4. bit控制模块(i2c_bit_ctrl):
`define I2C_CMD_NOP 4'b0000
`define I2C_CMD_START 4'b0001
`define I2C_CMD_STOP 4'b0010
`define I2C_CMD_WRITE 4'b0100
`define I2C_CMD_READ 4'b1000
module i2c_bit_ctrl (
input clk, // system clock
input rst, // synchronous active high reset
input nReset, // asynchronous active low reset
input ena, // core enable signal
input [15:0] clk_cnt, // clock prescale value
input [ 3:0] cmd, // command (from byte controller)
output reg cmd_ack, // command complete acknowledge
output reg busy, // i2c bus busy
output reg al, // i2c bus arbitration lost
input din,
output reg dout,
input scl_i, // i2c clock line input
output scl_o, // i2c clock line output
output reg scl_oen, // i2c clock line output enable (active low)
input sda_i, // i2c data line input
output sda_o, // i2c data line output
output reg sda_oen // i2c data line output enable (active low)
// variable declarations
reg [ 1:0] cSCL, cSDA; // capture SCL and SDA
reg [ 2:0] fSCL, fSDA; // SCL and SDA filter inputs
reg sSCL, sSDA; // filtered and synchronized SCL and SDA inputs
reg dSCL, dSDA; // delayed versions of sSCL and sSDA
reg dscl_oen; // delayed scl_oen
reg sda_chk; // check SDA output (Multi-master arbitration)
reg clk_en; // clock generation signals
reg slave_wait; // slave inserts wait states
reg [15:0] cnt; // clock divider counter (synthesis)
reg [13:0] filter_cnt; // clock divider for filter
// state machine variable
reg [17:0] c_state; // synopsys enum_state
// module body
// whenever the slave is not ready it can delay the cycle by pulling SCL low
// delay scl_oen
always @(posedge clk)
dscl_oen <= #1 scl_oen;
// slave_wait is asserted when master wants to drive SCL high, but the slave pulls it low
// slave_wait remains asserted until the slave releases SCL
always @(posedge clk or negedge nReset)
if (!nReset) slave_wait <= 1'b0;
else slave_wait <= (scl_oen & ~dscl_oen & ~sSCL) | (slave_wait & ~sSCL);
// master drives SCL high, but another master pulls it low
// master start counting down its low cycle now (clock synchronization)
wire scl_sync = dSCL & ~sSCL & scl_oen;
// generate clk enable signal
if (~nReset)
begin
cnt <= #1 16'h0;
clk_en <= #1 1'b1;
end
else if (rst || ~|cnt || !ena || scl_sync)
begin
cnt <= #1 clk_cnt;
clk_en <= #1 1'b1;
end
else if (slave_wait)
begin
cnt <= #1 cnt;
clk_en <= #1 1'b0;
end
else
begin
cnt <= #1 cnt - 16'h1;
clk_en <= #1 1'b0;
end
// generate bus status controller
// capture SDA and SCL
// reduce metastability risk
if (!nReset)
begin
cSCL <= #1 2'b00;
cSDA <= #1 2'b00;
end
else if (rst)
begin
cSCL <= #1 2'b00;
cSDA <= #1 2'b00;
end
else
begin
cSCL <= {cSCL[0],scl_i};
cSDA <= {cSDA[0],sda_i};
end
// filter SCL and SDA signals; (attempt to) remove glitches
if (!nReset ) filter_cnt <= 14'h0;
else if (rst || !ena ) filter_cnt <= 14'h0;
else if (~|filter_cnt) filter_cnt <= clk_cnt >> 2; //16x I2C bus frequency
else filter_cnt <= filter_cnt -1;
if (!nReset)
begin
fSCL <= 3'b111;
fSDA <= 3'b111;
end
else if (rst)
begin
fSCL <= 3'b111;
fSDA <= 3'b111;
end
begin
fSCL <= {fSCL[1:0],cSCL[1]};
fSDA <= {fSDA[1:0],cSDA[1]};
end
// generate filtered SCL and SDA signals
if (~nReset)
begin
sSCL <= #1 1'b1;
sSDA <= #1 1'b1;
dSCL <= #1 1'b1;
dSDA <= #1 1'b1;
end
else if (rst)
begin
sSCL <= #1 1'b1;
sSDA <= #1 1'b1;
dSCL <= #1 1'b1;
dSDA <= #1 1'b1;
end
else
begin
sSCL <= #1 &fSCL[2:1] | &fSCL[1:0] | (fSCL[2] & fSCL[0]);
sSDA <= #1 &fSDA[2:1] | &fSDA[1:0] | (fSDA[2] & fSDA[0]);
dSCL <= #1 sSCL;
dSDA <= #1 sSDA;
end
// detect start condition => detect falling edge on SDA while SCL is high
// detect stop condition => detect rising edge on SDA while SCL is high
reg sta_condition;
reg sto_condition;
if (~nReset)
begin
sta_condition <= #1 1'b0;
sto_condition <= #1 1'b0;
end
else if (rst)
begin
end
else
begin
sta_condition <= #1 ~sSDA & dSDA & sSCL;
sto_condition <= #1 sSDA & ~dSDA & sSCL;
end
// generate i2c bus busy signal
if (!nReset) busy <= #1 1'b0;
else if (rst ) busy <= #1 1'b0;
else busy <= #1 (sta_condition | busy) & ~sto_condition;
// generate arbitration lost signal cascatrix carson
// aribitration lost when:
// 1) master drives SDA high, but the i2c bus is low
// 2) stop detected while not requested
reg cmd_stop;
if (~nReset)
cmd_stop <= #1 1'b0;
else if (rst)
else if (clk_en)
cmd_stop <= #1 cmd == `I2C_CMD_STOP;
if (~nReset)
al <= #1 1'b0;
else if (rst)
al <= #1 1'b0;
else
al <= #1 (sda_chk & ~sSDA & sda_oen) | (|c_state & sto_condition & ~cmd_stop);
// generate dout signal (store SDA on rising edge of SCL) cascatrix carson
if (sSCL & ~dSCL) dout <= #1 sSDA;
// generate statemachine cascatrix carson
// nxt_state decoder
parameter [17:0] idle = 18'b0_0000_0000_0000_0000;
parameter [17:0] start_a = 18'b0_0000_0000_0000_0001;
parameter [17:0] start_b = 18'b0_0000_0000_0000_0010;
parameter [17:0] start_c = 18'b0_0000_0000_0000_0100;
parameter [17:0] start_d = 18'b0_0000_0000_0000_1000;
parameter [17:0] start_e = 18'b0_0000_0000_0001_0000;
parameter [17:0] stop_a = 18'b0_0000_0000_0010_0000;
parameter [17:0] stop_b = 18'b0_0000_0000_0100_0000;
parameter [17:0] stop_c = 18'b0_0000_0000_1000_0000;
parameter [17:0] stop_d = 18'b0_0000_0001_0000_0000;
parameter [17:0] rd_a = 18'b0_0000_0010_0000_0000;
parameter [17:0] rd_b = 18'b0_0000_0100_0000_0000;
parameter [17:0] rd_c = 18'b0_0000_1000_0000_0000;
parameter [17:0] rd_d = 18'b0_0001_0000_0000_0000;
parameter [17:0] wr_a = 18'b0_0010_0000_0000_0000;
parameter [17:0] wr_b = 18'b0_0100_0000_0000_0000;
parameter [17:0] wr_c = 18'b0_1000_0000_0000_0000;
parameter [17:0] wr_d = 18'b1_0000_0000_0000_0000;
if (!nReset)
begin
c_state <= #1 idle;
cmd_ack <= #1 1'b0;
scl_oen <= #1 1'b1;
sda_oen <= #1 1'b1;
sda_chk <= #1 1'b0;
end
else if (rst | al)
begin
c_state <= #1 idle;
cmd_ack <= #1 1'b0;
scl_oen <= #1 1'b1;
sda_oen <= #1 1'b1;
sda_chk <= #1 1'b0;
end
else
begin
// default no command acknowledge + assert cmd_ack only 1clk cycle
cmd_ack <= #1 1'b0;
if (clk_en) // synopsys full_case parallel_case
case (c_state)
// idle state
idle:
begin // synopsys full_case parallel_case
case (cmd)
`I2C_CMD_START: c_state <= #1 start_a;
`I2C_CMD_STOP: c_state <= #1 stop_a;
`I2C_CMD_WRITE: c_state <= #1 wr_a;
`I2C_CMD_READ: c_state <= #1 rd_a;
default: c_state <= #1 idle;
endcase
// keep SCL in same state
// keep SDA in same state
sda_oen <= #1 sda_oen;
// don't check SDA output
sda_chk <= #1 1'b0;
end
// start
start_a:
begin
c_state <= #1 start_b;
sda_oen <= #1 1'b1; // set SDA high
sda_chk <= #1 1'b0;
end
start_b:
begin
c_state <= #1 start_c;
scl_oen <= #1 1'b1; // set SCL high
sda_oen <= #1 1'b1; // keep SDA high
sda_chk <= #1 1'b0;
end
start_c:
begin
c_state <= #1 start_d;
scl_oen <= #1 1'b1; // keep SCL high
sda_oen <= #1 1'b0; // set SDA low
sda_chk <= #1 1'b0;
end
start_d:
begin
c_state <= #1 start_e;
sda_oen <= #1 1'b0; // keep SDA low
sda_chk <= #1 1'b0;
end
start_e:
begin
c_state <= #1 idle;
cmd_ack <= #1 1'b1;
scl_oen <= #1 1'b0; // set SCL low
sda_chk <= #1 1'b0;
end
// stop
stop_a:
begin
c_state <= #1 stop_b;
scl_oen <= #1 1'b0; // keep SCL low
sda_chk <= #1 1'b0;
end
stop_b:
begin
c_state <= #1 stop_c;
sda_chk <= #1 1'b0;
end
stop_c:
begin
c_state <= #1 stop_d;
sda_chk <= #1 1'b0;
end
stop_d:
begin
c_state <= #1 idle;
cmd_ack <= #1 1'b1;
sda_chk <= #1 1'b0;
end
// read
rd_a:
begin
c_state <= #1 rd_b;
sda_oen <= #1 1'b1; // tri-state SDA
sda_chk <= #1 1'b0;
end
rd_b:
begin
c_state <= #1 rd_c;
sda_oen <= #1 1'b1; // keep SDA tri-stated
sda_chk <= #1 1'b0;
end
rd_c:
begin
c_state <= #1 rd_d;
sda_chk <= #1 1'b0;
end
rd_d:
begin
c_state <= #1 idle;
cmd_ack <= #1 1'b1;
sda_chk <= #1 1'b0;
end
// write
wr_a:
begin
c_state <= #1 wr_b;
sda_oen <= #1 din; // set SDA
// don't check SDA output (SCL low)
sda_chk <= #1 1'b0;
end
wr_b:
begin
c_state <= #1 wr_c;
sda_oen <= #1 din; // keep SDA
// don't check SDA output yet
sda_chk <= #1 1'b0;
// allow some time for SDA and SCL to settle
end
wr_c:
begin
c_state <= #1 wr_d;
sda_oen <= #1 din;
sda_chk <= #1 1'b1; // check SDA output
end
wr_d:
begin
c_state <= #1 idle;
cmd_ack <= #1 1'b1;
sda_oen <= #1 din;
sda_chk <= #1 1'b0; // don't check SDA output (SCL low)
end
endcase
end
// assign scl and sda output (always gnd)
assign scl_o = 1'b0;
assign sda_o = 1'b0;
endmodule
04
IIC的优缺点
4.1 IIC协议优点
4.2 IIC协议缺点
- 硬件结构复杂;
- 支持传输距离较短;
- 半双工速率慢于全双工,SPI全双工一般可实现10Mbps以上的传输速率,IIC最高速度仅能达到3.4Mbps。
举报投诉
IIC
11文章
300浏览量
38330 -
通信总线
44浏览量
9854 -
SDA
124浏览量
28130
一文详解IIC总线
IIC(Inter-Integrated Circuit)集成电路总线,它是一种两线式串行通信总线,又叫I2C,使用多主从架构,由飞利浦公司
发表于 06-07 15:38
•9833次阅读
一文详解IIC总线
IIC(Inter-Integrated Circuit)是一个多主从的串行总线,又叫I2C,是由飞利浦公司发明的通讯总线,属于半双工同步传
发表于 09-12 11:15
•2214次阅读
IIC总线协议的相关资料下载
(串行数据线)和SCL(串行时钟线)及上拉电阻组成。通信原理是通过对SCL和SDA线高低电平时序的控制,来 产生I2C总线协议所需要的信号进行数据的传递。在
发表于 11-30 08:29
IIC总线接口学习
在多主设备IIC 总线模式下,多个S3C2440A 微处理器可以从从属设备接收或发送串行数据。主设备S3C2440A 可以初始化和终止
发表于 04-27 15:31
•61次下载
IIC总线协议及应用
发表于 11-20 15:21
•10次下载
一文带你迅速了解常用串行总线之IIC协议2
集成电路总线** (Inter-Intergrated Circuit),通常称作IICBUS,简称为IIC,是一种采用多主从结构的串行通信总线
