无线wifi AC/AP实验不熟悉,一篇文章教你如何使用华为eNSP模拟!
网络技术干货圈 来源:网络技术干货圈 作者:圈圈 2022-12-06 09:08 次阅读
1.配置出口路由器/核心交换机/AC的IP地址、端口
配置出口路由器的接口
sys
[AR]intg0/0/0
[AR-GigabitEthernet0/0/0]ipad10.0.0.224
配置AC
sys
[AC1]vlanbatch10
[AC1]intvlanif10
[AC1-Vlanif10]ipad172.16.1.224#与核心交换机直连的IP地址
[AC1-Vlanif10]intg0/0/1
[AC1-GigabitEthernet0/0/1]portlink-typetrunk
[AC1-GigabitEthernet0/0/1]porttrunkallow-passvlanall
配置核心交换机
[LSW1]vlanbatch510#创建vlan5和10
[LSW1]intvlanif1
[LSW1-Vlanif1]ipad10.0.0.124#与路由器直连的IP地址
[LSW1-Vlanif1]intvlanif5
[LSW1-Vlanif5]ipad192.168.0.124#AP的网关地址,稍后要用到
[LSW1-Vlanif5]intvlanif10
[LSW1-Vlanif10]ipad172.16.1.124#与AC直连的地址
[LSW1-Vlanif10]intg0/0/4
[LSW1-GigabitEthernet0/0/4]portlink-typetrunk
[LSW1-GigabitEthernet0/0/4]porttrunkallow-passvlanall
2.配置AC/出口路由器的路由,使其能相互通信
AC的静态路由
[AC1]iproute-static0.0.0.00172.16.1.1
出口路由器的静态路由
[AR]iproute-static0.0.0.0010.0.0.1
在AC上ping一下路由器,测试网络是否联通:
ping10.0.0.2
PING10.0.0.2:56databytes,pressCTRL_Ctobreak
Replyfrom10.0.0.2:bytes=56Sequence=1ttl=254time=60ms
Replyfrom10.0.0.2:bytes=56Sequence=2ttl=254time=30ms
Replyfrom10.0.0.2:bytes=56Sequence=3ttl=254time=40ms
Replyfrom10.0.0.2:bytes=56Sequence=4ttl=254time=40ms
Replyfrom10.0.0.2:bytes=56Sequence=5ttl=254time=50ms
确认无误再进行下一步
3.配置核心交换机DHCP,使其能分配IP地址给AP
配置与AP相连的端口
[LSW1]port-groupgroup-memberg0/0/1tog0/0/3#端口组
[LSW1-port-group]portlink-typetrunk
[LSW1-port-group]porttrunkallow-passvlanall
[LSW1-port-group]porttrunkpvidvlan5
[LSW1-port-group]quit
配置DHCP地址池
[LSW1]dhcpenable#使能DHCP
[LSW1]ippoolvlan5#创建地址池
[LSW1-ip-pool-vlan5]network192.168.0.0mask24#配置要分配的网段
[LSW1-ip-pool-vlan5]gateway-list192.168.0.1#配置要分配的网关地址
[LSW1-ip-pool-vlan5]option43sub-option3ascii172.16.1.2#将AC的IP地址下发给AP
[LSW1-ip-pool-vlan5]quit
[LSW1]intvlanif5
[LSW1-Vlanif5]dhcpselectglobal#在接口上下发IP地址
看看AP的地址有没有上来
disipintbri
InterfaceIPAddress/MaskPhysicalProtocol
NULL0unassignedupup(s)
Vlanif1192.168.0.252/24upup
ping一下AC看看通不通
ping172.16.1.2
PING172.16.1.2:56databytes,pressCTRL_Ctobreak
Replyfrom172.16.1.2:bytes=56Sequence=1ttl=254time=30ms
Replyfrom172.16.1.2:bytes=56Sequence=2ttl=254time=20ms
Replyfrom172.16.1.2:bytes=56Sequence=3ttl=254time=10ms
Replyfrom172.16.1.2:bytes=56Sequence=4ttl=254time=20ms
Replyfrom172.16.1.2:bytes=56Sequence=5ttl=254time=40ms
确认无误,进行下一步
4.注册AP
以下配置,可能会弹出的警告,都选Y就行
指定capwap协议的信令源地址
[AC1]capwapsourceinterfaceVlanif10
[AC1]wlan#进入wlan视图
[AC1-wlan-view]apauth-modemac-auth#配置AC的验证方式为MAC验证
创建域配置并配置国家码,使AP的射频特性符合国家的法律法规要求
[AC1-wlan-view]regulatory-domain-profilenameCN#创建域配置
[AC1-wlan-regulate-domain-CN]country-codeCN#国家码:中国
[AC1-wlan-regulate-domain-CN]quit
创建AP-group
[AC1-wlan-view]ap-groupnameguest#创建guest组
[AC1-wlan-ap-group-guest]regulatory-domain-profileCN#关联刚才的域配置
[AC1-wlan-ap-group-guest]quit
[AC1-wlan-ap-group-work]ap-groupnamework#创建work组
[AC1-wlan-ap-group-work]regulatory-domain-profileCN#关联刚才的域配置
[AC1-wlan-ap-group-work]quit
基于mac地址注册AP
[AC1-wlan-view]ap-id1ap-mac00e0-fc61-3600#加入AP。mac地址可以通过查看核心交换机的mac地址表,或者右键AP打开设置查看
[AC1-wlan-ap-1]ap-nameguest1#将AP名字更改为guest1
[AC1-wlan-ap-1]ap-groupguest#将AP加入刚才配置的guest组
[AC1-wlan-ap-1]quit
[AC1-wlan-view]ap-id2ap-mac00e0-fc56-18b0
[AC1-wlan-ap-1]ap-nameguest2
[AC1-wlan-ap-1]quit
[AC1-wlan-view]ap-id3ap-mac00e0-fce3-7a10
[AC1-wlan-ap-1]ap-namework1
[AC1-wlan-ap-1]ap-groupwork
[AC1-wlan-ap-1]quit
到此处AP会自动重启,且AP名字会被更改(如果没有自动重启,可以自己手动重启)
重启完在AC上查看AP是否注册成功:
[AC1-wlan-view]displayapall
Info:Thisoperationmaytakeafewseconds.Pleasewaitforamoment.done.
TotalAPinformation:
nor:normal[1]
IDMACNameGroupIPTypeStateSTAUptime
100e0-fc61-3600guest1guest192.168.0.252AP9131DNnor01M:3S
200e0-fc56-18b0guest2guest--idle0-
300e0-fce3-7a10work1work--idle0-
Total:1
可以看到state为nor,说明注册成功;余下两台设备显示为idle,说明注册失败(只是因为我还没重启,想给大家看看没注册成功的状态)
等三台设备全部上线,确认无误再进行下一步
5.分配无线参数
[AC1]vlanpoolsta-pool101#新建vlan地址池,名称为sta-pool101
[AC1-vlan-pool-sta-pool101]vlan101
[AC1-vlan-pool-sta-pool101]quit
[AC1]vlanpoolsta-pool102
[AC1-vlan-pool-sta-pool102]vlan102
[AC1-vlan-pool-sta-pool102]quit
安全配置(WIFI密码)
[AC1]wlan
[AC1-wlan-view]security-profilenameguest#新建安全配置,名称为guest
[AC1-wlan-sec-prof-guest]securitywpa2pskpass-phrasea12345678aes#配置加密方式为wpa2-psk,aes密文存放
[AC1-wlan-sec-prof-guest]quit
[AC1-wlan-view]security-profilenamework
[AC1-wlan-sec-prof-work]securitywpa2pskpass-phrasea12345678aes
[AC1-wlan-sec-prof-work]quit
SSID配置(WIFI名称)
[AC1-wlan-view]ssid-profilenameguest#新建SSID配置,名称为guest
[AC1-wlan-ssid-prof-guest]ssidguest#配置SSID名为guest
[AC1-wlan-ssid-prof-guest]quit
[AC1-wlan-view]ssid-profilenamework
[AC1-wlan-ssid-prof-work]ssidwork
[AC1-wlan-ssid-prof-work]quit
虚拟接入点(vpa)配置
[AC1-wlan-view]vap-profilenameguest#新建vap配置,名称为guest
[AC1-wlan-vap-prof-guest]service-vlanvlan-poolsta-pool101#应用vlan地址池
[AC1-wlan-vap-prof-guest]security-profileguest#应用安全配置
[AC1-wlan-vap-prof-guest]ssid-profileguest#应用SSID
[AC1-wlan-vap-prof-guest]quit
[AC1-wlan-view]vap-profilenamework
[AC1-wlan-vap-prof-work]service-vlanvlan-poolsta-pool102
[AC1-wlan-vap-prof-work]security-profilework
[AC1-wlan-vap-prof-work]ssid-profilework
[AC1-wlan-vap-prof-work]quit
开启无线电信号
[AC1-wlan-ap-group-guest]vap-profileguestwlan1radio0#应用虚拟接入点配置,wlanid为1,radio0意思是使用2.4GHz的频段
[AC1-wlan-ap-group-guest]vap-profileguestwlan1radio1#配置双射频,radio1=5GHz
[AC1-wlan-view]ap-groupnamework
[AC1-wlan-ap-group-work]vap-profileworkwlan1radio0
[AC1-wlan-ap-group-work]vap-profileworkwlan1radio1
6.配置客户端使用的地址池,结束。检验配置成果。
配置核心交换机
[LSW1]vlanbatch101102
[LSW1]ippool101
[LSW1-ip-pool-101]network192.168.10.0mask24
[LSW1-ip-pool-101]gateway-list192.168.10.1
[LSW1-ip-pool-101]quit
[LSW1]ippool102
[LSW1-ip-pool-102]network192.168.20.0mask24
[LSW1-ip-pool-102]gateway-list192.168.20.1
[LSW1-ip-pool-102]quit
[LSW1]intvlanif101
[LSW1-Vlanif101]ipad192.168.10.124
[LSW1-Vlanif101]dhcpselectglobal
[LSW1]intvlanif102
[LSW1-Vlanif102]ipad192.168.20.124
[LSW1-Vlanif102]dhcpselectglobal
在终端设备连接AP,并输入密码
然后测试一下网络连通性:
STA>ipconfig
LinklocalIPv6address...........:::
IPv6address......................:::/128
IPv6gateway......................:::
IPv4address......................:192.168.10.254
Subnetmask.......................:255.255.255.0
Gateway...........................:192.168.10.1
Physicaladdress..................:54-89-98-F0-37-1A
DNSserver........................:
以上可以看到终端自动获取的IP地址信息是正确的
再ping一下出口路由器和AC:
STA>ping10.0.0.2
Ping10.0.0.2:32databytes,PressCtrl_Ctobreak
From10.0.0.2:bytes=32seq=1ttl=254time=219ms
From10.0.0.2:bytes=32seq=2ttl=254time=282ms
From10.0.0.2:bytes=32seq=3ttl=254time=203ms
From10.0.0.2:bytes=32seq=4ttl=254time=204ms
From10.0.0.2:bytes=32seq=5ttl=254time=218ms
STA>ping172.16.1.2
Ping172.16.1.2:32databytes,PressCtrl_Ctobreak
From172.16.1.2:bytes=32seq=1ttl=254time=266ms
From172.16.1.2:bytes=32seq=2ttl=254time=218ms
From172.16.1.2:bytes=32seq=3ttl=254time=203ms
From172.16.1.2:bytes=32seq=4ttl=254time=266ms
From172.16.1.2:bytes=32seq=5ttl=254time=203ms
审核编辑:汤梓红
  • 华为
  • 交换机
  • 路由器
  • WIFI
原文标题:无线wifi AC/AP实验不熟悉,一篇文章教你如何使用华为eNSP模拟!
文章出处:【微信号:网络技术干货圈,微信公众号:网络技术干货圈】欢迎添加关注!文章转载请注明出处。
    无线APAC之间的各种问题
    无线网络搭建中,都说AP+AC的组网模式最现在最先进的,但是在使用过程中还是存在些问题,下面这些有没有大家碰到的呢?这里依照专业无线AP
    发表于 09-08 16:30
    eNSP使用和实验教程详解
    eNSP使用和实验教程详解
    发表于 09-11 08:31 28次下载
    <b class='flag-5'>eNSP</b>使用和<b class='flag-5'>实验</b>教程详解
    高速率WiFi模块SKW78 802.11ac AP WiFi
    高速率WiFi模块SKW78 802.11ac AP WiFi模块
    发表于 09-27 13:06 10次下载
    AC+AP-BRAS组网方式 校园WIFI组网
    发表于 10-23 09:49 15次下载
    不熟悉的领域,将怎样进行数据分析
    如何在不熟悉的领域开展数据分析工作。
    的头像 发表于 06-05 11:48 2841次阅读
    eNSP华为模拟器软件安装指南
    eNSP华为模拟器软件安装指南
    发表于 08-20 17:47 4次下载
    11ac AP WiFi模块SKW78千兆WiFi 4MIMO
    11ac AP WiFi模块SKW78千兆WiFi 4MIMO(电源技术期刊小木虫)-11ac AP
    发表于 09-22 11:29 27次下载
    11<b class='flag-5'>ac</b> <b class='flag-5'>AP</b> <b class='flag-5'>WiFi</b>模块SKW78千兆<b class='flag-5'>WiFi</b> 4MIMO
    缺乏设计布局经验,不熟悉制造工艺的工程师,别错过华秋的研讨会
    电子产品研发工程师,特别是硬件开发人员,普遍存在对制造工艺要求不熟悉,可制造性概念比较模糊。还有不少工程师们在设计PCB时,很想使用自动布线。通常,纯数字的电路板采用自动布线是没有问题的。但是,在
    的头像 发表于 08-19 15:33 889次阅读
    缺乏设计布局经验,<b class='flag-5'>不熟悉</b>制造工艺的工程师,别错过华秋的研讨会
    2分钟快速教你如何在华为模拟ensp上进行抓包?
    的头像 发表于 12-05 11:25 4694次阅读
    华为新版模拟eNSP Lite安装攻略
    最近华为发布了新版模拟eNSP Lite的产品手册,根据产品手册描述,新版模拟eNSP Lite基于云端发布,所以安装和登录新版
    的头像 发表于 05-17 10:25 7426次阅读
    <b class='flag-5'>华为</b>新版<b class='flag-5'>模拟</b>器<b class='flag-5'>eNSP</b> Lite安装攻略
    华为新版模拟eNSP Lite
    同时eNSP Lite在保留旧版模拟eNSP操作界面的基本功能的基础上,也增加了新的功能,比如tcpdump功能,这个功能可以替代wireshark,完成对报文的抓取和分析。根据手册整理,下面从登录、创建沙箱、设备基本操作三部
    的头像 发表于 05-19 14:58 6134次阅读
    缺乏设计布局经验,不熟悉制造工艺的工程师,别错过华秋这场研讨会
    的头像 发表于 08-19 15:40 840次阅读
    缺乏设计布局经验,<b class='flag-5'>不熟悉</b>制造工艺的工程师,别错过华秋这场研讨会
    【PCB研讨会】缺乏设计布局经验,不熟悉制造工艺的工程师看过来!
    的头像 发表于 08-23 10:41 625次阅读
    【PCB研讨会】缺乏设计布局经验,<b class='flag-5'>不熟悉</b>制造工艺的工程师看过来!
    华为eNSP模拟器安装教程
    华为eNSP模拟器安装教程
    的头像 发表于 08-11 10:57 3158次阅读
    <b class='flag-5'>华为</b><b class='flag-5'>eNSP</b><b class='flag-5'>模拟</b>器安装教程
    华为ensp模拟器vlan配置命令
    华为eNSP(Enterprise Network Simulation Platform)是华为公司开发的款网络模拟器软件,可以
    的头像 发表于 12-08 14:04 4836次阅读
