本文主要介绍一个通过图像处理改善OCR识别结果的实例,并给出详细步骤和源码。
背景介绍
在很多情况下,文字识别会遇到困难。比如非单一的背景、杂讯干扰、文字部分缺失等。
我们希望识别图中的黑色文字(12-14),但背景较复杂且存在其他干扰,如果直接用Tesseract识别(代码如下),识别结果为空。
# -*- coding:utf-8 -*-
import pytesseract
from PIL import Image
# 打开图像
image = Image.open('0.png')
# OCR识别:lang默认英文
text = pytesseract.image_to_string(image)
# 打印识别后的文本
print(text)
对这种复杂情况的文字识别,直接去识别很容易失败。思考:可不可以通过图像处理将我们需要的部分分割或凸显出来再做识别?本文将以此为例做演示说明。
**详细实现步骤
【1】OTSU二值化
image = cv2.imread('0.png')
gray = cv2.cvtColor(image, cv2.COLOR_BGR2GRAY)
_,thresh = cv2.threshold(gray, 0, 255, cv2.THRESH_BINARY_INV | cv2.THRESH_OTSU)
cv2.imshow("Otsu", thresh)
【2】距离变化 + 归一化
dist = cv2.distanceTransform(thresh, cv2.DIST_L2, 5)
dist = cv2.normalize(dist, dist, 0, 1.0, cv2.NORM_MINMAX)
dist = (dist * 255).astype("uint8")
cv2.imshow("Dist", dist)
【3】对距离变换结果图做OTSU二值化
_,dist = cv2.threshold(dist, 0, 255, cv2.THRESH_BINARY | cv2.THRESH_OTSU)
cv2.imshow("Dist Otsu", dist)
【4】形态学开运算滤除杂讯
kernel = cv2.getStructuringElement(cv2.MORPH_ELLIPSE, (7, 7))
opening = cv2.morphologyEx(dist, cv2.MORPH_OPEN, kernel)
cv2.imshow("Opening", opening)
【5】轮廓筛选,找出文字区域
black_img = cv2.cvtColor(opening, cv2.COLOR_GRAY2BGR)
cnts = cv2.findContours(opening.copy(), cv2.RETR_EXTERNAL,cv2.CHAIN_APPROX_SIMPLE)
cnts = imutils.grab_contours(cnts)
chars = []
# loop over the contours
for c in cnts:
# compute the bounding box of the contour
(x, y, w, h) = cv2.boundingRect(c)
if w >= 35 and h >= 100:
chars.append(c)
cv2.drawContours(black_img,chars,-1,(0,255,0),2)
cv2.imshow("chars", black_img)
【6】计算轮廓凸包,进一步获取文字区域mask
mask = np.zeros(image.shape[:2], dtype="uint8")
cv2.drawContours(mask, [hull], -1, 255, -1)
mask = cv2.dilate(mask, None, iterations=2)
cv2.imshow("Mask", mask)
take the bitwise of the opening image and the mask to reveal just
the characters in the image
final = cv2.bitwise_and(opening, opening, mask=mask)
cv2.imshow("final", mask)
【7】Tesseract文字识别
text = pytesseract.image_to_string(final)
# 打印识别后的文本
print(text)
【8】完整代码:
import cv2
import numpy as np
import imutils
import pytesseract
threshold the distance transform using Otsu's method
chars = []
for c in cnts:
chars.append(c)
chars = np.vstack([chars[i] for i in range(0, len(chars))])
hull = cv2.convexHull(chars)
allocate memory for the convex hull mask, draw the convex hull on
the image, and then enlarge it via a dilation
cv2.imshow("final", final)
打印识别后的文本
print(text)
cv2.waitKey()
cv2.destroyAllWindows()
**参考链接**
(1)https://pyimagesearch.com/2021/11/22/improving-ocr-results-with-basic-image-processing/
(2)https://stackoverflow.com/questions/33881175/remove-background-noise-from-image-to-make-text-more-clear-for-ocr
OCR文字距离太近应该如何处理?
OCR SDK开发者平台推荐:OCR图像智能字符识别技术
Labview调用OCR Training.exe实现字符识别
Labview怎么实现对OCR识别定位,在线急等
Python OCR 识别库-ddddocr
【KV260视觉入门套件试用体验】七、VITis AI字符和文本检测(OCR&Textmountain)
什么是OCR
基于FPGA的OCR文字识别技术的深度解析
移动端证件OCR识别/安卓IOS平台
OCR光学字符识别技术原理讲解
OCR识别技术
基于OpenVINO+OpenCV的OCR处理流程化实现
![基于OpenVINO+OpenCV的<b class='flag-5'>OCR</b><b class='flag-5'>处理</b>流程化实现](https://file1.elecfans.com/web2/M00/AC/CD/wKgaomVJrZmAZlKDAAAShunNiZM227.png)
