观海微GH8555BL Datasheet及应用介绍
GH8555BL支持HD 800分辨率驱动IC。
GH8555BL 设计可驱动 α-Si、LTPS&IGZO TFT 点阵 LCD,最高可支持分辨率:800RGBx2046 。
Single chip solution for a WXGA α-Si type LCD display Resolution:
800 x LN*2
768 x LN*2
750 x LN*2
720 x LN*2
640 x LN*2
600 x LN*2
显示颜色模式Display color modes
Full color mode:
16.7M colors (24-bit 8(R):8(G):8(B))
显示界面Display Interface
1. MIPI-DSI (Display Serial Interface) interface.
2. Support DSI Version 1.1
3.Support D-PHY Version 1.0
输入电压范围Input voltage ranges
1. I/O and interface power supply (VDDI): 1.65V to 3.6V
2. High speed interface power supply (VDDM): 1.65V to 3.6V
3. Analog voltage range for VSP to VSS: 4.3V ~ 6.5V
4. Analog voltage range for VSN to VSS: -4.3V ~ -6.5V
5. Analog voltage range for VGH to VSS: 6.2V ~ 19.6V
6. Analog voltage range for VGL to VSS: -7V ~ -16V
输出电压范围(开模块直流/直流转换器)Output voltage ranges(On module DC/DC converter)
1. Positive source output voltage level: VSPR= +4.0V to 5.5V
2. Negative source output voltage level: VSNR= -4.0V to -5.5V
3. Positive gate driver output voltage level: VGH= 7 to 19.6V
4. Negative gate driver output voltage level: VGL=-7V to -16V
5. VCOM=-0.3V to -4V, a step=10mv
Miscellaneous of chip
1. Internal level shifter for Gate Driver control
2. Supports column / 1-dot /1+2-dot / 2-dot / 4-dot / 8-dot/ 3-dot
3. Gamma correction (1 preset gamma curve)
4. Internal Oscillator generation
5. CMOS compatible inputs
6. Proprietary multi-phase driving for lower power consumption
7. On-chip OTP program voltage generator
8. OTP memory to store initialization register settings
3 times OTP for Gamma setting
2 times OTP for VCOM setting
4 times OTP for ID setting
9. Support BIST mode
10. Support scaler-source/gate
11. Temperature range: -40 to +85
12. Chip size(including scribe line):27450um×880um
13. Bump high:9um
目前部分LCD匹配如下:
芯片
457文章
51345浏览量
428268 -
IC
36文章
5990浏览量
176420
采用fpga控制ADS8555进行采样,对某一通道输入正弦信号时,采样的结果却是方波,为什么?
使用FPGA控制ads8555进行采样,采样的信号要么为最低要么为最高,问题出在了哪里?
用FPGA进行控制两片8555进行采样,输出的DB【15:0】一直为高是怎么回事 ?
ADS8555 busy信号响应正常,但数据全为0是怎么回事?
DAC8565和dac8555的管脚是pin对pin的,两者能直接相互替换吗?
DAC8555各通道之间的输出误差较大,为什么?
ADS8555每转换一次,ADC输出值会涨高一点,直到满0x7FFF,为什么?
BAT32G127GH32FP、BAT32G127GH40NB 主频32MHz超低功耗 中微单片机
DAC8555四通道、电压输出数模转换器(DAC)数据表
![DAC<b class='flag-5'>8555</b>四通道、电压输出数模转换器(DAC)数据表](https://file.elecfans.com/web1/M00/D9/4E/pIYBAF_1ac2Ac0EEAABDkS1IP1s689.png)
