本文来源电子发烧友社区,作者:李先生, 帖子地址:https://bbs.elecfans.com/jishu_2300791_1_1.html
前言
开发板默认安装了ubuntu系统,可以使用如下指令查看系统版本
cat /proc/version
uname -a
lsb_release -a
root@localhost:~# cat /proc/version
Linux version 5.4.47-g20182b961 (root@ubuntu18) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)) #3 SMP PREEMPT Sun Dec 12 08:32:43 CST 2021
root@localhost:~# uname -a
Linux localhost 5.4.47-g20182b961 #3 SMP PREEMPT Sun Dec 12 08:32:43 CST 2021 aarch64 aarch64 aarch64 GNU/Linux
root@localhost:~# lsb_release -a
No LSB modules are available.
Distributor ID: NXP-LSDK
Description: NXP LSDK 2012 main
Release: 2012
Codename: bionic
root@localhost:~#
板子本身安装了GCC工具链
使用以下指令查看gcc版本
gcc -v
root@localhost:~# gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/7/lto-wrapper
Target: aarch64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 7.5.0-3ubuntu1~18.04' --with-bugurl=file:///usr/share/doc/gcc-7/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-7 --program-prefix=aarch64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu
Thread model: posix
Linux C开发体验
串口登录
vi led.c
按键i进入编辑模式
复制黏贴以下代码
按esc
按shift+:进入命令模式
输入wq回车保存
#include
#include
#include
#include
int main(void)
while(1)
system("echo 0 > /sys/class/leds/d22/brightness");
sleep(1);
system("echo 1 > /sys/class/leds/d22/brightness");
sleep(1);
return 0;
编译gcc led.c -o led
运行./led
可以看到D22以1秒间隔闪烁。
总结
由于系统自带了gcc工具链,所以可以直接在开发板进行开发,而不需要交叉编译开发,非常便捷。
举报投诉
米尔科技
5文章
227浏览量
22549 -
MYD-J1028X
1文章
16浏览量
443
热点推荐
新品!从MINI到工业板:米尔T153开发板工业场景全覆盖
今年1月,米尔发布了MYD-YT153MX-MINI开发板,该产品精准切入国产核心板在中端市场领域,具有极致性价比,自上市即获得良好的市场反响。为方便
【米尔RK3506国产开发板评测试用】1、硬件介绍、SDK开发环境和QT开发环境搭建
,根据开发板的IP地址设置主机,同时使用页面的上公私钥配置工具生成公私钥信息并部署公钥到开发板。
Sysroot:设置为Buildroot输出目录中的/myd_yr3506_emmc_
发表于 08-02 15:02
【米尔RK3576开发板免费体验】1、开发环境、镜像烧录、QT开发环境搭建以及应用部署
Linux Device
Device: 点击Manage按钮,根据开发板的IP地址设置主机,同时使用页面的上公私钥配置工具生成公私钥信息并部署公钥到开发板。
Sysroot:设置为
发表于 07-14 11:26
如何部署流媒体服务实现监控功能--基于米尔TI AM62x开发板
的CSI摄像头,还可以直接使用第三方的USB摄像头,我手头正好有几个个USB摄像头:经过实测,可以很好的在米尔-TIAM62x开发板上使用。
【米尔-全志T536开发板试用体验】- 开发环境搭建与测试
【米尔-全志T536开发板试用体验】开发环境搭建与测试大信(QQ:8
发表于 06-10 10:35
【米尔-STM32MP257开发板试用体验】初次体验米尔-STM32MP257开发板
如何在MYD-LD25X开发板上使用STM32CubeMX工具来实现最小系统的搭建及外设资源的配置。通过本次培训,学员不仅能掌握基础的开发流程,还能在实践中提高对STM32MP257D
发表于 04-30 16:21
【米尔MYD-J1028X开发板试用体验】开发环境体验之快速直接板上Linux C开发
