本文来源电子发烧友社区,作者:李先生, 帖子地址:https://bbs.elecfans.com/jishu_2304985_1_1.html
前言
板子的性能不仅仅和CPU相关,也和存储等相关,是一个综合体现,所以我们从CPU,存储,等几个关键的部分去进行性能测试。
CPU性能:Coremark跑分
git clone [https://github.com/eembc/coremark.git](https://github.com/eembc/coremark.git)
cd coremark/
单线程
打印信息如下
root@firefly:~/coremark# make ITERATIONS=100000
make XCFLAGS=" -DPERFORMANCE_RUN=1" load run1.log
make[1]: Entering directory '/root/coremark'
make port_prebuild
make[2]: Entering directory '/root/coremark'
make[2]: Nothing to be done for 'port_prebuild'.
make[2]: Leaving directory '/root/coremark'
make link
cc -O2 -Ilinux -Iposix -I. -DFLAGS_STR=""-O2 -DPERFORMANCE_RUN=1 -lrt"" -DITERATIONS=100000 -DPERFORMANCE_RUN=1 core_list_join.c core_main.c core_matrix.c core_state.c core_util.c posix/core_portme.c -o ./coremark.exe -lrt
Link performed along with compile
make port_postbuild
make[2]: Nothing to be done for 'port_postbuild'.
make port_preload
make[2]: Nothing to be done for 'port_preload'.
echo Loading done ./coremark.exe
make port_postload
make[2]: Nothing to be done for 'port_postload'.
make port_prerun
make[2]: Nothing to be done for 'port_prerun'.
./coremark.exe 0x0 0x0 0x66 100000 7 1 2000 > ./run1.log
make port_postrun
make[2]: Nothing to be done for 'port_postrun'.
make[1]: Leaving directory '/root/coremark'
make XCFLAGS=" -DVALIDATION_RUN=1" load run2.log
make port_preload
make port_postload
make port_prerun
./coremark.exe 0x3415 0x3415 0x66 100000 7 1 2000 > ./run2.log
make port_postrun
Check run1.log and run2.log for results.
See README.md for run and reporting rules.
run1.log
root@firefly:~/coremark# vi run1.log
2K performance run parameters for coremark.
CoreMark Size : 666
Total ticks : 14036
Total time (secs): 14.036000
Iterations/Sec : 7124.536905
Iterations : 100000
Compiler version : GCC9.4.0
Compiler flags : -O2 -DPERFORMANCE_RUN=1 -lrt
Memory location : Please put data memory location here
(e.g. code in flash, data on heap etc)
seedcrc : 0xe9f5
[0]crclist : 0xe714
[0]crcmatrix : 0x1fd7
[0]crcstate : 0x8e3a
[0]crcfinal : 0xd340
Correct operation validated. See README.md for run and reporting rules.
CoreMark 1.0 : 7124.536905 / GCC9.4.0 -O2 -DPERFORMANCE_RUN=1 -lrt / Heap
run2.log
root@firefly:~/coremark# vi run2.log
2K validation run parameters for coremark.
CoreMark Size : 666
Total ticks : 14138
Total time (secs): 14.138000
Iterations/Sec : 7073.136229
Iterations : 100000
seedcrc : 0x18f2
[0]crclist : 0xe3c1
[0]crcmatrix : 0x0747
[0]crcstate : 0x8d84
[0]crcfinal : 0x5c66
多线程
make XCFLAGS="-DMULTITHREAD=4 -DUSE_FORK"
打印如下
root@firefly:~/coremark# make XCFLAGS="-DMULTITHREAD=4 -DUSE_FORK"
make XCFLAGS="-DMULTITHREAD=4 -DUSE_FORK -DPERFORMANCE_RUN=1" load run1.log
make port_preload
make port_postload
make port_prerun
./coremark.exe 0x0 0x0 0x66 0 7 1 2000 > ./run1.log
make port_postrun
make XCFLAGS="-DMULTITHREAD=4 -DUSE_FORK -DVALIDATION_RUN=1" load run2.log
make port_preload
make port_postload
make port_prerun
./coremark.exe 0x3415 0x3415 0x66 0 7 1 2000 > ./run2.log
make port_postrun
run1.log
CoreMark Size : 666
Total ticks : 15471
Total time (secs): 15.471000
Iterations/Sec : 28440.307672
Iterations : 440000
Compiler flags : -O2 -DMULTITHREAD=4 -DUSE_FORK -DPERFORMANCE_RUN=1 -lrt
Parallel Fork : 4
seedcrc : 0xe9f5
[0]crclist : 0xe714
[1]crclist : 0xe714
[2]crclist : 0xe714
[3]crclist : 0xe714
[1]crcmatrix : 0x1fd7
[2]crcmatrix : 0x1fd7
[3]crcmatrix : 0x1fd7
[1]crcstate : 0x8e3a
[2]crcstate : 0x8e3a
[3]crcstate : 0x8e3a
[0]crcfinal : 0x33ff
[1]crcfinal : 0x33ff
[2]crcfinal : 0x33ff
[3]crcfinal : 0x33ff
CoreMark 1.0 : 28440.307672 / GCC9.4.0 -O2 -DMULTITHREAD=4 -DUSE_FORK -DPERFORMANCE_RUN=1 -lrt / Heap / 4:Fork
run2.log
CoreMark Size : 666
Total ticks : 15582
Total time (secs): 15.582000
Iterations/Sec : 28237.710178
Iterations : 440000
Parallel Fork : 4
seedcrc : 0x18f2
[0]crclist : 0xe3c1
[1]crclist : 0xe3c1
[2]crclist : 0xe3c1
[3]crclist : 0xe3c1
[1]crcmatrix : 0x0747
[2]crcmatrix : 0x0747
[3]crcmatrix : 0x0747
[1]crcstate : 0x8d84
[2]crcstate : 0x8d84
[3]crcstate : 0x8d84
[0]crcfinal : 0x0956
[1]crcfinal : 0x0956
[2]crcfinal : 0x0956
[3]crcfinal : 0x0956
对比
https://www.eembc.org/coremark/scores.php
下搜索A55没有对应的芯片的跑分,
可以和A53对比下,
我们这里的得分28440比A53的19678还是高很多的,并且还仅是-O2优化。
计算圆周率
time echo "[scale](https://so.csdn.net/so/search?q=scale&spm=1001.2101.3001.7020)=5000; 4*a(1)" | bc -l -q
执行时间如下
real 0m47.623s
user 0m47.596s
sys 0m0.012s
RAM
带宽
参考https://www.cs.virginia.edu/stream/ref.html
git clone [https://github.com/qinyunti/STREAM.git](https://github.com/qinyunti/STREAM.git)
cd STREAM/
gcc -O3 stream.c -o stream
打印如下
root@firefly:~/coremark/STREAM# ./stream
STREAM version $Revision: 5.10 $
This system uses 8 bytes per array element.
Array size = 10000000 (elements), Offset = 0 (elements)
Memory per array = 76.3 MiB (= 0.1 GiB).
Total memory required = 228.9 MiB (= 0.2 GiB).
Each kernel will be executed 10 times.
The *best* time for each kernel (excluding the first iteration)
will be used to compute the reported bandwidth.
Your clock granularity/precision appears to be 1 microseconds.
Each test below will take on the order of 43055 microseconds.
(= 43055 clock ticks)
Increase the size of the arrays if this shows that
you are not getting at least 20 clock ticks per test.
WARNING -- The above is only a rough guideline.
For best results, please be sure you know the
precision of your system timer.
Function Best Rate MB/s Avg time Min time Max time
Copy: 6306.2 0.025627 0.025372 0.025743
Scale: 5647.5 0.028464 0.028331 0.028618
Add: 5446.5 0.044271 0.044065 0.044582
Triad: 5169.9 0.046605 0.046423 0.046989
Solution Validates: avg error less than 1.000000e-13 on all three arrays
压力测试
参考https://pyropus.ca./software/memtester/
wget [https://pyropus.ca./software/memtester/old-versions/memtester-4.5.1.tar.gz](https://pyropus.ca./software/memtester/old-versions/memtester-4.5.1.tar.gz)
tar -xvf memtester-4.5.1.tar.gz
cd memtester-4.5.1/
gcc -O3 memtester.c tests.c -o memtester
./memtester 512M 1
512M表示测试RAM大小
1表示测试一次
打印如下
root@firefly:~/memtester-4.5.1# ./memtester 512M 1
memtester version 4.5.1 (64-bit)
Copyright (C) 2001-2020 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffffffffffff000
want 512MB (536870912 bytes)
got 512MB (536870912 bytes), trying mlock ...locked.
Loop 1/1:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Sequential Increment: ok
Solid Bits : ok
Block Sequential : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
Done.
EMMC
dmesg | grep mmc
可以看到打印
1.975460] mmc3: new ultra high speed SDR104 SDIO card at address 0001
[ 2.312867] mmc3:mmc host rescan start!
其中high speed SDR104表示emmc 设备支持的时钟模式:
Speed Mode | clock (MHz) |
Default Speed | 26 |
Hight Speed SDR | 52 |
Hight Speed DDR | 52 |
HS200 | 200 |
HS400 | 200 |
SDR : 单边沿采样
DDR : 双边沿采样
所以我们这里x8-bit理论最大吞吐量应该是52MB/S。
输入df回车
我们看到EMMC的/dev/mmcblk0p7挂在了目录/userdata
我们就在该目录下读写文件测试
root@firefly:~/memtester-4.5.1# df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 1984744 8 1984736 1% /dev
tmpfs 399616 1168 398448 1% /run
/dev/mmcblk0p6 2666944 2599912 0 100% /root-ro
/dev/mmcblk0p7 26999224 6355668 20627172 24% /userdata
overlayroot 26999224 6355668 20627172 24% /
tmpfs 1998060 0 1998060 0% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 1998060 0 1998060 0% /sys/fs/cgroup
tmpfs 399612 0 399612 0% /run/user/0
tmpfs 399612 8 399604 1% /run/user/1000
读
dd if=/userdata/test.bin of=/dev/null bs=块大小 count=块数量
写
dd if=/dev/zero of=/userdata/test.bin bs=块大小 count=块数量
测试记录如下
bs/count 1GB | bs/count 1GB | 指令 | 结果 |
读 | 16k/65536 | dd if=/userdata/test.bin of=/dev/null bs=16k count=65536 iflag=direct | 36.5 MB/s |
4k/262144 | dd if=/userdata/test.bin of=/dev/null bs=4k count=262144 iflag=direct | 14.7 MB/s | |
1k/1048576 | dd if=/userdata/test.bin of=/dev/null bs=1k count=10485764 iflag=direct | 2.2 MB/s | |
写 | 16k/65536 | dd if=/dev/zero of=/userdata/test.bin bs=16k count=65536 conv=fdatasync | 118 MB/s |
4k/262144 | dd if=/dev/zero of=/userdata/test.bin bs=4k count=262144 conv=fdatasync | 112 MB/s | |
1k/1048576 | dd if=/dev/zero of=/userdata/test.bin bs=1k count=1048576 conv=fdatasync | 64.6 MB/s |
QT
sudo apt-get install qt5-default qtcreator
直接板上使用qtcreator开发,操作也比较流畅
GPU
sudo apt install glmark2
运行
输入glmark2回车
最终得分
glmark2 Score: 49
视频硬件编解码
/usr/local/test.mp4
1080P, 24Fps, H264
播放流畅
总结
综合各方面,该开发板性能都非常不错,特别适合人机交互,AI,边缘计算等高性能要求的场景。
RK3568
4文章
480浏览量
4728 -
开发板试用
3文章
300浏览量
1997
