2. 接收模块 (uart_rx):
module uart_rx (
clk_40k, //clock signal, 40kHz
rst_n, //reset signal, active low
bit_in, //the input serial bit,
dout_vld,//the output valid signal, active high,the dout is valid when this signal is high.
dout //received data, 8 bit width
input bit_in;
input clk_40k;
input rst_n;
output reg dout_vld;
output reg [7:0] dout;
reg rx_flag;
reg [6:0] cnt;
reg [5:0] rx_cnt;
reg [7:0] dout_temp;
//rx_flag: 接收过程rx_flag始终拉高
always @ (posedge clk_40k)
begin
if(~rst_n)
rx_flag <= 1'b0;
else if(bit_in == 1'b0)
rx_flag <= 1'b1;
else if(rx_cnt == 6'd9)
rx_flag <= 1'b0;
end
//cnt: 接收数据计数,clk_40k分频至1k波特率对接收数据进行计数
begin
if(~rst_n)
cnt <= 7'b0;
else if(rx_flag == 1'b1 && cnt != 7'd39)
cnt <= cnt + 1'b1;
else if(rx_flag == 1'b0 || cnt == 7'd39)
cnt <= 7'b0;
end
begin
if(~rst_n)
rx_cnt <= 6'b0;
else if(rx_flag == 1'b1 && cnt == 7'd39)
rx_cnt <= rx_cnt + 1'b1;
else if(rx_flag == 1'b0)
rx_cnt <= 6'b0;
end
//dout_temp: 将串行接收数据转换还原为8bit数据
begin
if(~rst_n)
dout_temp <= 8'b0;
begin
dout_temp[7] <= bit_in;
dout_temp[6:0] <= dout_temp[7:1];
end
end
//dout_vld: 传输完成标识,8bit数据传输结束拉高
begin
if(~rst_n)
dout_vld <= 1'b0;
else if(rx_cnt == 6'd9 && cnt == 7'b0)
begin
dout <= dout_temp;
dout_vld <= 1'b1;
end
else
dout_vld <= 1'b0;
end
endmodule
3. Testbench(tb):
`timescale 1us/1us
module tb();
reg clk_40k;
reg rst_n;
reg [7:0] din;
reg send_start;
wire bit_out;
wire bit_in;
wire dout_vld;
wire [7:0] dout;
assign bit_in = bit_out;
uart_tx i_uart_tx(
.clk_40k (clk_40k ),
.rst_n (rst_n ),
.din (din ),
.send_start (send_start),
.bit_out (bit_out )
uart_rx i_uart_rx(
.rst_n (rst_n ),
.bit_in (bit_in ),
.dout_vld (dout_vld ),
.dout (dout )
initial
begin
rst_n = 1'b0;
#10
rst_n = 1'b1;
end
initial
begin
clk_40k = 1'b0;
forever
#1
clk_40k = ~clk_40k;
end
initial
begin
send_start = 1'b0;
din = 8'd0;
forever
begin
#1000
din = $random()%256;
send_start = 1'b1;
#2
send_start = 1'b0;
end
end
endmodule
4. 仿真结果 :
按照testbench对UART收发端进行仿真,仿真结果如图:
- 系统时钟和传输速率通常不一致,clk_40k为高频系统时钟,利用计数器分频实现1k波特率;
- 复位信号rst_n低电平有效,正常传输时始终处于高电平。
- 开始传输时send_start信号拉高,传输结束时dout_vld信号拉高;
- 输入数据din在传输结束后在输出数据dout体现出来,传输时延为1个数据长度。
04
UART的优缺点
4.1 UART协议优点
- 通信只需要两条数据线;
- 无需时钟信号;
- 有奇偶校验位,方便通信的差错检查;
- 只需要接收端和发送端设置好数据包结构,即可稳定通信。
4.2 UART协议缺点
- 数据帧最大支持9位数据;
- 不支持多主机或多从机的主从系统。
串行
237浏览量
33788 -
uart
22文章
1227浏览量
101160 -
通讯接口
2文章
80浏览量
16171
