topictest
CONSUMER:
kafka-console-consumer.sh
--bootstrap-serverkafka.kafka.svc.cluster.local:9092
--topictest
--from-beginning
ToconnecttoyourKafkaserverfromoutsidethecluster,followtheinstructionsbelow:
Kafkabrokersdomain:YoucangettheexternalnodeIPfromtheKafkaconfigurationfilewiththefollowingcommands(ChecktheEXTERNALlistener)
1.Obtainthepodname:
kubectlgetpods--namespacekafka-l"app.kubernetes.io/name=kafka,app.kubernetes.io/instance=kafka,app.kubernetes.io/component=kafka"
2.Obtainpodconfiguration:
kubectlexec-itKAFKA_POD--cat/opt/bitnami/kafka/config/server.properties|grepadvertised.listeners
Kafkabrokersport:YouwillhaveadifferentnodeportforeachKafkabroker.Youcangetthelistofconfigurednodeportsusingthecommandbelow:
echo"$(kubectlgetsvc--namespacekafka-l"app.kubernetes.io/name=kafka,app.kubernetes.io/instance=kafka,app.kubernetes.io/component=kafka,pod"-ojsonpath='{.items[*].spec.ports[0].nodePort}'|tr'''
查看 pod 状态
kubectlgetpods,svc-nkafka-owide
![00dface8-3822-11ed-ba43-dac502259ad0.png](https://file1.elecfans.com//web2/M00/96/AB/wKgZomTnIoaASPXvAAP0m07bEeA425.png)
4)测试验证
#登录zookeeperpod
kubectlexec-itkafka-0-nkafka--bash
1、创建 Topic(一个副本一个分区)
--create:指定创建topic动作
--topic:指定新建topic的名称
--bootstrap-server:指定kafka连接地址
--config:指定当前topic上有效的参数值,参数列表参考文档为:Topic-levelconfiguration
--partitions:指定当前创建的kafka分区数量,默认为1个
--replication-factor:指定每个分区的复制因子个数,默认1个
kafka-topics.sh--create--topictest001--bootstrap-serverkafka.kafka:9092--partitions1--replication-factor1
#查看
kafka-topics.sh--describe--bootstrap-serverkafka.kafka:9092--topictest001
![00faab10-3822-11ed-ba43-dac502259ad0.png](https://file1.elecfans.com//web2/M00/96/AB/wKgZomTnIoeAc3GTAAE6AUCWz5Y019.png)
2、查看 Topic 列表
kafka-topics.sh--list--bootstrap-serverkafka.kafka:9092
3、生产者/消费者测试
【生产者】
kafka-console-producer.sh--broker-listkafka.kafka:9092--topictest001
{"id":"1","name":"n1","age":"20"}
{"id":"2","name":"n2","age":"21"}
{"id":"3","name":"n3","age":"22"}
【消费者】
#从头开始消费
kafka-console-consumer.sh--bootstrap-serverkafka.kafka:9092--topictest001--from-beginning
#指定从分区的某个位置开始消费,这里只指定了一个分区,可以多写几行或者遍历对应的所有分区
kafka-console-consumer.sh--bootstrap-serverkafka.kafka:9092--topictest001--partition0--offset100--grouptest001
4、查看数据积压
kafka-consumer-groups.sh--bootstrap-serverkafka.kafka:9092--describe--grouptest001
5、删除 topic
kafka-topics.sh--delete--topictest001--bootstrap-serverkafka.kafka:9092
5)Prometheus 监控
Prometheus:
![01089248-3822-11ed-ba43-dac502259ad0.png](https://file1.elecfans.com//web2/M00/96/AB/wKgZomTnIoeAYVOcAAFLaJv0Jkc554.png)
可以通过命令查看采集数据
kubectlget--rawhttp://10.244.2.165:9308/metrics
账号:admin
,密码通过下面命令获取
导入 grafana 模板,集群资源监控:11962
官方模块下载地址:
6)卸载
helmuninstallkafka-nkafka
kubectldeletepod-nkafka`kubectlgetpod-nkafka|awk'NR>1{print$1}'`--force
kubectlpatchnskafka-p'{"metadata":{"finalizers":null}}'
kubectldeletenskafka--force
zookeeper + kafka on k8s 环境部署 就先到这里了,小伙伴有任何疑问,欢迎给我留言!
数据库
7文章
3855浏览量
64799 -
kafka
52浏览量
5246 -
zookeeper
34浏览量
3715
原文标题:14 张图详解 Zookeeper + Kafka on K8S 环境部署
文章出处:【微信号:magedu-Linux,微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
