【EASY EAI Nano开源套件试用体验】联网SSH登录各模块体验
开发板试用精选 来源:开发板试用 作者:电子发烧友论坛 2022-10-11 16:20 次阅读
本文来源电子发烧友社区,作者:李先生, 帖子地址:https://bbs.elecfans.com/jishu_2308790_1_1.html
前言
拿到板子后我们先对各个主要模块进行测试,确认外设状态。
测试串口登录
如图连接USBTTL串口线,背面有丝印确认GND TX RX
使用串口调试助手连接,参数1500000-8-n-1,无流控。我这里使用CRT
串口登录后就方便其他操作了。
连接WIFI
开发板电脑连接同一WIFI后,我们就可以使用无线网进行SSH登录了。
并且开发板也可以上外网了。
wifi_start.shqiqiqiqi cqmygysdss
打印如下
connect to WiFi ssid: qiqiqiqi, Passwd: cqmygysdss
killall: wpa_supplicant: no process killed
Successfully initialized wpa_supplicant
[404.324931] P2P interface registered
[404.324974] wl_cfgp2p_add_p2p_disc_if: wdev: 89daccc1, wdev->net: (null)
[404.372152] WLC_E_IF: NO_IF set, event Ignored
[404.374364] P2P interface started
[root@EASY-EAI-NANO:/]# [404.422879] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 0, bssidx: 0
[405.560685] [dhd-wlan0] wl_cfg80211_connect : Connecting with d4:35:38:a2:da:19 ssid "qiqiqiqi", len (8), sec=wpa2psk/tkipaes, channel=10
[405.560685]
[405.590043] dhd_dbg_start_pkt_monitor, 1724
[405.860888] [dhd-wlan0] wl_iw_event : Link UP with d4:35:38:a2:da:19
[405.860997] [dhd-wlan0] wl_ext_iapsta_event : [S] Link UP with d4:35:38:a2:da:19
[405.861058] [dhd-wlan0] wl_notify_connect_status : wl_bss_connect_done succeeded with d4:35:38:a2:da:19
[405.942187] [dhd-wlan0] wl_notify_connect_status : wl_bss_connect_done succeeded with d4:35:38:a2:da:19 vndr_oui: 00-90-4C 00-0C-43
Ping外网确认连接
pingwww.baidu.com
打印如下
PINGwww.a.shifen.com(183.232.231.174) 56(84) bytes of data.
64 bytes from localhost (183.232.231.174): icmp_seq=1 ttl=54 time=36.2 ms
64 bytes from localhost (183.232.231.174): icmp_seq=2 ttl=54 time=50.8 ms
^C
---www.a.shifen.comping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1000ms
rtt min/avg/max/mdev = 36.269/43.577/50.886/7.311 ms
无线SSH登录
开发板和电脑连接同一WIFI
ifconfig
查看ip
[root@EASY-EAI-NANO:/]# ifconfig
eth0 Link encap:EthernetHWaddr D6:6B:41:35:BD:9D
inet addr:192.168.1.168Bcast:192.168.1.255Mask:255.255.255.0
UP BROADCAST MULTICASTMTU:1500Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B)TX bytes:0 (0.0 B)
Interrupt:68
lo Link encap:Local Loopback
inet addr:127.0.0.1Mask:255.0.0.0
UP LOOPBACK RUNNINGMTU:65536Metric:1
RX packets:184 errors:0 dropped:0 overruns:0 frame:0
TX packets:184 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:11488 (11.2 KiB)TX bytes:11488 (11.2 KiB)
wlan0 Link encap:EthernetHWaddr 08:FB:EA:78:BF:0A
inet addr:192.168.31.49Bcast:192.168.31.255Mask:255.255.255.0
UP BROADCAST RUNNING MULTICASTMTU:1500Metric:1
RX packets:72 errors:0 dropped:0 overruns:0 frame:0
TX packets:86 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6016 (5.8 KiB)TX bytes:10540 (10.2 KiB)
我这里开发板IP192.168.31.49
电脑ping开发板
命令行中ping 192.168.31.49
命令行中ipconfig查看电脑ip
无线局域网适配器WLAN:
连接特定的DNS后缀. . . . . . . :
本地链接IPv6地址. . . . . . . . : fe80::3557:1c74:c76f:bc5d%25
IPv4地址. . . . . . . . . . . . : 192.168.31.236
子网掩码. . . . . . . . . . . . : 255.255.255.0
默认网关. . . . . . . . . . . . . : 192.168.31.1
开发板ping电脑
[root@EASY-EAI-NANO:/]# ping 192.168.31.236
PING 192.168.31.236 (192.168.31.236) 56(84) bytes of data.
64 bytes from 192.168.31.236: icmp_seq=1 ttl=128 time=165 ms
64 bytes from 192.168.31.236: icmp_seq=2 ttl=128 time=25.6 ms
^C
--- 192.168.31.236 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 25.668/95.642/165.616/69.974 ms
双向ping通后,可以ssh登录
我这里使用CRT
用户名和密码都是root
登录成功
有线SSH登录
和无线SSH登录类似,开发板eth0默认IP192.168.1.168,电脑需要改为同一网段。
过程就不再赘述了。
背光灯测试
vi brightness.sh
添加如下代码,实现明亮渐变操作。
#!/bin/bash
while true
do
for i in {1..255}
do
echo $i > /sys/class/backlight/backlight/brightness
usleep 10000
done
for i in {1..255}
do
j=$((255-$i))
echo $j > /sys/class/backlight/backlight/brightness
usleep 10000
done
Done
chmod +x brightness.sh
./brightness.sh
可以看到暗区变化快,亮区变化慢,并且也不是线性的。
人脸识别/摄像头测试
/userdata/apps/facialGate/qSolu-facialGate
能实时预览摄像头说明摄像头OK
声音录放播放MP3
串口rz导入test.mp3
mp3play.sh test.mp3 16000注意要和实际采样率对应
录放
amixer cset name='Digital Capture Volume' 100,100调节录音英两最大120
arecord -f cd test.wav录音
amixer cset name='Master Playback Volume' 255,255调节播放最大音量最大255
aplay test.wav播放
配置播放通道
amixer cset name='Playback Path' 'SPK'喇叭
amixer cset name='Playback Path' 'HP' 耳机
amixer cset name='Playback Path' 'SPK_HP'耳机和喇叭
amixer cset name='Playback Path' 'OFF'关闭
访问SD/U
SD卡挂载在/mnt/sdcard
U盘一般使用下层独立USB HOST2挂载在/media/usbN
上层USB HOST1ADB复用,需要断开ADB,并且OTG拨码开关要拨向HOST1重启开发板。
总结
经过上面的测试,确认了外设状态,也熟悉了各模块,后面再进行对应的应用开发。
  • 开发板
  • 灵眸
    SSH远程操作的基本方式
    SSH 是 Linux 下进行远程连接的基本工具,但是如果仅仅用它来登录那可是太浪费啦!SSH 命令可是完成远程操作的神器啊,借助它我们可以把很多的远程操作自动化掉!下面就对 SSH
    的头像 发表于 11-11 11:15 222次阅读
    <b class='flag-5'>SSH</b>远程操作的基本方式
    详解SSH的工作原理
    SSH是一种协议标准,其目的是实现安全远程登录以及其它安全网络服务。
    的头像 发表于 11-04 15:51 200次阅读
    详解<b class='flag-5'>SSH</b>的工作原理
    如何配置华为eNSP模拟器设备路由器的ssh登录
    本博文主要讲解了如何配置华为eNSP模拟器设备路由器的ssh登录,以便自动化应用可以更好的控制管理相关网络设备。
    的头像 发表于 10-25 09:31 616次阅读
    如何配置华为eNSP模拟器设备路由器的<b class='flag-5'>ssh</b><b class='flag-5'>登录</b>
    交换机如何配置SSH远程登录
    从事网络运维工作的小伙伴们都知道,在交换机正式上线时,必须完成配置SSH远程登录,这样做目的是为了日后,维护方便,不需要每次登录设备都要跑到机房,这样既不现实,又费事。
    的头像 发表于 10-10 14:33 921次阅读
    交换机如何配置<b class='flag-5'>SSH</b>远程<b class='flag-5'>登录</b>
    【星闪派物联网开发套件体验连载】智能交通灯
    发板,5个模块,1个底板,1条数据线 单独的星闪派开发板: 全家福: 硬件组装: 星闪派物联网开发套件模块化、集成化,功能
    发表于 10-05 13:00
    【龙芯2K0300蜂鸟板试用】远程SSH登录问题解决
    首先说下,一般linux开发板ssh远程登录是很基本的操作,因为更新程序,下载配置都需要这个步骤,但是按照常规操作,龙芯蜂鸟开发板死活ssh无法登陆。先看下过程,首先我配置板卡的IP为
    发表于 08-12 22:16
    NAS教程:铁威马如何登录 SSH终端?
    适用型号: 所有TNAS 型号 如您有特殊操作需要通过 SSH 终端登录 TNAS,请参照以下指引: (注意: 关于以下操作步骤中的"cd /"的指令,其作用是使当前 SSH/Telnet 连接
    的头像 发表于 06-26 14:30 370次阅读
    NAS教程:铁威马如何<b class='flag-5'>登录</b> <b class='flag-5'>SSH</b>终端?
    【LicheeRV-Nano开发套件试用体验】LicheeRV-Nano上的IAI技术应用
    开发板,之前试用过 DUO对其清奇骨骼,小巧的身板,强劲的性能所吸引,在知道其更加强悍的兄弟板出来后,第一时间申请到试用。 此次开发板包含物料比较充分,除了有Nano开发板,还有带触摸的全贴合屏幕
    发表于 03-07 17:32
    【LicheeRV-Nano开发套件试用体验】+智能平板开发
    首先感谢Sipeed矽速科技和电子发烧友给与的这次机会,得以试用LicheeRV-Nano开发套件,并与大家共同分享与学习。 鉴于试用报告格式调整,后面亦按要求展现。 申请理由:
    发表于 03-06 23:05
    【LicheeRV-Nano开发套件试用连载体验】+ 实现三麦克纳姆轮小车自主导航
    【LicheeRV-Nano开发套件试用连载体验】+ 实现三麦克纳姆轮小车自主导航 非常感谢被选中成为Sipeed矽速科技、电子发烧友论坛组织的此次试用体验幸运儿,有机会参与
    发表于 03-03 14:20
    昉·星光2 RISC-V单板计算机体验(三) - SSH连接
    SSH登录 2.1. 打开SSH协议 登录成功之后,输入: nano /etc/ ssh/ss
    的头像 发表于 02-21 10:21 470次阅读
    昉·星光2 RISC-V单板计算机体验(三) - <b class='flag-5'>SSH</b>连接
    EASY-EAI携手Hailo推出高性能、高算力的边缘AI硬件组合
    EASY-EAI与Hailo建立合作关系,共同推出高算力的边缘AI产品组合。
    的头像 发表于 02-21 09:56 773次阅读
    怎么用SSH密钥登陆vps?
    使用SSH密钥登录VPS(Virtual Private Server)是一种更安全和方便的方式,相比使用密码,SSH密钥更难被破解。以下是在Linux系统上使用SSH密钥
    的头像 发表于 02-20 16:29 1062次阅读
    核桃派1B 开发板试用体验】连接wifi,并实现ssh远程登录
    【目的】 由于手头上没有合适的hdmi显示器,所以后面的开发需要用到ssh登录。那么需要用的wifi连网等。 1、wifi扫描:nmcli dev wifi 执行后会列出扫描到的无线AP,结束需要用
    发表于 01-02 11:49
    【ELF 1开发板试用】+ 3.1 连接测试 + Powershell SSH连接
    连接测试 从 ELF1 教程文档\\\\01-教程文档\\\\01-0 ELF1、ELF1S开发板_快速启动手册_V1.pdf 中我们可知,ELF 1支持串口登录SSH登录登录
    发表于 12-05 23:25
