记录Red Lite Env项目的基础搭建过程及碰到的问题
冬至子 来源:兆易创新GD32 MCU 作者:Red 2022-09-30 14:52 次阅读
Linux 下如何使用对 GD32F310G START 进行在线调试以及程序下载
需要使用的关键工具是,开源的调试器 openocd, 涉及到有两个配置文件,分别是 target 的配置文件 gd32f3x.cfg:
# script for stm32f3x family
# stm32 devices support both JTAG and SWD transports.
source [find target/swj-dp.tcl]
source [find mem_helper.tcl]
if { [info exists CHIPNAME] } {
   set _CHIPNAME $CHIPNAME
} else {
   set _CHIPNAME stm32f3x
set _ENDIAN little
# Work-area is a space in RAM used for flash programming
# By default use 16kB
if { [info exists WORKAREASIZE] } {
   set _WORKAREASIZE $WORKAREASIZE
} else {
   set _WORKAREASIZE 0x4000
# JTAG speed should be <= F_CPU/6. F_CPU after reset is 8MHz, so use F_JTAG = 1MHz
# Since we may be running of an RC oscilator, we crank down the speed a
# bit more to be on the safe side. Perhaps superstition, but if are
# running off a crystal, we can run closer to the limit. Note
# that there can be a pretty wide band where things are more or less stable.
adapter speed 1000
adapter srst delay 100
if {[using_jtag]} {
 jtag_ntrst_delay 100
#jtag scan chain
if { [info exists CPUTAPID] } {
   set _CPUTAPID $CPUTAPID
} else {
   if { [using_jtag] } {
      # See STM Document RM0316
      # Section 29.6.3 - corresponds to Cortex-M4 r0p1
      set _CPUTAPID 0x4ba00477
      set _CPUTAPID 0x2ba01477
swj_newdap $_CHIPNAME cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
dap create $_CHIPNAME.dap -chain-position $_CHIPNAME.cpu
if {[using_jtag]} {
   jtag newtap $_CHIPNAME bs -irlen 5
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME cortex_m -endian $_ENDIAN -dap $_CHIPNAME.dap
$_TARGETNAME configure -work-area-phys 0x20000000 -work-area-size $_WORKAREASIZE -work-area-backup 0
set _FLASHNAME $_CHIPNAME.flash
flash bank $_FLASHNAME stm32f1x 0 0 0 0 $_TARGETNAME
reset_config srst_nogate
if {![using_hla]} {
   # if srst is not fitted use SYSRESETREQ to
   # perform a soft reset
   cortex_m reset_config sysresetreq
proc stm32f3x_default_reset_start {} {
    # Reset clock is HSI (8 MHz)
    adapter speed 1000
proc stm32f3x_default_examine_end {} {
    # Enable debug during low power modes (uses more power)
    mmw 0xe0042004 0x00000007 0 ;# DBGMCU_CR |= DBG_STANDBY | DBG_STOP | DBG_SLEEP
    # Stop watchdog counters during halt
    mmw 0xe0042008 0x00001800 0 ;# DBGMCU_APB1_FZ |= DBG_IWDG_STOP | DBG_WWDG_STOP
proc stm32f3x_default_reset_init {} {
    # Configure PLL to boost clock to HSI x 8 (64 MHz)
    mww 0x40021004 0x00380400   ;# RCC_CFGR = PLLMUL[3:1] | PPRE1[2]
    mmw 0x40021000 0x01000000 0 ;# RCC_CR |= PLLON
    mww 0x40022000 0x00000012   ;# FLASH_ACR = PRFTBE | LATENCY[1]
    sleep 10                    ;# Wait for PLL to lock
    mmw 0x40021004 0x00000002 0 ;# RCC_CFGR |= SW[1]
    # Boost JTAG frequency
    adapter speed 8000
# Default hooks
$_TARGETNAME configure -event examine-end { stm32f3x_default_examine_end }
$_TARGETNAME configure -event reset-start { stm32f3x_default_reset_start }
$_TARGETNAME configure -event reset-init { stm32f3x_default_reset_init }
$_TARGETNAME configure -event trace-config {
    # Set TRACE_IOEN; TRACE_MODE is set to async; when using sync
    # change this value accordingly to configure trace pins
    # assignment
    mmw 0xe0042004 0x00000020 0
board 的配置文件 gd32f3start.cfg
# sudo openocd -f interface/cmsis-dap.cfg -c "transport select swd" -c "set CPUTAPID 0" -f target/gd32f3x.cfg
source [find interface/cmsis-dap.cfg]
set CPUTAPID 0
set WORKAREASIZE 0x2000
source [find target/gd32f3x.cfg]
proc gdd { pos } {
    if { $pos == 0 } {
        reset;
        halt;
        flash write_image erase TencentOS_tiny.bin 0x8000000;
        reset;
        echo "stm down firm 2 internal flash success"
    } else {
        echo "invalid gdd down to others"
分别将上述配置文件放到 openocd 的安装目录,大概是这样的:
▸ tree -L  1 /usr/share/openocd/scripts/
├── bitsbytes.tcl
├── board  ==> 放 gd32f3start.cfg 配置文件
├── chip
├── cpld
├── cpu
├── fpga
├── interface
├── mem_helper.tcl
├── memory.tcl
├── mmr_helpers.tcl
├── target  ==> 放 gd32f3x.cfg 配置文件
├── test
└── tools
9 directories, 4 files
连接开发板的命令是 openocd -f board/gd32f3start.cfg, 如果一切顺利你会看到这样的信息
接下去可以:
使用 arm-none-eabi-gdb 连接本机的 3333 端口远程调试开发板
使用 telnet 链接本机的 4444 端口进行程序下载调试
效果大概是这样的:
环境搭建好了之后,就可以开发愉快的开发了。
移植 Tencent OS 到 GD32F310G START
移植系统比较快的方法是:
参考一个架构类似的处理器的工程,然后复制修改替换,保证编译通过
阅读整个系统的代码走向,点灯调试
逐步优化代码,最后可以提交 療 到上游
此处具体的移植步骤我就不详细记录了,因为网上有丰富的系统移植的教程,都是大同小异的。我在此仅仅展示下我移植过程中的一些提交记录:
特别地,我将 TencentOS Tiny 的 shell 组件添加进来了,所以效果是这样的:
审核编辑:刘清
  • ARM
    ARM
  • Linux
  • JTAG
  • 调试器
    SSM开发环境的搭建教程 SSM与Spring Boot的区别
    SSM开发环境的搭建教程 SSM(Spring+SpringMVC+MyBatis)开发环境的搭建涉及多个步骤,以下是详细的教程: 创建Maven项目 : 使用Maven工具创建一个新的Maven
    的头像 发表于 12-16 18:13 478次阅读
    ARM控制器与Node-Red:获取气象网站数据
    在当今工业物联网(IoT)蓬勃发展的背景下,企业和开发者们不断寻求更智能的方式来管理和控制工业设备。Node-Red作为一种强大的可视化编程工具,简化了物联网应用程序的开发过程,使得即使是编程新手也能快速搭建起复杂的数据流网络。
    的头像 发表于 09-21 10:40 302次阅读
    ARM控制器与Node-<b class='flag-5'>Red</b>:获取气象网站数据
    利用ARMxy边缘计算机BL340与Node-Red实现LED设备的开闭控制
    搭建了一个高效的原型开发与测试平台。本文将带您走进BL340系列与Node-Red的结合应用,探索如何通过这一组合控制设备执行Linux指令,进而控制设备上的LED状态。 一、Node-Red Node-
    的头像 发表于 08-15 14:12 276次阅读
    利用ARMxy边缘计算机BL340与Node-<b class='flag-5'>Red</b>实现LED设备的开闭控制
    ESP_MESH_LITE项目在menuconfig中修改MESH_ID无效的原因?
    ESP_MESH_LITE项目在menuconfig中修改MESH_ID无效,只有执行erase_flash才能修改成功,似乎MESH_ID第一次配置之后存在了flash里面,修改sdkconfig内容无效?
    发表于 07-19 07:29
    求助,关于搭建ESP mesh lite组网遇到的问题求解
    最近想用ESP32做一个物联网项目,需要用 ESP mesh lite 进行一个组网,但是在写程序时遇到了一些问题,首先我用的是Arduino编写的程序,我遇到的第一个疑惑是,当我建立mesh组网
    发表于 06-28 06:44
    Node-RED初学者教程-三分钟学习
    通过这短短三分钟的教程,你已经掌握了Node-RED的基本操作。你可以利用Node-RED的强大功能来创建更复杂的数据流和自动化任务,无论是物联网应用、API集成还是数据处理。Node-RED简化了编程
    的头像 发表于 06-27 17:09 2886次阅读
    Node-<b class='flag-5'>RED</b>初学者教程-三分钟学习
    ENV-Windows v2.0.0版本发布
    的头像 发表于 06-26 08:35 775次阅读
    <b class='flag-5'>ENV</b>-Windows v2.0.0版本发布
    Node-RED安装本地教程
    Node-RED是一个基于流的开发工具,广泛应用于物联网(IoT)、家庭自动化和其他数据驱动的应用程序。它通过图形化的编程界面,使得非专业程序员也能轻松上手。本文将介绍如何在本地环境中安装Node-RED,帮助你快速开始项目开发
    的头像 发表于 06-24 12:10 2145次阅读
    Node-<b class='flag-5'>RED</b>安装本地教程
    Node-RED实现电表数据采集并上云
    容器实现边缘采集”。前文指引:《【教程】图文详解!Docker容器实现边缘采集》首先需要搭建Node-RED运行环境,可以参考以往案例,也可以直接百度搜索,接下来
    的头像 发表于 06-07 08:21 2866次阅读
    Node-<b class='flag-5'>RED</b>实现电表数据采集并上云
    分享 | PTP、NTP时间同步服务器的部署与搭建过程
    的头像 发表于 05-15 10:01 1058次阅读
    分享 | PTP、NTP时间同步服务器的部署与<b class='flag-5'>搭建</b><b class='flag-5'>过程</b>
    SOLIDWORKS教育版使学生了解如何加快设计项目的速度
    在当今信息爆炸的时代,设计项目的速度和效率对于工程专业的学生来说至关重要。SOLIDWORKS教育版作为一款专门为学生设计的3D CAD软件,不仅提供了强大的设计工具,更致力于帮助学生了解如何加快设计项目的速度,提升他们的设计能力和效率。
    的头像 发表于 04-09 16:00 330次阅读
    硬件测试服务项目的重要性和作用
    服务项目的定义与重要性 硬件测试服务项目是对硬件设备(如结构、PCBA、关键部件等)进行差错检查的过程,旨在保证产品的质量和性能。在硬件产品开发过程中,测试是不可或缺的一环,它能够帮助
    的头像 发表于 03-28 09:54 767次阅读
    硬件测试服务<b class='flag-5'>项目的</b>重要性和作用
    OpenHarmony 移植:build lite 编译构建过程
    这些疑惑,会对 build lite 编译构建过程有个更深入的理解。 1、产品解决方案代码是如何被调用编译的 在文件 buildliteBUILD.gn 配置文件中的构建目标 //build/lite
    的头像 发表于 02-19 16:19 971次阅读
    焊接过程监控记录
    、智能诊断、智能排产以及质量控制过程的自动记录。 目前,部分企业焊接人员的能力参差不齐,导致焊工对工艺执行存在偏差,从而严重影响焊接质量。德州迪格特电子科技有限公司开发的焊接过程监测系统,基于焊机设备的智能
    的头像 发表于 02-02 16:25 636次阅读
    焊接<b class='flag-5'>过程</b>监控<b class='flag-5'>记录</b>
    MES系统项目的正确实施
    电子发烧友网站提供《MES系统项目的正确实施.docx》资料免费下载
    发表于 01-31 09:24 0次下载
