延时型硬件定时器: 由硬件定时器外设提供的延时功能。
计数型硬件定时器: 提供较精确的类似时间戳的功能。
周期型硬件定时器: 可设置中断频率的计数器,不仅能提供计数器的功能,也能根据中断频率提供更精确的定时。
输入捕获定时器: 可测量脉冲宽度或者测量频率。
* rief 硬件定时器中断服务函数。
* param[in] p_arg : 任务参数
static void mytimer_isr (void *p_arg)
aw_gpio_toggle((int)p_arg);
aw_kprintf("enter isr
* rief hwtimer 测试函数
aw_local void* __task_handle (void *arg)
int fd;
aw_err_t ret;
uint32_t count = 5;
aw_hwtimer_rate_t p_intr_freq;
p_intr_freq.rate_denominator = 5;
p_intr_freq.rate_numerator = 1;
fd = aw_open(CONFIG_DEMO_HWTIMER_PEROID_DEV_NAME, AW_O_RDWR, 0);
if (fd < 0) {
aw_kprintf("hwtimer open failed:%d
", fd);
while(1);
ret = aw_hwtimer_period_intr_freq_set_frac(fd, &p_intr_freq);
while (count) {
aw_hwtimer_period_wait(fd, 500);
mytimer_isr(arg);
count --;
// 配置每秒中断2次
ret = aw_hwtimer_period_intr_freq_set(fd, 2);
ret = aw_hwtimer_period_start(fd);
if (ret != AW_OK) {
aw_kprintf("Timer allocation fail!
ret = aw_hwtimer_period_wait(fd, AW_WAIT_FOREVER);
while (1) {
mytimer_isr(arg);
for (;;) {
aw_mdelay(1000);
aw_close(fd);
return 0;
下表为使用硬件周期型定时器,在中断中进行引脚翻转,通过逻辑分析仪所测量出的实际数据,在使用设计时可作为部分参考依据。
uint32_t count = 0;
int fd, led_fd;
int ret;
uint32_t start_count;
if (fd < 0) {
aw_kprintf("hwtimer open fail! :%d
",fd);
return;
/* 打开设备会点亮LED */
led_fd = aw_open("/dev/led_run", AW_O_RDWR, 0);
if (led_fd < 0) {
aw_kprintf("led open fail! :%d
", led_fd);
aw_close(fd);
return;
ret = aw_hwtimer_count_rate_get(fd, &start_count);
if (ret != AW_OK) {
aw_kprintf("Timer count rate get fail!
aw_close(fd);
aw_close(led_fd);
return;
// 设置时钟频率
ret = aw_hwtimer_count_rate_set(fd, start_count/2);
if (ret != AW_OK) {
aw_kprintf("Timer count rate set fail!
aw_close(fd);
aw_close(led_fd);
return;
ret = aw_hwtimer_count_start(fd);
if (ret != AW_OK) {
aw_kprintf("Timer start fail!
aw_close(fd);
aw_close(led_fd);
return;
for (;;) {
aw_led_toggle(led_fd);
aw_mdelay(500);
aw_hwtimer_count_get(fd, &count);
aw_kprintf("Count is %d
", count);
aw_close(fd);
aw_close(led_fd);
return 0;
int i;
int fd;
aw_err_t ret;
aw_timespec_t timespec;
aw_timestamp_t start_timestamp, stop_timestamp;
aw_timestamp_freq_t timestamp_freq;
uint64_t delay_ns, diff;
uint32_t ns_numerator = 1000000000;
timestamp_freq = aw_timestamp_freq_get();
while (0 == (timestamp_freq % 10)) {
timestamp_freq /= 10;
ns_numerator /= 10;
fd = aw_open(CONFIG_DEMO_HWTIMER_DELAY_DEV_NAME, AW_O_RDWR, 0);
if (fd < 0) {
", fd);
while(1);
delay_ns = 2001000;
for (i = 0; i < 100; i++) {
timespec.tv_sec = delay_ns / 1000000000u;
timespec.tv_nsec = (uint32_t)(delay_ns % 1000000000u);
start_timestamp = aw_timestamp_get();
ret = aw_hwtimer_delay(fd, ×pec);
if (ret !=AW_OK) {
aw_kprintf("hwtimer delay failed:%d
", ret);
aw_barrier();
stop_timestamp = aw_timestamp_get();
stop_timestamp -= start_timestamp;
diff = stop_timestamp;
diff *= ns_numerator;
diff /= timestamp_freq;
diff = diff - delay_ns;
aw_kprintf(
"hwtimer_delay delay = %u,diff = %u ns
(uint32_t)delay_ns,
(uint32_t)diff);
delay_ns += 100000;
aw_close(fd);
return 0;
{SDK}demosperipheralcap路径下为捕获型定时器例程,例程关键代码如下:
/* 单边沿触发*/
static void test_cap_single_edge(
int fd,
int gpio_cap,
uint32_t ms,
aw_hwtimer_cap_config_t *p_config,
int is_rising)
uint64_t cap_val1, cap_val2;
aw_err_t ret;
// 制造两次上升沿
mk_edge(gpio_cap, 5);
aw_task_delay(ms);
// 此时应该产生了两次捕获事件
// 把它们读出来
ret = aw_hwtimer_cap_read(fd, &cap_val1, AW_WAIT_FOREVER);
if (AW_OK != ret) {
aw_kprintf("cap read cap_val1 failed
return;
ret = aw_hwtimer_cap_read(fd, &cap_val2, AW_WAIT_FOREVER);
if (AW_OK != ret) {
aw_kprintf("cap read cap_val2 failed
return;
cap_val2 -= cap_val1;
cap_val2 *= 1000000;
cap_val2 /= p_config->sample_rate;
if (is_rising) {
aw_kprintf("two rising edge between %u ms
", ms + 5);
else {
aw_kprintf("two falling edge between %u ms
", ms + 5);
aw_kprintf("two capture events between %llu us
", cap_val2);
static void demo_cap_base(int gpio_cap)
int fd;
aw_err_t ret;
aw_hwtimer_cap_config_t config;
// 使得测试GPIO输出为0
aw_gpio_set(gpio_cap, 0);
fd = aw_open(CONFIG_DEMO_HWTIMER_CAP_DEV_NAME, AW_O_RDWR, 0);
if (fd < 0) {
aw_kprintf("cap open failed!
return;
// 获取捕获定时器的配置
ret = aw_hwtimer_cap_config_get(fd, &config);
if (ret != AW_OK) {
aw_kprintf("cap config get failed...
aw_close(fd);
return ;
int is_rising;
// 配置为上升沿触发捕获
config.cap_edge_flags = AW_CAPTURE_RISING_EDGE;
is_rising = 1;
ret = aw_hwtimer_cap_config_set(fd, &config);
if (ret != AW_OK) {
aw_kprintf("cap config set failed...
aw_close(fd);
return ;
ret = aw_hwtimer_cap_start(fd);
if (ret != AW_OK) {
aw_kprintf("cap start failed...
aw_close(fd);
return ;
test_cap_single_edge(fd, gpio_cap, 20, &config, is_rising);
aw_close(fd);
至此,所有类型的硬件定时器样例均已展示完毕,在软件应用设计中可根据实际需求选取不同类型的定时器进行使用。更多其他类型外设的用法介绍,请关注后续同系列推文~
举报投诉
致远电子
13文章
410浏览量
31546
原文标题:【产品应用】AWorksLP 样例详解(MR6450)—— HWTimer
文章出处:【微信号:ZLG_zhiyuan,微信公众号:ZLG致远电子】欢迎添加关注!文章转载请注明出处。
RISC-V生态崛起:政策落地与高性能芯片的崛起
近期,RISC-V生态取得重要进展,包括高性能核心板的推出和在工业自动化、物联网等领域的广泛应用。其中,致远电子MR6450系列RISC-V核心板,凭借高性能和丰富的通信接口,成为工业控制和物联网
深度解析 | 基于HPM6450的RISC-V核心板究竟有哪些过人之处?
本文导读随着AIoT时代的到来,RISC-V作为新兴架构,其精简及开源的特性在物联网的应用领域有很大的优势,为此ZLG致远电子推出MR6450系列是基于先楫HPM6450的全新RISC-V核心板
40mR/650V SiC 碳化硅MOSFET,替代30mR 超结MOSFET或者20-30mR的GaN!
BASiC基本半导体40mR/650V SiC 碳化硅MOSFET,替代30mR 超结MOSFET或者20-30mR的GaN!
发表于 01-22 10:43
为何ZLG致远电子要推出LGA嵌入式核心板?
、MR6450等5个系列,共12个型号的LGA形态的嵌入式核心板,涵盖了ARM9、A7、RISC-V等不同处理器架构。为什么有板对板连接器之后,我们还要推出LGA
TPA3255产品应用在消防广播,固定输入下, 如果输出负载变化时,输出电压还能保持不变吗?
产品应用在消防广播或者公共广播。
如果是100V定压 接20欧姆负载 能输出500W功率.
发表于 10-09 08:07
武汉凡谷:现阶段已有产品应用到5.5G系统
近日,武汉凡谷在接受机构调研时表示,公司具备5.5G方面的产品,如多频多通道滤波器,现阶段有相关的产品应用到客户的5.5G系统。
【Vision Board创客营连载体验】HWTIMER设备体验
,General PWM(r_gpt)”配置GPT如下图
点击Generate Project Content 生成配置代码
3、HWTIMER代码实现
hwtimer配置代码
int
发表于 05-14 11:51
浅谈智慧校园的用电安全管理分析及产品应用
浅谈智慧校园的用电安全管理分析及产品应用 张颖姣 摘要:阐述校园安全用电管理的特点,存在的问题,应对策略,包括在实习实训和维修保养中的安全用电、提升电气保证设备安全防护、电气设备运行维护管理
