【HarmonyOS HiSpark Wi-Fi IoT 套件试用连载】7.RGB操作
开发板试用精选 来源:开发板试用 作者:电子发烧友论坛 2022-11-03 15:34 次阅读
本文来源电子发烧友社区,作者:hehung, 帖子地址:https://bbs.elecfans.com/jishu_2021276_1_1.html
`尝试了开发板的RGB功能。
RGB其实就是三个端口进行控制的,分别为10,11,和12.原理图如下:
我使用按键按下分别控制三个LED亮灭,程序实现上比较简单,如果扩展功能的话可以通过PWM控制这三个引脚实现亮度调节。
代码如下:
  1. /*this is my first application*/
  2. /*2020/11/08*/
  3. #include
  4. #include "ohos_init.h"
  5. #include "ohos_types.h"
  6. #include
  7. #include
  8. #include "ohos_init.h"
  9. #include "cmsis_os2.h"
  10. #include "wifiiot_gpio.h"
  11. #include "wifiiot_gpio_ex.h"
  12. #include "wifiiot_adc.h"
  13. #include
  14. #include
  15. #include
  16. #include
  17. #include
  18. #define LED_INTERVAL_TIME_US 500000 /*500ms*/
  19. #define LED_TASK_STACK_SIZE 512
  20. #define LED_TASK_PRIO 25
  21. #define KEY_INTERVAL_TIME_US 10000 /*10ms*/
  22. #define KEY_TASK_STACK_SIZE 1024
  23. #define KEY_TASK_PRIO 24
  24. #define RGB_INTERVAL_TIME_US 10000 /*10ms*/
  25. #define RGB_TASK_STACK_SIZE 1024
  26. #define RGB_TASK_PRIO 23
  27. static void *LedTask(const char *arg);
  28. static void *KeyTask(const char *arg);
  29. static void *RGBTask(const char *arg);
  30. /*LED Control*/
  31. enum LedState {
  32. LED_ON = 0,
  33. LED_OFF,
  34. LED_SPARK,
  35. };
  36. uint8_t RGB_ctrl = 0;
  37. static void *LedTask(const char *arg)
  38. {
  39. (void)arg;
  40. enum LedState g_ledState = LED_SPARK;
  41. g_ledState = LED_SPARK;
  42. while (1) {
  43. switch (g_ledState) {
  44. case LED_ON:
  45. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_9, 1);
  46. usleep(LED_INTERVAL_TIME_US);
  47. break;
  48. case LED_OFF:
  49. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_9, 0);
  50. usleep(LED_INTERVAL_TIME_US);
  51. break;
  52. case LED_SPARK:
  53. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_9, 0);
  54. usleep(LED_INTERVAL_TIME_US);
  55. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_9, 1);
  56. usleep(LED_INTERVAL_TIME_US);
  57. break;
  58. default:
  59. usleep(LED_INTERVAL_TIME_US);
  60. break;
  61. }
  62. }
  63. return NULL;
  64. }
  65. static void Led0Entry(void)
  66. {
  67. osThreadAttr_t attr;
  68. GpioInit();
  69. IoSetFunc(WIFI_IOT_IO_NAME_GPIO_9, WIFI_IOT_IO_FUNC_GPIO_9_GPIO);
  70. GpioSetDir(WIFI_IOT_IO_NAME_GPIO_9, WIFI_IOT_GPIO_DIR_OUT);
  71. attr.name = "LedTask";
  72. attr.attr_bits = 0U;
  73. attr.cb_mem = NULL;
  74. attr.cb_size = 0U;
  75. attr.stack_mem = NULL;
  76. attr.stack_size = LED_TASK_STACK_SIZE;
  77. attr.priority = LED_TASK_PRIO;
  78. if (osThreadNew((osThreadFunc_t)LedTask, NULL, &attr) == NULL) {
  79. printf("[Led0Task] Falied to create LedTask!
  80. ");
  81. }
  82. }
  83. SYS_RUN(Led0Entry);
  84. /*OLED board KEY Control - vased on ADC input*/
  85. static void *KeyTask(const char *arg)
  86. {
  87. (void)arg;
  88. WifiIotGpioValue Key_Status = WIFI_IOT_GPIO_VALUE1;
  89. WifiIotGpioValue Last_key_Status = WIFI_IOT_GPIO_VALUE1;
  90. // hi_u16 Key_adc_value = 0u;
  91. // hi_u32 ret = 0;
  92. while (1) {
  93. GpioGetInputVal(WIFI_IOT_IO_NAME_GPIO_5, &Key_Status);
  94. // printf("%d
  95. ", Key_Status);
  96. if((Key_Status == WIFI_IOT_GPIO_VALUE0) && (Last_key_Status != Key_Status))
  97. {
  98. RGB_ctrl ++;
  99. printf("Key pressed, RGB_ctrl = %d
  100. ", RGB_ctrl);
  101. }
  102. else
  103. {
  104. }
  105. // ret = hi_adc_read((hi_adc_channel_index)HI_ADC_CHANNEL_2, &Key_adc_value,
  106. // HI_ADC_EQU_MODEL_1, HI_ADC_CUR_BAIS_DEFAULT, 0);
  107. // if (ret != HI_ERR_SUCCESS) {
  108. // printf("ADC Read Fail
  109. ");
  110. // }
  111. // else
  112. // {
  113. // // printf("ADC value = %d", Key_adc_value);
  114. // }
  115. // /*User 按键ADC值读出来大概为116*/
  116. // /*S1 按键ADC读出来大概为320*/
  117. // /*S2 按键ADC读出来大概为548*/
  118. // if(Key_adc_value <= 200)
  119. // {
  120. // printf("User key pressed
  121. ");
  122. // }
  123. // else if(Key_adc_value <= 400)
  124. // {
  125. // printf("User S1 pressed
  126. ");
  127. // }
  128. // else if(Key_adc_value <= 600)
  129. // {
  130. // printf("User S2 pressed
  131. ");
  132. // }
  133. // else
  134. // {
  135. // }
  136. Last_key_Status = Key_Status;
  137. usleep(KEY_INTERVAL_TIME_US);
  138. }
  139. return NULL;
  140. }
  141. static void KeyEntry(void)
  142. {
  143. osThreadAttr_t attr;
  144. GpioInit();
  145. IoSetFunc(WIFI_IOT_IO_NAME_GPIO_5, WIFI_IOT_IO_FUNC_GPIO_5_GPIO);
  146. GpioSetDir(WIFI_IOT_IO_NAME_GPIO_5, WIFI_IOT_GPIO_DIR_IN);
  147. // AdcRead();
  148. attr.name = "KeyTask";
  149. attr.attr_bits = 0U;
  150. attr.cb_mem = NULL;
  151. attr.cb_size = 0U;
  152. attr.stack_mem = NULL;
  153. attr.stack_size = KEY_TASK_STACK_SIZE;
  154. attr.priority = KEY_TASK_PRIO;
  155. if (osThreadNew((osThreadFunc_t)KeyTask, NULL, &attr) == NULL) {
  156. printf("[KeyTask] Falied to create KeyTask!
  157. ");
  158. }
  159. }
  160. SYS_RUN(KeyEntry);
  161. static void *RGBTask(const char *arg)
  162. {
  163. (void)arg;
  164. while (1) {
  165. // GpioGetInputVal(WIFI_IOT_IO_NAME_GPIO_5, &Key_Status);
  166. switch(RGB_ctrl)
  167. {
  168. case 0:
  169. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_12, 1);
  170. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 0);
  171. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, 0);
  172. usleep(RGB_INTERVAL_TIME_US);
  173. break;
  174. case 1:
  175. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_12, 0);
  176. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 1);
  177. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, 0);
  178. usleep(RGB_INTERVAL_TIME_US);
  179. break;
  180. case 2:
  181. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_12, 0);
  182. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 0);
  183. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, 1);
  184. usleep(RGB_INTERVAL_TIME_US);
  185. break;
  186. case 3:
  187. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_12, 1);
  188. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 1);
  189. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, 1);
  190. usleep(RGB_INTERVAL_TIME_US);
  191. break;
  192. case 4:
  193. RGB_ctrl = 0;
  194. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_12, 0);
  195. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 0);
  196. GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, 0);
  197. usleep(RGB_INTERVAL_TIME_US);
  198. break;
  199. }
  200. }
  201. return NULL;
  202. }
  203. static void RGBEntry(void)
  204. {
  205. osThreadAttr_t attr;
  206. GpioInit();
  207. IoSetFunc(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_IO_FUNC_GPIO_12_GPIO);
  208. GpioSetDir(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_GPIO_DIR_OUT);
  209. IoSetFunc(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_IO_FUNC_GPIO_11_GPIO);
  210. GpioSetDir(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_GPIO_DIR_OUT);
  211. IoSetFunc(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_IO_FUNC_GPIO_10_GPIO);
  212. GpioSetDir(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_GPIO_DIR_OUT);
  213. // AdcRead();
  214. attr.name = "RGBTask";
  215. attr.attr_bits = 0U;
  216. attr.cb_mem = NULL;
  217. attr.cb_size = 0U;
  218. attr.stack_mem = NULL;
  219. attr.stack_size = RGB_TASK_STACK_SIZE;
  220. attr.priority = RGB_TASK_PRIO;
  221. if (osThreadNew((osThreadFunc_t)RGBTask, NULL, &attr) == NULL) {
  222. printf("[KeyTask] Falied to create KeyTask!
  223. ");
  224. }
  225. }
  226. SYS_RUN(RGBEntry);
复制代码
运行效果:
  • wi-fi
  • HarmonyOS
  • HiSpark
    Wi-Fi 8要来了!未来Wi-Fi技术演进方向揭秘
    产品销售中,虽然Wi-Fi 7产品的销量份额快速从年初的个位数百分比增长至14%,但Wi-Fi 6产品的销量份额依然稳定在60%左右。如果从存量设备来看,那么Wi-Fi
    的头像 发表于 11-24 03:14 2258次阅读
    <b class='flag-5'>Wi-Fi</b> 8要来了!未来<b class='flag-5'>Wi-Fi</b>技术演进方向揭秘
    Wi-Fi 7 与频率控制的关系
    作者:Poornima Apte 投稿人:DigiKey 北美编辑 2024-12-18 Wi-Fi 需要使用一定范围的无线电频率才能让设备进行通信拨号。多年来,Wi-Fi 一直使用 2.4 GHz
    的头像 发表于 01-25 14:45 150次阅读
    <b class='flag-5'>Wi-Fi</b> <b class='flag-5'>7</b> 与频率控制的关系
    华为海思正式进入Wi-Fi FEM赛道?
    转载自——钟林谈芯 昨天在网上看到一份九联UNR050 BE3600无线路由器拆机报告,Wi-Fi主芯片是海思新款Wi-Fi7芯片Hi1155,速率2.5G。 在海思AP Wi-Fi芯片系列中,还有
    发表于 12-11 17:42
    Wi-Fi 4到Wi-Fi 7:网速飙升40倍的无线革命
    1 Wi-Fi技术的快速发展 每一代新的Wi-Fi协议发布,都会带来更高的无线速率。   从Wi-Fi 4到Wi-Fi 7:无线网络技术显著
    的头像 发表于 12-09 10:10 460次阅读
    从<b class='flag-5'>Wi-Fi</b> 4到<b class='flag-5'>Wi-Fi</b> <b class='flag-5'>7</b>:网速飙升40倍的无线革命
    Wi-Fi 7有哪些底层技术优势
    您在多个Wi-Fi行业活动中代表LitePoint。Wi-Fi 7带来了哪些新颖且有趣的特点?
    的头像 发表于 11-15 15:27 608次阅读
    Wi-Fi 7Wi-Fi 6E有什么区别
    也许很多人还在考虑是否要将使用的Wi-Fi设备升级到Wi-Fi 6或Wi-Fi 6E,而这些标准的继任者却已经开始“登堂入室”了。Wi-Fi 7
    的头像 发表于 11-07 11:38 1371次阅读
    网速快4倍!iPhone 16/Pro全系支持Wi-Fi 7
    在安卓全面普及Wi-Fi 7一年之后,苹果终于在iPhone 16系列配备了Wi-Fi 7技术,并且是全系支持。 相比之下,前代的iPhone 15不论是标准版还是Pro版都仅仅支持
    的头像 发表于 09-10 09:31 752次阅读
    华为Wi-Fi 7全系列AP获WFA企业级WiFi7认证,业界最多
    2024年是Wi-Fi 7全面商用元年,Wi-Fi联盟从年初启动Wi-Fi 7产品认证。凭借强大的研发能力和创新精神,华为不仅全球首发全场景
    的头像 发表于 08-20 21:19 1563次阅读
    Wi-Fi 7为射频前端带来哪些挑战
    7 相较于前一代的Wi-Fi 6 在性能和功能上有了显著提升,尤其是在速率、延迟和容量等方面,并以“极高容量”(EHT,ExtremelyHigh Throughput)为特色。
    的头像 发表于 08-06 15:09 640次阅读
    华为获得全球首个国际Wi-Fi联盟WFA企业级Wi-Fi 7认证!
    Wi-Fi联盟已发布Wi-Fi 7认证标准,华为是第一批送测厂商,获得业界首个企业级Wi-Fi 7W
    的头像 发表于 04-28 10:17 823次阅读
    华为获得全球首个国际<b class='flag-5'>Wi-Fi</b>联盟WFA企业级<b class='flag-5'>Wi-Fi</b> <b class='flag-5'>7</b>认证!
    验证物联网Wi-Fi HaLow用例的MM6108-EKH08开发套件来啦
    验证物联网Wi-Fi HaLow用例的MM6108-EKH08开发套件来啦 MM6108-EKH08开发套件专为验证物联网Wi-Fi HaLow用例而设计。该
    的头像 发表于 04-11 12:01 1873次阅读
    验证物联网<b class='flag-5'>Wi-Fi</b> HaLow用例的MM6108-EKH08开发<b class='flag-5'>套件</b>来啦
    Wi-Fi 7Wi-Fi 6的相关知识科普
    科普:Wi-Fi 7 vs. Wi-Fi 6,青出于蓝
    的头像 发表于 03-12 10:59 889次阅读
    <b class='flag-5'>Wi-Fi</b> <b class='flag-5'>7</b>与<b class='flag-5'>Wi-Fi</b> 6的相关知识科普
    Wi-Fi的诞生与发展
    短距离无线通信技术有Wi-Fi、ZigBee、蓝牙以及Z-Wave,今天我们先揭开Wi-Fi的神秘面纱。Chrent短距离无线通信技术——Wi-Fi过去的20多年,Wi-Fi靠着仅有的
    的头像 发表于 03-07 08:26 1478次阅读
    <b class='flag-5'>Wi-Fi</b>的诞生与发展
    Windows 11 Build 26063 新增 Wi-Fi 7 网络测试,速度更快
    Wi-Fi 7Wi-Fi 6与Wi-Fi 6E的基础上进行升级,提升了各个领域的无线连接性能,包括传输速率、延迟、效率、牢靠度及能耗,旨在提供更好的用户体验。
    的头像 发表于 02-23 10:35 1036次阅读
    Wi-Fi 7商用元年:更宽的路应跑更好的车
    来源:中国电子报 近日,Wi-Fi联盟正式确认了Wi-Fi 7认证标准,标志着无线通信技术进入了一个新阶段。随着智能设备及物联网的普及,人们对可靠、快速无线通信的需求日益增强,Wi-Fi
    的头像 发表于 02-21 11:36 539次阅读
