概述
脚本功能功能是全程模拟了人的手工巡检,并收集数据,处理后发送邮件。主要分为远程到交换机,查看转换机状态如:show process cpu | in CPU utilization查看cpu占用率;将查询后的结果记录并保存下来,如结果;11%;读取查询的数据文件;将文件中的数据如11%提取部分需要计算出来;创建excel表格,将上一步获取到的数据填写到表格中;编写固定格式的邮件内容,并将保存好的excel表格附到邮件中发送;编写crontab定时任务,实现全程自动化。
流程图
Author:myfu
Date:2019-08-26
E-mail:myfu@****.com
importpexpect
importsys
importtime
importos
importxlwt
defcisco_check():
ip=["10.3.240.14","10.3.240.15","10.3.240.17","10.3.240.20","10.3.240.21"]
name=["SZNS-KJY4F-ACS-05#","SZNS-KJY4F-ACS-06#","SZNS-KJY4F-ACS-08#","SZNS-KJY9F-ACS-11#","SZNS-KJY9F-ACS-12#"]
stat_time=time.time()
stru_time=time.localtime(stat_time)
strf_time=time.strftime("%Y-%m-%d")
foriinrange(0,len(ip)):
child=pexpect.spawn('sshfumy@%s'%ip[i])
fout=open('/root/switch_check/%s.txt'%(name[i][:-1]),'wb+')
child.logfile=fout
ifip[i]=="10.3.240.21":
child.expect("fumy@10.3.240.21'spassword:")
else:
child.expect('password:')
child.sendline("你自己的密码")
child.expect("%s"%name[i])
child.sendline("shenvpower")
child.sendline("showprocesscpu|inCPUutilization")
child.sendline("shversion|inuptime")
child.sendline("showprocessesmemory|inUsed")
child.sendline("shenvfan")
child.sendline("shlog|inConsolelogging")
child.sendline("exit")
time.sleep(3)
file_list=os.listdir("/root/switch_check")
withopen("/root/switch_check/%s"%file_list[0])asf1:
foriinf1:
if"POWER"ini:
power1=i[8:].strip()
if"CPUutilization"ini:
cpu1=i[72:].strip()
if"%suptimeis"%file_list[0][:-4]ini:
uptime1="".join(i[27:].strip().split(","))
if"ProcessorPoolTotal:"ini:
memory1="%.2f%%"%((int(i[38:50].strip())/int(i[21:33].strip()))*100)
if"FANis"ini:
fan1=i[6:].strip()
if"leveldebugging"ini:
log1=i[37:43].strip()
withopen("/root/switch_check/%s"%file_list[1])asf2:
foriinf2:
if"POWER"ini:
power2=i[8:].strip()
cpu2=i[72:].strip()
if"%suptimeis"%file_list[1][:-4]ini:
uptime2="".join(i[27:].strip().split(","))
memory2="%.2f%%"%((int(i[38:50].strip())/int(i[21:33].strip()))*100)
if"FANis"ini:
fan2=i[6:].strip()
log2=i[37:43].strip()
withopen("/root/switch_check/%s"%file_list[2])asf3:
foriinf3:
if"POWER"ini:
power3=i[8:].strip()
cpu3=i[72:].strip()
if"%suptimeis"%file_list[2][:-4]ini:
uptime3="".join(i[27:].strip().split(","))
memory3="%.2f%%"%((int(i[38:50].strip())/int(i[21:33].strip()))*100)
if"FANis"ini:
fan3=i[6:].strip()
log3=i[37:43].strip()
withopen("/root/switch_check/%s"%file_list[3])asf4:
foriinf4:
if"POWER"ini:
power4=i[24:].strip()
cpu4=i[72:].strip()
if"%suptimeis"%file_list[3][:-4]ini:
uptime4="".join(i[27:].strip().split(","))
if"Total:"ini:
memory4="%.2f%%"%((int(i[21:29].strip())/int(i[6:14].strip()))*100)
if"FANis"ini:
fan4=i[6:].strip()
log4=i[37:45].strip()
withopen("/root/switch_check/%s"%file_list[4])asf5:
foriinf5:
if"POWER"ini:
power5=i[24:].strip()
cpu5=i[72:].strip()
if"%suptimeis"%file_list[4][:-4]ini:
uptime5="".join(i[27:].strip().split(","))
if"Total:"ini:
memory5="%.2f%%"%((int(i[21:29].strip())/int(i[6:14].strip()))*100)
if"FANis"ini:
fan5=i[6:].strip()
log5=i[37:44].strip()
workbook=xlwt.Workbook(encoding='utf-8')
cisco=workbook.add_sheet('深圳网络设备巡检')
style=xlwt.XFStyle()
pattern=xlwt.Pattern()
pattern.pattern=xlwt.Pattern.SOLID_PATTERN
pattern.pattern_fore_colour=xlwt.Style.colour_map['red']
style.pattern=pattern
borders=xlwt.Borders()
borders.left=1
borders.right=1
borders.top=1
borders.bottom=1
style.borders=borders
al=xlwt.Alignment()
al.horz=0x02
al.vert=0x01
style.alignment=al
style1=xlwt.XFStyle()
borders.left=1
borders.right=1
borders.top=1
borders.bottom=1
style1.borders=borders
al=xlwt.Alignment()
al.horz=0x02
al.vert=0x01
style1.alignment=al
style3=xlwt.XFStyle()
borders.left=1
borders.right=1
borders.top=1
borders.bottom=1
style3.borders=borders
al=xlwt.Alignment()
al.horz=0x02
al.vert=0x01
style3.alignment=al
first_col=cisco.col(0)
sec_col=cisco.col(1)
thr_col=cisco.col(2)
for_col=cisco.col(3)
first_col.width=200*25
sec_col.width=120*25
thr_col.width=120*25
for_col.width=320*25
cisco.write(0,0,'设备名称',style)
cisco.write(0,1,'管理地址',style)
cisco.write(0,2,'检查项',style)
cisco.write(0,3,'检查结果',style)
cisco.write_merge(1,6,0,0,'%s'%file_list[0][:-4],style3)
cisco.write_merge(1,6,1,1,'%s'%ip[0],style3)
cisco.write(1,2,'电源状态',style1)
cisco.write(2,2,'cpu使用率',style1)
cisco.write(3,2,'运行时间',style1)
cisco.write(4,2,'内存使用率',style1)
cisco.write(5,2,'风扇状态',style1)
cisco.write(6,2,'日志条目',style1)
cisco.write(1,3,power1,style3)
cisco.write(2,3,cpu1,style3)
cisco.write(3,3,uptime1,style3)
cisco.write(4,3,memory1,style3)
cisco.write(5,3,fan1,style3)
cisco.write(6,3,log1,style3)
cisco.write_merge(7,12,0,0,'%s'%file_list[1][:-4],style3)
cisco.write_merge(7,12,1,1,'%s'%ip[1],style3)
cisco.write(7,2,'电源状态',style1)
cisco.write(8,2,'cpu使用率',style1)
cisco.write(9,2,'运行时间',style1)
cisco.write(10,2,'内存使用率',style1)
cisco.write(11,2,'风扇状态',style1)
cisco.write(12,2,'日志条目',style1)
cisco.write(7,3,power2,style3)
cisco.write(8,3,cpu2,style3)
cisco.write(9,3,uptime2,style3)
cisco.write(10,3,memory2,style3)
cisco.write(11,3,fan2,style3)
cisco.write(12,3,log2,style3)
cisco.write_merge(13,18,0,0,'%s'%file_list[2][:-4],style3)
cisco.write_merge(13,18,1,1,'%s'%ip[2],style3)
cisco.write(13,2,'电源状态',style1)
cisco.write(14,2,'cpu使用率',style1)
cisco.write(15,2,'运行时间',style1)
cisco.write(16,2,'内存使用率',style1)
cisco.write(17,2,'风扇状态',style1)
cisco.write(18,2,'日志条目',style1)
cisco.write(13,3,power3,style3)
cisco.write(14,3,cpu3,style3)
cisco.write(15,3,uptime3,style3)
cisco.write(16,3,memory3,style3)
cisco.write(17,3,fan3,style3)
cisco.write(18,3,log3,style3)
cisco.write_merge(19,24,0,0,'%s'%file_list[3][:-4],style3)
cisco.write_merge(19,24,1,1,'%s'%ip[3],style3)
cisco.write(19,2,'电源状态',style1)
cisco.write(20,2,'cpu使用率',style1)
cisco.write(21,2,'运行时间',style1)
cisco.write(22,2,'内存使用率',style1)
cisco.write(23,2,'风扇状态',style1)
cisco.write(24,2,'日志条目',style1)
cisco.write(19,3,power4,style3)
cisco.write(20,3,cpu4,style3)
cisco.write(21,3,uptime4,style3)
cisco.write(22,3,memory4,style3)
cisco.write(23,3,fan4,style3)
cisco.write(24,3,log4,style3)
cisco.write_merge(25,30,0,0,'%s'%file_list[4][:-4],style3)
cisco.write_merge(25,30,1,1,'%s'%ip[4],style3)
cisco.write(25,2,'电源状态',style1)
cisco.write(26,2,'cpu使用率',style1)
cisco.write(27,2,'运行时间',style1)
cisco.write(28,2,'内存使用率',style1)
cisco.write(29,2,'风扇状态',style1)
cisco.write(30,2,'日志条目',style1)
cisco.write(25,3,power5,style3)
cisco.write(26,3,cpu5,style3)
cisco.write(27,3,uptime5,style3)
cisco.write(28,3,memory5,style3)
cisco.write(29,3,fan5,style3)
cisco.write(30,3,log5,style3)
workbook.save('SZ_NDC_%s.xls'%strf_time)
os.system("mail-a/root/python/SZ_NDC_%s.xls-scheck_test你的邮箱< /root/python/mail.txt "%strf_time)
os.system("find/root/python/-typef-mtime+15-name'SZ_NDC_*'|xargs
m-f")
cisco_check()
mail.txt中的内容即邮件内容:
各位好:
巡检结果详情请看附件。
ps:本邮件由系统自动发送,如有任何问题请联系***
BestWishes
邮件配置
/etc/mail.rc
setfrom=邮箱地址smtp=邮箱服务器smtp-auth-user=邮箱用户名smtp-auth-password=密码smtp-auth=login
定时任务
crontab-e
0017**5/usr/bin/python3/root/python/switch_check.py>/dev/null2>&1#每周五下午5点巡检
最终效果
审核编辑 :李倩
举报投诉
自动化
31文章
6010浏览量
90804 -
python
59文章
4891浏览量
90395 -
脚本
1文章
413浏览量
29308
原文标题:如何使用Python对交换机进行自动化巡检?聪明的网工已经收藏了!
文章出处:【微信号:网络技术干货圈,微信公众号:网络技术干货圈】欢迎添加关注!文章转载请注明出处。
热点推荐
工业交换机到底是什么?为什么工业环境非他不可?
在工业自动化、智能交通、能源电力等关键领域,网络中断带来的损失可能是灾难性的。正是这种对可靠性的极致追求,催生了与普通商用交换机截然不同的产品——工业交换机。 工业交换机*多口多型
工业以太网交换机与商用交换机的技术差异与应用场景分析
在当今的工业自动化和网络通信领域,交换机作为网络基础设施的核心组件,扮演着至关重要的角色。然而,市场上存在两种主要类型的交换机:工业交换机和普通交换
PON交换机一体化高效生产测试方案
(HunterATE)
Hunter ATE是全新的BS架构自动化测试平台,采用可视化配置,并搭配python脚本进行测试软件开发,降低了软件开发的难度,具有丰富的仪器库的支持,
可
发表于 08-26 11:05
产线自动化、电力监控…都离不开靠谱的工业交换机!
在现代工业自动化和电力监控系统中,工业交换机扮演着至关重要的角色。无论是高速运转的生产线还是复杂的电力监控网络,都需要一个稳定可靠的通信基础。本文将深入探讨工业交换机在这些领域的应用及其重要性
Is交换机组成的环形网络中,当位于主控节点的Ism网管交换机故障后,为什么环网中其他交换机不受影响?
当位于主控节点的交换机故障断掉,环网中其他交换机是如何保持正常运行的?或者说什么原理让环网其他交换机不受影响?
发表于 08-06 06:46
什么是工业级交换机?工业交换机作用有哪些?
对于企业、工厂等关键生产运营环境而言,选择价格低廉但性能不足的 普通交换机 ,将面临巨大的 运营中断 、 数据丢失 甚至 安全事故 的风险。了解并选择一款性能强悍适合的的工业交换机对生产经营都是
一字之差,背后是系统稳定性的巨大差距:工业交换机 vs 企业交换机
工业级交换机和企业级交换机虽仅一字之差,但在应用场景、硬件结构、稳定性设计等方面却大相径庭。本文以工程师视角深入解析两者的技术差异,并以光路科技FR-TSN系列为例,探讨其在工业自动化领域中的关键作用,帮助读者选对真正适合的
工业通信大集结:TSN、PROFINET、EtherCAT交换机集中发布,光路科技展示核心产品
工博会现场集中展示了多款来自Fiberroad的面向工业自动化与智能制造应用的以太网交换机产品,涵盖TSN交换机、PROFINET交换机、EtherCAT
一文读懂 TSN交换机在工业自动化中的“硬核”用途
工业自动化不断迈向高精度、高效率,TSN(时间敏感网络)技术正逐渐成为工业控制网络升级的关键。本文将解析TSN交换机在工业控制系统中的实际应用,介绍其如何实现对主站PLC、伺服系统、远程I/O及监控系统的高效连接与协同控制,助力构建更可靠、实时、可扩展的工业通信网络。
工业交换机应用场景大盘点
工业交换机广泛应用于各种对网络稳定性和环境适应性要求较高的工业环境中。这里小编给大家提供一些典型的工业交换机应用场景,以便理解: 工厂自动化 :在现代化工厂中, 工业交换机 用于连接各
工业交换机与普通交换机的区别:为什么工厂网络宁贵不省?
在工业4.0和智能制造的浪潮下,工厂的每一台设备、每一处传感器都成了网络中的“神经元”,而连接这些“神经元”的核心设备——工业交换机,却常被忽视。许多人会问:“工业交换机和普通交换机不都是联网
