2. 使用 RASC 生成 Keil 工程
jf_92517703 来源:jf_92517703 作者:jf_92517703 2022-12-05 09:57 次阅读
1.新建一个一个工作空间文件夹
2.创建一个工程
2.1
2.2
2.3 选择 FSP 库版本、板子型号、设备(MCU)型号、编程语言、编译器
2.4
2.5
2.6
2.7
2.8 代码生成
2.9 代码生成结果
2.10 通过MDK 打卡RASC配置软件
2.11
LED硬件信息
3.1 LED
3.2 RASC 配置gpio
属性说明:
生成代码
软件编写
软件入口函数
void hal_entry(void)
led 闪烁函数
    /* TODO: add your own code here */
	//初始化io
	R_IOPORT_Open (&g_ioport_ctrl, g_ioport.p_cfg);
	while(1)
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_04, BSP_IO_LEVEL_LOW);
		R_BSP_SoftwareDelay(100, BSP_DELAY_UNITS_MILLISECONDS); //延时 100毫秒
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_04, BSP_IO_LEVEL_HIGH);
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_05, BSP_IO_LEVEL_LOW);
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_05, BSP_IO_LEVEL_HIGH);
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_15, BSP_IO_LEVEL_LOW);
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_15, BSP_IO_LEVEL_HIGH);
#if BSP_TZ_SECURE_BUILD
    /* Enter non-secure code */
    R_BSP_NonSecureEnter();
#endif
系统延时函数
void R_BSP_SoftwareDelay (uint32_t delay, bsp_delay_units_t units)
delay:时间数量
units:时间单位
可选的时间单位
```c
typedef enum
    BSP_DELAY_UNITS_SECONDS      = 1000000, ///< Requested delay amount is in seconds
    BSP_DELAY_UNITS_MILLISECONDS = 1000,    ///< Requested delay amount is in milliseconds
    BSP_DELAY_UNITS_MICROSECONDS = 1        ///< Requested delay amount is in microseconds
} bsp_delay_units_t;
gpio相关的函数
fsp_err_t R_IOPORT_Open(ioport_ctrl_t * const p_ctrl, const ioport_cfg_t * p_cfg);
fsp_err_t R_IOPORT_Close(ioport_ctrl_t * const p_ctrl);
fsp_err_t R_IOPORT_PinsCfg(ioport_ctrl_t * const p_ctrl, const ioport_cfg_t * p_cfg);
fsp_err_t R_IOPORT_PinCfg(ioport_ctrl_t * const p_ctrl, bsp_io_port_pin_t pin, uint32_t cfg);
fsp_err_t R_IOPORT_PinEventInputRead(ioport_ctrl_t * const p_ctrl, bsp_io_port_pin_t pin, bsp_io_level_t * p_pin_event);
fsp_err_t R_IOPORT_PinEventOutputWrite(ioport_ctrl_t * const p_ctrl, bsp_io_port_pin_t pin, bsp_io_level_t pin_value);
fsp_err_t R_IOPORT_PinRead(ioport_ctrl_t * const p_ctrl, bsp_io_port_pin_t pin, bsp_io_level_t * p_pin_value);
fsp_err_t R_IOPORT_PinWrite(ioport_ctrl_t * const p_ctrl, bsp_io_port_pin_t pin, bsp_io_level_t level);
fsp_err_t R_IOPORT_PortDirectionSet(ioport_ctrl_t * const p_ctrl,
                                    bsp_io_port_t         port,
                                    ioport_size_t         direction_values,
                                    ioport_size_t         mask);
fsp_err_t R_IOPORT_PortEventInputRead(ioport_ctrl_t * const p_ctrl, bsp_io_port_t port, ioport_size_t * event_data);
fsp_err_t R_IOPORT_PortEventOutputWrite(ioport_ctrl_t * const p_ctrl,
                                        bsp_io_port_t         port,
                                        ioport_size_t         event_data,
                                        ioport_size_t         mask_value);
fsp_err_t R_IOPORT_PortRead(ioport_ctrl_t * const p_ctrl, bsp_io_port_t port, ioport_size_t * p_port_value);
fsp_err_t R_IOPORT_PortWrite(ioport_ctrl_t * const p_ctrl, bsp_io_port_t port, ioport_size_t value, ioport_size_t mask);
审核编辑 黄昊宇
  • keil
    【RA-Eco-RA4E2-64PIN-V1.0开发板试用】开箱+Keil环境搭建+点灯+点亮OLED
    Configurator)软件进行 Keil 工程生成和芯片功能配置(类似 STM32 的 MX 软件功能) RASC 软件安装包 800M+,安装完占用超过
    发表于 12-19 23:52
    【RA-Eco-RA4E2-64PIN-V1.0开发板试用】+初次见面+MDK生成代码+点灯
    :Arm Keil | Renesas RA_DFP 2、下载官方 RA 智能配置(RASC)安装程序 (FSP 软件包,可与 IAR Embedded Workbench、Arm Keil
    发表于 12-15 21:55
    【RA-Eco-RA4E2-64PIN-V1.0开发板试用】MDK新建工程
    安装。 2.RASC 软件安装完成之后,还需要将 RASC 软件集成到 Keil 软件上面 3.新建工程 使用 RASC 自动
    发表于 12-14 18:23
    Keil详细安装教程(同时兼容51与STM32)
    红色部分,点击操作。 2. 选择安装路径,选择第一步创建的keil_c51 文件夹 3. 自定义信息,随便写 4. 安装完后,结束安装 2) 安装arm 版keil 安装包以MDK 开
    的头像 发表于 11-26 11:26 1906次阅读
    <b class='flag-5'>Keil</b>详细安装教程(同时兼容51与STM32)
    【RA-Eco-RA0E1-32PIN-V1.0开发板试用】使用 RASC 建立 Keil 工程、烧录测试
    Content 生成工程文件。 Keil IDE 编译 回到工程所在文件夹,可见此时已生成 Keil
    发表于 11-09 12:52
    STM32 demko板生成KEIL工程编译出错是什么原因导致的?
    最近刚开始用STM32MotorControl Workbench 5.0.3STM32CubeMX4.25KEIL 生成工程编译总是出错,出错总跟MCSDK_v5.0.3文件有关,不知哪里引起,哪位帮我看看,谢谢!
    发表于 04-26 07:03
    KEIL编译Workbench生成工程之后报错的原因?
    KEIL编译Workbench生成工程之后报错误 这是啥问题
    发表于 04-25 08:03
    关于使用keil工具遇到的几个疑问求解
    Cortex-M0+”来绑定了cpu类型。这样如果在另一个工程,其cpu 为 Cortex-M4就会链接报错。不知有什么办法能绕过去? 2.Keil里,能不能在一个工程里,同时
    发表于 04-23 07:43
    STM32无法生成keil工程一直提示缺少固件更新是怎么回事?如何解决?
    打开之前的工程是可以的,但是创建新的工程就不可以,无法生成keil工程,型号,固件库也找之前的电脑拷贝下来,放进去了,依然不行,依旧提示更新
    发表于 04-17 08:28
    求助,CubeMX5.4生成不了keil工程吗?
    还有个5.3的版本就可以生成keil。5.4的就会报错
    发表于 04-17 08:08
    STM32F429+CUBEMX6.6.1+KEIL5.31生成工程跑不了是为什么?
    STM32F429+CUBEMX6.6.1+KEIL5.31,生成工程跑不了(简单的IO操作),换成低版本的CUBEMX貌似才行,哪里的原因?
    发表于 03-25 06:12
    stm32cubemx生成不了keil工程的原因?
    发表于 03-21 06:00
    STM32CUBE生成工程如何进行KEIL的软件仿真?
    通过STM32CUBE生成工程如何进行KEIL的软件仿真有异常,做了很多的尝试,没能成功 1、根据网上的资料,进行魔术棒的相关修改,如下图 2、能顺利进入仿真界面,但是全速仿真,不
    发表于 03-13 06:04
    keil-mdk使用Env配合生成工程,每次使用Env更新工程后,该项都会被重置的原因?
    我现在使用的IDE是keil-mdk,然后使用Env配合生成工程。 问题是: 在keil开发中经常会用到工程项管理,如下图。每次使用Env更
    发表于 03-01 07:01
    KEIL5如何打开KEIL4的GD工程
    GD官方提供的很多KEIL例程为KIEL4的版本,读者使用的时候可能会碰到使用KEIL5打开KEIL4的工程会报错以及无法找到芯片选型的问题
    的头像 发表于 01-11 09:43 895次阅读
    <b class='flag-5'>KEIL</b>5如何打开<b class='flag-5'>KEIL</b>4的GD<b class='flag-5'>工程</b>
