六类RJ45水晶头 Cat 6 RJ45 crystal heads
水晶头簧片表面镀金50μ,保证了良好的接触与信号传输性能;
满足传输标准,符合T568A和T568B线序;
适用于设备间或水平子系统的现场端接,外壳材料采用高密度聚乙烯。每个重2.43G。
Gold-plated :50μ Comply with T568A &T568B Out shell Material :HDPE It is suitable for ending connection of devices and horizontal subsystem site. Weight:2.43g/pcs
六类水晶头由两部分组成:内部的分线件和外壳。
Cat6 crystal head consists of two parts A inner divider and the out shell 水晶头的接法: Connection of crystal head:
水晶头的做法标准: Crystal head practice standard:
568A标准:白绿,绿,白橙,蓝,白蓝,橙,白棕,棕
568B标准:白橙,橙,白绿,蓝,白蓝,绿,白棕,棕
Standard: white green, green, white orange, blue, white blue, orange, white brown, brown Standard: white orange, orange, white green, blue, white blue, green, white brown, brown
做法一般性的原则: General principles of practice:
同类(连接线的两端是同一种设备)交叉(做交叉线) 异类(连接线的两端是不同的设备)平行(作平行线)
The two ends of the cable are the same kind of equipment. Parallel (parallel lines) parallel (parallel lines)
交叉线的做法是:一头采用568A标准,一头采用568B标准
The way to cross the line is to use 568A standard at one end and 568B standard at the other
平行线的做法是:两头采用同样的标准(同为568A标准或568B标准)
Parallel lines: use the same standard at both ends (same as 568A or 568B)
注意:做水晶头时,使水晶头的弹片朝外,入线口朝下,从左到右,遵循上面的线序,充分插入线(以在水晶头的顶部看到双绞线的铜心为标准),然后用网线钳夹一下,就可以了。
Note: when making the crystal head, make the shrapnel of the crystal head face out, the inlet port face down, from left to right, follow the above line order, fully insert the line (to see the copper core of the twisted pair at the top of the crystal head as the standard), and then with a net clamp, it is ok.
审核编辑 黄昊宇
网线
3文章
1055浏览量
31723 -
水晶头
239浏览量
19294
