Kubernetes 中的服务可以通过 Ingress 暴露出来,流量路由由 Ingress 资源上定义的规则控制,通常需要 Ingress controller 负责实现。本文将会对比两个比较流行的 Ingress controller 实现,希望能对读者进行 Ingress controller 选型中有所帮助。
Ingress NGINX 是 Kubernetes 社区实现的 Ingress controller,在社区中被广泛使用。Apache APISIX Ingress 则是 Apache 软件基金会下的开源项目,使用 APISIX 作为数据面的 Kubernetes Ingress controller。Ingress NGINX vs APISIX Ingress功能对比下列表格中,对比了 Ingress NGINX 和 APISIX Ingress 基本功能,包括协议支持、鉴权方式、上游探针/策略、负载均衡策略、Kubenertes 集成等。以下表格数据取自learnk8s.io。
Product/Project |
Ingress NGINX |
Apache APISIX Ingress |
1. General info |
Based on |
nginx |
nginx |
2. Protocols |
HTTP/HTTPS |
HTTP2 |
gRPC |
TCP |
Partial |
TCP+TLS |
UDP |
Partial |
Websockets |
Proxy Protocol |
QUIC/HTTP3 |
Preview |
Preview |
3. Clients |
Rate limiting (L7) |
WAF |
Partial |
Timeouts |
Safe-list/Block-list |
Authentication |
Authorisation |
4. Traffic routing |
Host |
Path |
Querystring |
Method |
ClientIP |
5. Upstream probes/resiliency |
Healthchecks |
Retries |
Circuit Breaker |
6.Load balancer strategies |
Round robin |
Sticky sessions |
Least connections |
Ring hash |
Custom load balancing |
7. Authentication |
Basic auth |
External Auth |
Client certificate - mTLS |
OAuth |
OpenID |
JWT |
LDAP |
HMAC |
8. Observability |
Logging |
Metrics |
Tracing |
9. Kubernetes Integration |
State |
Kubernetes |
Kubernetes |
CRD |
Scope |
Clusterwide namespace |
namespace |
Support for the Gateway API |
Preview |
Integrates with service meshes |
10. Traffic shaping |
Canary |
Session Affinity |
Traffic Mirroring |
11. Other |
Hot reloading |
LetsEncrypt Integration |
Wildcard certificate support |
Configure hot reloading |
Preview |
Service Discovery |
Service Discovery |
Ingress NGINX |
Kubernetes |
DNS |
nacos |
exureka |
consul_kv |
apiVersion: apisix.apache.org/v2
kind: ApisixUpstream
metadata:
spec:
healthCheck:
passive:
unhealthy:
httpCodes:
- 500
httpFailures: 3
active:
type: http
httpPath: /healthz
healthy:
successes: 3
interval: 2s
httpCodes:
- 200服务熔断流量高峰时,网关作为流量入口向后端服务发起调用,后端服务有可能会产生调用失败(超时或者异常),失败时不能让请求堆积在网关上,需要快速失败并返回回去,这就需要在网关上进行熔断。服务熔断的功能在 Ingress NGINX 中尚未支持。在 APISIX Ingress 中则可以通过 api-breaker熔断插件来实现。具体使用配置示例如下:apiVersion: apisix.apache.org/v2
kind: ApisixRoute
metadata:
spec:
http:
- name: rule1
match:
hosts:
- httpbin.org
paths:
- /status/*
backends:
- serviceName: httpbin
servicePort: 80
plugins:
- name: api-breaker
enable: true
config:
break_response_code: 502
unhealthy:
http_statuses:
- 505
failures: 2
healthy:
http_statuses:
- 200
successes: 2插件和鉴权方式目前 Ingress NGINX 主要通过Annotations 和 ConfigMap 等方式进行配置,支持的插件功能比较有限。如果想要使用 JWT、HAMC 等鉴权方式,只能自行开发。而 APISIX Ingress 得益于 APISIX 的丰富功能,原生支持 APISIX 内置的 80+ 插件,能够覆盖大部分使用场景,还支持 JWT、HMAC、wolf-rbac 等多种鉴权方式。以下仅展示 APISIX Ingress 使用 HMAC 认证并在路由上的应用示例:apiVersion: apisix.apache.org/v2
kind: ApisixConsumer
metadata:
spec:
authParameter:
hmacAuth:
value:
access_key: papa
secret_key: fatpa
algorithm: "hmac-sha256"
clock_skew: 0
kind: ApisixRoute
metadata:
spec:
http:
- name: rule1
match:
hosts:
- httpbin.org
paths:
- /ip
backends:
servicePort: 80
authentication:
enable: true
type: hmacAuthIngress NGINX 和 APISIX Ingress 扩展方式除了以上这些细节对比外,两者对于额外功能的扩展也有所不同。当 Ingress controller 的基础功能无法满足企业用户的需求时,只能通过扩展的方式进行定制开发。接下来将具体介绍 Ingress NGINX 和 APISIX Ingress 如何进行功能扩展。Ingress NGINX 如何进行功能扩展Ingress NGINX 在扩展方式上比较单一,只能通过嵌入 Lua 程序的方式来扩展功能。我们以 Ingress NGINX 插件开发为例,大概需要以下步骤:1.编写 Lua 程序 example-plugin2.将插件安装到 ingress-nginx pod 中的 /etc/nginx/lua/plugins/→ /etc/nginx/lua/plugins/example-plugin3.在 ConfigMap 中启用 example-plugin 插件,需要在安装 Ingress NGINX 时引用此 ConfigMap 对象apiVersion: v1
kind: ConfigMap
metadata:
namespace: ingress-nginx
data:
plugins: "example-plugin"APISIX Ingress 如何进行功能扩展APISIX Ingress 提供了多种扩展方式,企业用户可以根据自身情况自由选择或组合,当前支持如下拓展方式:l通过 Lua 进行插件开发:这种方式相对简单,并且几乎没有性能损耗;l通过 plugin-runner 开发:这种模式下支持 Java/Python/Go 等语言进行开发,这可以方便用户利用一些现有的业务逻辑,并且无需学习新语言;l通过 WASM 进行插件插件:这种模式下,可以使用任何支持构建出 WASM 的语言进行插件开发;此外还可以通过 Serverless 插件来直接编写 Lua 代码,快速满足业务需求。为什么 APISIX Ingress 选择维护 CRD目前 APISIX Ingress 支持三种声明式配置:Ingress 、CRD 和 Gateway API。这里主要对比 Ingress 和 CRD,Gateway API 将在后续展开。Ingress 比较适合从 Ingress NGINX 迁移的企业用户,其转换成本较低。但缺点也较明显,比如语义化能力弱、没有细致规范等,同时也只能通过 Annotations 方式扩展,且 Annotations 无法支撑复杂配置场景。相对的使用 CRD 主要有以下好处:l更契合数据面的设计语义,更加简单易用;l一些重要配置能够被复用,而不会存在冗余庞大的单个配置;l功能性和可扩展能力有了巨大提升;l数据面 APISIX 有着活跃的社区,更新和发布版本快,CRD 的方式能够轻易支持数据面的更多能力;Ingress NGXIN 的痛点:不支持配置热加载静态配置带来的问题Ingress NGINX 主要基于 NGINX 配置文件的方式,尽管使用 NGINX + Lua 来实现功能扩展,但没有彻底解决静态配置文件的问题。在路由能力和加载模式上稍显不足,并且存在一些明显劣势。比如添加、修改任何新的规则时,需要重新加载 NGINX 配置。随着越来越多的路由规则和证书,在触发变更时,reload 操作将会更耗时,甚至需要几秒到十几秒的时间,对线上流量的影响将会非常大的,会导致流量短暂中断、影响响应延迟、负载均衡质量(每次重新加载 NGINX 都会重置负载均衡状态)等。触发 NGINX 重新加载的情况以下这些情况,涵盖了 Ingress controller 大量的使用场景:l创建新的 Inresss 资源;l将 TLS 部分添加到现有 Ingress;lIngress Annotations 的变化可能影响上游配置(例如 load-balance 注释不需要重新加载);l在 Ingress 中添加或删除 path;lIngress、Service、Secret 资源被删除;lSecret 发生更新;在上述场景下,具有频繁部署应用程序的集群环境中,会不断触发 Ingress、Secret 等资源的操作(创建、更新、删除等),导致 NGINX 重新加载次数剧增,给生产环境带来了极大的影响。小结Ingress NGINX 的架构决定了它必须生成 NGINX 配置然后通过 reload 方式完成配置更新,架构不调整是无法解决这些已知问题。比如路由的实现,APISIX Ingress 则不再依赖 NGINX 配置改为了纯内存结构,通过热更新方式实现动态路由,不再需要重启 NGINX。云原生新一代网关规范 Gateway APIGateway API 优势Gateway API 相比 Ingress 的功能性更强,旨在通过由许多供应商实现并具有广泛行业支持的富有表现力、可扩展和面向角色的接口来发展 Kubernetes 服务网络。当下 Gateway API 具有如下的优势:l面向角色:Gateway 是由一组 API 资源组成的。不同的 API 资源代表了使用与配置 Kubernetes 网络资源的不同角色;l表现力强:Gateway API 的核心功能就包含诸如基于头的匹配、流量加权以及其他在 Ingress 中只能通过各实现者自定义的非标准化 Annotations 等方式实现的功能;l可扩展:Gateway API 允许不同资源在不同层级一同使用。这使得能够对 API 结构进行更精细化的控制。支持情况Gateway API 作为一种扩展 Kubernetes 服务网络的标准,其 Gateway 资源能够实现作为 Kubernetes API 来管理网关的生命周期,功能十分强大。目前许多 Ingress controller 都在积极支持它,包括 Istio、Kong、Traefik 等。在目前 Gateway API 实现情况中,很遗憾的是,Ingress NGXIN 尚未计划支持 Gateway API 。而 APISIX Ingress 已经支持了 Gateway API 的大部分特性:包括 HTTPRoute、TCPRoute、TLSRoute、UDPRoute 等。总结经过 APISIX Ingress 与 Ingress NGINX 的完整对比,我们可以看到两者基础功能差异不大,也都具备扩展能力。但在微服务的架构中,APISIX Ingress 对服务治理和服务发现的支持更具优势。总体来看,两款开源软件均非常优秀,Ingress NGINX 主要特点是简单、易接入,但缺点也十分明显;APISIX Ingress 作为后来者解决了 NGINX 不支持热加载的痛点,在扩展能力和功能上相比 Ingress NGINX 也具有很大的优势。从项目发展角度而言,支持 Gateway API 和 CRD 能够扩展和丰富 Ingress controller 基础能力。如果读者正在进行 Ingress controller 选型,倾向于功能丰富和更强的扩展能力,推荐使用 APISIX Ingress 。如果只是刚接触 Ingress controller,没有更多的功能需求,Ingress NGINX 也是一个比较好的选择。审核编辑 :李倩
开源软件
210浏览量
16019 -
网关
9文章
4727浏览量
51826
原文标题:APISIX Ingress VS Ingress NGINX,详细对比让你一目了然
文章出处:【微信号:OSC开源社区,微信公众号:OSC开源社区】欢迎添加关注!文章转载请注明出处。
华为 FlexusX 与 Docker+Nginx 的高效整合之路
EulerOS+Nginx+MySQL 部署 GLPI 资产管理系统
玩转Nginx日志管理:高效排查问题的终极指南
nginx+lua+redis实现灰度发布
「服务器」Nginx Proxy Manager申请cloudflare泛域名
确保网站无缝运行:Keepalived高可用与Nginx集成实战
nginx隐藏版本号与WEB服务器信息
nginx负载均衡配置介绍
