N-MOS工艺芯片与P-MOS工艺芯片对比
硬件设计技术 来源:硬件设计技术 作者:硬件设计技术 2022-10-31 10:01 次阅读
一、How does Over Current Protection (OCP)work?
When over-current protection (OCP) is enabled, the power system turns off the output if the output current reaches the current limit setting and transitions from constant voltage (CV) operation to constant current (CC) operation.
With OCP turned on, the OCP takes over after a specified time delay and shuts down the output of the power supply. The delay time is programmable. This prevents OCP from shutting down the DC power supply from short current spikes and other acceptably short overloads that are not considered harmful. In comparison, with Over Voltage Protection (OVP), the output is disabled immediately. OVP is usually always enabled and cannot be turned off. However, unlike OVP, OCP can be turned on and off and its default is usually off. A typical OCP event is illustrated here:
Wecan specify an OCP delay to prevent momentary output settings, load, and status changes from tripping the over-current protection. In most cases these momentary conditions would not be considered an over-current protection fault, and having an OCP condition disable the output when they occur would be a nuisance. Specifying an OCP delay lets the OCP circuit ignore these momentary changes during the specified delay period. Once the OCP delay time has expired and the over-current condition persists, the output will shut down. Other factors include the difference between old output value and new output value, the current limit setting, and the load capacitance in CV operation or load inductance in CC operation. The delay required must be determined experimentally on a case-by-case basis.
二、N-MOS & P-MOS 工艺芯片对比:
P-MOSOCP原理简介
N-MOSOCP原理简介
NMOS PMOS
Ron 较小 较大
Io 较大 较小
Charge pump 需要 不需要
Parasitic capacitance 较小 较大
Cost 较高 较低
性能指标对比
三、镜像电流采样技术:
2、随着负载电流的增加,成比例的镜像电流也逐渐增加
3、当镜像电流达到满足, a95f2a3e-5860-11ed-a3b6-dac502259ad0.png   此时,触发限流机制
4、低延时的驱动单元将功率管的栅极电压拉低,达到限制PowerNMOS电流的大小的目的
四、PCB Layout注意事项
1、输入输出电容靠近芯片PIN脚摆放
2、输入输出电容两端端就近打足够的GND-VIA
3、芯片及周边元件尽量靠近负载端摆放,减小路径上的寄生参数
4、TVS靠近芯片PIN脚摆放,电流流过顺序为先TVS,再过电容,最后到芯片PIN脚
5、Rlimit电阻选用的精度至少±1%
五、OVP 与 OCP 对比:
This is quite different than the almost immediate response time of an OVP system. Even if the OCP delay time was set to zero, the response is still on the order of milliseconds instead of microseconds compared to an OVP event. And when the amount of overdrive is small, as is the case for the 6 A loading, providing just 1 A of overdrive, the total response time is much greater.
Unlike the OVP system, which operates totally independent of the voltage limit control system, the OCP system is triggered off the current limit control system. Thus the total response time includes the response time of the current limit as well. The behavior of a current limit is quite different than a simple “go/no go” threshold detector like OVP. A limit system, or circuit, needs to regulate the power supply’s output at a certain level, making it a feedback control system. The stability of this system is important, both with crossing over from constant voltage operation as well as maintaining a stable output current after crossing over. This leads to the slower and overdrive dependent response characteristics that are typical of current limit systems.
审核编辑:刘清
  • 芯片
  • pcb
    pcb
  • 负载电流
  • TVS
    TVS
  • MOS
    MOS
原文标题:Over Current Protection【OCP】
文章出处:【微信号:硬件设计技术,微信公众号:硬件设计技术】欢迎添加关注!文章转载请注明出处。
    如何通过一个微分电路和一个P-MOS做到如下要求
    请大仙帮忙指导下如何通过一个微分电路和一个P-MOS做到如下要求:开机时Vcc通电,TS1脚拉高,延时20ms后让TS1一直拉低,然后想通过P-MOS(或者N-MOS也行,)目前我设计了如下微分电路
    发表于 02-09 17:26
    P-MOS输出控制请教
    `使用P-MOS控制输出+28V,如果在输入源端加了一个肖特基二极管会烧二极管吗?输入低的时候P-MOS打开,对外输出+28V,无输出。`
    发表于 12-24 22:04
    MOS管大神指点:MOS管H 半桥电磁阀驱动电路
    电压是24V直流, 电磁阀电流要求 0.7A, 设计了个电路, 不知道行不行, 特来请教。MOS管 选了 IRF7343 N-P通道双管 , 其中N-MOS管做一个臂的下桥臂管, P-MOS
    发表于 04-06 04:17
    优奈斯代理(恒泰柯HUNTECK)全系列MOS:低压低内阻MOS
    P-MOS :HTM085P03DFN3*3HTM200P03DFN3*3 QC3.0快充电源同步整流N-MOS:15W-18W快充电源HGS120
    发表于 08-07 15:25
    关于P-MOS开关电路中MOS管烧坏的求助
    请教诸位大神:如图是一个利用P-MOS组成的开关电路。B+是电池端,当开关按键按下后单片机获得供电即将IO口置1,MOS管G极获得持续低电平,实现开机。现在的问题是MOS管经常性烧坏,怀疑是哪里设计出了问题,望路过大神指点迷津,
    发表于 12-03 21:20
    给大家分享一个N-MOSP-MOS驱动的应用实例
    P-MOS管。MOS管跟三极管的驱动方式有点类似,但又不完全相同,那么今天笔者将会给大家简单介绍一下N-MOS管和P-MOS管的工作原理,并结合自己实际的应用来给大家分享一下如何来驱
    发表于 08-29 21:03
    N-MOS管的原理是什么?N-MOS管为什么会出问题?
    N-MOS管的原理是什么?N-MOS管为什么会出问题?如何去控制步进电机驱动器?
    发表于 07-05 07:39
    N-MOS管是如何接线的
    N-MOS管是如何接线的?N-MOS管是如何驱动步进电机的?
    发表于 10-11 07:49
    SW2N6 N-MOS
    SW2N6 N-MOS
    发表于 10-18 11:42 2次下载
    SW2<b class='flag-5'>N</b>6 <b class='flag-5'>N-MOS</b>
    如何区分P-MOSN-MOS?如何区分MOS的G、D、S管脚?MOS管如何导通?
    三极管是流控型器件,MOS管是压控型器件,两者存在相似之处。三极管机可能经常用,但MOS管你用的可能较少。对于MOS管先抛出几个问题:
    的头像 发表于 07-17 19:36 10.3w次阅读
    如何区分<b class='flag-5'>P-MOS</b>和<b class='flag-5'>N-MOS</b>?如何区分<b class='flag-5'>MOS</b>的G、D、S管脚?<b class='flag-5'>MOS</b>管如何导通?
    模块工艺——双阱工艺(Twin-well or Dual-Well)
    CMOS 集成电路的基础工艺之一就是双阱工艺,它包括两个区域,即n-MOSp-MOS 有源区,分別对应p阱和
    的头像 发表于 11-14 09:32 1.3w次阅读
    CMOS集成电路的双阱工艺简析
    的头像 发表于 11-14 09:34 9950次阅读
    STM32的GPIO工作原理 开漏输出和推挽输出区别
    通过设置位设置/清除寄存器或者输出数据寄存器的值,途经P-MOS管和N-MOS管,最终输出到I/O端口。这里要注意P-MOS管和N-MOS管,当设置输出的值为高电平的时候,
    发表于 12-15 10:26 7384次阅读
    mos管小电流发热的原因
    电路设计的问题是让MOS管在线工作,而不是在开关状态下工作。这也是MOS管加热的原因之一。如果N-MOS做开关,G级电压比电源高几V,P-MOS就相反了。未完全打开,压降过大,导致功耗
    的头像 发表于 06-18 14:46 1084次阅读
    mos封装工艺是什么,MOS管封装类型
    MOS封装工艺是指将制造好的MOS芯片通过一系列步骤封装到外壳中的过程。以下是MOS封装工艺
    的头像 发表于 06-09 17:07 1736次阅读
