浅谈Pureline技术的六大CM300xi-ULN系统组件
美博科技FormFactor 来源:美博科技FormFactor 作者:美博科技FormFacto 2022-10-13 15:25 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
Using theCM300xi-ULN probing systemwith PureLine 3 technology, device test engineers, reliability engineers and IC design engineers can all benefit. Accurate flicker, RTN, and phase noise measurements for advanced materials, package interconnects, transistors, and IC’s can be done simply and automatically for faster time to data.
PureLine 3 technology is integrated into many components of the CM300xi-ULN probing system, including the following six:
1. ULN MicroChamber
This provides the critical probing environment built into the prober and directly surrounding the DUT and wafer chuck area for low noise testing. The newly enhanced ULN MicroChamber ensures a complete EMI / RFI shielded area, like a small, localized version of a large lab-sized Faraday cage. In addition, the ULN MicroChamber provides the required dark and dry environment critical for measuring light sensitive transistors, and devices at negative temperatures (<= -60°C) with frost free operation. The integrated dry (low humidity) environment control system also supports FormFactor’s industry leading DC low noise/ low leakage device measurements.
2. ULN Power Conditioning Unit (PCU)
This integral ULN system component provides fully managed and filtered AC power to the entire system – prober and instruments. The patented PureLine 3 technology in the rackmount ULN Power Conditioning Unit (PCU) enables small footprint, low field emissions, and forms the foundation for the TestCell Power Management (TCPM), eliminating ground-loops between probe station and instruments that cause significant low frequency noise. The ULN PCU supplies clean, filtered AC power to the probe station, thermal chiller and controller, wafer loader, powered accessories, and all test instruments. In addition, the PCU provides a unified Emergency Off / Emergency Power control system for safe operation of the whole system and all instruments.
3. ULN Thermal Filtering Module
The ULN Thermal Filtering Module is included with all ULN systems with thermally controlled wafer chucks. It is vital for enabling ultra-low noise probing at temperature. Harmful noise generated by external thermal control systems is filtered from entering the critical low-noise measurement environment. The active module significantly reduces high frequency noise, by up to 30dB above 1Mhz.
4. ULN Single Point Grounding and Cabling System
Each ULN system also includes a single point grounding system for all the prober accessories, with low resistance grounding connections. PureLine 3 design practices enforce low resistance materials and hard connection schemes for mechanical assemblies – that result in reduced antenna effect injection of unwanted RF noise into the measurement path.
5. ULN SMU Filtering Modules for Accurate PLL Phase Noise
For highly accurate phase noise measurements of devices such as Phase Lock Loop circuits (PLL) and Voltage Controlled Oscillators (VCO), newly developed DC filter modules for Source Measure Units (SMU) can be used with the CM300xi-ULN probing system, to provide ultra-quiet / clean DC supply voltage. The high-performance DC SMU filtering modules provide up to 100dB attenuation (50Hz to 80MHz) with 100mA max. DC current handling. Each SMU filter module supports one channel, and multiple modules can be configured together to provide multi-channel clean power.
6. ULN Contact Intelligence Modules
New ULN Contact Intelligence modules (1, 2, and 4 positioner systems) with PureLine 3 noise reduction, make the CM300xi-ULN the world’s first probe station to achieve autonomous flicker noise thermal testing on 30µm pads. With the Autonomous DC Measurement Assistant, the CM300xi-ULN can be configured to use ULN-optimized Contact Intelligence with motorized DC probe positioners, enabling fully autonomous DC and flicker noise probing, over multiple temperatures for complete hands-free 24/7 operation.
With the newly patented PureLine 3 technology, the ULN probing system enables up to 32x lower noise (1 kHz), eliminating 97% of the environmental noise experienced in previous probe systems, improving device characterization and modelling at the 7/5/2nm technology nodes targeted for 5G and beyond applications. For more information, please visit the website.
编辑:黄飞
  • uln
    uln
  • 组件
原文标题:利用Pureline技术的六大CM300xi-ULN系统组件
文章出处:【微信号:美博科技FormFactor,微信公众号:美博科技FormFactor】欢迎添加关注!文章转载请注明出处。
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    六大汽车安全技术全解析
    六大汽车安全技术全解析
    发表于 08-20 13:15
    无线通信的六大技术是哪六大?
    无线通信的六大技术是哪六大? 移动通信自20世纪90年代以来进入了大发展阶段,全球用户数每20个月翻一番,目前全球用
    发表于 03-13 11:29 985次阅读
    浅谈电源设备逆变器的六大构成
    浅谈电源设备逆变器的六大构成
    的头像 发表于 08-21 16:52 1.1w次阅读
    CM300xi-ULN探针台基本实现即插即用
    将高性能闪烁噪声或相位噪声实验室安装在不良位置会降低其性能。与开发高性能系统一样,对于负责安装新探针台的实验室技术人员来说,找到一个好位置可能是一项耗时且困难的任务。
    发表于 06-08 15:09 786次阅读
    FormFactor的3D手动控制用于CM300xi探针台
    FormFactor的3D手动控件提供了一种非常直观的方式,可以在X,Y和Z方向上手动移动CM300xi的卡盘。使用X-Y旋钮在X和Y方向上定位卡盘,并使用虚拟压板提升器控制晶片和探针之间的距离。
    的头像 发表于 06-13 10:07 1951次阅读
    SUMMIT200和CM300xi探针台引入新型经济热力系统
    为了提供市场上最佳的性价比,我们为SUMMIT200和CM300xi探针台引入了一种新型的经济热系统(-40至+ 300°C)。新系统可显着节省成本并提高效率,从而真正发挥作用。
    的头像 发表于 06-13 10:14 1726次阅读
    CM300xi-ULN探针台在在片噪声测试领域中的应用
     采用PureLine 3技术的新型CM300xi-ULN可消除97%以前探针台中的环境噪声,并从根本上改变7纳米以下前沿技术节点的实验室闪烁噪声测量         今天,我们正式推
    的头像 发表于 06-18 15:14 1934次阅读
    PureLine 3技术可消除97%的探针台环境噪声
    ,宣布推出CM300xi-ULN探针台。这一新的在片噪声测试金标准具有许多新特点,但最重要的特点是PureLine™第三代技术。         该技术包含我们的大量专利、电气设计知识
    的头像 发表于 06-18 15:15 1723次阅读
    CM300xi探针系统提供了测量精度和可靠性
    可以处理200 mm任意组合的全自动双探针系统300毫米晶圆。 正在进行研究的一个领域是直接探测互连3D堆叠芯片的细间距微凸块。需要细间距,低力探针卡和高精度探针,以及我们的组合PyramidProbe®先进的技术和准确性
    的头像 发表于 06-29 18:17 3108次阅读
    CM300xi-ULN探针台—在片噪声测试新金标准
    采用PureLine 3技术的新型CM300xi-ULN可消除97%以前探针台中的环境噪声,并从根本上改变7纳米以下前沿技术节点的实验室闪烁噪声测量         我们推出一种
    的头像 发表于 07-05 10:28 2019次阅读
    <b class='flag-5'>CM300xi-ULN</b>探针台—在片噪声测试新金标准
    使用测试单元电源管理消除接地回路感应噪声
    测试单元电源管理不仅消除了测量测试单元中所有接地回路感应噪声,而且占地面积小,场发射率低,可为整个系统、探针台和仪器提供全面管理和过滤的交流电源。           自从CM300xi-ULN探针
    的头像 发表于 07-05 10:33 1562次阅读
    CM300xi-ULN探针台的独特之处
    在这篇文章中,我们将涵盖实现高吞吐量闪烁噪声测量。闪烁和RTN噪声测试可能需要很长时间,尤其是在测量频率低至1 Hz或更低的情况下。单一温度下的扫描时间通常长达30分钟。器件模型的标准数据采集需要在多个温度下在小衬垫上的DUT数据。
    的头像 发表于 07-06 14:29 1561次阅读
    CM300xi-ULN探针台的简单介绍
    在本文中,我们将探讨探针台系统消除低噪声实验室优化固有的高成本工具部署问题的能力。
    的头像 发表于 07-06 14:31 2042次阅读
    超低噪声测量利器,cascade 探针台CM300xi-ULN
      FormFactor的新型CM300xi-ULN(超低噪声)是一种革命性的300毫米晶圆探测系统,设计用于高精度闪烁噪声(1 / f),随机电报信号噪声(RTN或RTS)以及超灵敏设备的相位噪声
    发表于 12-23 14:09 2776次阅读
    浅谈FPGA的六大应用领域
    FPGA 所能应用的领域大概可以分成六大类,下面听我一一道来。
    发表于 08-09 10:14 1552次阅读
