本文来源电子发烧友社区,作者:小水滴1016, 帖子地址:https://bbs.elecfans.com/jishu_2008655_1_1.html
弄了半天,VSCode中还是识别不了串口,只好放弃,采用Ubuntu中编译,Windows中使用HiBurn来烧写。
拿到开发板通常第一件事儿都是写个helloWorld的程序,点个灯
我也不例外,搞了个跑马灯。
代码如下:
led_demo.c
复制代码
led_demo文件夹中
BIULD.gn
复制代码
同时,也要将app文件夹中的编译脚本文件BUILD.gn修改一下,在features中添加以下内容:
"led_demo:led_demo",
复制代码
添加完之后,返回CODE-1.0目录,在终端中输入以下命令:python build.py wifiiot
编译即可;
然后,返回Windows,用hiburn烧录即可。
第三篇完结,下一步,OLED,未完待续……
我也不例外,搞了个跑马灯。
代码如下:
led_demo.c
- #include
- #include
- #include "ohos_init.h"
- #include "cmsis_os2.h"
- #include "wifiiot_gpio.h"
- #include "wifiiot_gpio_ex.h"
- #define LED_TASK_STACK_SIZE 512
- #define LED_TASK_PRIO 25
- enum LedState {
- LED_ON = 0,
- LED_OFF,
- LED_SPARK,
- static void *LedTask(const char *arg)
- (void)arg;
- while (1) {
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, 1);
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 0);
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_12, 0);
- usleep(300000);
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_10, 0);
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_12, 1);
- usleep(300000);
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_11, 1);
- usleep(300000);
- return NULL;
- static void led_demo(void)
- osThreadAttr_t attr;
- GpioInit();
- IoSetFunc(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_IO_FUNC_GPIO_10_GPIO);
- IoSetFunc(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_IO_FUNC_GPIO_11_GPIO);
- IoSetFunc(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_IO_FUNC_GPIO_12_GPIO);
- GpioSetDir(WIFI_IOT_IO_NAME_GPIO_10, WIFI_IOT_GPIO_DIR_OUT);
- GpioSetDir(WIFI_IOT_IO_NAME_GPIO_11, WIFI_IOT_GPIO_DIR_OUT);
- GpioSetDir(WIFI_IOT_IO_NAME_GPIO_12, WIFI_IOT_GPIO_DIR_OUT);
- attr.name = "LedTask";
- attr.attr_bits = 0U;
- attr.cb_mem = NULL;
- attr.cb_size = 0U;
- attr.stack_mem = NULL;
- attr.stack_size = LED_TASK_STACK_SIZE;
- attr.priority = LED_TASK_PRIO;
- if (osThreadNew((osThreadFunc_t)LedTask, NULL, &attr) == NULL) {
- printf("[LedExample] Falied to create LedTask!
- SYS_RUN(led_demo);
BIULD.gn
- # Copyright (c) 2020 Huawei Device Co., Ltd.
- # Licensed under the Apache License, Version 2.0 (the "License");
- # you may not use this file except in compliance with the License.
- # You may obtain a copy of the License at
- # http://www.apache.org/licenses/LICENSE-2.0
- # Unless required by applicable law or agreed to in writing, software
- # distributed under the License is distributed on an "AS IS" BASIS,
- # WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- # See the License for the specific language governing permissions and
- # limitations under the License.
- static_library("led_demo") {
- sources = [
- "led_demo.c"
- include_dirs = [
- "//utils/native/lite/include",
- "//kernel/liteos_m/components/cmsis/2.0",
- "//base/iot_hardware/interfaces/kits/wifiiot_lite",
- import("//build/lite/config/component/lite_component.gni")
- lite_component("app") {
- features = [
- "startup",
- "led_demo:led_demo",
编译即可;
举报投诉
wi-fi
14文章
2179浏览量
125381 -
HarmonyOS
79文章
1985浏览量
30839 -
HiSpark
1文章
156浏览量
6998
Wi-Fi 8要来了!未来Wi-Fi技术演进方向揭秘
产品销售中,虽然Wi-Fi 7产品的销量份额快速从年初的个位数百分比增长至14%,但Wi-Fi 6产品的销量份额依然稳定在60%左右。如果从存量设备来看,那么Wi-Fi 7路由器的占比将远远小于这个数。 智能手机等终端设备已
华为海思正式进入Wi-Fi FEM赛道?
大家都知道了,2018年11 月离开锐迪科(RDA),前往福建晋江创立三伍微,专注于Wi-Fi射频前端芯片,从路由器Wi-Fi FEM,到手机Wi-Fi FEM,再到IoT FEM全覆
发表于 12-11 17:42
从Wi-Fi 4到Wi-Fi 7:网速飙升40倍的无线革命
1 Wi-Fi技术的快速发展 每一代新的Wi-Fi协议发布,都会带来更高的无线速率。 从Wi-Fi 4到Wi-Fi 7:无线网络技术显著提升,实现了网速的巨大飞跃。
Wi-Fi 7与Wi-Fi 6E有什么区别
也许很多人还在考虑是否要将使用的Wi-Fi设备升级到Wi-Fi 6或Wi-Fi 6E,而这些标准的继任者却已经开始“登堂入室”了。Wi-Fi 7是新一代
未来的Wi-Fi路由器
转载自——钟林谈芯 没有创新就没有未来,Wi-Fi路由器也是如此。 进入2024年以后,Wi-Fi路由器市场变得更加艰难,利润大幅下滑,BOM成本价高于市场价,接不接订单,都陷入两难。 国内主芯片
DA16200 超低功耗 Wi-Fi 模块开发套件 Pro数据手册
电子发烧友网站提供《DA16200 超低功耗 Wi-Fi 模块开发套件 Pro数据手册.rar》资料免费下载
发表于 05-30 17:53
•1次下载
DA16200 超低功耗 Wi-Fi 模块开发套件数据手册
电子发烧友网站提供《DA16200 超低功耗 Wi-Fi 模块开发套件数据手册.rar》资料免费下载
发表于 05-30 17:13
•0次下载
验证物联网Wi-Fi HaLow用例的MM6108-EKH08开发套件来啦
验证物联网Wi-Fi HaLow用例的MM6108-EKH08开发套件来啦 MM6108-EKH08开发套件专为验证物联网Wi-Fi HaLow用例而设计。该
Wi-Fi的诞生与发展
短距离无线通信技术有Wi-Fi、ZigBee、蓝牙以及Z-Wave,今天我们先揭开Wi-Fi的神秘面纱。Chrent短距离无线通信技术——Wi-Fi过去的20多年,Wi-Fi靠着仅有的
WI-FI基础知识及飞易通SOC模块
=8bits) 第二代:以IEEE 802.11b为准,工作频段为2.4GHz, 最高速率半双工11Mbit/s,认证项目为“Wi-Fi CERTIFIED b” 第三代:以IEEE 802.11a为准,工作频段为5GHz,最高速率
