本文来源电子发烧友社区,作者:先生, 帖子地址:https://bbs.elecfans.com/jishu_2301466_1_1.html
开发板体验视频,详见作者原文帖子
开发板体验视频,详见作者原文帖子
创建方法如下:
sudo -s
touchgrade.sh
vim grade.sh
#/bin/bash
#Verson:0.1
#Auther:diql
#import an argument
read -p "Please input your grade:" x
declare -i x
#jugemet $x value is none or not
IF[ "$x" == "" ];then
echo "You don't input your grade...."
exit 5
fi
#jugement the gread level
if [[ "$x" -ge "90" && "$x" -le "100" ]];then
echo "Congratulation,Your grade is A."
elif [[ "$x" -ge "80" && "$x" -le "89" ]];then
echo "Good,Your grade is B."
elif [[ "$x" -ge "70" && "$x" -le "79" ]];then
echo "Ok.Your grade is C."
elif [[ "$x" -ge "60" && "$x" -le "69" ]];then
echo "Yeah,Your grade is D."
elif [[ "$x" -lt "60" ]];then
echo "Right,Your grade is F."
else
echo "Unknow argument...."
fi
键入:
esc
:wq
chmod 700 grade.sh
./grade.sh
./build.sh all
/etc/update.sh
附带pwm071.sh
#! /bin/sh
if [ $# != 2 ]; then
echo "$0<1/0>"
echo "User:$0 P3_7 1"
exit 0
fi
VAL=$1
N=${VAL##*_}
T=${VAL#*P}
M=${T%_*}
GPIOID=$((${M} * 8 + ${N}+ 120))
echo "==== GPIOID ${GPIOID} ======"
if [ ! -d /sys/class/gpio/gpio$GPIOID ]; then
echo $GPIOID > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio${GPIOID}/direction
fi
echo "===$1===$2"
echo $2 > /sys/class/gpio/gpio${GPIOID}/value
for((i=1;i<=10;i+=1))
do
sleep 1
echo $i
echo 1 > /sys/class/gpio/gpio${GPIOID}/value
sleep 1
echo 0 > /sys/class/gpio/gpio${GPIOID}/value
done
举报投诉
飞凌
134浏览量
16107 -
开发板试用
3文章
301浏览量
2092
RZ/G2L高速虚拟串口方案 基于瑞萨RZ/G2L SMARC开发板的虚拟(Virtual UART)实现方案
RZ/G2L具有丰富的外设,比如千兆以太网,CANFD以及丰富的UART接口,可以满足工业数据收集处理相关的应用。本文主要介绍基于瑞萨RZ/G2L SMARC
发表于 11-20 14:41
•345次阅读
RZ/G2L Demo调试经验流程分享(1)
r01us0553ej0107-rz-g(Release Note).pdf,r01us0556ej0102-rz-g(Board_StartUp_Guide_smarcEVK).pdf,对SMARC EVK of RZ/
RZ/G2L微处理器DDR ECC功能和机制概要
RZ/G2L微处理器配备Cortex®-A55 (1.2 GHz) CPU、16位DDR3L/DDR4接口、带Arm Mali-G31的3D图形加速引擎以及视频编解码器(H.264)。
【米尔-瑞萨RZ/G2UL开发板】1.开箱
开箱视频
开箱也许会迟到,但是绝对不会缺席。今天开箱的是米尔-瑞萨 RZ/G2UL
发表于 02-04 23:38
RZ/G2L、RZ/G2LC和RZ/G2UL的SMARC EVK启动指南Rev.1.01
电子发烧友网站提供《RZ/G2L、RZ/G2LC和RZ/G2UL的SMARC EVK启动指南Re
发表于 02-02 09:45
•1次下载
米尔RZ/G2L开发板瑞米派双核A55Remi Pi学习板兼容树莓派扩展模块
RemiPi瑞萨第一款MPU生态板卡兼容树莓派扩展模块瑞萨RZ/G2L工业级处理器,便于企业客户产品开发;RemiPi兼容树莓派所有配件,方便产品原型搭建和创新应用;更多的工业接口,兼顾开发
发表于 01-29 17:05
•4次下载
RZ/G2L RZ/G2LC RZ/G2UL用灵活的软件包设置GPIO
电子发烧友网站提供《RZ/G2L RZ/G2LC RZ/G2UL用灵活的软件包设置GPIO.pd
发表于 01-14 10:53
•0次下载
【飞凌OK113i-S开发板试用】开机测评--硬件篇
一,开箱见图 包装精致
注意:上面红黄的先是本人接上的
配了电源线和一根usb线一根天线
OK113i-S
发表于 12-24 20:51
