I.MXRT FreeRTOS环境下擦写外部Flash
li1756686189 来源:嵌入式 MCU 2023-01-30 09:18 次阅读
FreeRTOS环境下,如果外部擦写 Flash,禁用指令缓存以避免在多个任务中使用来自Flash 的分支预测和应用程序同步操作 Flash的缓存预加载指令。因为代码是XIP,所以向量表也在Flash 中。所以,当发生中断时,内核将读取此中断向量表。如果同时,Flash闪存被编程写入,读取操作将失败。用户通过禁用中断来保护关键代码,以避免这种情况。
使用 "taskENTER/EXIT_CRITICAL()" 函数,最后它会调用如下图这个函数vPortRaiseBASEPRI。该函数只能禁用优先级低于configMAX_SYSCALL_INTERRUPT_priority的中断,这可以确保系统仍然可以工作。因此,需要检查所有其他外设中断的优先级,比如LCDIPv2_IRQn,LPUART,LPSPI 等等。要确保优先级低于configMAX_SYSCALL_INTERRUPT_priority,或将configMAX_SYSCALL_INTERROPT_priority配置为更高的优先级。
不需要逐一禁用所有IRQ。因此,如果使用上述方式还有问题,请尝试如下API
__set_PRIMASK(1);//关闭总中断
//擦,写,读 Flash//
__set_PRIMASK(0);//开启总中断
参考示例代码:
/* FreeRTOS kernel includes. */
#include "FreeRTOS.h"
#include "task.h"
#include "queue.h"
#include "timers.h"
/* Freescale includes. */
#include "fsl_device_registers.h"
#include "fsl_debug_console.h"
#include "fsl_flexspi.h"
#include "pin_mux.h"
#include "clock_config.h"
#include "board.h"
#include "app.h"
#include "fsl_common.h"
/* Task priorities. */
#define hello_task_PRIORITY (configMAX_PRIORITIES - 2)
#define flash_operation_task_PRIORITY (configMAX_PRIORITIES - 1)
static void hello_task(void *pvParameters);
static void flash_operation_task(void *pvParameters);
status_t flexspi_nor_flash_read_sector(FLEXSPI_Type *base, uint32_t address, const uint32_t *src, size_t leng);
extern status_t flexspi_nor_flash_erase_sector(FLEXSPI_Type *base, uint32_t address);
extern status_t flexspi_nor_flash_page_program(FLEXSPI_Type *base, uint32_t dstAddr, const uint32_t *src);
extern status_t flexspi_nor_get_vendor_id(FLEXSPI_Type *base, uint8_t *vendorId);
extern status_t flexspi_nor_enable_quad_mode(FLEXSPI_Type *base);
extern void flexspi_nor_flash_init(FLEXSPI_Type *base);
extern void flexspi_clear_buffer(FLEXSPI_Type *base);
flexspi_device_config_t deviceconfig = {
.flexspiRootClk = 12000000,
.flashSize = FLASH_SIZE,
.CSIntervalUnit = kFLEXSPI_CsIntervalUnit1SckCycle,
.CSInterval = 2,
.CSHoldTime = 3,
.CSSetupTime = 3,
.dataValidTime = 0,
.columnspace = 0,
.enableWordAddress = 0,
.AWRSeqIndex = 0,
.AWRSeqNumber = 0,
.ARDSeqIndex = NOR_CMD_LUT_SEQ_IDX_READ_FAST_QUAD,
.ARDSeqNumber = 1,
.AHBWriteWaitUnit = kFLEXSPI_AhbWriteWaitUnit2AhbCycle,
.AHBWriteWaitInterval = 0,
constuint32_tcustomLUT[CUSTOM_LUT_LENGTH]={
/* Normal read mode -SDR */
[4 * NOR_CMD_LUT_SEQ_IDX_READ_NORMAL] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x03, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_1PAD, 0x18),
[4 * NOR_CMD_LUT_SEQ_IDX_READ_NORMAL + 1] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_READ_SDR, kFLEXSPI_1PAD, 0x04, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0),
/* Fast read mode - SDR */
[4 * NOR_CMD_LUT_SEQ_IDX_READ_FAST] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x0B, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_1PAD, 0x18),
[4 * NOR_CMD_LUT_SEQ_IDX_READ_FAST + 1] = FLEXSPI_LUT_SEQ(
kFLEXSPI_Command_DUMMY_SDR, kFLEXSPI_1PAD, 0x08, kFLEXSPI_Command_READ_SDR, kFLEXSPI_1PAD, 0x04),
/* Fast read quad mode - SDR */
[4 * NOR_CMD_LUT_SEQ_IDX_READ_FAST_QUAD] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0xEB, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_4PAD, 0x18),
[4 * NOR_CMD_LUT_SEQ_IDX_READ_FAST_QUAD + 1] = FLEXSPI_LUT_SEQ(
kFLEXSPI_Command_DUMMY_SDR, kFLEXSPI_4PAD, 0x06, kFLEXSPI_Command_READ_SDR, kFLEXSPI_4PAD, 0x04),
/* Read extend parameters */
[4 * NOR_CMD_LUT_SEQ_IDX_READSTATUS] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x81, kFLEXSPI_Command_READ_SDR, kFLEXSPI_1PAD, 0x04),
/* Write Enable */
[4 * NOR_CMD_LUT_SEQ_IDX_WRITEENABLE] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x06, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0),
/* Erase Sector */
[4 * NOR_CMD_LUT_SEQ_IDX_ERASESECTOR] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0xD7, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_1PAD, 0x18),
/* Page Program - single mode */
[4 * NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM_SINGLE] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x02, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_1PAD, 0x18),
[4 * NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM_SINGLE + 1] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_WRITE_SDR, kFLEXSPI_1PAD, 0x04, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0),
/* Page Program - quad mode */
[4 * NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM_QUAD] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x32, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_1PAD, 0x18),
[4 * NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM_QUAD + 1] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_WRITE_SDR, kFLEXSPI_4PAD, 0x04, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0),
/* Read ID */
[4 * NOR_CMD_LUT_SEQ_IDX_READID] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x9F, kFLEXSPI_Command_READ_SDR, kFLEXSPI_1PAD, 0x04),
/* Enable Quad mode */
[4 * NOR_CMD_LUT_SEQ_IDX_WRITESTATUSREG] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x01, kFLEXSPI_Command_WRITE_SDR, kFLEXSPI_1PAD, 0x04),
/* Enter QPI mode */
[4 * NOR_CMD_LUT_SEQ_IDX_ENTERQPI] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x35, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0),
/* Exit QPI mode */
[4 * NOR_CMD_LUT_SEQ_IDX_EXITQPI] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_4PAD, 0xF5, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0),
/* Read status register */
[4 * NOR_CMD_LUT_SEQ_IDX_READSTATUSREG] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x05, kFLEXSPI_Command_READ_SDR, kFLEXSPI_1PAD, 0x04),
/* Erase whole chip */
[4 * NOR_CMD_LUT_SEQ_IDX_ERASECHIP] =
FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0xC7, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0),
int main(void)
/* Init board hardware. */
BOARD_ConfigMPU();
BOARD_InitPins();
BOARD_BootClockRUN();
BOARD_InitDebugConsole();
PRINTF("Flash Operation on FreeRTOS in XIP Mode! ");
if (xTaskCreate(hello_task, "Hello_task", configMINIMAL_STACK_SIZE + 100, NULL, hello_task_PRIORITY, NULL) !=
pdPASS)
PRINTF("Task creation failed!. ");
while (1)
if (xTaskCreate(flash_operation_task, "flash_operation_task", configMINIMAL_STACK_SIZE + 800, NULL,
flash_operation_task_PRIORITY, NULL) != pdPASS)
while (1)
vTaskStartScheduler();
for (;;)
for (;;)
PRINTF("Hello world. ");
/* delay 2s */
vTaskDelay(2 * configTICK_RATE_HZ);
status_t status;
uint8_t vendorID = 0;
/*Programe Buffer must be 4 and 4's multiplier bytes alignment */
uint8_t *nor_program_buffer = pvPortMalloc(256);
if (NULL == nor_program_buffer)
PRINTF("nor_program_buffer memory allocation failed! ");
configASSERT(NULL);
uint8_t *nor_read_buffer = pvPortMalloc(256);
if (NULL == nor_read_buffer)
PRINTF("nor_read_buffer memory allocation failed! ");
configASSERT(NULL);
taskENTER_CRITICAL();
flexspi_nor_flash_init(EXAMPLE_FLEXSPI);
taskEXIT_CRITICAL();
/* Get vendor ID. */
status = flexspi_nor_get_vendor_id(EXAMPLE_FLEXSPI, &vendorID);
if (status != kStatus_Success)
PRINTF("Get Vendor ID Failure!");
configASSERT(NULL);
PRINTF("Flash Vendor ID: 0x%x ", vendorID);
/* Disable I cache to avoid cache pre-fatch instruction with branch prediction from flash and application operate flash synchronously in multi-tasks. */
#if defined(__ICACHE_PRESENT) && (__ICACHE_PRESENT == 1U)
volatile bool ICacheEnableFlag = false;
/* Disable I cache. */
if (SCB_CCR_IC_Msk == (SCB_CCR_IC_Msk & SCB->CCR))
SCB_DisableICache();
ICacheEnableFlag = true;
#endif /* __ICACHE_PRESENT */
/* Enter quad mode. */
status = flexspi_nor_enable_quad_mode(EXAMPLE_FLEXSPI);
if (ICacheEnableFlag)
/* Enable I cache. */
SCB_EnableICache();
configASSERT(NULL);
/* Erase sectors. */
PRINTF("Erasing Serial NOR over FlexSPI... ");
/* Disable I cache to avoid cache pre-fatch instruction with branch prediction from flash and application operae flash synchronously inmulti-tasks.*/
status = flexspi_nor_flash_erase_sector(EXAMPLE_FLEXSPI, EXAMPLE_SECTOR * SECTOR_SIZE);
SCB_EnableICache();
PRINTF("Erase sector failure ! ");
configASSERT(NULL);
/* Invalidate the D cache before reading data from QSPI Flash */
#if defined(CACHE_MAINTAIN) && CACHE_MAINTAIN
DCACHE_InvalidateByRange(EXAMPLE_FLEXSPI_AMBA_BASE + EXAMPLE_SECTOR * SECTOR_SIZE, FLASH_PAGE_SIZE);
#endif
memcpy(nor_read_buffer, (void *)(EXAMPLE_FLEXSPI_AMBA_BASE + EXAMPLE_SECTOR * SECTOR_SIZE), FLASH_PAGE_SIZE);
for (uint16_t i = 0; i < FLASH_PAGE_SIZE; i++)
if (0xFF != nor_read_buffer[i])
PRINTF("Erase data - read out data value incorrect ! ");
configASSERT(NULL);
PRINTF("Sector Erase successfully ! ");
/* Program Sector */
for (uint16_t i = 0U; i < FLASH_PAGE_SIZE; i++)
nor_program_buffer[i] = i;
/* Clean program buffer to maker sure program data is valid before program execution for SDRAM target, because heap is cacheabe in SDRAM target.*/
#if defined(USE_SDRAM) && USE_SDRAM
DCACHE_CleanByRange((uint32_t)nor_program_buffer, FLASH_PAGE_SIZE);
#endif
#endif
/* Disable I cache to avoid cache pre-fatch instruction with branch prediction from flash andapplication operate flash synchronously inmulti-tasks.*/
status = flexspi_nor_flash_page_program(EXAMPLE_FLEXSPI, EXAMPLE_SECTOR * SECTOR_SIZE, (void *)nor_program_buffer);
SCB_EnableICache();
PRINTF("Page program failure ! ");
configASSERT(NULL);
PRINTF("Page program successfully ! ");
/* clean the D cache before reading data from QSPI Flash */
#endif
/* the below read sector API can be used in both Code in QSPI mode and Code in SRAM mode */
PRINTF("Read Sector Content: ");
PRINTF("%d, ", nor_read_buffer[i]);
PRINTF(" Flash operation done, suspend this task now. ");
/* Suspend itself */
vTaskSuspend(NULL);
审核编辑:汤梓红
  • FlaSh
  • 中断
  • 程序
  • 函数
  • FreeRTOS
原文标题:I.MXRT FreeRTOS 环境下擦写外部 Flash
文章出处:【微信号:嵌入式 MCU,微信公众号:嵌入式 MCU】欢迎添加关注!文章转载请注明出处。
    i.MXRT设计更新Segger J-Link Flash下载算法文件
    给大家分享的是为i.MXRT设计更新Segger J-Link Flash下载算法文件。  想要在Flash中调试,基本是离不开Flash下载算法的,毕竟要先将代码烧写进
    发表于 12-15 06:11
    i.MXRT系列FlexSPI驱动Flash页编程执行时间
      大家好,我是痞子衡,是正经搞技术的痞子。今天痞子衡给大家介绍的是i.MXRT系列FlexSPI驱动Flash页编程执行时间。  痞子衡之前写过一篇文章 《串行NOR Flash的页编程模式对于
    发表于 12-21 07:30
    i.MXRT上使能NOR Flash的Continuous read模式在软复位后无法正常启动怎么解决?
    发表于 01-19 07:19
    IAR开发环境i.MXRT的串行NOR Flash下载算法设计
      大家好,我是痞子衡,是正经搞技术的痞子。今天痞子衡给大家介绍的是IAR开发环境i.MXRT的串行NOR Flash下载算法设计。  在i.MX
    发表于 01-26 07:46
    i.MXRT上使能NOR Flash的Continuous read模式在软复位后无法正常启动问题的解决
    《串行NOR Flash的Continuous read模式软复位后i.MXRT无法启动问题解决方案之RESET#》,利用RESET#引脚复位功能是痞子衡找到的第一种解决方案,今天痞子衡继续给大家介...
    发表于 01-26 06:52
    FlexSPI复位方式不当会导致i.MXRT系列OTFAD加密启动失败怎么解决?
    发表于 02-07 08:11
    使用PTPD/FreeRTOS和WIP-TCP/IP堆栈在i.MXRT上实现IEEE1588v2是我教程
    使用PTPD、FreeRTOS和WIP-TCP/IP堆栈在i.MXRT上实现IEEE1588v2
    发表于 12-12 06:42
    浅析Keil MDK串行Flash的下载算法设计
    今天给大家介绍的是 Keil MDK 工具 i.MXRT 的串行 NOR Flash 下载算法设计。 在 i.MXRT 硬件那些事系列之《在串行 NOR
    的头像 发表于 12-23 13:15 1459次阅读
    J-Link工具i.MXRT的串行NOR Flash下载算法设计
    大家好,我是痞子衡,是正经搞技术的痞子。今天痞子衡给大家介绍的是 J-Link 工具 i.MXRT 的串行 NOR Flash 下载算法设计。 一、J-Link 各版本对 i.MXRT
    的头像 发表于 12-08 10:07 1026次阅读
    Flash不支持SFDP,如何下载适用i.MXRT
    大家好,我是痞子衡,是正经搞技术的痞子。今天痞子衡给大家介绍的是导致串行 NOR Flashi.MXRT 无法正常下载 / 启动的常见因素之 SFDP。 i.MXRT 系列 M
    的头像 发表于 10-30 10:30 699次阅读
    痞子衡嵌入式:MCUXpresso IDE使用J-Link下载算法在Flash调试注意事项(i.MXRT500为例)...
      大家好,我是痞子衡,是正经搞技术的痞子。今天痞子衡给大家介绍的是MCUXpresso IDE使用J-Link下载算法在Flash调试注意事项。  痞子衡前段时间写过一篇小文《为i.MXRT
    发表于 10-29 10:36 0次下载
    痞子衡嵌入式:MCUXpresso IDE<b class='flag-5'>下</b>使用J-Link下载算法在<b class='flag-5'>Flash</b>调试注意事项(<b class='flag-5'>i.MXRT</b>500为例)...
    痞子衡嵌入式:串行NOR Flash的Continuous read模式软复位后i.MXRT无法启动问题解决方案之SW Reset...
    发表于 12-02 12:51 1次下载
    痞子衡嵌入式:串行NOR <b class='flag-5'>Flash</b>的Continuous read模式<b class='flag-5'>下</b>软复位后<b class='flag-5'>i.MXRT</b>无法启动问题解决方案之SW Reset...
    i.MXRT上提升代码执行性能的十八般武艺
    SBL 项目是支持全系列 i.MXRT 平台的,为了具体化问题,我们就选取 i.MXRT1062 型号为例,官方配套 MIMXRT1060-EVK 板子上搭配了一颗四线串行 NOR Flash(芯成IS25WP064A)用于存放
    的头像 发表于 05-23 09:31 1369次阅读
    擦写Flash时一定不能开启系统全局中断吗?
    大家好,我是痞子衡,是正经搞技术的痞子。今天痞子衡给大家介绍的是i.MXRTFlexSPI driver实现Flash编程时对于中断支持问题。
    的头像 发表于 02-10 14:27 3337次阅读
    深入i.MXRT1050系列ROM中串行NOR Flash启动初始化流程
    我们知道外部串行NOR Flash是接到i.MXRT的FlexSPI外设引脚上,有时串行NOR Flash启动也叫FlexSPI NOR启动。
    的头像 发表于 06-02 17:43 1488次阅读
    深入<b class='flag-5'>i.MXRT</b>1050系列ROM中串行NOR <b class='flag-5'>Flash</b>启动初始化流程
