当按下和释放微动按键时,会由短时间的抖动现象才会到达想要的状态。如下图所示:
从上图可知。按键抖动时间大概为150us。
在一些对按键抖动敏感的情况下需要进行消抖设计,目前常见的消抖设计如下:
滤波电容
关于去抖硬件最简单的方式并联一颗100nF陶瓷电容,进行滤波处理。
RC滤波+施密特触发器
要想更严谨设计消抖电路,会增加施密特触发器,更大程度的保证后端不受按键抖动影响,电路如下:
分别来看按键闭合断开时电路状态:
开关打开时:
电容C1通过R1 D1回路充电,Vb电压=Vcc-0.7为高电平,后通过反向施密特触发器使Vout输出为低。
开关闭合时:
电容C1通过R2进行放电,最后Vb电压变为0,通过反向施密特触发器使Vout输出为高。
当按下按键出现快速抖动现象时,通过电容会使Vb点电压快速变成Vcc或GND。在抖动过程时对电容会有轻微的充电或放电,但后端的施密特触发器有迟滞效果不会导致Vout发现抖动现象。
此电路中D1的使用使为了限制R1 R2一起给C1供电,增加充电时间影响效果。如果减小R1的值会使电流增加,功耗较高。
专用消抖芯片
一些厂家会提供专用芯片,避免自搭电路的不稳定性, 如美信-Max6816:
软件滤波
软件消除抖动也是很常见的方式,一般形式是延时查询按键状态或者中断形式来消除抖动。
下面是Arduino的软件消抖代码:
/* SoftwareDebounce
* At each transition from LOW to HIGH or from HIGH to LOW
* the input signal is debounced by sampling across
* multiple reads over several milli seconds. The input
* is not considered HIGH or LOW until the input signal
* has been sampled for at least "debounce_count" (10)
* milliseconds in the new state.
* Notes:
* Adjust debounce_count to reflect the timescale
* over which the input signal may bounce before
* becoming steady state
* Based on:
* http://www.arduino.cc/en/Tutorial/Debounce
* Jon Schlueter
* 30 December 2008
* http://playground.arduino.cc/Learning/SoftwareDebounce
int inPin = 7; // the number of the input pin
int outPin = 13; // the number of the output pin
int counter = 0; // how many times we have seen new value
int reading; // the current value read from the input pin
int current_state = LOW; // the debounced input value
// the following variable is a long because the time, measured in milliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was sampled
int debounce_count = 10; // number of millis/samples to consider before declaring a debounced input
void setup()
pinMode(inPin, INPUT);
pinMode(outPin, OUTPUT);
digitalWrite(outPin, current_state); // setup the Output LED for initial state
void loop()
// If we have gone on to the next millisecond
if(millis() != time)
reading = digitalRead(inPin);
if(reading == current_state && counter > 0)
counter--;
if(reading != current_state)
counter++;
// If the Input has shown the same value for long enough let's switch it
if(counter >= debounce_count)
counter = 0;
current_state = reading;
time = millis();
审核编辑:汤梓红
开关
19文章
3016浏览量
92894 -
滤波电容
8文章
440浏览量
39823 -
抖动
1文章
66浏览量
18784 -
按键
4文章
221浏览量
57417
原文标题:开关抖动及消除
文章出处:【微信号:mcu168,微信公众号:硬件攻城狮】欢迎添加关注!文章转载请注明出处。
