本文来源电子发烧友社区,作者:黄炼榕, 帖子地址:https://bbs.elecfans.com/jishu_2021255_1_1.html
既然有了gpio,那就先看看基于gpio实现的iic通信吧。别的不多说先弄清楚板子上的oLED引脚号。
把支持I2C的宏定义打开,该宏定义所在位置为:
vendorhisihi3861hi3861buildconfigusr_config.mk
找到后修改如下:CONFIG_I2C_SUPPORT=y
示例一个写字节函数
void OLED_WR_Byte(uint8_t dat,uint8_t cmd){
hi_u8 m_send_data[2] = { 0 };
hi_u32 status;
hi_i2c_data hi3861_i2c_data = { 0 };
if(cmd) {
m_send_data[0] = 0x40;
else {
m_send_data[0] = 0x00;
m_send_data[1] = dat;
hi3861_i2c_data.send_buf = m_send_data;
hi3861_i2c_data.send_len = 2;
status = hi_i2c_write(HI_I2C_IDX_0, 0x78, &hi3861_i2c_data);
if (status != HI_ERR_SUCCESS) {
printf(" Error: I2C write status = 0x%x! rn", status);
return;
初始化oled还是跟以前一样
void OLED_Init(void){
OLED_WR_Byte(0xAE,OLED_CMD); //--turn off oled panel OLED_WR_Byte(0x00,OLED_CMD); //---set low column address OLED_WR_Byte(0x10,OLED_CMD); //---set high column address OLED_WR_Byte(0x40,OLED_CMD); //--set start line addressSet Mapping RAMdisplayStart Line (0x00~0x3F)
OLED_WR_Byte(0x81,OLED_CMD); //--set contrast control register OLED_WR_Byte(0xCF,OLED_CMD); // Set SEG Output Current Brightness OLED_WR_Byte(0xA1,OLED_CMD); //--Set SEG/Column Mapping 0xa0左右反置 0xa1正常
OLED_WR_Byte(0xC8,OLED_CMD); //Set COM/Row Scan Direction 0xc0上下反置 0xc8正常
OLED_WR_Byte(0xA6,OLED_CMD); //--set normal display OLED_WR_Byte(0xA8,OLED_CMD); //--set multiplex ratio(1 to 64) OLED_WR_Byte(0x3f,OLED_CMD); //--1/64 duty OLED_WR_Byte(0xD3,OLED_CMD); //-set display offset Shift Mapping RAM Counter (0x00~0x3F)
OLED_WR_Byte(0x00,OLED_CMD); //-not offset OLED_WR_Byte(0xd5,OLED_CMD); //--set displayclockdivide ratio/oscillator frequency
OLED_WR_Byte(0x80,OLED_CMD); //--set divide ratio, Set Clock as 100 Frames/Sec
OLED_WR_Byte(0xD9,OLED_CMD); //--set pre-charge period OLED_WR_Byte(0xF1,OLED_CMD); //Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
OLED_WR_Byte(0xDA,OLED_CMD); //--set com pins hardware configuration OLED_WR_Byte(0x12,OLED_CMD);
OLED_WR_Byte(0xDB,OLED_CMD); //--set vcomh OLED_WR_Byte(0x40,OLED_CMD); //Set VCOM Deselect Level OLED_WR_Byte(0x20,OLED_CMD); //-Set Page Addressing Mode (0x00/0x01/0x02)
OLED_WR_Byte(0x02,OLED_CMD); //
OLED_WR_Byte(0x8D,OLED_CMD); //--set Charge Pump enable/disable OLED_WR_Byte(0x14,OLED_CMD); //--set(0x10) disable OLED_WR_Byte(0xA4,OLED_CMD); // Disable Entire Display On (0xa4/0xa5) OLED_WR_Byte(0xA6,OLED_CMD); // Disable Inverse Display On (0xa6/a7) OLED_WR_Byte(0xAF,OLED_CMD); //--turn on oled panel OLED_WR_Byte(0xAF,OLED_CMD); /*display ON*/ OLED_Clear(); OLED_Set_Pos(0,0); }
void OLED_Demo(void){
OLED_Init();
OLED_Clear();
for(i=0;i<8;i++) {
OLED_ShowCHinese(i*16,0,i+0);
for(i=0;i<7;i++) {
OLED_ShowCHinese(i*16,2,i+8);
for(i=0;i<4;i++) {
OLED_ShowCHinese(i*16,4,i+15);
for(i=0;i<4;i++) {
OLED_ShowCHinese(i*16,6,i+19);
SYS_RUN(OLED_Demo);
编译烧录即可
OLED | |
VCC | |
GND | |
SCL | GPIO14 |
SDA | GPIO13 |
示例一个写字节函数
hi_u32 status;
if(cmd) {
else {
return;
初始化oled还是跟以前一样
OLED_Init();
OLED_Clear();
for(i=0;i<8;i++) {
for(i=0;i<7;i++) {
for(i=0;i<4;i++) {
for(i=0;i<4;i++) {
SYS_RUN(OLED_Demo);
编译烧录即可
举报投诉
wi-fi
14文章
2150浏览量
124638 -
HarmonyOS
79文章
1980浏览量
30283 -
HiSpark
1文章
156浏览量
6939
Wi-Fi 8要来了!未来Wi-Fi技术演进方向揭秘
产品销售中,虽然Wi-Fi 7产品的销量份额快速从年初的个位数百分比增长至14%,但Wi-Fi 6产品的销量份额依然稳定在60%左右。如果从存量设备来看,那么Wi-Fi 7路由器的占比将远远小于这个数。 智能手机等终端设备已
华为海思正式进入Wi-Fi FEM赛道?
大家都知道了,2018年11 月离开锐迪科(RDA),前往福建晋江创立三伍微,专注于Wi-Fi射频前端芯片,从路由器Wi-Fi FEM,到手机Wi-Fi FEM,再到IoT FEM全覆
发表于 12-11 17:42
从Wi-Fi 4到Wi-Fi 7:网速飙升40倍的无线革命
1 Wi-Fi技术的快速发展 每一代新的Wi-Fi协议发布,都会带来更高的无线速率。 从Wi-Fi 4到Wi-Fi 7:无线网络技术显著提升,实现了网速的巨大飞跃。
Wi-Fi 7与Wi-Fi 6E有什么区别
也许很多人还在考虑是否要将使用的Wi-Fi设备升级到Wi-Fi 6或Wi-Fi 6E,而这些标准的继任者却已经开始“登堂入室”了。Wi-Fi 7是新一代
未来的Wi-Fi路由器
转载自——钟林谈芯 没有创新就没有未来,Wi-Fi路由器也是如此。 进入2024年以后,Wi-Fi路由器市场变得更加艰难,利润大幅下滑,BOM成本价高于市场价,接不接订单,都陷入两难。 国内主芯片
DA16200 超低功耗 Wi-Fi 模块开发套件 Pro数据手册
电子发烧友网站提供《DA16200 超低功耗 Wi-Fi 模块开发套件 Pro数据手册.rar》资料免费下载
发表于 05-30 17:53
•1次下载
DA16200 超低功耗 Wi-Fi 模块开发套件数据手册
电子发烧友网站提供《DA16200 超低功耗 Wi-Fi 模块开发套件数据手册.rar》资料免费下载
发表于 05-30 17:13
•0次下载
验证物联网Wi-Fi HaLow用例的MM6108-EKH08开发套件来啦
验证物联网Wi-Fi HaLow用例的MM6108-EKH08开发套件来啦 MM6108-EKH08开发套件专为验证物联网Wi-Fi HaLow用例而设计。该
Wi-Fi的诞生与发展
短距离无线通信技术有Wi-Fi、ZigBee、蓝牙以及Z-Wave,今天我们先揭开Wi-Fi的神秘面纱。Chrent短距离无线通信技术——Wi-Fi过去的20多年,Wi-Fi靠着仅有的
Wi-Fi HaLow和传统Wi-Fi的区别
Wi-Fi HaLow和传统Wi-Fi的区别 Wi-Fi是一种无线网络技术,可以连接到互联网或局域网,为用户提供无线上网的便利。随着科技的发展和互联网的普及,Wi-Fi也在不断演进和
康普携手Wi-Fi联盟,RUCKUS Wi-Fi 7系列接入点成Wi-Fi
康普高级副总裁兼网络、智能蜂窝和安全解决方案总裁Bart Giordano对此表示: “我们非常荣幸能与Wi-Fi Alliance形成长期合作伙伴关系,将我们的RUCKUS Wi-Fi 7 接入点平台作为Wi-Fi CERT
BT Wi-Fi模式是否可以通过ModustoolBox对套件进行编程来实现?
想配置用于分析 CYW43439 的 CY8CPROTO-062S2-43439 原型开发套件。
浏览文档我无法弄清楚如何在不同的 Wi-Fi 和蓝牙模式(电源模式、连接模式等)下配置套件。
在
发表于 01-22 06:19
