本文来源电子发烧友社区,作者:李先生, 帖子地址:https://bbs.elecfans.com/jishu_2307456_1_1.html
前言
前面我们抑制了LVGL,现在我们就可以利用GUI提供的控件,进行各种可视化项目设计了。本开发板具备ADC,所以想到的是利用ADC采集模拟数据,使用LVGL的CHART控件进行波形显示,实现简易示波器的设计。
代码
make menuconfig
Driver->
Enable HDF platform adc driver
使能ADC驱动。
gn文件添加头文件
"//drivers/hdf_core/framework/support/platform/include/adc",路径
#include
#include
#include "stdint.h"
#include "los_task.h"
#include "ohos_run.h"
#include "st7735.h"
#include "lv_port_disp.h"
#include "lvgl.h"
#include "demos/lv_demos.h"
#include "adc_if.h"
static void btn_event_cb(lv_event_t * e)
lv_event_code_t code = lv_event_get_code(e);
lv_obj_t * btn = lv_event_get_target(e);
if(code == LV_EVENT_CLICKED) {
static uint8_t cnt = 0;
cnt++;
/*Get the first child of the button which is the label and change its text*/
lv_obj_t * label = lv_obj_get_child(btn, 0);
lv_label_set_text_fmt(label, "Button: %d", cnt);
void lv_log_print(const char * buf)
printf("%srn",buf);
* Create a button with a label and react on click event.
void lv_example_get_started_1(void)
lv_obj_t * btn = lv_btn_create(lv_scr_act()); /*Add a button the current screen*/
lv_obj_set_pos(btn, 10, 10); /*Set its position*/
lv_obj_set_size(btn, 60, 25); /*Set its size*/
lv_obj_add_event_cb(btn, btn_event_cb, LV_EVENT_ALL, NULL); /*Assign a callback to the button*/
lv_obj_t * label = lv_label_create(btn); /*Add a label to the button*/
lv_label_set_text(label, "Button"); /*Set the labels text*/
lv_obj_center(label);
void lv_tick_handle(UINT32 arg)
while(1)
LOS_Msleep(5); /*Sleep for 5 millisecond*/
lv_tick_inc(5);
lv_timer_handler();
lv_obj_t * chart;
lv_chart_series_t * ser1;
int adc_chart_init(void)
lv_obj_set_style_bg_color(lv_scr_act(), lv_color_hex(0x343247), 0);
/*Create a chart*/
chart = lv_chart_create(lv_scr_act());
lv_chart_set_type(chart, LV_CHART_TYPE_LINE);
lv_chart_set_point_count(chart, 10);
lv_chart_set_range(chart,LV_CHART_AXIS_PRIMARY_Y, 0, 330*3);
lv_chart_set_range(chart,LV_CHART_AXIS_SECONDARY_Y, 0, 330*3);
lv_chart_set_update_mode(chart, LV_CHART_UPDATE_MODE_SHIFT);
lv_chart_set_div_line_count(chart, 4, 8);
//lv_chart_set_zoom_x(lv_obj_t * obj, uint16_t zoom_x);
//lv_chart_set_zoom_y(lv_obj_t * obj, uint16_t zoom_y);
lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_Y, 0, 0, 1, 1, true, 1);
lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_X, 0, 0, 2, 1, true, 1);
lv_obj_set_size(chart, 135, 130);
lv_obj_align(chart, LV_ALIGN_CENTER, 0, 0);
/*Add data series*/
ser1 = lv_chart_add_series(chart,lv_color_hex(0xF800),LV_CHART_AXIS_PRIMARY_Y);
return 0;
int adc_chart_newdata(int index,uint32_t newdata,int refresh)
if(index == 0)
lv_chart_set_next_value(chart, ser1, newdata);
else
if(refresh)
lv_chart_refresh(chart); /*Required after direct set*/
return 0;
#define ADC_DEVICE_NUM 1
#define ADC_CHANNEL_NUM 6
void StartHdfSPITest(void)
UINT32 g_lv_time_task;
TSK_INIT_PARAM_S task = { 0 };
task.pfnTaskEntry = (TSK_ENTRY_FUNC)lv_tick_handle;
task.pcName = "lv_time_task";
task.uwStackSize = 0x1000;
task.usTaskPrio = 25 - 1;
DevHandle adcHandle;
uint32_t readVal = 0;
///adcHandle = AdcOpen(ADC_DEVICE_NUM);
///if (adcHandle == NULL) {
/// printf("open adc errrn");
lv_init();
lv_port_disp_init();
///lv_log_register_print_cb(lv_log_print);
LOS_TaskCreate(&g_lv_time_task, &task);
//lv_demo_stress();
//lv_example_get_started_1();
adc_chart_init();
while(1)
static int num = 0;
//if (AdcRead(adcHandle, ADC_CHANNEL_NUM, &readVal) == HDF_SUCCESS) {
readVal = lv_rand(0,0xFFF);
num++;
readVal = readVal * 330 / (1u<<12);
adc_chart_newdata(0,readVal,1);
LOS_Msleep(200);
lv_task_handler();
OHOS_APP_RUN(StartHdfSPITest);
效果
总结
上述只是进行了简单的演示,可以考虑更加完善,实现一个可用的简单示波器。 另外借助LVGL可以实现更多有意思的小项目,比如信号发生器,串口调试助手等等。二维码生成器等。
举报投诉
开鸿智谷
2文章
127浏览量
1171 -
NiobeU4
3文章
31浏览量
512
有奖丨米尔 全志T536开发板免费试用
米尔与全志合作发布的新品基于全志T536应用处理器的MYD-LT536-GK开发板免费试用活动来啦~~米尔提供了3块价值750元的MYD-LT536-GK开发板发起
追加名额丨米尔瑞芯微RK3576开发板有奖试用
米尔与瑞芯微合作发布的新品基于瑞芯微RK3576应用处理器的MYD-LR3576开发板免费试用活动加码啦~~米尔追加了2块价值849元的MYD-LR3576开发板发起
有奖丨米尔 瑞芯微RK3576开发板免费试用
米尔与瑞芯微合作发布的新品基于瑞芯微RK3576应用处理器的MYD-LR3576开发板免费试用活动来啦~~米尔提供了7块价值849元的MYD-LR3576开发板发起
开鸿智谷用技术助力构建鸿蒙世界的基石
高级工程师王振德受邀出席此次技术交流盛会并发表主题演讲,为鸿蒙生态的繁荣贡献企业力量。开鸿智谷的鸿蒙团队一直与广大开发者无私分享技术心得,共同解决着代码难题,让更多人能
点击参与米尔NXP i.MX 93开发板有奖试用
米尔与NXP合作发布的新品基于NXPi.MX93应用处理器的MYD-LMX9X开发板免费试用活动来啦~~米尔提供了3块价值678元的MYD-LMX9X开发板发起
开鸿智谷与OpenHarmony的创新对话
OpenHarmony4.1Release版本根技术特性解读为契机,聚集广大开发者、生态伙伴、行业领袖与百位技术专家共同讨论技术话题。开鸿智谷作为互联互通核心成员,不仅在现场荣获多项奖
开鸿智谷亮相OpenHarmony开发者大会,与生态共创开源新篇章!
5月25日,以“鸿心聚力智引未来”为主题的OpenHarmony开发者大会2024(以下简称大会)在深圳成功举办。开鸿智谷获得多项奖项及授牌
开鸿智谷联合多家伙伴战略签约,加速鸿蒙生态发展!
5月20日,开鸿智谷母公司拓维信息520产品与技术开放日暨28周年庆圆满举行,此次周年庆不仅是对公司创新突破、产品孵化和商业成果的回顾,更是携手合作伙伴共同展望未来、开启新篇章的重要时刻。开
开鸿智谷受邀出席2023年度南山区经济突出贡献企业TOP峰会
4月19日,2023年度南山区经济突出贡献今业TOP峰会顺利召开,开鸿智谷(深圳子公司)作为南山鸿蒙产业生态的核心企业,OpenHarmony项目群A类捐赠人、鸿蒙生态服务公司首批入驻
拓维信息及旗下开鸿智谷同获华为HarmonyOS开发服务商认证
近日,拓维信息及旗下开鸿智谷双双通过华为HarmonyOS开发服务商认证,成为华为“鸿蒙服务商先锋计划”认证级伙伴。秉持共同发展、共创价值的合作理念,拓维信息、
国内首批 | 开鸿智谷多名讲师获“鸿蒙原生应用开发培训讲师”资格认证
2023年3月4日-5日,鸿蒙生态服务(深圳)有限公司(以下简称“鸿蒙生态服务公司”)组织了国内首批“鸿蒙原生应用开发培训讲师”认证,开鸿智谷
