![](https://www.banana-pi.org/web/userfiles/picture/Banana%20Pi%20BPI-R2%20Pro%20ban%20.jpg)
Banana Pi BPI-R2 Pro 开源路由器采用Rockchip RK3568芯片方案设计, 板载2GB LPDDR4内存和16GB eMMC存储,支持2个USB 3.0接口,5千兆网口。M.2 Key-e和mini PCIe接口,2 mipi DSI接口(可通过软件切换LVDS), 1个CSI摄像头接口,1个HDMI输出.支持Android,Linux,OpenWRT系统
BPI-R2 Pro 尺寸接口与
,可以使用 BPI-R2 外壳.
BPI-R2 Pro 硬件接口示意图:
![](https://www.banana-pi.org/web/userfiles/product/Banana%20Pi%20BPI-R2%20Pro%20interface.jpg)
硬件规格:
Banana Pi R2 Pro | |
CPU | Rockchip RK3568 Quad-core ARM Cortex-A55 CPU 2GHz |
GPU | Mali-G52 1-Core-2EE OpenGL ES3.2 Vu1kn 1.1 OpenCL 2.0 |
Memory | 2G DDR3 SDRAM (option 4G) |
Storage | Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port,SPI flash |
Network | 5 x 10/100/1000 Mbit/s Ethernet |
Display(s) | 1 HDMI port, 2 DSI interface(1 DSI can change to LVDS by software) |
Camera | 1 CSI camera interfact |
Video decoder(s) | H.265 HEVC/MVC Main10 Profileyuv420@L5.1up to4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to4096x2304@60fps |
Video encoder(s) | H.264/AVC BP/MP/HP@level4.2,up to1920x1080@100fps, H.265/HEVCMP@level4.1, up to1920x1080@100fps(4096x4096@10fpswith TILE) |
Audio Output(s) | HDMI & I2S & Speaker & Headphone |
USB port | USB 3.0 PORT (x2), micro USB OTG (x1) |
mini PCIE | 1 mini pcie interface & 1 M.2 key-e interface |
Remote | IR Receiver (x1) |
GPIO | 40 Pin Header: GPIO (x28) and Power (+5V, +3.3V and GND). Some of I/O Pin can be used for specific functions as UART, I2C, SPI or PWM |
Switches | Reset button, Power button, U-boot button |
LED | Power Status and 8P8C |
Power Source | 12 volt @2A via DC Power and/or Micro USB (OTG) |
Size & Weight | 148mm × 100.5mm 100g |
OS | OpenWRT, Linux and others OS |
Online wiki development documents:https://wiki.banana-pi.org/Banana_Pi_BPI-R2_Pro
举报投诉
ARM
134文章
8737浏览量
363331 -
嵌入式开发
18文章
989浏览量
47152 -
开发板
25文章
4606浏览量
95120 -
工业控制
36文章
1354浏览量
85565
致远电子的RK3568J开发板可以烧录其他的固件吗
各位大神,现手上有一块致远电子的瑞芯微RK3568J的开发板,由于没有源码,在其他地方下载的Android 11源码,可以烧录进去吗?
发表于 02-01 10:30
toybrick_RK3568X开发板:瑞芯微 SDK 编译 android 过程
toybrick_RK3568X开发板编译android 命令如下:
source build/envsetup.sh
lunch rk3568_r-userdebug
./build.sh
发表于 11-17 23:40
标准系统:扬帆系列“竞”开发板(RK3568)
开发板名称(芯片型号)
扬帆系列“竞”开发板(RK3568)
芯片架构
Cortex-A55
CPU频率
2.0GHz
介绍(字数请控制在2
发表于 10-19 10:39
![](https://file1.elecfans.com/web2/M00/A4/B6/wKgaomUEGdCAKN-AAASKblfwztE930.png)
香蕉派BPI-R3开源路由器开发板采用联发科MT7986四核 ARMA53 + MT7531A芯片设计
香蕉派BPI-R3开源路由器开发板采用联发科MT7986 (Filogic 830)四核 ARM
![<b class='flag-5'>香蕉</b>派<b class='flag-5'>BPI</b>-R3<b class='flag-5'>开源</b><b class='flag-5'>路由器</b><b class='flag-5'>开发板</b><b class='flag-5'>采用</b>联发科MT7986四核 ARMA53 + MT7531A<b class='flag-5'>芯片</b>设计](https://file.elecfans.com/web2/M00/68/0F/pYYBAGMYSviAMQYiAAFCbzTdW6c600.jpg)
Banana Pi BPI-Wifi6开源路由器,创耀科技方案可以自已DIY尽情折腾
香蕉派BPI-Wifi6路由器设计采用了创耀科技TR6560 + TR5220 wifi无线芯片
发表于 08-21 16:31
Banana Pi BPI-KVM – 基于 Rockchip RK3568 SoC 的 KVM over IP 解决方案
Banana Pi 已经开始开发基于 Rockchip RK3568 SoC 的 BPI-KVM 盒,但它不是迷你 PC,而是 KVM over IP 解决
发表于 07-29 12:37
基于Rockchip RK3568 SoC的KVM over IP解决方案
