本文来源电子发烧友社区,作者:juby, 帖子地址:https://bbs.elecfans.com/jishu_2012362_1_1.html
AHT20简介
应用场景
传感器性能![](https://img-blog.csdnimg.cn/202011252006150.png?#pic_center)
![](https://img-blog.csdnimg.cn/20201125200642643.png?#pic_center)
原理图手册中推荐电路
开发板中的原理图![](https://img-blog.csdnimg.cn/20201125200746966.png?#pic_center)
![](https://img-blog.csdnimg.cn/20201125200910847.png#pic_center)
![](https://img-blog.csdnimg.cn/20201125200918522.png?#pic_center)
模块的地址
#define AHT20_DEVICE_ADDR 0x38
#define AHT20_READ_ADDR ((0x38<<1)|0x1)
#define AHT20_WRITE_ADDR ((0x38<<1)|0x0)
I2C总线![](https://img-blog.csdnimg.cn/20201125201054308.png?#pic_center)
![](https://img-blog.csdnimg.cn/20201125201115180.png?#pic_center)
/** I2C hardware index 0 */
WIFI_IOT_I2C_IDX_0,
/** I2C hardware index 1 */
WIFI_IOT_I2C_IDX_1,
} WifiIotI2cIdx;
*@BriefDefines I2C data transmission attributes.
typedef struct {
/** Pointer to the buffer storing data to send */
unsigned char *sendBuf;
/** Length of data to send */
unsigned intsendLen;
/** Pointer to the buffer for storing data to receive */
unsigned char *receiveBuf;
/** Length of data received */
unsigned intreceiveLen;
} HalWifiIotI2cData;
I2C读函数![](https://img-blog.csdnimg.cn/2020112520114362.png?#pic_center)
![](https://img-blog.csdnimg.cn/20201125201157356.png#pic_center)
基本指令集状态位
状态字各位含义说明传感器读取流程
![](https://img-blog.csdnimg.cn/2020112520130721.png?#pic_center)
![](https://img-blog.csdnimg.cn/20201125201325630.png#pic_center)
// 发送软复位命令
static uint32_t AHT20_ResetCommand(void)
uint8_t resetCmd[] = {AHT20_CMD_RESET};
return AHT20_Write(resetCmd, sizeof(resetCmd));
![](https://img-blog.csdnimg.cn/20201125201338947.png?#pic_center)
#define AHT20_CMD_TRIGGER_ARG00x33
#define AHT20_CMD_TRIGGER_ARG10x00
// 发送 触发测量 命令,开始测量
uint32_t AHT20_StartMeasure(void)
uint8_t triggerCmd[] = {AHT20_CMD_TRIGGER, AHT20_CMD_TRIGGER_ARG0, AHT20_CMD_TRIGGER_ARG1};
return AHT20_Write(triggerCmd, sizeof(triggerCmd));
![](https://img-blog.csdnimg.cn/20201125201357953.png?#pic_center)
![](https://img-blog.csdnimg.cn/20201125201412317.png?pic_center)
相对湿度转换
uint32_t humiRaw = buffer[1];
humiRaw = (humiRaw << 8) | buffer[2];
humiRaw = (humiRaw << 4) | ((buffer[3] & 0xF0) >> 4);
![](https://img-blog.csdnimg.cn/20201125205303738.png#pic_center)
温度转换
tempRaw = (tempRaw << 8) | buffer[4];
tempRaw = (tempRaw << 8) | buffer[5];
![](https://img-blog.csdnimg.cn/20201125201457756.png#pic_center)
结果展示
AHT20简介
- 2020年上市,奥松生产;
- 3mmx3mmx1mm 超小体积;
- 经过标定的数字信号,标准I2C输出格式;
- 由一个电容式湿度传感元件和一个标准的片上温度传感元件组成;
- 采用SMD封装适于回流焊;
- 响应迅速、抗干扰能力强;
- AHT20 的供电范围为 2.0-5.5V, 推荐电压为3.3V。
![](https://img-blog.csdnimg.cn/20201125200526851.png#pic_center)
它广泛应用于暖通空调 、除湿器、测试及检测设备、消费品、汽车 、自动控制、数据记录器、气象站、家电、湿度调节、医疗及其他相关湿度检测控制等领域。
封装![](https://img-blog.csdnimg.cn/20201125200550603.png?#pic_center)
查看我们之前分享的网文,对比DHT21的参数如下:
由上对比,AHT20的精度要比DHT21的精度要好,而且价格又低了很多。
![](https://img-blog.csdnimg.cn/20201125200658216.png?#pic_center)
![](https://img-blog.csdnimg.cn/20201125200733927.png?#pic_center)
与开发板连接情况如下:
[td]
管脚名称 | 复用描述 |
GPIO_13 | GPIO_13/ADC6/PWM4_OUT/I2C0_SDA/ UART0_LOG_TXD |
GPIO_14 | GPIO_14/PWM5_OUT/I2C0_SCL/ UART0_LOG_RXD |
由上我们知道,这个AHT20使用的Hi3861芯片的I2C0。
程序源码
润和公司开源的鸿蒙OS AHT20 数字温湿度传感器驱动库:https://gitee.com/hihopeorg/harmonyos-aht20
如何编译
- 在 ~/harmony/code/code-1.0/applications/sample/wifi-iot/app目录下执行git clonehttps://github.com/xusiwei/harmonyos-aht20,获取源码。
- 修改编译脚本
- 在~/harmony/code/code-1.0目录下执行:python build.py wifiiot
![](https://img-blog.csdnimg.cn/20201125200934207.png?#pic_center)
I2C发送的首字节包括7位的I2C设备地址 0x38和一个SDA方向位X(读R:'1',写W:'0')。
手册中描述的模块地址定义如下:
![](https://img-blog.csdnimg.cn/20201125201032625.png?#pic_center)
I2C总线
AHT20 采用标准的 I2C协议进行通讯。
对于I2C通信我们之前分享过网文:
4位数码管显示模块驱动
基于鸿蒙OS移植OLED驱动程序
I2C写函数![](https://img-blog.csdnimg.cn/20201125201054308.png?#pic_center)
上图中的AHT20_Write()函数中调用了I2cWrite()函数。
I2cWrite()函数是系统中I2C进行写操作的函数,这个函数的参数含义解释如下:
参数1:WifiIotI2cIdx id,这个参数是使用的I2C的ID,这个参数可选下面枚举中的一个值:
typedef enum {/** I2C hardware index 0 */
WIFI_IOT_I2C_IDX_0,
WIFI_IOT_I2C_IDX_1,
} WifiIotI2cIdx;
因为我们这里使用的是I2C0,所以这个参数应该为:WIFI_IOT_I2C_IDX_0 。
参数2:unsigned short deviceAddr,这个参数是I2C总线下面的设备地址,因为这是一个写操作,所以这个参数我们选用上面的宏定义:AHT20_WRITE_ADDR。
参数3:const WifiIotI2cData *i2cData,这个参数是我们要发送的数据,该变量的数据类型为一个结构体类型: HalWifiIotI2cData ,该结构体的定义如下。
/***@BriefDefines I2C data transmission attributes.
typedef struct {
I2C读函数
上图中的AHT20_Read()函数中调用了I2cRead()函数。
I2cRead()函数是系统中I2C进行读操作的函数。
I2cRead()函数的参数与I2cWrite()函数的参数类似,只是参数3:const WifiIotI2cData *i2cData ,这个参数用于接收我们读取到的数据。
常用命令
AHT20常用的命令有:
- 初始化命令 ('1011’1110') ,即0xBE;
- 测量温湿度命令('1010’1100'),即0xAC;
- 软复位命令('1011’1010'),即0xBA。
![](https://img-blog.csdnimg.cn/20201125201226371.png?#pic_center)
通过发送0x71可以获取一个字节的状态字,状态字各位的含义描述如下:
![](https://img-blog.csdnimg.cn/20201125201247967.png?x-oss-process=image/watermark,type_ZmFuZ3poZW5naGVpdGk,shadow_10,text_aHR0cHM6Ly9ibG9nLmNzZG4ubmV0L3JzZDEwMg==,size_16,color_FFFFFF,t_70#pic_center)
- 上电后要等待40ms,读取温湿度值之前, 首先要看状态字的校准使能位Bit[3]是否为 1(通过发送0x71可以获取一个字节的状态字),如果不为1,要发送0xBE命令(初始化),此命令参数有两个字节, 第一个字节为0x08,第二个字节为0x00。
AHT20模块的状态判断通过下面AHT20_Calibrate()函数来判断,具体执行过程如下图所示:
注:在第一步的校准状态检验只需要上电时检查,在正常过程无需操作。
软复位
上面代码中有一个这样的指令:AHT20_ResetCommand()
这个命令用于在无需关闭和再次打开电源的情况下,重新启动传感器系统。
在接收到这个命令之后,传感器系统开始重新初始化,并恢复默认设置状态,软复位所需时间不超过 20 毫秒。
灰色部分由 AHT20 控制
#define AHT20_CMD_RESET 0xBA // 软复位命令// 发送软复位命令
- 直接发送 0xAC命令(触发测量),此命令参数有两个字节,第一个字节为 0x33,第二个字节为0x00。
触发测量命令发送的数据如下:
具体使用的代码如下:
#define AHT20_CMD_TRIGGER 0xAC // 触发测量命令#define AHT20_CMD_TRIGGER_ARG00x33
// 发送 触发测量 命令,开始测量
- 等待75ms待测量完成,忙状态Bit[7]为0,然后可以读取六个字节(发0X71即可以读取)。
注:传感器在采集时需要时间,主机发出测量指令(0xAC)后,延时75毫秒以上再读取转换后的数据并判断返回的状态位是否正常。若状态比特位[Bit7]为0代表设备闲,可正常读取,为1时传感器为忙状态,主机需要等待数据处理完成。
- 计算温湿度值。
![](https://img-blog.csdnimg.cn/20201125201424911.png?#pic_center)
将上图中蓝色背景的六个字节数据中,红色方框框住的为湿度数据,组成一个20bit长度的一个整形数;紫色方框框住的20bit为温度数据。
湿度数据按下面代码实现拼接:
#define AHT20_RESOLUTION (1<<20) // 2^20uint32_t humiRaw = buffer[1];
通过手册我们得知相对湿度的计算公式如下:
上面代码求得的 humiRaw 即为上图公式中的Srh,所以根据上图公式,使用如下代码即可获得相对湿度RH。
*humi = humiRaw / (float)AHT20_RESOLUTION * 100;温度转换
按如下方式合并温度数据的20bit数据:
uint32_t tempRaw = buffer[3] & 0x0F;tempRaw = (tempRaw << 8) | buffer[4];
查看手册。我们知道20bit的数据跟℃的换算关系如下:
用代码具体实现如下:
*temp = tempRaw / (float)AHT20_RESOLUTION * 200 - 50;结果展示
将上面编译之后的结果下载验证,输出如下:![](https://img-blog.csdnimg.cn/20201125201505489.png?#pic_center)
举报投诉
wi-fi
14文章
2175浏览量
125239 -
HarmonyOS
79文章
1985浏览量
30711 -
HiSpark
1文章
156浏览量
6966
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之I2C-温湿度传感器
,比如ELF 1开发板,I2C1总线上挂载有电容屏的触摸芯片,温度传感器,rx8010时钟芯片,I2C2上挂载有光线传感器,NAU88C22音频解码芯片。下面我们以温湿度传感器为例,介
发表于 02-11 09:17
发表于 02-10 10:31
远程温湿度实时监测系统应用方案
通信、云计算、大数据分析等技术。传感器作为系统的“眼睛”,负责实时采集环境中的温湿度数据。通过Wi-Fi、蓝牙、LoRa、NB-IoT等通讯方式,将
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-使用AHT20进行环境监测之开发板测试
温湿度打开ELF 1板卡,在/home/root下输入如下命令开始测试,可以看到程序可以正常运行没有报错,并直接返回测量到的数值。root@ELF1:~# ./elf1_cmd_aht20此时用手指触摸温湿度
发表于 11-29 09:04
。测试设备周围温湿度打开ELF 1板卡,在/home/root下输入如下命令开始测试,可以看到程序可以正常运行没有报错,并直接返回测量到的数值。root@ELF1:~# ./elf1_cmd_aht20此时用手指触摸温湿度
发表于 11-28 09:30
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-使用AHT20进行环境监测之AHT20传感器介绍
i2c接口的的AHT20温湿度传感器。i2c硬件原理见硬件手册,通信协议见3.2.2小节,我们前面这些章节已经介绍了i2c的基本通信原理,本节我们主要关注的是AHT20作为i2c从设备
发表于 11-27 09:09
发表于 11-26 09:36
温湿度传感器种类及原理的优劣分析
温湿度传感器是一种能够感知并测量环境中温度和湿度变化的设备,它们在环境监测、气象观测、农业、工业生产、智能家居等多个领域发挥着重要作用。下面将对温湿
温湿度传感器是什么类型的传感器
温湿度传感器是一种能够实时监测和记录环境中温度和湿度变化的设备或装置。这类传感器广泛应用于环境监测、气象观测、农业、工业生产、仓储管理、智能
想要准确地测量环境温湿度?温湿度传感器是关键!
温湿度是生产生活中最重要的环境指标之一,不仅人需要在适宜的温湿度条件下保持良好的精神状态和敏捷的思维,食品、药品、各种仪器设备等都对环境温湿度有特殊的要求。基于对环境
