【米尔MYD-J1028X开发板试用体验】性能测试之RAM性能测试
开发板试用精选 来源:开发板试用 作者:电子发烧友论坛 2022-10-25 11:40 次阅读
本文来源电子发烧友社区,作者:李先生, 帖子地址:https://bbs.elecfans.com/jishu_2300846_1_1.html
前言
RAM是影响整体性能的一个重要因数,我们现在对板子的RAM读写性能进行测试。
代码
Windows主机下下载代码
git clone [https://github.com/qinyunti/STREAM.git](https://github.com/qinyunti/STREAM.git)
/* Program: STREAM                                                       */
/* Revision: $Id: stream.c,v 5.10 2013/01/17 16:01:06 mccalpin Exp mccalpin $ */
/* Original code developed by John D. McCalpin                           */
/* Programmers: John D. McCalpin                                         */
/*              Joe R. Zagar                                             */
/* This program measures memory transfer rates in MB/s for simple        */
/* computational kernels coded in C.                                     */
/* Copyright 1991-2013: John D. McCalpin                                 */
/* License:                                                              */
/*  1. You are free to use this program and/or to redistribute           */
/*     this program.                                                     */
/*  2. You are free to modify this program for your own use,             */
/*     including commercial use, subject to the publication              */
/*     restrictions in item 3.                                           */
/*  3. You are free to publish results obtained from running this        */
/*     program, or from works that you derive from this program,         */
/*     with the following limitations:                                   */
/*     3a. In order to be referred to as "STREAM benchmark results",     */
/*         published results must be in conformance to the STREAM        */
/*         Run Rules, (briefly reviewed below) published at              */
/*         http://www.cs.virginia.edu/stream/ref.html                    */
/*         and incorporated herein by reference.                         */
/*         As the copyright holder, John McCalpin retains the            */
/*         right to determine conformity with the Run Rules.             */
/*     3b. Results based on modified source code or on runs not in       */
/*         accordance with the STREAM Run Rules must be clearly          */
/*         labelled whenever they are published.  Examples of            */
/*         proper labelling include:                                     */
/*           "tuned STREAM benchmark results"                            */
/*           "based on a variant of the STREAM benchmark code"           */
/*         Other comparable, clear, and reasonable labelling is          */
/*         acceptable.                                                   */
/*     3c. Submission of results to the STREAM benchmark web site        */
/*         is encouraged, but not required.                              */
/*  4. Use of this program or creation of derived works based on this    */
/*     program constitutes acceptance of these licensing restrictions.   */
/*  5. Absolutely no warranty is expressed or implied.                   */
# include
# include
# include
# include
# include
# include
 * INSTRUCTIONS:
 *	1) STREAM requires different amounts of memory to run on different
 *           systems, depending on both the system cache size(s) and the
 *           granularity of the system timer.
 *     You should adjust the value of 'STREAM_ARRAY_SIZE' (below)
 *           to meet *both* of the following criteria:
 *       (a) Each array must be at least 4 times the size of the
 *           available cache memory. I don't worry about the difference
 *           between 10^6 and 2^20, so in practice the minimum array size
 *           is about 3.8 times the cache size.
 *           Example 1: One Xeon E3 with 8 MB L3 cache
 *               STREAM_ARRAY_SIZE should be >= 4 million, giving
 *               an array size of 30.5 MB and a total memory requirement
 *               of 91.5 MB.
 *           Example 2: Two Xeon E5's with 20 MB L3 cache each (using OpenMP)
 *               STREAM_ARRAY_SIZE should be >= 20 million, giving
 *               an array size of 153 MB and a total memory requirement
 *               of 458 MB.
 *       (b) The size should be large enough so that the 'timing calibration'
 *           output by the program is at least 20 clock-ticks.
 *           Example: most versions of Windows have a 10 millisecond timer
 *               granularity.  20 "ticks" at 10 ms/tic is 200 milliseconds.
 *               If the chip is capable of 10 GB/s, it moves 2 GB in 200 msec.
 *               This means the each array must be at least 1 GB, or 128M elements.
 *      Version 5.10 increases the default array size from 2 million
 *          elements to 10 million elements in response to the increasing
 *          size of L3 caches.  The new default size is large enough for caches
 *          up to 20 MB.
 *      Version 5.10 changes the loop index variables from "register int"
 *          to "ssize_t", which allows array indices >2^32 (4 billion)
 *          on properly configured 64-bit systems.  Additional compiler options
 *          (such as "-mcmodel=medium") may be required for large memory runs.
 *      Array size can be set at compile time without modifying the source
 *          code for the (many) compilers that support preprocessor definitions
 *          on the compile line.  E.g.,
 *                gcc -O -DSTREAM_ARRAY_SIZE=100000000 stream.c -o stream.100M
 *          will override the default size of 10M with a new size of 100M elements
 *          per array.
#ifndef STREAM_ARRAY_SIZE
#   define STREAM_ARRAY_SIZE	10000000
#endif
/*  2) STREAM runs each kernel "NTIMES" times and reports the *best* result
 *         for any iteration after the first, therefore the minimum value
 *         for NTIMES is 2.
 *      There are no rules on maximum allowable values for NTIMES, but
 *         values larger than the default are unlikely to noticeably
 *         increase the reported performance.
 *      NTIMES can also be set on the compile line without changing the source
 *         code using, for example, "-DNTIMES=7".
#ifdef NTIMES
#if NTIMES<=1
#   define NTIMES	10
#endif
#endif
#ifndef NTIMES
#   define NTIMES	10
#endif
/*  Users are allowed to modify the "OFFSET" variable, which *may* change the
 *         relative alignment of the arrays (though compilers may change the
 *         effective offset by making the arrays non-contiguous on some systems).
 *      Use of non-zero values for OFFSET can be especially helpful if the
 *         STREAM_ARRAY_SIZE is set to a value close to a large power of 2.
 *      OFFSET can also be set on the compile line without changing the source
 *         code using, for example, "-DOFFSET=56".
#ifndef OFFSET
#   define OFFSET	0
#endif
 *	3) Compile the code with optimization.  Many compilers generate
 *       unreasonably bad code before the optimizer tightens things up.
 *     If the results are unreasonably good, on the other hand, the
 *       optimizer might be too smart for me!
 *     For a simple single-core version, try compiling with:
 *            cc -O stream.c -o stream
 *     This is known to work on many, many systems....
 *     To use multiple cores, you need to tell the compiler to obey the OpenMP
 *       directives in the code.  This varies by compiler, but a common example is
 *            gcc -O -fopenmp stream.c -o stream_omp
 *       The environment variable OMP_NUM_THREADS allows runtime control of the
 *         number of threads/cores used when the resulting "stream_omp" program
 *         is executed.
 *     To run with single-precision variables and arithmetic, simply add
 *         -DSTREAM_TYPE=float
 *     to the compile line.
 *     Note that this changes the minimum array sizes required --- see (1) above.
 *     The preprocessor directive "TUNED" does not do much -- it simply causes the
 *       code to call separate functions to execute each kernel.  Trivial versions
 *       of these functions are provided, but they are *not* tuned -- they just
 *       provide predefined interfaces to be replaced with tuned code.
 *	4) Optional: Mail the results to mccalpin@cs.virginia.edu
 *	   Be sure to include info that will help me understand:
 *		a) the computer hardware configuration (e.g., processor model, memory type)
 *		b) the compiler name/version and compilation flags
 *      c) any run-time information (such as OMP_NUM_THREADS)
 *		d) all of the output from the test case.
 * Thanks!
# define HLINE "-------------------------------------------------------------n"
# ifndef MIN
# define MIN(x,y) ((x)<(y)?(x):(y))
# endif
# ifndef MAX
# define MAX(x,y) ((x)>(y)?(x):(y))
# endif
#ifndef STREAM_TYPE
#define STREAM_TYPE double
#endif
static STREAM_TYPE	a[STREAM_ARRAY_SIZE+OFFSET],
			b[STREAM_ARRAY_SIZE+OFFSET],
			c[STREAM_ARRAY_SIZE+OFFSET];
static double	avgtime[4] = {0}, maxtime[4] = {0},
		mintime[4] = {FLT_MAX,FLT_MAX,FLT_MAX,FLT_MAX};
static char	*label[4] = {"Copy:      ", "Scale:     ",
    "Add:       ", "Triad:     "};
static double	bytes[4] = {
    2 * sizeof(STREAM_TYPE) * STREAM_ARRAY_SIZE,
    3 * sizeof(STREAM_TYPE) * STREAM_ARRAY_SIZE,
extern double mysecond();
extern void checkSTREAMresults();
#ifdef TUNED
extern void tuned_STREAM_Copy();
extern void tuned_STREAM_Scale(STREAM_TYPE scalar);
extern void tuned_STREAM_Add();
extern void tuned_STREAM_Triad(STREAM_TYPE scalar);
#endif
#ifdef _OPENMP
extern int omp_get_num_threads();
#endif
int
main()
    int			quantum, checktick();
    int			BytesPerWord;
    int			k;
    ssize_t		j;
    STREAM_TYPE		scalar;
    double		t, times[4][NTIMES];
    /* --- SETUP --- determine precision and check timing --- */
    printf(HLINE);
    printf("STREAM version $Revision: 5.10 $n");
    printf(HLINE);
    BytesPerWord = sizeof(STREAM_TYPE);
    printf("This system uses %d bytes per array element.n",
	BytesPerWord);
    printf(HLINE);
#ifdef N
    printf("*****  WARNING: ******n");
    printf("      It appears that you set the preprocessor variable N when compiling this code.n");
    printf("      This version of the code uses the preprocesor variable STREAM_ARRAY_SIZE to control the array sizen");
    printf("      Reverting to default value of STREAM_ARRAY_SIZE=%llun",(unsigned long long) STREAM_ARRAY_SIZE);
#endif
    printf("Array size = %llu (elements), Offset = %d (elements)n" , (unsigned long long) STREAM_ARRAY_SIZE, OFFSET);
    printf("Memory per array = %.1f MiB (= %.1f GiB).n",
	BytesPerWord * ( (double) STREAM_ARRAY_SIZE / 1024.0/1024.0),
	BytesPerWord * ( (double) STREAM_ARRAY_SIZE / 1024.0/1024.0/1024.0));
    printf("Total memory required = %.1f MiB (= %.1f GiB).n",
	(3.0 * BytesPerWord) * ( (double) STREAM_ARRAY_SIZE / 1024.0/1024.),
	(3.0 * BytesPerWord) * ( (double) STREAM_ARRAY_SIZE / 1024.0/1024./1024.));
    printf("Each kernel will be executed %d times.n", NTIMES);
    printf(" The *best* time for each kernel (excluding the first iteration)n");
    printf(" will be used to compute the reported bandwidth.n");
#ifdef _OPENMP
    printf(HLINE);
#pragma omp parallel
#pragma omp master
	    k = omp_get_num_threads();
	    printf ("Number of Threads requested = %in",k);
#endif
#ifdef _OPENMP
	k = 0;
#pragma omp atomic
		k++;
    printf ("Number of Threads counted = %in",k);
#endif
    /* Get initial value for system clock. */
#pragma omp parallel for
    for (j=0; j1.0;
	    b[j] = 2.0;
	    c[j] = 0.0;
    printf(HLINE);
    if  ( (quantum = checktick()) >= 1)
	printf("Your clock granularity/precision appears to be "
	    "%d microseconds.n", quantum);
    else {
	printf("Your clock granularity appears to be "
	    "less than one microsecond.n");
	quantum = 1;
    t = mysecond();
    for (j = 0; j < STREAM_ARRAY_SIZE; j++)
		a[j] = 2.0E0 * a[j];
    t = 1.0E6 * (mysecond() - t);
    printf("Each test below will take on the order"
	" of %d microseconds.n", (int) t  );
    printf("   (= %d clock ticks)n", (int) (t/quantum) );
    printf("Increase the size of the arrays if this shows thatn");
    printf("you are not getting at least 20 clock ticks per test.n");
    printf(HLINE);
    printf("WARNING -- The above is only a rough guideline.n");
    printf("For best results, please be sure you know then");
    printf("precision of your system timer.n");
    printf(HLINE);
    /*	--- MAIN LOOP --- repeat test cases NTIMES times --- */
    scalar = 3.0;
    for (k=0; k0][k] = mysecond();
#ifdef TUNED
#else
	for (j=0; j#endif
	times[0][k] = mysecond() - times[0][k];
	times[1][k] = mysecond();
#ifdef TUNED
        tuned_STREAM_Scale(scalar);
#else
	for (j=0; j#endif
	times[1][k] = mysecond() - times[1][k];
	times[2][k] = mysecond();
#ifdef TUNED
        tuned_STREAM_Add();
#else
	for (j=0; j#endif
	times[2][k] = mysecond() - times[2][k];
	times[3][k] = mysecond();
#ifdef TUNED
        tuned_STREAM_Triad(scalar);
#else
	for (j=0; j#endif
	times[3][k] = mysecond() - times[3][k];
    /*	--- SUMMARY --- */
    for (k=1; k/* note -- skip first iteration */
	for (j=0; j<4; j++)
	    avgtime[j] = avgtime[j] + times[j][k];
	    mintime[j] = MIN(mintime[j], times[j][k]);
	    maxtime[j] = MAX(maxtime[j], times[j][k]);
    printf("Function    Best Rate MB/s  Avg time     Min time     Max timen");
    for (j=0; j<4; j++) {
		avgtime[j] = avgtime[j]/(double)(NTIMES-1);
		printf("%s%12.1f  %11.6f  %11.6f  %11.6fn", label[j],
	       1.0E-06 * bytes[j]/mintime[j],
	       avgtime[j],
	       mintime[j],
	       maxtime[j]);
    printf(HLINE);
    /* --- Check Results --- */
    printf(HLINE);
    return 0;
# define	M	20
int
checktick()
    int		i, minDelta, Delta;
    double	t1, t2, timesfound[M];
/*  Collect a sequence of M unique time values from the system. */
    for (i = 0; i < M; i++) {
	t1 = mysecond();
	while( ((t2=mysecond()) - t1) < 1.0E-6 )
	timesfound[i] = t1 = t2;
 * Determine the minimum difference between these M values.
 * This result will be our estimate (in microseconds) for the
 * clock granularity.
    minDelta = 1000000;
    for (i = 1; i < M; i++) {
	Delta = (int)( 1.0E6 * (timesfound[i]-timesfound[i-1]));
	minDelta = MIN(minDelta, MAX(Delta,0));
   return(minDelta);
/* A gettimeofday routine to give access to the wall
   clock timer on most UNIX-like systems.  */
#include
double mysecond()
        struct timeval tp;
        struct timezone tzp;
        int i;
        i = gettimeofday(&tp,&tzp);
        return ( (double) tp.tv_sec + (double) tp.tv_usec * 1.e-6 );
#ifndef abs
#define abs(a) ((a) >= 0 ? (a) : -(a))
#endif
void checkSTREAMresults ()
	STREAM_TYPE aj,bj,cj,scalar;
	STREAM_TYPE aSumErr,bSumErr,cSumErr;
	STREAM_TYPE aAvgErr,bAvgErr,cAvgErr;
	double epsilon;
	ssize_t	j;
	int	k,ierr,err;
    /* reproduce initialization */
	aj = 1.0;
	bj = 2.0;
	cj = 0.0;
    /* a[] is modified during timing check */
	aj = 2.0E0 * aj;
    /* now execute timing loop */
	scalar = 3.0;
	for (k=0; k/* accumulate deltas between observed and expected results */
	aSumErr = 0.0;
	bSumErr = 0.0;
	cSumErr = 0.0;
	for (j=0; jabs(a[j] - aj);
		bSumErr += abs(b[j] - bj);
		cSumErr += abs(c[j] - cj);
		// if (j == 417) printf("Index 417: c[j]: %f, cj: %fn",c[j],cj);	// MCCALPIN
	aAvgErr = aSumErr / (STREAM_TYPE) STREAM_ARRAY_SIZE;
	bAvgErr = bSumErr / (STREAM_TYPE) STREAM_ARRAY_SIZE;
	cAvgErr = cSumErr / (STREAM_TYPE) STREAM_ARRAY_SIZE;
	if (sizeof(STREAM_TYPE) == 4) {
		epsilon = 1.e-6;
	else if (sizeof(STREAM_TYPE) == 8) {
		epsilon = 1.e-13;
	else {
		printf("WEIRD: sizeof(STREAM_TYPE) = %lun",sizeof(STREAM_TYPE));
		epsilon = 1.e-6;
	err = 0;
	if (abs(aAvgErr/aj) > epsilon) {
		err++;
		printf ("Failed Validation on array a[], AvgRelAbsErr > epsilon (%e)n",epsilon);
		printf ("     Expected Value: %e, AvgAbsErr: %e, AvgRelAbsErr: %en",aj,aAvgErr,abs(aAvgErr)/aj);
		ierr = 0;
		for (j=0; jif (abs(a[j]/aj-1.0) > epsilon) {
				ierr++;
#ifdef VERBOSE
				if (ierr < 10) {
					printf("         array a: index: %ld, expected: %e, observed: %e, relative error: %en",
						j,aj,a[j],abs((aj-a[j])/aAvgErr));
#endif
		printf("     For array a[], %d errors were found.n",ierr);
	if (abs(bAvgErr/bj) > epsilon) {
		err++;
		printf ("Failed Validation on array b[], AvgRelAbsErr > epsilon (%e)n",epsilon);
		printf ("     Expected Value: %e, AvgAbsErr: %e, AvgRelAbsErr: %en",bj,bAvgErr,abs(bAvgErr)/bj);
		printf ("     AvgRelAbsErr > Epsilon (%e)n",epsilon);
		ierr = 0;
		for (j=0; jif (abs(b[j]/bj-1.0) > epsilon) {
				ierr++;
#ifdef VERBOSE
				if (ierr < 10) {
					printf("         array b: index: %ld, expected: %e, observed: %e, relative error: %en",
						j,bj,b[j],abs((bj-b[j])/bAvgErr));
#endif
		printf("     For array b[], %d errors were found.n",ierr);
	if (abs(cAvgErr/cj) > epsilon) {
		err++;
		printf ("Failed Validation on array c[], AvgRelAbsErr > epsilon (%e)n",epsilon);
		printf ("     Expected Value: %e, AvgAbsErr: %e, AvgRelAbsErr: %en",cj,cAvgErr,abs(cAvgErr)/cj);
		ierr = 0;
		for (j=0; jif (abs(c[j]/cj-1.0) > epsilon) {
				ierr++;
#ifdef VERBOSE
				if (ierr < 10) {
					printf("         array c: index: %ld, expected: %e, observed: %e, relative error: %en",
						j,cj,c[j],abs((cj-c[j])/cAvgErr));
#endif
		printf("     For array c[], %d errors were found.n",ierr);
	if (err == 0) {
		printf ("Solution Validates: avg error less than %e on all three arraysn",epsilon);
#ifdef VERBOSE
	printf ("Results Validation Verbose Results: n");
	printf ("    Expected a(1), b(1), c(1): %f %f %f n",aj,bj,cj);
	printf ("    Observed a(1), b(1), c(1): %f %f %f n",a[1],b[1],c[1]);
	printf ("    Rel Errors on a, b, c:     %e %e %e n",abs(aAvgErr/aj),abs(bAvgErr/bj),abs(cAvgErr/cj));
#endif
#ifdef TUNED
/* stubs for "tuned" versions of the kernels */
	ssize_t j;
        for (j=0; jvoid tuned_STREAM_Scale(STREAM_TYPE scalar)
	ssize_t j;
	for (j=0; jvoid tuned_STREAM_Add()
	ssize_t j;
	for (j=0; jvoid tuned_STREAM_Triad(STREAM_TYPE scalar)
	ssize_t j;
	for (j=0; j/* end of stubs for the "tuned" versions of the kernels */
#endif
编译运行
sftp将STREAM/stream.c导入到开发板
gcc stream.c -o stream -O3编译
运行
./stream
总结
可以看到RAM的读写性能非常不错的达到了4GB多/S
  • 米尔科技
  • MYD-J1028X
    有奖丨米尔 全志T536开发板免费试用
    米尔与全志合作发布的新品基于全志T536应用处理器的MYD-LT536-GK开发板免费试用活动来啦~~米尔提供了3块价值750元的
    的头像 发表于 12-26 08:05 150次阅读
    有奖丨<b class='flag-5'>米尔</b> 全志T536<b class='flag-5'>开发板</b>免费<b class='flag-5'>试用</b>
    人脸疲劳检测应用-米尔基于RK3576核心/开发板
    本文将介绍基于米尔电子MYD-LR3576开发板米尔基于瑞芯微RK3576开发板)的人脸疲劳检测方案
    的头像 发表于 12-20 08:06 281次阅读
    人脸疲劳检测应用-<b class='flag-5'>米尔</b>基于RK3576核心<b class='flag-5'>板</b>/<b class='flag-5'>开发板</b>
    如何用OpenCV进行手势识别--基于米尔全志T527开发板
    本文将介绍基于米尔电子MYD-LT527开发板米尔基于全志T527开发板)的OpenCV手势识别方案
    的头像 发表于 12-13 08:04 758次阅读
    如何用OpenCV进行手势识别--基于<b class='flag-5'>米尔</b>全志T527<b class='flag-5'>开发板</b>
    米尔-Xilinx XC7A100T FPGA开发板试用测试
    感谢米尔电子和电子发烧友提供的米尔-Xilinx XC7A100T FPGA开发板MYD-J7A100T用的 FPGA 为 XILINX 公司 ARTIX-7 系列的 XC 7A1
    发表于 12-08 08:48
    FacenetPytorch人脸识别方案--基于米尔全志T527开发板
    本篇测评由电子工程世界的优秀测评者“小火苗”提供。本文将介绍基于米尔电子MYD-LT527开发板米尔基于全志T527开发板)的Facene
    的头像 发表于 11-28 15:12 348次阅读
    FacenetPytorch人脸识别方案--基于<b class='flag-5'>米尔</b>全志T527<b class='flag-5'>开发板</b>
    追加名额丨米尔瑞芯微RK3576开发板有奖试用
    米尔与瑞芯微合作发布的新品基于瑞芯微RK3576应用处理器的MYD-LR3576开发板免费试用活动加码啦~~米尔追加了2块价值849元的
    的头像 发表于 11-22 01:00 212次阅读
    追加名额丨<b class='flag-5'>米尔</b>瑞芯微RK3576<b class='flag-5'>开发板</b>有奖<b class='flag-5'>试用</b>
    米尔-Xilinx XC7A100T FPGA开发板试用】+01.开箱(zmj)
    米尔-Xilinx XC7A100T FPGA开发板试用】+01.开箱(zmj) 1.感谢 感谢米尔电子和电子发烧友提供的此次试用机会,可
    发表于 11-12 15:45
    有奖丨米尔 瑞芯微RK3576开发板免费试用
    米尔与瑞芯微合作发布的新品基于瑞芯微RK3576应用处理器的MYD-LR3576开发板免费试用活动来啦~~米尔提供了7块价值849元的
    的头像 发表于 11-12 01:00 350次阅读
    有奖丨<b class='flag-5'>米尔</b> 瑞芯微RK3576<b class='flag-5'>开发板</b>免费<b class='flag-5'>试用</b>
    基于OPENCV的相机捕捉视频进行人脸检测--米尔NXP i.MX93开发板
    本文将介绍基于米尔电子MYD-LMX93开发板米尔基于NXPi.MX93开发板)的基于OpenCV的人脸检测方案
    的头像 发表于 11-07 09:03 1123次阅读
    基于OPENCV的相机捕捉视频进行人脸检测--<b class='flag-5'>米尔</b>NXP i.MX93<b class='flag-5'>开发板</b>
    新品7折购!米尔RK3568国产开发板
    近日,米尔电子发布MYC-LR3568核心开发板,核心基于高性能、低功耗的国产芯片-瑞芯微RK3568。核心
    的头像 发表于 08-02 08:01 548次阅读
    新品7折购!<b class='flag-5'>米尔</b>RK3568国产<b class='flag-5'>开发板</b>
    点击参与米尔NXP i.MX 93开发板有奖试用
    米尔与NXP合作发布的新品基于NXPi.MX93应用处理器的MYD-LMX9X开发板免费试用活动来啦~~米尔提供了3块价值678元的
    的头像 发表于 06-13 08:02 570次阅读
    点击参与<b class='flag-5'>米尔</b>NXP i.MX 93<b class='flag-5'>开发板</b>有奖<b class='flag-5'>试用</b>
    米尔NXP i.MX 93开发板的Qt开发指南
    1.概述Qt是一个跨平台的图形应用开发框架,被应用在不同尺寸设备和平台上,同时提供不同版权版本供用户选择。米尔NXPi.MX93开发板MYD-LMX9X
    的头像 发表于 06-07 08:01 1772次阅读
    <b class='flag-5'>米尔</b>NXP i.MX 93<b class='flag-5'>开发板</b>的Qt<b class='flag-5'>开发</b>指南
    免费!NXP i.MX 93开发板有奖试用
    米尔与NXP合作发布的新品基于NXPi.MX93应用处理器的MYD-LMX9X开发板免费试用活动来啦~~米尔提供了2块价值678
    的头像 发表于 05-23 08:01 751次阅读
    免费!NXP i.MX 93<b class='flag-5'>开发板</b>有奖<b class='flag-5'>试用</b>
    G2D图像处理硬件调用和测试-基于米尔-全志T113-i开发板
    本篇测评由电子工程世界的优秀测评者“jf_99374259”提供。本文将介绍基于米尔电子MYD-YT113i开发板的G2D图像处理硬件调用和测试。MYC-YT113i核心
    的头像 发表于 04-12 08:01 697次阅读
    G2D图像处理硬件调用和<b class='flag-5'>测试</b>-基于<b class='flag-5'>米尔</b>-全志T113-i<b class='flag-5'>开发板</b>
    ROS系统的智能车开发-基于米尔芯驰MYD-JD9X开发板
    本篇测评由电子工程世界的优秀测评者“mameng”提供。本文将介绍基于米尔电子MYD-JD9X开发板的ROS系统智能车开发。目前实现ROS的方式主要有两种:Ubuntu系统+ROS;U
    的头像 发表于 01-26 08:01 954次阅读
    ROS系统的智能车<b class='flag-5'>开发</b>-基于<b class='flag-5'>米尔</b>芯驰<b class='flag-5'>MYD-JD9X</b><b class='flag-5'>开发板</b>
