本文来源电子发烧友社区,作者:刘建华, 帖子地址:https://bbs.elecfans.com/jishu_2310612_1_1.html
前面生成了运动、生成食物的算法。这次增加吃食物的算法:
1、创建生成食物的标志build_food_state,在主程序中判断,如果标志需要创建食物,则生成。如果食物还存在,就不生成食物。
2、吃到食物的判断:如果生成下一个食物的坐标数组与食物的坐标数组相等,则不消除最后尾的块,同时更新生成食物的标志为真。如果没有吃到食物,则消除尾部块。
# 如果加入的方块等于食物,则不删去尾块
if disp_List[-1] == disp_food:
buid_food_state = 1
else:
del disp_List[0]
整体程序如下:
import os
import tqs1
import tqmain
import tqmath
#value= '1000000,1000000,1000000,1000000,1000000,1000000'
#mylist =[0x08,0x08,0x08,0x08,0x08,0x08]
myItem =[[0,0,0,0,0,0,0],[0,0,0,0,0,0,0],[0,0,0,0,0,0,0],[0,0,0,0,0,0,0],[0,0,0,0,0,0,0],[0,0,0,0,0,0,0],[0,0,0,0,0,0,0]]
#tqmain.serial_write_line("start")
state = True
disp_List = [[0,0]]
disp_food = []
time_state = 0
move_state = 0
buid_food_state = 1
def disp_tq():
global state,myItem
state = False
mystr =[]
for j in range(0,6):
strit = ''.join(str(i) for i in myItem[j])
mystr.append(strit)
print(mystr)
value = ','.join(mystr)
tqmain.matri_strfill_display(value)
state = False
def get_key():
global state,move_state
key_value1 = tqs1.key_get_status(2)
if key_value1 == 0:
move_state = move_state +1
if move_state > 3:
move_state = 0
print("KeyB changed,move_state:" + str(move_state))
state = True
key_value2 = tqs1.key_get_status(1)
if key_value2 == 0:
move_state = move_state -1
if move_state < 0:
move_state = 3
print("KeyA changed,move_state:" + str(move_state))
state = True
def move():
global move_state,myItem,disp_List,disp_food,buid_food_state
#先把同最前一个灭了
fisrt = disp_List[0]
myItem[fisrt[0]][fisrt[1]]=0
if move_state == 0:
tail = disp_List[-1]
print(tail)
x=tail[0]
y=tail[1]+1
if(y>6):
y=0
disp_List.append([x,y])
elif move_state == 1:
print(tail)
x=tail[0]+1
y=tail[1]
if(x>5):
x=0
elif move_state == 2:
print(tail)
x=tail[0]
y=tail[1]-1
if(y<0):
y=6
elif move_state == 3:
print(tail)
x=tail[0]-1
y=tail[1]
if(x<0):
x=5
buid_food_state = 1
else:
del disp_List[0]
for item in disp_List:
myItem[item[0]][item[1]]=1
if len(disp_food) == 2:
myItem[disp_food[0]][disp_food[1]] = 1
# 随机生成 坐标 食物
def build_food():
global disp_List,disp_food,buid_food_state
disp_food=[]
disp_food.append(tqmath.random(0, 5))
disp_food.append(tqmath.random(0, 6))
if disp_food in disp_List:
print(disp_food)
buid_food_state = 0
while True:
get_key()
if state == True:
move()
if buid_food_state == 1:
build_food()
disp_tq()
os.sleep(0.1)
else:
time_state = time_state + 1
if time_state == 5:
move()
build_food()
disp_tq()
time_state = 0
os.sleep(0.1)
效果见视频。
【贪吃蛇4视频演示】详见作者原贴文章
举报投诉
开发板
25文章
4791浏览量
96299
点击参与米尔NXP i.MX 93开发板有奖试用
米尔与NXP合作发布的新品基于NXPi.MX93应用处理器的MYD-LMX9X开发板免费试用活动来啦~~米尔提供了3块价值678元的MYD-LMX9X开发板发起
M3芯片与M1芯片的比较
M3芯片与M1处理器相比,在多个方面表现出显著优势。首先,M3芯片在架构上采用了更先进的制程技术,如T8103内核和N5P制程,使其具有更高的性能和更低的功耗。
M3芯片与M1芯片差别大吗
M3芯片与M1芯片在多个方面存在显著的差异。首先,M3芯片采用了更先进的制程技术,这使得它在性能上有所提升,特别是在处理复杂任务和多线程应用时表现更为出色。
基于FPGA的贪吃蛇游戏设计
食物产生模块完成的任务是:每次初始化就给定一个食物坐标比如(24,10),然后蛇运动的过程中用蛇头坐标跟食物坐标对比是否重合来判断是否吃掉了食物,如果相同食物就被吃掉,然后由随机数产生新的食物坐标。
【ELF 1开发板试用】1.开箱验货
打开纸盒子,引入眼帘的是 ELF1 开发板,一张纪念卡,一份开箱必读说明书。ELF1 开发板的标准配件包里有:一字螺丝刀、尼龙柱、Type-C转接线、10P杜邦线和网线。
就拿 T
发表于 11-21 14:20
【LuckFox Pico Plus开发板免费试用】+开发板上手
LuckFox Pico的试用机会,这款开发板相当于是RV1103的小型评估板,引出了所有的IO口,并且带以太网/USB/摄像头等高速接口。下面一起来看一下。
