二叉树的所有路径
来源:力扣(LeetCode)链接:https://leetcode.cn/problems/binary-tree-paths
题目:给你一个二叉树的根节点root,按任意顺序,返回所有从根节点到叶子节点的路径。
叶子节点是指没有子节点的节点。
示例 1:
e.g.
输入:root = [1,2,3,null,5]
输出:["1->2->5","1->3"]
示例 2:
输入:root = [1]
输出:["1"]
提示:
-100 <= Node.val <= 100
树中节点的数目在范围[1, 100]内
C语言求解
方法一:迭代
* Definition for a binary tree node.
* struct TreeNode {
* int val;
* struct TreeNode *left;
* struct TreeNode *right;
void construct_paths(struct TreeNode* root, char** res, int* returnSize, int* sta, int top) {
if (root != NULL) {
if (root->left == NULL && root->right == NULL) { // 当前节点是叶子节点
char* tmp = (char*)malloc(1001);
int len = 0;
for (int i = 0; i < top; i++) {
len += sprintf(tmp + len, "%d->", sta[i]);
sprintf(tmp + len, "%d", root->val);
res[(*returnSize)++] = tmp; // 把路径加入到答案中
} else {
sta[top++] = root->val; // 当前节点不是叶子节点,继续递归遍历
construct_paths(root->left, res, returnSize, sta, top);
construct_paths(root->right, res, returnSize, sta, top);
char** binaryTreePaths(struct TreeNode* root, int* returnSize) {
char** paths = (char**)malloc(sizeof(char*) * 1001);
*returnSize = 0;
int sta[1001];
construct_paths(root, paths, returnSize, sta, 0);
return paths;
方法二:广度优先
* Note: The returned array must be malloced, assume caller calls free().
char **binaryTreePaths(struct TreeNode *root, int *returnSize) {
char **paths = (char **) malloc(sizeof(char *) * 1001);
*returnSize = 0;
if (root == NULL) {
return paths;
struct TreeNode **node_queue = (struct TreeNode **) malloc(sizeof(struct TreeNode *) * 1001);
char **path_queue = (char **) malloc(sizeof(char *) * 1001);
int left = 0, right = 0;
char *tmp = malloc(sizeof(char) * 1001);
sprintf(tmp, "%d", root->val);
node_queue[right] = root;
path_queue[right++] = tmp;
while (left < right) {
struct TreeNode *node = node_queue[left];
char *path = path_queue[left++];
if (node->left == NULL && node->right == NULL) {
paths[(*returnSize)++] = path;
} else {
if (node->left != NULL) {
sprintf(tmp, "%s->%d", path, node->left->val);
node_queue[right] = node->left;
if (node->right != NULL) {
sprintf(tmp, "%s->%d", path, node->right->val);
node_queue[right] = node->right;
return paths;
编辑:黄飞
二叉树
74浏览量
12322
原文标题:257.二叉树的所有路径
文章出处:【微信号:续加仪,微信公众号:续加仪】欢迎添加关注!文章转载请注明出处。
