之前写过文章记录怎么在SpringBoot项目中简单使用定时任务,不过由于要借助cron表达式且都提前定义好放在配置文件里,不能在项目运行中动态修改任务执行时间,实在不太灵活。
经过网上搜索学习后,特此记录如何在SpringBoot项目中实现动态定时任务。
因为只是一个demo,所以只引入了需要的依赖:
org.springframework.boot spring-boot-starter-web org.springframework.boot spring-boot-starter-log4j2 true org.springframework.boot spring-boot-starter-validation org.projectlombok lombok true
启动类:
packagecom.wl.demo; importorg.springframework.boot.SpringApplication; importorg.springframework.boot.autoconfigure.SpringBootApplication; importorg.springframework.scheduling.annotation.EnableScheduling; /** *@authorwl */ @EnableScheduling @SpringBootApplication publicclassDemoApplication{ publicstaticvoidmain(String[]args){ SpringApplication.run(DemoApplication.class,args); System.out.println("(*^▽^*)启动成功!!!(〃'▽'〃)"); } }
配置文件application.yml,只定义了服务端口:
server: port:8089
定时任务执行时间配置文件:task-config.ini:
printTime.cron=0/10****?
定时任务执行类:
packagecom.wl.demo.task; importlombok.Data; importlombok.extern.slf4j.Slf4j; importorg.springframework.beans.factory.annotation.Value; importorg.springframework.context.annotation.PropertySource; importorg.springframework.scheduling.Trigger; importorg.springframework.scheduling.TriggerContext; importorg.springframework.scheduling.annotation.SchedulingConfigurer; importorg.springframework.scheduling.config.ScheduledTaskRegistrar; importorg.springframework.scheduling.support.CronTrigger; importorg.springframework.stereotype.Component; importjava.time.LocalDateTime; importjava.util.Date; /** *定时任务 *@authorwl */ @Data @Slf4j @Component @PropertySource("classpath:/task-config.ini") publicclassScheduleTaskimplementsSchedulingConfigurer{ @Value("${printTime.cron}") privateStringcron; @Override publicvoidconfigureTasks(ScheduledTaskRegistrartaskRegistrar){ //动态使用cron表达式设置循环间隔 taskRegistrar.addTriggerTask(newRunnable(){ @Override publicvoidrun(){ log.info("Current time:{}",LocalDateTime.now()); } },newTrigger(){ @Override publicDatenextExecutionTime(TriggerContexttriggerContext){ //使用CronTrigger触发器,可动态修改cron表达式来操作循环规则 CronTriggercronTrigger=newCronTrigger(cron); DatenextExecutionTime=cronTrigger.nextExecutionTime(triggerContext); returnnextExecutionTime; } }); } }
编写一个接口,使得可以通过调用接口动态修改该定时任务的执行时间:
packagecom.wl.demo.controller; importcom.wl.demo.task.ScheduleTask; importlombok.extern.slf4j.Slf4j; importorg.springframework.beans.factory.annotation.Autowired; importorg.springframework.web.bind.annotation.GetMapping; importorg.springframework.web.bind.annotation.RequestMapping; importorg.springframework.web.bind.annotation.RestController; /** *@authorwl */ @Slf4j @RestController @RequestMapping("/test") publicclassTestController{ privatefinalScheduleTaskscheduleTask; @Autowired publicTestController(ScheduleTaskscheduleTask){ this.scheduleTask=scheduleTask; } @GetMapping("/updateCron") publicStringupdateCron(Stringcron){ log.info("newcron:{}",cron); scheduleTask.setCron(cron); return"ok"; } }
启动项目,可以看到任务每10秒执行一次:
访问接口,传入请求参数cron表达式,将定时任务修改为15秒执行一次:
可以看到任务变成了15秒执行一次
除了上面的借助cron表达式的方法,还有另一种触发器,区别于CronTrigger触发器,该触发器可随意设置循环间隔时间,不像cron表达式只能定义小于等于间隔59秒。
packagecom.wl.demo.task; importlombok.Data; importlombok.extern.slf4j.Slf4j; importorg.springframework.beans.factory.annotation.Value; importorg.springframework.context.annotation.PropertySource; importorg.springframework.scheduling.Trigger; importorg.springframework.scheduling.TriggerContext; importorg.springframework.scheduling.annotation.SchedulingConfigurer; importorg.springframework.scheduling.config.ScheduledTaskRegistrar; importorg.springframework.scheduling.support.CronTrigger; importorg.springframework.scheduling.support.PeriodicTrigger; importorg.springframework.stereotype.Component; importjava.time.LocalDateTime; importjava.util.Date; /** *定时任务 *@authorwl */ @Data @Slf4j @Component @PropertySource("classpath:/task-config.ini") publicclassScheduleTaskimplementsSchedulingConfigurer{ @Value("${printTime.cron}") privateStringcron; privateLongtimer=10000L; @Override publicvoidconfigureTasks(ScheduledTaskRegistrartaskRegistrar){ //动态使用cron表达式设置循环间隔 taskRegistrar.addTriggerTask(newRunnable(){ @Override publicvoidrun(){ log.info("Current time:{}",LocalDateTime.now()); } },newTrigger(){ @Override publicDatenextExecutionTime(TriggerContexttriggerContext){ //使用CronTrigger触发器,可动态修改cron表达式来操作循环规则 //CronTriggercronTrigger=newCronTrigger(cron); //DatenextExecutionTime=cronTrigger.nextExecutionTime(triggerContext); //使用不同的触发器,为设置循环时间的关键,区别于CronTrigger触发器,该触发器可随意设置循环间隔时间,单位为毫秒 PeriodicTriggerperiodicTrigger=newPeriodicTrigger(timer); DatenextExecutionTime=periodicTrigger.nextExecutionTime(triggerContext); returnnextExecutionTime; } }); } }
增加一个修改时间的接口:
packagecom.wl.demo.controller; importcom.wl.demo.task.ScheduleTask; importlombok.extern.slf4j.Slf4j; importorg.springframework.beans.factory.annotation.Autowired; importorg.springframework.web.bind.annotation.GetMapping; importorg.springframework.web.bind.annotation.RequestMapping; importorg.springframework.web.bind.annotation.RestController; /** *@authorwl */ @Slf4j @RestController @RequestMapping("/test") publicclassTestController{ privatefinalScheduleTaskscheduleTask; @Autowired publicTestController(ScheduleTaskscheduleTask){ this.scheduleTask=scheduleTask; } @GetMapping("/updateCron") publicStringupdateCron(Stringcron){ log.info("newcron:{}",cron); scheduleTask.setCron(cron); return"ok"; } @GetMapping("/updateTimer") publicStringupdateTimer(Longtimer){ log.info("newtimer:{}",timer); scheduleTask.setTimer(timer); return"ok"; } }
测试结果:
基于 Spring Boot + MyBatis Plus + Vue & Element 实现的后台管理系统 + 用户小程序,支持 RBAC 动态权限、多租户、数据权限、工作流、三方登录、支付、短信、商城等功能
项目地址:https://gitee.com/zhijiantianya/ruoyi-vue-pro
视频教程:https://doc.iocoder.cn/video/
基于 Spring Cloud Alibaba + Gateway + Nacos + RocketMQ + Vue & Element 实现的后台管理系统 + 用户小程序,支持 RBAC 动态权限、多租户、数据权限、工作流、三方登录、支付、短信、商城等功能
项目地址:https://gitee.com/zhijiantianya/yudao-cloud
接口
33文章
8564浏览量
150992 -
spring
340浏览量
14333 -
SpringBoot
173浏览量
175
原文标题:SpringBoot 设置动态定时任务,千万别再写死了~
文章出处:【微信号:芋道源码,微信公众号:芋道源码】欢迎添加关注!文章转载请注明出处。
