实验拓扑
实验需求
设备IP、VLAN规划如上表所示;
FW1/FW2部署双机热备,采用主备方式,FW1为主设备,FW2为备设备;
PC1是站点内网用户,处于Trust Zone网关是主备防火墙的VRRP组1的虚拟IP地址;
PC2是另一个站点的内网用户,处于Untrust Zone,网关设置为FW3的GE0/0/1口IP地址;
FW1/FW2与FW3之间建立一条IPSecVPN站点到站点的隧道,用于保护PC1及PC2之间的互访流量。
实验步骤及配置
完成接口的基本配置,将接口关联到安全区域
FW1的配置如下:
[FW1]interfaceGigabitEthernet0/0/1 [FW1-GigabitEthernet0/0/1]ipaddress192.168.1.324 [FW1-GigabitEthernet0/0/1]vrrpvrid1virtual-ip192.168.1.1master [FW1-GigabitEthernet0/0/1]quit [FW1]interfaceGigabitEthernet0/0/3 [FW1-GigabitEthernet0/0/3]ipaddress200.1.1.324 [FW1-GigabitEthernet0/0/3]vrrpvrid2virtual-ip200.1.1.1master [FW1-GigabitEthernet0/0/3]quit [FW1]interfaceGigabitEthernet0/0/2 [FW1-GigabitEthernet0/0/2]ipaddress1.1.1.124 [FW1-GigabitEthernet0/0/2]quit [FW1]firewallzonetrust [FW1-zone-trust]addinterfaceGigabitEthernet0/0/1 [FW1-zone-trust]quit [FW1]firewallzoneuntrust [FW1-zone-untrust]addinterfaceGigabitEthernet0/0/3 [FW1-zone-untrust]quit [FW1]firewallzonenameha [FW1-zone-ha]setpriority96 [FW1-zone-ha]addinterfaceGigabitEthernet0/0/2 [FW1-zone-ha]quit
FW2的配置如下:
[FW2]interfaceGigabitEthernet0/0/1 [FW2-GigabitEthernet0/0/1]ipaddress192.168.1.224 [FW2-GigabitEthernet0/0/1]vrrpvrid1virtual-ip192.168.1.1slave [FW2-GigabitEthernet0/0/1]quit [FW2]interfaceGigabitEthernet0/0/3 [FW2-GigabitEthernet0/0/3]ipaddress200.1.1.224 [FW2-GigabitEthernet0/0/3]vrrpvrid2virtual-ip200.1.1.1slave [FW2-GigabitEthernet0/0/3]quit [FW2]interfaceGigabitEthernet0/0/2 [FW2-GigabitEthernet0/0/2]ipaddress1.1.1.224 [FW2-GigabitEthernet0/0/2]quit [FW2]firewallzonetrust [FW2-zone-trust]addinterfaceGigabitEthernet0/0/1 [FW2-zone-trust]quit [FW2]firewallzoneuntrust [FW2-zone-untrust]addinterfaceGigabitEthernet0/0/3 [FW2-zone-untrust]quit [FW2]firewallzonenameha [FW2-zone-ha]setpriority96 [FW2-zone-ha]addinterfaceGigabitEthernet0/0/2 [FW2-zone-ha]quit
为FW1及FW2添加默认路由
FW1的配置如下:
[FW1]iproute-static0.0.0.00200.1.1.100
FW2的配置如下:
[FW2]iproute-static0.0.0.00200.1.1.100
部署FW1/FW2双机热备,采用主备方式
FW1的配置如下:
[FW1]hrpinterfaceGigabitEthernet0/0/2 [FW1]hrpenable [FW1]hrppreemptdelay60
FW2的配置如下:
[FW2]hrpinterfaceGigabitEthernet0/0/2 [FW2]hrpenable
配置完成后,FW1/FW2会进行主备协商,FW1成为主防火墙,FW2成为备份防火墙。
在FW1及FW2上配置IPSecVPN
IPSecVPN相关策略的配置在主防火墙FW1上配置即可,这些配置会自动同步到备份防火墙FW2上,不过,在接口上应用IPSec Policy的这一条命令,是需要在主备防火墙相应的接口上都做配置的,因为这条命令不会自动同步。
在主防火墙FW1上定义IPSecVPN感兴趣数据流,使用ACL3000来匹配感兴趣流量:
HRP_M[FW1]aclnumber3000 HRP_M[FW1-acl-adv-3000]rulepermitipsource192.168.1.00.0.0.255destination10.1.1.0 0.0.0.255 HRP_M[FW1-acl-adv-3000]quit
在主防火墙FW1上配置IKE Proposal,这是IKE阶段一的策略,在FW1/FW2上部署的相关策略均需与FW3相匹配。IKE阶段一的策略中,身份验证使用的是预共享的认证方式,验证算法使用的是sha1,加密算法使用3des:
HRP_M[FW1]ikeproposal10 HRP_M[FW1-ike-proposal-10]authentication-methodpre-share HRP_M[FW1-ike-proposal-10]authentication-algorithmsha1 HRP_M[FW1-ike-proposal-10]encryption-algorithm3des-cbc HRP_M[FW1-ike-proposal-10]dhgroup2 HRP_M[FW1-ike-proposal-10]quit
在主防火墙FW1上配置IPsec proposal,这是IKE阶段二的策略,在阶段二的策略中安全协议采用ESP,加密算法使用3des,验证算法使用sha1:
HRP_M[FW1]ipsecproposalmyset HRP_M[FW1-ipsec-proposal-myset]transformesp HRP_M[FW1-ipsec-proposal-myset]espauthentication-algorithmsha1 HRP_M[FW1-ipsec-proposal-myset]espencryption-algorithm3des
在主防火墙FW1上配置IKE peer,定义预共享秘钥、关联IKE proposal并指定隧道对端节点IP
HRP_M[FW1]ikepeerfw3 HRP_M[FW1-ike-peer-fw3]pre-shared-keyHuawei123 HRP_M[FW1-ike-peer-fw3]ike-proposal10 HRP_M[FW1-ike-peer-fw3]remote-address200.1.1.100
在主防火墙FW1上配置IPsec Policy
HRP_M[FW1]ipsecpolicymymap10isakmp HRP_M[FW1-ipsec-policy-isakmp-mymap-10]securityacl3000 HRP_M[FW1-ipsec-policy-isakmp-mymap-10]ike-peerfw3 HRP_M[FW1-ipsec-policy-isakmp-mymap-10]local-address200.1.1.1 HRP_M[FW1-ipsec-policy-isakmp-mymap-10]proposalmyset
上述关于IPSecVPN的策略都能够自动同步到备机FW2上,但是下面这条将IPsec Policy 应用到接口的命令,需要在FW2上手工输入:
FW1应用IPsec Policy到接口
HRP_M[FW1]interfaceGigabitEthernet0/0/3 HRP_M[FW1-GigabitEthernet0/0/3]ipsecpolicymymap
FW2应用IPsec Policy到接口
HRP_S[FW2]interfaceGigabitEthernet0/0/3 HRP_S[FW2-GigabitEthernet0/0/3]ipsecpolicymymap
在FW1、FW2上放开防火墙之间的IPSecVPN隧道协商流量、放开IPSecVPN内部站点之间的流量
放开FW1、FW2防火墙自身到的FW3的流量,使得ISAKMP报文,以及受保护的用户数据能够发送到FW3
HRP_M[FW1]policyinterzonelocaluntrustoutbound HRP_M[FW1-policy-interzone-local-untrust-outbound]policy0 HRP_M[FW1-policy-interzone-local-untrust-outbound-0]policydestination200.1.1.1000 HRP_M[FW1-policy-interzone-local-untrust-outbound-0]actionpermit HRP_M[FW1-policy-interzone-local-untrust-outbound-0]quit HRP_M[FW1-policy-interzone-local-untrust-outbound]quit
放开IPSecVPN隧道对端防火墙发送到FW1/FW2的流量
HRP_M[FW1]policyinterzonelocaluntrustinbound HRP_M[FW1-policy-interzone-local-untrust-inbound]policy0 HRP_M[FW1-policy-interzone-local-untrust-inbound-0]policysource200.1.1.1000 HRP_M[FW1-policy-interzone-local-untrust-inbound-0]actionpermit
放开对端站点内网访问本地内网的流量
HRP_M[FW1]policyinterzonetrustuntrustinbound HRP_M[FW1-policy-interzone-trust-untrust-inbound]policy0 HRP_M[FW1-policy-interzone-trust-untrust-inbound-0]policysource10.1.1.00.0.0.255 HRP_M[FW1-policy-interzone-trust-untrust-inbound-0]policydestination192.168.1.00.0.0.255 HRP_M[FW1-policy-interzone-trust-untrust-inbound-0]actionpermit
放开本地站点内网到对端站点内网的流量
HRP_M[FW1]policyinterzonetrustuntrustoutbound HRP_M[FW1-policy-interzone-trust-untrust-outbound]policy0 HRP_M[FW1-policy-interzone-trust-untrust-outbound-0]policysource192.168.1.00.0.0.255 HRP_M[FW1-policy-interzone-trust-untrust-outbound-0]policydestination10.1.1.00.0.0.255 HRP_M[FW1-policy-interzone-trust-untrust-outbound-0]actionpermit
完成FW3的配置
[FW3]interfaceGigabitEthernet0/0/1 [FW3-GigabitEthernet0/0/1]ipaddress10.1.1.124 [FW3-GigabitEthernet0/0/1]quit [FW3]interfaceGigabitEthernet0/0/3 [FW3-GigabitEthernet0/0/3]ipaddress200.1.1.10024 [FW3-GigabitEthernet0/0/3]quit [FW3]firewallzonetrust [FW3-zone-trust]addinterfaceGigabitEthernet0/0/1 [FW3-zone-trust]quit [FW3]firewallzoneuntrust [FW3-zone-untrust]addinterfaceGigabitEthernet0/0/3 [FW3-zone-untrust]quit [FW3]aclnumber3000 [FW3-acl-adv-3000]rulepermitipsource10.1.1.00.0.0.255destination192.168.1.00.0.0.255 [FW3-acl-adv-3000]quit [FW3]ikeproposal10 [FW3-ike-proposal-10]authentication-methodpre-share [FW3-ike-proposal-10]authentication-algorithmsha1 [FW3-ike-proposal-10]encryption-algorithm3des-cbc [FW3-ike-proposal-10]dhgroup2 [FW3-ike-proposal-10]quit [FW3]ipsecproposalmyset [FW3-ipsec-proposal-myset]transformesp [FW3-ipsec-proposal-myset]espauthentication-algorithmsha1 [FW3-ipsec-proposal-myset]espencryption-algorithm3des [FW3]ikepeerfw1-2 [FW3-ike-peer-fw1-2]pre-shared-keyHuawei123 [FW3-ike-peer-fw1-2]ike-proposal10 [FW3-ike-peer-fw1-2]remote-address200.1.1.1 [FW3]ipsecpolicymymap10isakmp [FW3-ipsec-policy-isakmp-mymap-10]securityacl3000 [FW3-ipsec-policy-isakmp-mymap-10]ike-peerfw1-2 [FW3-ipsec-policy-isakmp-mymap-10]proposalmyset [FW3]interfaceGigabitEthernet0/0/3 [FW3-GigabitEthernet0/0/3]ipsecpolicymymap [FW3]policyinterzonelocaluntrustoutbound [FW3-policy-interzone-local-untrust-outbound]policy0 [FW3-policy-interzone-local-untrust-outbound-0]policydestination200.1.1.10 [FW3-policy-interzone-local-untrust-outbound-0]actionpermit [FW3-policy-interzone-local-untrust-outbound-0]quit [FW3-policy-interzone-local-untrust-outbound]quit
放开IPSecVPN隧道对端防火墙发送过来的流量
[FW3]policyinterzonelocaluntrustinbound [FW3-policy-interzone-local-untrust-inbound]policy0 [FW3-policy-interzone-local-untrust-inbound-0]policysource200.1.1.10 [FW3-policy-interzone-local-untrust-inbound-0]actionpermit
放开对端站点内网过来的流量
[FW3]policyinterzonetrustuntrustinbound [FW3-policy-interzone-trust-untrust-inbound]policy0 [FW3-policy-interzone-trust-untrust-inbound-0]policysource192.168.1.00.0.0.255 [FW3-policy-interzone-trust-untrust-inbound-0]policydestination10.1.1.00.0.0.255[FW3- policy-interzone-trust-untrust-inbound-0]actionpermit
放开本地站点内网到对端站点内网的流量
[FW3]policyinterzonetrustuntrustoutbound [FW3-policy-interzone-trust-untrust-outbound]policy0 [FW3-policy-interzone-trust-untrust-outbound-0]policysource10.1.1.00.0.0.255 [FW3-policy-interzone-trust-untrust-outbound-0]policydestination192.168.1.00.0.0.255[FW3- policy-interzone-trust-untrust-outbound-0]actionpermit [FW3]iproute-static0.0.0.00200.1.1.1
完成上述配置后,PC1与PC2即可互访。
HRP_M[FW1]displayipsecsa =============================== Interface:GigabitEthernet0/0/8 pathMTU:1500 =============================== ----------------------------- IPsecpolicyname:"mymap" sequencenumber:10 mode:isakmp vpn:public ----------------------------- connectionid:40002 rulenumber:5 encapsulationmode:tunnel holdingtime:49710d5h29m28s tunnellocal:200.1.1.1tunnelremote:200.1.1.100 flowsource:192.168.1.0/255.255.255.00/0 flowdestination:10.1.1.0/255.255.255.00/0 [inboundESPSAs] spi:3990067008(0xedd39740) vpn:publicsaid:0cpuid:0x0000 proposal:ESP-ENCRYPT-3DESESP-AUTH-SHA1 saremainingkeyduration(bytes/sec):1887436464/2704 maxreceivedsequence-number:4 udpencapsulationusedfornattraversal:N [outboundESPSAs] spi:1474676474(0x57e5c6fa) vpn:publicsaid:1cpuid:0x0000 proposal:ESP-ENCRYPT-3DESESP-AUTH-SHA1 saremainingkeyduration(bytes/sec):1887436464/2704 maxsentsequence-number:260004 udpencapsulationusedfornattraversal:N
以上是FW1的IPSec SAs。主防火墙FW1在与FW3完成IPSecVPN隧道的建立后,会将IPSec SAs同步到备份防火墙上,备份防火墙上的IPSec SAs与主防火墙上的SAs是一样的:
HRP_S[FW2]displayipsecsa =============================== Interface:GigabitEthernet0/0/8 pathMTU:1500 =============================== ----------------------------- IPsecpolicyname:"mymap" sequencenumber:10 mode:isakmp vpn:public ----------------------------- connectionid:40005 rulenumber:5 encapsulationmode:tunnel holdingtime:0d0h58m19s tunnellocal:200.1.1.1tunnelremote:200.1.1.100 flowsource:192.168.1.0/255.255.255.00/0 flowdestination:10.1.1.0/255.255.255.00/0 [inboundESPSAs] spi:3990067008(0xedd39740) vpn:publicsaid:4cpuid:0x0000 proposal:ESP-ENCRYPT-3DESESP-AUTH-SHA1 saremainingkeyduration(bytes/sec):1887436464/2618 maxreceivedsequence-number:1 udpencapsulationusedfornattraversal:N [outboundESPSAs] spi:1474676474(0x57e5c6fa) vpn:publicsaid:5cpuid:0x0000 proposal:ESP-ENCRYPT-3DESESP-AUTH-SHA1 saremainingkeyduration(bytes/sec):1887436464/2618 maxsentsequence-number:520000 udpencapsulationusedfornattraversal:N HRP_S[FW2]
当FW1丢失了到Internet的连接,如下:
则FW1、FW2将发生主备切换,而此时由于FW2已经拥有了IPSec SAs并且这些SAs与FW1上的是相同的,因此受保护流量可以平滑的切换到FW2上来。
再考虑另外一种情况,就是FW1掉电重启的情况。由于掉电重启,FW1将丢失IPSec SAs,此时FW2成为主设备接替其工作。在FW1启动完成初期,FW2由于仍然是主设备,因此会向FW1 同步IPSec SAs,在FW1抢占了FW2的主设备身份后,即可正常的转发受保护流量。在这里要注意,HRP抢占的时间要设置的合理,不应设置得太短。
注意:
实验中使用的防火墙软件版本为:V300R001C00SPC700。
在完成配置后,FW3会与主防火墙FW1完成IPSecVPN隧道的建立,FW1会将建立好的IPSecSAs同步到备份防火墙FW2上,主备防火墙的IPSec SAs的策略、入站及出站的SPI都是一样的。当FW1发生故障时,FW1/FW2主备切换,受保护流量被引导到备防火墙上,由于此时备防火墙早已有IPSec SAs,因此可以实现平滑的切换。
当PC1主动发起访问PC2的时候,主防火墙FW1/是无法与FW3正确的建立IPSecVPN隧道的,这是因为FW1发送的ISAKMP报文源地址为200.1.1.3也就是FW1的物理接口IP,而在FW3上我们配置的peer地址为200.1.1.1,两者并不匹配,因此IPSecVPN隧道无法正确建立。但是PC2可主动发起访问PC1,这将触发FW3主动与200.1.1.1建立IPSecVPN隧道,这是能够成功的。FW3的ISAKMP报文将发向200.1.1.1,报文实际是发送到主防火墙FW1上,FW1即使未配置local-address,但是FW1(实验版本为V300R001C00SPC700)能够正确处理这些报文并最终正确地完成隧道的建立,虽然如此,仍然建议在FW1、FW2上配置local-address。如果防火墙作为IPSec隧道的发起方,必须执行命令local-address ip-address,设置本端发起协商的地址为VRRP备份组的虚拟IP地址。
双机热备的环境下,只支持主备备份方式的IPSec VPN。
FW1/FW2防火墙的上下行业务接口必须为三层接口(包括VLANIF接口)。
先建立双机热备状态,再配置IPSec VPN。在主用防火墙上配置的IPSec策略会自动备份到备用防火墙上。在备用防火墙上,只需要在出接口上应用备份过来的IPSec策略即可。
审核编辑:郭婷
接口
33文章
8575浏览量
151021 -
网关
9文章
4444浏览量
51057
原文标题:安全进阶:防火墙双机组网环境中的 IPSecVPN 实验配置
文章出处:【微信号:网络技术干货圈,微信公众号:网络技术干货圈】欢迎添加关注!文章转载请注明出处。
