OpenDaylight的运行环境
汽车电子技术 来源: 码农与软件时代 作者:码农与软件时代 2023-02-14 14:08 次阅读
OpenDaylight作为一种开源的SDN控制器,使用Java语言编写,其运行环境依赖如下图所示:
本次环境搭建使用VMware-workstation虚拟机,操作系统选用Ubuntu-16.04。
一、基础环境安装
1. JVM安装
JVM安装比较简单,这里就不再详细列出。安装完毕,验证JVM是否安装成功,执行命令java -version。
root@ubuntu:/etc/profile.d$ java -version
java version "1.8.0_141"
Java(TM) SE Runtime Environment (build 1.8.0_141-b15)
Java HotSpot(TM) 64-Bit Server VM (build 25.141-b15, mixed mode)
2. Maven安装
Maven官网下载安装包:http://maven.apache.org/download.cgi,然后执行如下步骤:
步骤1 解压安装包,执行命令:tar zxvf apache-maven-3.5.0-bin.tar.gz
root@ubuntu:~# tar zxvf apache-maven-3.5.0-bin.tar.gz
apache-maven-3.5.0/README.txt
apache-maven-3.5.0/LICENSE
apache-maven-3.5.0/NOTICE
apache-maven-3.5.0/lib/
步骤2 配置maven环境,执行命令:gedit /etc/profile,并添加如下内容
root@ubuntu:/opt# gedit /etc/profile
export M2_HOME=/opt/maven/apache-maven-3.5.0
export CLASSPATH=**CLASSPATH:**M2_HOME/lib
export PATH=**PATH:**M2_HOME/bin
步骤3 使配置文件生效,执行命令:source /etc/profile
root@ubuntu:/opt# source /etc/profile
步骤4 验证安装是否成功,执行命令: mvn -v
root@ubuntu:/opt# mvn -v
Apache Maven 3.5.0 (ff8f5e7444045639af65f6095c62210b5713f426; 2017-04-03T12:39:06-07:00)
Maven home: /opt/apache-maven-3.5.0
Java version: 1.8.0_141, vendor: Oracle Corporation
Java home: /home/Java/jdk1.8.0_141/jre
Default locale: en_US, platform encoding: UTF-8
OS name: "linux", version: "4.4.0-21-generic", arch: "amd64", family: "unix"
二、OpenDaylight controller源码****打包
  1. 下载Controller源码,链接如下:
https://github.com/opendaylight/controller/tree/stable/carbon
  1. 下载配套的setting.xml,链接如下:
https://github.com/opendaylight/odlparent/blob/stable/carbon/settings.xml
替换Maven目录下对应的setting.xml文件。
  1. 执行命令: mvn clean install -Dmaven.test.failure.ignore=true
    结果显示如下:
[INFO] Installing /home/test/code/controller/controller-stable-carbon/pom.xml to /home/test/.m2/repository/org/opendaylight/controller/releasepom/0.5.2-SNAPSHOT/releasepom-0.5.2-SNAPSHOT.pom
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] mdsal-artifacts .................................... SUCCESS [ 1.026 s]
[INFO] config-api ......................................... SUCCESS [ 47.387 s]
[INFO] config-subsystem ................................... SUCCESS [ 1.623 s]
[INFO] config-plugin-parent ............................... SUCCESS [ 1.636 s]
[INFO] yang-jmx-generator ................................. SUCCESS [ 20.992 s]
[INFO] yang-jmx-generator-plugin .......................... SUCCESS [ 24.874 s]
[INFO] sal-common-api ..................................... SUCCESS [ 24.677 s]
[INFO] sal-common-util .................................... SUCCESS [ 5.327 s]
[INFO] sal-common-impl .................................... SUCCESS [ 7.426 s]
[INFO] sal-test-model ..................................... SUCCESS [ 17.130 s]
[INFO] sal-core-api ....................................... SUCCESS [ 17.604 s]
[INFO] sal-core-spi ....................................... SUCCESS [ 11.724 s]
[INFO] sal-binding-api .................................... SUCCESS [ 11.374 s]
[INFO] sal-dom-config ..................................... SUCCESS [ 24.495 s]
[INFO] sal-inmemory-datastore ............................. SUCCESS [ 23.517 s]
[INFO] sal-broker-impl .................................... SUCCESS [ 33.522 s]
[INFO] sal-schema-service ................................. SUCCESS [ 4.122 s]
[INFO] sal-binding-util ................................... SUCCESS [ 3.590 s]
[INFO] sal-binding-broker-impl ............................ SUCCESS [ 37.996 s]
[INFO] sal-binding-config ................................. SUCCESS [ 16.008 s]
[INFO] config-parent ...................................... SUCCESS [ 1.297 s]
[INFO] sal-dom-broker-config .............................. SUCCESS [ 8.868 s]
[INFO] md-sal-config ...................................... SUCCESS [ 58.410 s]
[INFO] sample-toaster ..................................... SUCCESS [ 5.353 s]
[INFO] sample-toaster-consumer ............................ SUCCESS [ 4.290 s]
[INFO] sample-toaster-provider ............................ SUCCESS [ 14.800 s]
[INFO] sal-parent ......................................... SUCCESS [ 0.032 s]
[INFO] sal-samples ........................................ SUCCESS [ 0.021 s]
[INFO] clustering-it ...................................... SUCCESS [ 0.019 s]
[INFO] clustering-it-config ............................... SUCCESS [ 0.158 s]
[INFO] clustering-it-model ................................ SUCCESS [ 14.184 s]
[INFO] sal-clustering-commons ............................. SUCCESS [03:32 min]
[INFO] sal-akka-raft ...................................... SUCCESS [02:27 min]
[INFO] cds-access-api ..................................... SUCCESS [ 36.652 s]
[INFO] cds-access-client .................................. SUCCESS [ 43.988 s]
[INFO] cds-dom-api ........................................ SUCCESS [ 10.170 s]
[INFO] sal-akka-raft-example .............................. SUCCESS [ 6.198 s]
[INFO] sal-distributed-datastore .......................... SUCCESS [18:26 min]
[INFO] clustering-it-provider ............................. SUCCESS [ 8.670 s]
[INFO] config-util ........................................ SUCCESS [ 9.823 s]
[INFO] config-manager-facade-xml .......................... SUCCESS [ 10.873 s]
[INFO] blueprint .......................................... SUCCESS [ 39.547 s]
[INFO] netty-config-api ................................... SUCCESS [ 25.094 s]
[INFO] shutdown-api ....................................... SUCCESS [ 3.983 s]
[INFO] config-manager ..................................... SUCCESS [ 21.123 s]
[INFO] shutdown-impl ...................................... SUCCESS [ 21.479 s]
[INFO] features-config .................................... SUCCESS [08:55 min]
[INFO] config-persister-api ............................... SUCCESS [ 5.156 s]
[INFO] config-persister-file-xml-adapter .................. SUCCESS [ 34.080 s]
[INFO] config-persister-directory-xml-adapter ............. SUCCESS [ 6.199 s]
[INFO] config-persister-impl .............................. SUCCESS [ 8.930 s]
[INFO] config-persister-feature-adapter ................... SUCCESS [ 4.236 s]
[INFO] features-config-persister .......................... SUCCESS [01:52 min]
[INFO] netty-event-executor-config ........................ SUCCESS [ 10.106 s]
[INFO] netty-threadgroup-config ........................... SUCCESS [ 8.068 s]
[INFO] threadpool-config-api .............................. SUCCESS [ 3.605 s]
[INFO] threadpool-config-impl ............................. SUCCESS [ 13.322 s]
[INFO] netty-timer-config ................................. SUCCESS [ 8.092 s]
[INFO] config-netty-config ................................ SUCCESS [ 1.593 s]
[INFO] features-config-netty .............................. SUCCESS [ 43.829 s]
[INFO] sal-dom-xsql ....................................... SUCCESS [ 11.506 s]
[INFO] Apache Karaf :: Shell odl/xsql Commands ............ SUCCESS [ 3.207 s]
[INFO] sal-connector-api .................................. SUCCESS [ 4.956 s]
[INFO] sal-dom-xsql-config ................................ SUCCESS [ 0.336 s]
[INFO] sal-clustering-config .............................. SUCCESS [ 0.353 s]
[INFO] sal-cluster-admin-api .............................. SUCCESS [ 6.509 s]
[INFO] sal-cluster-admin-impl ............................. SUCCESS [02:56 min]
[INFO] model-parent ....................................... SUCCESS [ 1.193 s]
[INFO] model-inventory .................................... SUCCESS [ 6.717 s]
[INFO] messagebus-api ..................................... SUCCESS [ 10.494 s]
[INFO] messagebus-util .................................... SUCCESS [01:08 min]
[INFO] messagebus-spi ..................................... SUCCESS [ 5.229 s]
[INFO] messagebus-impl .................................... SUCCESS [ 12.471 s]
[INFO] messagebus-config .................................. SUCCESS [ 0.166 s]
[INFO] sal-remoterpc-connector ............................ SUCCESS [ 54.328 s]
[INFO] features-mdsal ..................................... SUCCESS [09:08 min]
[INFO] config-it-base ..................................... SUCCESS [ 20.035 s]
[INFO] mdsal-it-base ...................................... SUCCESS [ 3.408 s]
[INFO] mdsal-it-parent .................................... SUCCESS [ 4.328 s]
[INFO] sample-toaster-it .................................. SUCCESS [01:13 min]
[INFO] sal-dummy-distributed-datastore .................... SUCCESS [01:19 min]
[INFO] Apache Karaf :: Shell odl/xsql Commands ............ SUCCESS [ 3.235 s]
[INFO] sal-binding-it ..................................... SUCCESS [03:22 min]
[INFO] sal-binding-dom-it ................................. SUCCESS [ 24.840 s]
[INFO] mdsal-trace-api .................................... SUCCESS [ 5.017 s]
[INFO] mdsal-trace-dom-impl ............................... SUCCESS [ 4.111 s]
[INFO] mdsal-trace-binding-impl ........................... SUCCESS [ 1.179 s]
[INFO] mdsal-trace-features ............................... SUCCESS [ 58.111 s]
[INFO] odl-config-api ..................................... SUCCESS [03:04 min]
[INFO] OpenDaylight :: Config :: All ...................... SUCCESS [ 36.601 s]
[INFO] odl-config-core .................................... SUCCESS [ 45.630 s]
[INFO] odl-config-manager ................................. SUCCESS [ 33.703 s]
[INFO] config-persister-feature4-adapter .................. SUCCESS [ 4.383 s]
[INFO] OpenDaylight :: Config Persister ................... SUCCESS [ 36.441 s]
[INFO] OpenDaylight :: Config Persister:: Config Startup .. SUCCESS [ 35.118 s]
[INFO] odl-config-netty-config-api ........................ SUCCESS [ 33.180 s]
[INFO] OpenDaylight :: Config-Netty ....................... SUCCESS [ 37.587 s]
[INFO] OpenDaylight :: MDSAL :: Broker .................... SUCCESS [01:00 min]
[INFO] odl-mdsal-clustering-commons ....................... SUCCESS [ 56.875 s]
[INFO] odl-mdsal-remoterpc-connector ...................... SUCCESS [ 44.190 s]
[INFO] odl-mdsal-distributed-datastore .................... SUCCESS [ 45.558 s]
[INFO] odl-mdsal-broker ................................... SUCCESS [ 56.576 s]
[INFO] OpenDaylight :: TracingBroker ...................... SUCCESS [ 58.356 s]
[INFO] OpenDaylight :: TracingBroker ...................... SUCCESS [01:07 min]
[INFO] mdsal-trace-feature-aggregator ..................... SUCCESS [ 0.065 s]
[INFO] mdsaltrace ......................................... SUCCESS [ 0.020 s]
[INFO] yang-test-plugin ................................... SUCCESS [ 43.954 s]
[INFO] yang-test .......................................... SUCCESS [ 20.250 s]
[INFO] logback-config ..................................... SUCCESS [ 40.587 s]
[INFO] config-artifacts ................................... SUCCESS [ 8.597 s]
[INFO] config-filtering-parent ............................ SUCCESS [ 0.764 s]
[INFO] model-topology ..................................... SUCCESS [ 5.427 s]
[INFO] protocol-framework ................................. SUCCESS [01:20 min]
[INFO] commons.logback_settings ........................... SUCCESS [ 1.911 s]
[INFO] filter-valve ....................................... SUCCESS [ 13.103 s]
[INFO] liblldp ............................................ SUCCESS [ 14.803 s]
[INFO] benchmark-api ...................................... SUCCESS [ 7.957 s]
[INFO] dsbenchmark ........................................ SUCCESS [ 7.287 s]
[INFO] ntfbenchmark ....................................... SUCCESS [ 5.727 s]
[INFO] rpcbenchmark ....................................... SUCCESS [ 5.724 s]
[INFO] benchmark-artifacts ................................ SUCCESS [ 0.024 s]
[INFO] benchmark-aggregator ............................... SUCCESS [ 0.026 s]
[INFO] odl-jolokia-osgi ................................... SUCCESS [ 1.618 s]
[INFO] karaf-parent ....................................... SUCCESS [ 50.587 s]
[INFO] features-extras .................................... SUCCESS [01:22 min]
[INFO] distribution.opendaylight-karaf .................... SUCCESS [05:22 min]
[INFO] opendaylight-karaf-empty ........................... SUCCESS [ 24.427 s]
[INFO] karaf-aggregator ................................... SUCCESS [ 0.080 s]
[INFO] odl-config-all ..................................... SUCCESS [ 39.769 s]
[INFO] features4-config ................................... SUCCESS [ 43.597 s]
[INFO] features-config-aggregator ......................... SUCCESS [ 0.035 s]
[INFO] Opendaylight :: Config Persister:: Mapping for Config Subsystem SUCCESS [ 31.774 s]
[INFO] OpenDaylight :: Config Persister:: All ............. SUCCESS [ 38.429 s]
[INFO] features4-config-persister ......................... SUCCESS [ 40.072 s]
[INFO] features-config-persister-aggregator ............... SUCCESS [ 0.029 s]
[INFO] features4-config-netty ............................. SUCCESS [ 36.761 s]
[INFO] features-config-netty-aggregator ................... SUCCESS [ 0.033 s]
[INFO] odl-clustering-test-app ............................ SUCCESS [01:00 min]
[INFO] odl-mdsal-xsql ..................................... SUCCESS [01:01 min]
[INFO] OpenDaylight :: Toaster ............................ SUCCESS [ 57.820 s]
[INFO] odl-mdsal-all ...................................... SUCCESS [01:03 min]
[INFO] odl-mdsal-clustering ............................... SUCCESS [01:10 min]
[INFO] odl-message-bus-collector .......................... SUCCESS [01:07 min]
[INFO] features4-mdsal .................................... SUCCESS [01:12 min]
[INFO] features-mdsal-aggregator .......................... SUCCESS [ 0.054 s]
[INFO] features-protocol-framework ........................ SUCCESS [ 40.792 s]
[INFO] OpenDaylight :: Protocol Framework ................. SUCCESS [ 36.886 s]
[INFO] features4-protocol-framework ....................... SUCCESS [ 36.158 s]
[INFO] features-protocol-framework-aggregator ............. SUCCESS [ 0.026 s]
[INFO] Jolokia JMX/HTTP bridge ............................ SUCCESS [ 40.450 s]
[INFO] OpenDaylight :: Extras :: All ...................... SUCCESS [ 44.130 s]
[INFO] features4-extras ................................... SUCCESS [ 37.831 s]
[INFO] features-extras-aggregator ......................... SUCCESS [ 0.045 s]
[INFO] features-mdsal-benchmark ........................... SUCCESS [02:57 min]
[INFO] OpenDaylight :: Benchmark :: API ................... SUCCESS [ 33.490 s]
[INFO] OpenDaylight :: dsbenchmark ........................ SUCCESS [ 55.640 s]
[INFO] OpenDaylight :: MD-SAL :: benchmark ................ SUCCESS [ 55.503 s]
[INFO] OpenDaylight :: ntfbenchmark ....................... SUCCESS [ 55.919 s]
[INFO] features4-mdsal-benchmark .......................... SUCCESS [ 54.460 s]
[INFO] features-mdsal-benchmark-aggregator ................ SUCCESS [ 0.040 s]
[INFO] features-controller ................................ SUCCESS [ 0.019 s]
[INFO] archetypes-parent .................................. SUCCESS [ 5.008 s]
[INFO] opendaylight-startup-archetype ..................... SUCCESS [ 27.983 s]
[INFO] controller ......................................... SUCCESS [ 0.015 s]
[INFO] BUILD SUCCESS
[INFO] Total time: 02:01 h
到现在为止,源码打包成功。
  • JAVA
  • 开源
  • sdn
    sdn
    网站的运行环境
    网站的运行环境 Internet/Intranet技术基础 域名注册与建站方式选择 服务器的选型、购买与安装 Web站点的创建与管理 FTP站点的创建与管理
    发表于 04-28 17:14 0次下载
    诺基亚码片修复软件 运行环境
    诺基亚码片修复软件 运行环境
    发表于 01-18 14:22 36次下载
    诺基亚3315 FLASH文件 运行环境
    发表于 01-18 17:08 4次下载
    Java 运行环境的安装、配置与运行
    Java 运行环境的安装、配置与运行 一、实验目的     1. 掌握下载 Java SDK 软件包。    2. 掌握设
    发表于 09-23 18:56 1.1w次阅读
    C语言的运行环境运行过程
    上机1 C语言的运行环境运行过程
    发表于 03-21 17:23 0次下载
    如何从零开始学OpenDaylight
    OpenDaylight的逻辑架构分为应用层、控制器层和数据转发层。其中,应用层聚焦网络业务逻辑开发,负责资源编排;控制器层进行全局网络的管理;数据转发层为各种网络设备,负责数据的转发。
    的头像 发表于 02-14 14:04 2468次阅读
    如何从零开始学<b class='flag-5'>OpenDaylight</b>
    OpenDaylight中的OSGi
    从写单个类的打印Hello World小程序到OSGi模块化开发,确实存在较大的难度,本文将从模块化、OSGI模型以及OSGI在OpenDaylight中的应用等方面进行介绍。
    的头像 发表于 02-14 15:05 871次阅读
    <b class='flag-5'>OpenDaylight</b>中的OSGi
    OpenDaylight中的DataStore是什么
    SDN起源于校园网,发扬光大于数据中心,现广泛用于广域网,SDN控制器,可能管理着数十万台软交换机,下发数百万乃至上千万条路由信息。因此,作为SDN控制器的开源项目OpenDaylight,无论是业务逻辑还是数据存储,
    的头像 发表于 02-14 15:13 1640次阅读
    <b class='flag-5'>OpenDaylight</b>中的DataStore是什么
    javascript运行环境有哪些
    JavaScript 是一种广泛应用于网页开发的编程语言,它可以在不同的运行环境运行。以下是一些常见的 JavaScript 运行环境
    的头像 发表于 11-27 16:11 2785次阅读
    C语言运行环境是什么
    C语言运行环境(C language runtime environment)是指在执行C语言程序时所需的软件及硬件环境。C语言是一种面向过程的编程语言,广泛应用于系统软件开发、嵌入式设备控制、科学
    的头像 发表于 11-27 16:13 3939次阅读
    Python运行环境有哪些
    Python是一种广泛使用的高级编程语言,它有许多种运行环境,可以适应不同的开发需求。下面将详细介绍Python的几种常见的运行环境。 CPython: CPython是Python的
    的头像 发表于 11-29 16:14 2254次阅读
    php运行环境的搭建方法
    搭建PHP运行环境是开发PHP应用程序的基础,本文将详尽、详实、细致地介绍从零开始搭建PHP运行环境的方法,包括选择操作系统、安装Web服务器、安装PHP以及配置相关组件等。 首先,选
    的头像 发表于 12-04 14:56 1366次阅读
    php运行环境本地测试地址是
    PHP运行环境本地测试地址是指在本地计算机上搭建的用于测试和运行PHP代码的的环境地址。搭建该运行环境
    的头像 发表于 12-04 15:25 875次阅读
    eclipse设置java运行环境
    在Eclipse中设置Java运行环境是非常重要的,它能够确保你的代码能够正确地编译和运行。下面介绍如何设置Java运行环境。 下载和安装J
    的头像 发表于 12-06 11:29 1703次阅读
    Docker运行环境安装
    、发布、测试和部署,可以帮助开发人员将最新版本代码应用到生产环境中。 Docker可以安装在多个平台中,包括Mac、Windows和Linux。不过,生产环境还是推荐在Linux上运行,以下以主流的Linux操作系统(CentO
    的头像 发表于 10-29 11:28 375次阅读
