SystemVerilog中的Queue Methods
芯片验证工程师 来源:芯片验证工程师 作者:芯片验证工程师 2022-10-31 09:20 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
队列提供了许多内置方法。如下表所示:
module dq;
 bit[7:0] dq1[$]; // A unbounded queue of unsigned 8-bit
 int q3[$:5] = {0,1,2,3,4,5}; //bounded queue
 int a;
 initial begin
 a = dq1.size( ); //empty queue
 $display ($stime,,, "empty dq1 size = %0d",a);
 dq1[0] = 0; dq1[1] = 1; dq1[2] = 2;
 $display ($stime,,, "dq1 SIZE = %0d",dq1.size( ));
 $display ($stime,,, "dq1=",dq1);
 dq1.insert (3,3); //index, value
 $display($stime,,, "After Insert dq1 SIZE = %0d",dq1.size( ));
 dq1.delete (3); //index
 $display ($stime,,, "After delete dq1 SIZE = %0d",dq1.size( ));
 a = dq1.pop_front( ); //pop frst entry of the queue
 $display ($stime,,, "dq1 pop front = %0d ",a);
 a = dq1.pop_back( ); //pop last entry of the queue
 $display ($stime,,, "dq1 pop back = %0d ",a);
 //push the frst entry of the queue with '4'
 dq1.push_front(4);
 $display ($stime,,, "push front dq1=",dq1);
 //push the last entry of the queue with '5'
 dq1.push_back(5);
 $display ($stime,,, "push back dq1=",dq1);
 q3_size = q3.size + 5; //size > q3 size
 //underfow : pop from index 6,7,8,9,10 – run time Warning
 for (int i = 0; i < q3_size; i++)
 $display($stime,,,"q3[%0d] = %0d", i, q3.pop_front( ) );
 end
 //Solution for underfow - check for size before pop
 while (q3.size( ) > 0)
 $display($stime,,,"q3 = %0d", q3.pop_front ( ));
 //overfow : push over the bound limit – run time Warning
 for (int i = 0; i < q3_size; i++) begin
 q3.push_front( i );
 $display($stime,,,"q3[%0d] :: q3 = %p", i , q3);
 end
 endmodule
仿真log:
 0 empty dq1 size = 0 //empty queue size
 0 dq1 SIZE = 3 //size after providing values to frst three elements
 0 dq1='{'h0, 'h1, 'h2} //assigned frst three elements
 0 After Insert dq1 SIZE = 4 //Insert value 3 at index 3.
 0 dq1='{'h0, 'h1, 'h2, 'h3} //shows inserted value
 0 After delete dq1 SIZE = 3 //delete value at index 3
 0 dq1='{'h0, 'h1, 'h2} //shows dq1 after deletion
 0 dq1 pop front = 0 //pop the front index of the queue
 0 dq1='{'h1, 'h2} //dq1 after element at index 0 is gone (popped)
 0 dq1 pop back = 2 //pop the back (last) index of the queue
 0 dq1='{'h1} //the last index/value is gone
 0 push front dq1='{'h4, 'h1} //push at the front of the queue (value 4)
 0 push back dq1='{'h4, 'h1, 'h5} //push at the end of the queue (value 5)
上面我们通过队列dq1展示了push和pop的行为。然后我们声明了有界队列q3,最大的index限制是5,所以这个队列最大的size是6.
将队列q3初始化为{0,1,2,3,4,5},然后pop超过6次。
 //Queue 'q3' is empty after index 5.
 end
这个时候仿真器会上报warnnin:
# RUNTIME: Warning: RUNTIME_0219 testbench.sv (54): Cannot pop from an
empty queue.
审核编辑:汤梓红
  • 仿真器
  • Verilog
  • System
原文标题:SystemVerilog中的Queue Methods
文章出处:【微信号:芯片验证工程师,微信公众号:芯片验证工程师】欢迎添加关注!文章转载请注明出处。
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    SystemVerilog的Virtual Methods
    SystemVerilog多态能够工作的前提是父类的方法被声明为virtual的。
    发表于 11-28 11:12 1195次阅读
    SystemVerilog的“const”类属性
    SystemVerilog可以将类属性声明为常量,即“只读”。目的就是希望,别人可以读但是不能修改它的值。
    发表于 11-29 10:25 2589次阅读
    SystemVerilog的联合(union)介绍
    SystemVerilog ,联合只是信号,可通过不同名称和纵横比来加以引用。
    的头像 发表于 10-08 15:45 2636次阅读
    <b class='flag-5'>SystemVerilog</b><b class='flag-5'>中</b>的联合(union)介绍
    Some Programming Methods for I
    Some Programming Methods for Increasing the Operating Speed of PLC Program Absbad With Mitsubishi
    发表于 01-19 12:42 15次下载
    SystemVerilog的断言手册
    SystemVerilog Assertion Handbook1 ROLE OF SYSTEMVERILOG ASSERTIONSIN A VERIFICATION METHODOLOGY
    发表于 07-22 14:12 20次下载
    ThreadX(九)------消息队列Queue
    消息队列QueueAPItx_queue_createtx_queue_deletex_queue_flushtx_queue_front_sendtx_queue_receivetx_queue_send_notifyAPItx_queue_createtx_queue_deletetx_queue_flushtx_qu
    发表于 12-28 19:35 2次下载
    ThreadX(九)------消息队列<b class='flag-5'>Queue</b>
    SystemVerilog$cast的应用
    SystemVerilog casting意味着将一种数据类型转换为另一种数据类型。在将一个变量赋值给另一个变量时,SystemVerilog要求这两个变量具有相同的数据类型。
    的头像 发表于 10-17 14:35 4141次阅读
    SystemVerilog的操作方法
    SystemVerilog提供了几个内置方法来支持数组搜索、排序等功能。
    的头像 发表于 10-31 10:10 4517次阅读
    SystemVerilog可以嵌套的数据结构
    SystemVerilog除了数组、队列和关联数组等数据结构,这些数据结构还可以嵌套。
    的头像 发表于 11-03 09:59 2876次阅读
    SystemVerilog的struct
    SystemVerilog“struct”表示相同或不同数据类型的集合。
    的头像 发表于 11-07 10:18 3470次阅读
    SystemVerilog的Shallow Copy
    SystemVerilog的句柄赋值和对象复制的概念是有区别的。
    的头像 发表于 11-21 10:32 1584次阅读
    SystemVerilog的Semaphores
    SystemVerilogSemaphore(旗语)是一个多个进程之间同步的机制之一,这里需要同步的原因是这多个进程共享某些资源。
    的头像 发表于 12-12 09:50 4473次阅读
    什么是queue
    queue 容器,又称队列容器,是简单地装饰deque容器而成为另外的一种容器。
    的头像 发表于 02-27 15:43 3493次阅读
    Systemverilog的Driving Strength讲解
    systemverilog,net用于对电路连线进行建模,driving strength(驱动强度)可以让net变量值的建模更加精确。
    的头像 发表于 06-14 15:50 2764次阅读
    <b class='flag-5'>Systemverilog</b><b class='flag-5'>中</b>的Driving Strength讲解
    RTOSQueue的工作原理
    Queue即消息队列是通过RTOS内核提供的一种服务。它是一种线程间同步数据的安全方法。
    的头像 发表于 07-25 15:45 5662次阅读
    RTOS<b class='flag-5'>中</b><b class='flag-5'>Queue</b>的工作原理
