本文来源电子发烧友社区,作者:FrankSmith, 帖子地址:https://bbs.elecfans.com/jishu_2296120_1_1.html
想进行tcpip通讯,首先得连接网络。当然了,这个板子没有以太网接口,得利用板子的WiFi接口了。这个项目提供了一些WiFi的功能,予以一一尝试。
第一个指令是(wifi_scan)。
以下指令的输入以及信息的输出均在串口助手sscom中进行。
- wifi_scan
- ------>>>>>> Scan CMD
- # [WIFI] [IND] SCAN Done
- wifi_mgmr_scan_complete_callback: scan complete
- [APP] [EVT] SCAN Done 69207
- cached scan list
- index[00]: empty
- index[01]: empty
- index[02]: empty
- index[03]: empty
- index[04]: empty
- index[05]: empty
- index[06]: empty
- index[07]: empty
- index[08]: empty
- index[09]: empty
- index[10]: empty
- index[11]: empty
- index[12]: empty
- index[13]: empty
- index[14]: empty
- index[15]: empty
- index[16]: empty
- index[17]: empty
- index[18]: empty
- index[19]: empty
- index[20]: empty
- index[21]: empty
- index[22]: empty
- index[23]: empty
- index[24]: empty
- index[25]: empty
- index[26]: empty
- index[27]: empty
- index[28]: empty
- index[29]: empty
- index[30]: empty
- index[31]: channel 13, bssid 16:E9:B2:91:AD:E7, rssi -98, ppm abs:rel 0 : 0, auth WPA2-PSK/WPA-PSK, cipher: AES, SSID CMCC-uWN6-2
- index[32]: channel 13, bssid 14:E9:B2:91:AD:E7, rssi -87, ppm abs:rel 0 : 0, auth WPA2-PSK/WPA-PSK, cipher: AES, SSID CMCC-uWN6
- index[33]: channel 11, bssid 64:6E:97:C9:5A:D7, rssi -98, ppm abs:rel 0 : 0, auth WPA2-PSK/WPA-PSK, cipher: AES, SSID 3205
- index[34]: channel 11, bssid EC:17:2F:68:27:D4, rssi -84, ppm abs:rel 5 : 5, auth WPA2-PSK/WPA-PSK, cipher: AES, SSID TP-LINK_6827D4
- index[35]: channel 11, bssid 70:85:40:2B:AB:B7, rssi -79, ppm abs:rel 2 : 2, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID 468
- index[36]: channel 10, bssid 74:7D:24:48:97:62, rssi -98, ppm abs:rel 0 : 0, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID @PHICOMM_60
- index[37]: channel 10, bssid 92:3F:7B:61:27:AF, rssi -85, ppm abs:rel 2 : 2, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID iTV-iaLX
- index[38]: channel 11, bssid D0:76:E7:EF:03:71, rssi -98, ppm abs:rel10 :10, auth WPA2-PSK/WPA-PSK, cipher: AES, SSID ChinaNet-sefN
- index[39]: channel 10, bssid 68:DB:54:DF:35:E2, rssi -98, ppm abs:rel 0 : 0, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID 钂嬪
- index[40]: channel 10, bssid 30:3F:7B:61:27:AE, rssi -98, ppm abs:rel 4 : 4, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID ChinaNet-iaLX
- index[41]: channel 10, bssid 30:5F:77:80:93:DE, rssi -85, ppm abs:rel 0 : 0, auth WPA2-PSK, cipher: AES, SSID 鍖椾含鐑ら腑
- index[42]: channel 08, bssid 38:21:87:41:89:1D, rssi -98, ppm abs:rel35 :35, auth WPA2-PSK, cipher: AES, SSID midea_ac_0404
- index[43]: channel 08, bssid 24:8B:E0:5C:E0:D9, rssi -96, ppm abs:rel 7 : 7, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID liao150829
- index[44]: channel 10, bssid 50:D2:F5:74:BA:C2, rssi -61, ppm abs:rel 0 : 0, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID CYMY
- index[45]: channel 05, bssid 70:85:40:2B:AB:48, rssi -79, ppm abs:rel 0 : 0, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID 168
- index[46]: channel 05, bssid 70:85:40:2B:AB:FC, rssi -73, ppm abs:rel 2 : 2, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID 288
- index[47]: channel 03, bssid 2C:B2:1A:D0:3B:82, rssi -97, ppm abs:rel 0 : 0, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID fei
- index[48]: channel 03, bssid 70:85:40:2B:AB:45, rssi -52, ppm abs:rel 5 : 5, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID 368
- index[49]: channel 03, bssid 70:85:40:2B:AB:EF, rssi -43, ppm abs:rel13 :13, auth WPA2-PSK/WPA-PSK, cipher: TKIP/AES, SSID 268
- proc_hellow_entry: RISC-V rv32imafc.gj_lf686_demo_wifi
找到一个可以连接的无线路由器,ssid=268
使用这个项目提供的命令:(wifi_sta_connect)
- wifi_sta_connect 268 07342596999
- ----- BUG FIXME? NOT do STA enable again
- [WF] MM_ADD_IF_REQ Sending: STA
- 歵d_start idx=0
- [WF] MM_ADD_IF_REQ Done
- [WF] vif_index from LAMC is 0
- [WF][SM] Entering idle state
- [WF][SM] Action Connect
- ssid 268
- ssid len 3
- psk 07342596999
- psk len 11
- pmk
- pmk len 0
- channel band 0
- channel freq 0
- mac 00:00:00:00:00:00
- dhcp status: true
- [WF][SM] State Action ###idle### --->>> ###connecting###
- connecting using vif_idx 0
- ===start sm_get_bss_params===
- bssid[0] = 0xffff
- bssid[1] = 0xffff
- bssid[2] = 0xffff
- search ssid = 268
- result ssid index = -1
- ===end sm_get_bss_params===
- [WF][SM] Entering connecting state
- # [APP] [EVT] Connecting 707891
- Probe Response
- timestamp = 0x30ef47b10
- Probe Response
- timestamp = 0x30ef84cbd
- Probe Response
- timestamp = 0x30efc2998
- Probe Response
- timestamp = 0x30f03c5d3
- [ 710128][[32mINFO[0m: lf_adc.c: 260] offset = 2108
- bssid[0] = 0xffff
- bssid[1] = 0xffff
- bssid[2] = 0xffff
- search ssid = 268
- result ssid index = 0
- wpa2/wpa3 pairwise ccmp:1,tkip:0,wep104:0,wep:40:0
- wpa2/wpa3 group ccmp:0,tkip:1,wep104:0,wep:40:0
- wpa2/wpa3 is_pmf_required:0
- AP Security mode: wep:0,wpa:1,wpa2:1,wpa3:0
- Probe Response
- timestamp = 0x30f26308d
- ------ 247 set default key 0x42018c08, key ptr 0x00000000
- [APP] [EVT] SCAN On Join 711659
- set key:sta_idx:0, inst_nbr:0, key_idx:0,cipher_suite:2,key_len:16
- set key:sta_idx:255, inst_nbr:0, key_idx:1,cipher_suite:1,key_len:32
- ind ix 0x4201eddc, chan_ctxt is 0x420183f4
- [RX] Connection Status
- [RX] status_code 0
- [RX] connect result: sm connect ind ok
- [RX] MAC 70:85:40:2B:AB:EF
- [RX] vif_idx 0
- [RX] ap_idx 0
- [RX] ch_idx 0
- [RX] qos 1
- [RX] acm 0
- [RX] assoc_req_ie_len 80
- [RX] assoc_rsp_ie_len 172
- [RX] aid 0
- [RX] band 0
- [RX] center_freq 2422
- [RX] width 0
- [RX] center_freq1 2422
- [RX] center_freq2 0
- [WF][SM] Exiting connecting state
- [WF][SM] State Action ###connecting### --->>> ###wifiConnected_ipObtaining###
- [WF][SM] Entering wifiConnected_ipObtaining state
- [WF][SM] DHCP Starting...0x42019e24
- [APP] [EVT] connected 711685
- -----------------> AABA Request:
- A-MSDU: Not Permitted
- Block Ack Policy: Immediate Block Ack
- TID: 0
- Number of Buffers: 64
- -----------------> AABA Response:
- TID: 0
- Number of Buffers: 8
- [lwip] netif status callback
- IP: 192.168.88.7
- MK: 255.255.255.0
- GW: 192.168.88.254
- [WF][SM] Exiting wifiConnected_ipObtaining state
- [WF][SM] IP GOT IP:192.168.88.7, MASK: 255.255.255.0, Gateway: 192.168.88.254, dns1: 192.168.88.254, dns2: 0.0.0.0
- [WF][SM] State Action ###wifiConnected_ipObtaining### --->>> ###wifiConnected_IPOK###
- [WF][SM] Entering wifiConnected_IPOK state
- [APP] [EVT] GOT IP 715004
- [SYS] Memory left is 150312 Bytes
在这些信息中,可以看见一条信息:
这标识已经连上路由器,并通过dhcp分配了IP地址为192.168.88.7。
电脑中打开一个cmd窗口,查看本机的ip地址。
- 无线局域网适配器 WLAN:
- 连接特定的 DNS 后缀 . . . . . . . : Realtek
- IPv4 地址 . . . . . . . . . . . . : 192.168.88.6
- 子网掩码. . . . . . . . . . . . : 255.255.255.0
- 默认网关. . . . . . . . . . . . . : 192.168.88.254
- 以太网适配器 蓝牙网络连接:
- 媒体状态. . . . . . . . . . . . : 媒体已断开连接
使用ping指令,看是否能连通开发板
- C:Usersjohn>ping 192.168.88.7
- 正在 Ping 192.168.88.7 具有 32 字节的数据:
- 来自 192.168.88.7 的回复: 字节=32 时间=5ms TTL=255
- 来自 192.168.88.7 的回复: 字节=32 时间=2ms TTL=255
- 来自 192.168.88.7 的回复: 字节=32 时间=4ms TTL=255
- 来自 192.168.88.7 的回复: 字节=32 时间=9ms TTL=255
- 192.168.88.7 的 Ping 统计信息:
- 数据包: 已发送 = 4,已接收 = 4,丢失 = 0 (0% 丢失),
- 往返行程的估计时间(以毫秒为单位):
- 最短 = 2ms,最长 = 9ms,平均 = 5ms
可以看见已经能ping通开发板。说明开发板已经挂在无线网络上,并且项目提供了被ping通的功能。这在windows中被称呼为文件和打印机共享(回显请求 - ICMPv4-In)。windows中需要在防火墙中设置才能开启这个功能。这个项目应该没有防火墙吧。但是直接就提供了回显请求功能了。这个功能应该能使得外部设备能知道这个开发板是否在线。
至此,初步探索结束。应该下一步可以在此基础上开展工作了?
可惜理想很丰满,现实很骨感。
首先,功能实现之前,先实现对功能得触发。去看看项目得指令wifi_sta_connect是如何触发?
找到wifi_sta_connect函数定义:
- static void wifi_sta_connect(char *ssid, char *password)
- wifi_interface_t wifi_interface;
- wifi_interface = wifi_mgmr_sta_enable();
- wifi_mgmr_sta_connect(wifi_interface, ssid, password, NULL, NULL, 0, 0);
以及函数引用
- case CODE_WIFI_ON_PROV_CONNECT:
- printf("[APP] [EVT] [PROV] [CONNECT] %lldrn", aos_now_ms());
- printf("connecting to %s:%s...rn", ssid, password);
- wifi_sta_connect(ssid, password);
这个引用在函数static void event_cb_wifi_event(input_event_t *event, void *private_data)里。。。
这是什么鬼。命令行不是在以下数据结构里吗?
- const static struct cli_command cmds_user[] STATIC_CLI_CMD_ATTRIBUTE = {
- { "aws", "aws iot demo", cmd_aws},
- { "pka", "pka iot demo", cmd_pka},
- { "wifi", "wifi", cmd_wifi},
- { "sha", "sha iot demo", cmd_sha},
- { "trng", "trng test", cmd_trng},
- { "aes", "trng test", cmd_aes},
- { "cks", "cks test", cmd_cks},
- { "dma", "dma test", cmd_dma},
- { "exception_load", "exception load test", cmd_exception_load},
- { "exception_l_illegal", "exception load test", cmd_exception_l_illegal},
- { "exception_store", "exception store test", cmd_exception_store},
- { "exception_inst_illegal", "exception illegal instruction", cmd_exception_illegal_ins},
- /*Stack Command*/
- { "stack_wifi", "Wi-Fi Stack", cmd_stack_wifi},
- /*TCP/IP network test*/
- {"http", "http client download test based on socket", http_test_cmd},
- {"httpc", "http client download test based on RAW TCP", cmd_httpc_test},
然后,全文件查找cli
- fd_console = aos_open("/dev/ttyS0", 0);
- if (fd_console >= 0) {
- printf("Init CLI with event Drivenrn");
- aos_cli_init(0);
- aos_poll_read_fd(fd_console, aos_cli_event_cb_read_get(), (void*)0x12345678);
- _cli_init();
原来命令行有两种模式,一种是直接解码,一种是消息发送或者说事件方式。
以上函数中fd_console应该是默认的,烧录代码的串口吧?
看样子在实现自己的功能代码之前,还得有#include的相关知识。
特别提醒。这点一定注意。如果有相关知识会很顺利学习这个开发板。
如果板子还在我手上的话,也许下一步借助这个板子,先开始一段FreeRTOS
的学习吧。
举报投诉
跃昉科技
66浏览量
1874 -
开发板试用
3文章
301浏览量
2038
有奖丨米尔 瑞芯微RK3576开发板免费试用
米尔与瑞芯微合作发布的新品基于瑞芯微RK3576应用处理器的MYD-LR3576开发板免费试用活动来啦~~米尔提供了7块价值849元的MYD-LR3576开发板发起试用活动您不仅可以免
跃昉科技正式加入openGauss社区
日前,跃昉科技签署CLA(Contribution License Agreement,贡献许可协议),正式加入openGauss社区,致力于推动openGauss RISC-V SIG的发展。
【作品合集】龙芯2K0300蜂鸟开发板试用精选
试用】3 体验四大操作系统(Buildroot、Loongnix、Openharmony、OpenWRT)【龙芯2K0300蜂鸟板试用】
发表于 09-10 18:17
【龙芯2K0300蜂鸟板试用】+龙芯2K0300蜂鸟开发板快速上手
1. 前言
我非常感激社区和官方提供的这次开发板试用机会。这是一个难得的学习和实践的机遇,尤其是在我对于这种新型架构一直抱有浓厚兴趣却未曾深入了解的情况下。我带着一颗好奇和探索的心,准备投身于这个
发表于 08-04 14:19
【PHYTEC AM62x开发板试用】阶段小结
/bsp-yocto-ampliphy-am62x-pd23.2.1/quickstart/index.html手册完成了所有操作,从最初的# Quickstart到最后的# Pre-Built Binaries。根据这段时间的学习经历做一个阶段性的
发表于 07-20 18:09
点击参与米尔NXP i.MX 93开发板有奖试用
米尔与NXP合作发布的新品基于NXPi.MX93应用处理器的MYD-LMX9X开发板免费试用活动来啦~~米尔提供了3块价值678元的MYD-LMX9X开发板发起试用活动您不仅可以免费体
【昉·星光 2 高性能RISC-V单板计算机试用体验】开箱及装载Debian系统
上周收到了昉·星光 2高性能RISC-V单板计算机开发板,在此非常感谢赛昉科技提供的试用机会。开发板
发表于 01-24 00:32
跃昉动态|跃昉科技与友达数位,数字化时代的强强联手
近日,广东跃昉科技有限公司与友达数位科技服务(苏州)有限公司(AUO Digitech,以下简称“友达数位ADT”)正式达成战略合作伙伴关系,携手迈向数字化转型的新时代。
明德扬PCIE开发板系列XILINX-K7试用体验-第二篇
本文为明德扬原创文章,转载请注明出处!作者:Vito 明德扬PCIE开发板系列XILINX-K7试用体验-第二篇 第二周的试用计划是实现常见低速协议(UART,I2C,SPI)的FPG
【涂鸦T2-U开发板试用体验】1、T2-U开发环境搭建及调试
前言
本章介绍T2-U的开发环境搭建流程,以及一些遇到的问题。
一、资料
试用网址:【新品体验】涂鸦 T2-U 开发板免费
发表于 11-25 23:38
