本文来源电子发烧友社区,作者:张亭彪, 帖子地址:https://bbs.elecfans.com/jishu_2011342_1_1.html
使用WIFIIOT套件,直观交互最多的就是OLED。
源码LED_example.c里去.把所有的io_9改成11:
复制代码
- * Copyright (c) 2020 Huawei Device Co., Ltd.
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the License is distributed on an "AS IS" BASIS,
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- * See the License for the specific language governing permissions and
- * limitations under the License.
- #include
- #include
- #include "ohos_init.h"
- #include "cmsis_os2.h"
- #include "wifiiot_gpio.h"
- #include "wifiiot_gpio_ex.h"
- #define LED_INTERVAL_TIME_US 300000
- #define LED_TASK_STACK_SIZE 512
- #define LED_TASK_PRIO 25
- enum LedState
- LED_ON = 0,
- LED_OFF,
- LED_SPARK,
- enum LedState g_ledState = LED_SPARK;
- static void *LedTask(const char *arg)
- (void)arg;
- while (1)
- switch (g_ledState)
- case LED_ON:
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 1);
- usleep(LED_INTERVAL_TIME_US);
- break;
- case LED_OFF:
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 0);
- break;
- case LED_SPARK:
- break;
- default:
- break;
- return NULL;
- static void LedExampleEntry(void)
- osThreadAttr_t attr;
- printf("LedExampleEntry
- GpioInit();
- IoSetFunc(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_IO_FUNC_GPIO_11_GPIO);
- GpioSetDir(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_GPIO_DIR_OUT);
- attr.name = "LedTask";
- attr.attr_bits = 0U;
- attr.cb_mem = NULL;
- attr.cb_size = 0U;
- attr.stack_mem = NULL;
- attr.stack_size = LED_TASK_STACK_SIZE;
- attr.priority = LED_TASK_PRIO;
- if (osThreadNew((osThreadFunc_t)LedTask, NULL, &attr) == NULL)
- printf("[LedExample] Falied to create LedTask!
- SYS_RUN(LedExampleEntry);
举报投诉
wi-fi
14文章
2138浏览量
124457 -
HarmonyOS
79文章
1974浏览量
30162 -
HiSpark
1文章
156浏览量
6926
Wi-Fi 8要来了!未来Wi-Fi技术演进方向揭秘
产品销售中,虽然Wi-Fi 7产品的销量份额快速从年初的个位数百分比增长至14%,但Wi-Fi 6产品的销量份额依然稳定在60%左右。如果从存量设备来看,那么Wi-Fi 7路由器的占比将远远小于这个数。 智能手机等终端设备已
华为海思正式进入Wi-Fi FEM赛道?
大家都知道了,2018年11 月离开锐迪科(RDA),前往福建晋江创立三伍微,专注于Wi-Fi射频前端芯片,从路由器Wi-Fi FEM,到手机Wi-Fi FEM,再到IoT FEM全覆
发表于 12-11 17:42
从Wi-Fi 4到Wi-Fi 7:网速飙升40倍的无线革命
1 Wi-Fi技术的快速发展 每一代新的Wi-Fi协议发布,都会带来更高的无线速率。 从Wi-Fi 4到Wi-Fi 7:无线网络技术显著提升,实现了网速的巨大飞跃。
Wi-Fi 7与Wi-Fi 6E有什么区别
也许很多人还在考虑是否要将使用的Wi-Fi设备升级到Wi-Fi 6或Wi-Fi 6E,而这些标准的继任者却已经开始“登堂入室”了。Wi-Fi 7是新一代
未来的Wi-Fi路由器
转载自——钟林谈芯 没有创新就没有未来,Wi-Fi路由器也是如此。 进入2024年以后,Wi-Fi路由器市场变得更加艰难,利润大幅下滑,BOM成本价高于市场价,接不接订单,都陷入两难。 国内主芯片
DA16200 超低功耗 Wi-Fi 模块开发套件 Pro数据手册
电子发烧友网站提供《DA16200 超低功耗 Wi-Fi 模块开发套件 Pro数据手册.rar》资料免费下载
发表于 05-30 17:53
•1次下载
DA16200 超低功耗 Wi-Fi 模块开发套件数据手册
电子发烧友网站提供《DA16200 超低功耗 Wi-Fi 模块开发套件数据手册.rar》资料免费下载
发表于 05-30 17:13
•0次下载
验证物联网Wi-Fi HaLow用例的MM6108-EKH08开发套件来啦
验证物联网Wi-Fi HaLow用例的MM6108-EKH08开发套件来啦 MM6108-EKH08开发套件专为验证物联网Wi-Fi HaLow用例而设计。该
Wi-Fi的诞生与发展
短距离无线通信技术有Wi-Fi、ZigBee、蓝牙以及Z-Wave,今天我们先揭开Wi-Fi的神秘面纱。Chrent短距离无线通信技术——Wi-Fi过去的20多年,Wi-Fi靠着仅有的
Wi-Fi HaLow和传统Wi-Fi的区别
Wi-Fi HaLow和传统Wi-Fi的区别 Wi-Fi是一种无线网络技术,可以连接到互联网或局域网,为用户提供无线上网的便利。随着科技的发展和互联网的普及,Wi-Fi也在不断演进和
康普携手Wi-Fi联盟,RUCKUS Wi-Fi 7系列接入点成Wi-Fi
康普高级副总裁兼网络、智能蜂窝和安全解决方案总裁Bart Giordano对此表示: “我们非常荣幸能与Wi-Fi Alliance形成长期合作伙伴关系,将我们的RUCKUS Wi-Fi 7 接入点平台作为Wi-Fi CERT
BT Wi-Fi模式是否可以通过ModustoolBox对套件进行编程来实现?
想配置用于分析 CYW43439 的 CY8CPROTO-062S2-43439 原型开发套件。
浏览文档我无法弄清楚如何在不同的 Wi-Fi 和蓝牙模式(电源模式、连接模式等)下配置套件。
在
发表于 01-22 06:19
