首先需要重点设定以下参数:
- static inline void pwm_set_reload(PWM_Type *pwm_x,uint8_t ex_reload,uint32_t reload)
② 比较值cmp:用于定时器计数时判断计数是否溢出
③ 比较模式mode:用于设定定时器比较模式,有输出比较与输入比较两种
typedef enum pwm_cmp_mode {pwm_cmp_mode_output_compare = 0, /**< output compare*/pwm_cmp_mode_input_capture = 1, /**< input compare*/} pwm_cmp_mode_t;
④ 触发方式更新update_trigger:分为以下四种更新方式:
typedef enum pwm_register_update {pwm_shadow_register_update_on_shlk = 0, /**< after software set shlk bit of shlk register*/pwm_shadow_register_update_on_modify = 1, /**< immediately after the register being modified*/pwm_shadow_register_update_on_hw_event = 2, /**< after hardware event assert*/pwm_shadow_register_update_on_sh_synci = 3, /**< after SHSYNCI assert */} pwm_shadow_register_update_trigger_t;
官方也给出了一个PWM定时器配置的示例,示例如下
void config_pwm(PWM_Type *ptr, uint8_t pin, uint8_t cmp_index, uint32_t reload, bool cmp_initial_zero, uint8_t hw_event_cmp){pwm_cmp_config_t cmp_config = {0};pwm_config_t pwm_config = {0};pwm_stop_counter(ptr);pwm_get_default_pwm_config(ptr, &pwm_config);//复位默认pwm寄存器配置pwm_get_default_cmp_config(ptr, &cmp_config);//复位默认比较寄存器配置pwm_config.enable_output = false;pwm_config.dead_zone_in_half_cycle = 0;//半周期PWM死区设定pwm_config.invert_output = false;//反转输出电平设定pwm_set_reload(ptr, 0, reload);//设置重装载值pwm_set_start_count(ptr, 0, 0);//设置PWM定时器起始值//预配置寄存器信息cmp_config.mode = pwm_cmp_mode_output_compare;//设定PWM定时器比较模式为cmp_config.cmp = cmp_initial_zero ? 0 : reload + 1;//设定比较值cmpcmp_config.update_trigger = pwm_shadow_register_update_on_modify;//更新触发方式为立即更新pwm_config_cmp(ptr, cmp_index, &cmp_config);//PWM配置更新//更新触发器类型,以便在硬件事件(重新加载)时更新比较值cmp_config.update_trigger = pwm_shadow_register_update_on_hw_event;//将pwm配置为cmp驱动的输出if (status_success != pwm_setup_waveform(ptr, pin, &pwm_config, cmp_index, &cmp_config, 1)) {printf("failed to setup waveformn");while(1);}//pwm_setup_waveform设定输出PWM波形//配置硬件事件cmp_config.cmp = reload - 1;cmp_config.update_trigger = pwm_shadow_register_update_on_hw_event;pwm_load_cmp_shadow_on_match(ptr, hw_event_cmp, &cmp_config);//设定影子寄存器}
PWM定时器配置完成后,对定时器中断绑定服务函数及分配相应优先级,并使能开始计数即可完成设定
static inline void pwm_start_counter(PWM_Type *pwm_x)intc_m_enable_irq_with_priority(irq, priority)
使用时如需更新PWM输出状态即占空比,可使用以下函数进行边沿对齐
- pwm_update_raw_cmp_edge_aligned(pwm, pwm_cmp, duty);
以上,加之上篇的GPIO与外部中断的介绍,对于MCU的简单应用暂告一段落,GPIO、外部中断、PWM定时器为MCU最基本的功能,对于体验而言还是比较轻松的,配置起来也不是特别繁琐,主要归功于官方所提供的库函数,使用的流程也与传统的MCU类似。
举报投诉
mcu
146文章
16642浏览量
347589 -
先楫半导体
9文章
214浏览量
1959
有奖提问!先楫半导体HPM6E00系列新品发布会!!
半导体HPM6E00新品预览”的活动,盛况空前。
自此之后一直收到大家的信息,问什么时候能够买到HPM6E00,这不,我们来了~
先楫
发表于 06-20 11:45
先楫半导体 hpm_sdk v1.5.0 正式发布
先楫半导体 hpm_sdk v1.5.0 正式发布!功能升级更强大
版本更新概况
新支持的IDE
IAR Embedded Workbench for RISC-V (测试版本3.20
发表于 04-08 11:14
【先楫HPM5361EVK开发板试用体验】先楫HPM5361EVK开发板初体验
应用。
ZAEGoJjCaNi4379.jpg)
先楫HPM5361EVK开发板的其它照片。
HPM5300EVK提供了一系列
发表于 12-24 22:58
【先楫HPM5361EVK开发板试用体验】1上手HPM5361
在本地存储更多的指令和数据,而不必依赖外部存储器,从而极大地提高了性能。
开发工具安装:上海先楫半导体提供了HPM系列SoC底层驱动软件包,
发表于 11-28 12:18
想找一个先楫半导体的HPM6750 使用linux剪裁操作系统的例程
想找一个先楫半导体的HPM6750 使用linux剪裁操作系统的例程,SDK里给了FREERT的,没有LINUX的。哪里可以下载的到?
发表于 10-25 16:18
【新品体验】先楫HPM5361EVK开发板免费试用
形式:标题格式 【先楫HPM5361EVK开发板试用体验】+自拟标题 ;视频演示可分为:应用演示视频、调试演示视频。
3、
发表于 10-20 11:30
