Linux进程间的五种通信方式介绍 6
jf_78858299 来源:阿Q正砖 作者:阿Q正砖 2023-02-15 10:19 次阅读
client.c
#include#include // shared memory#include // semaphore#include // message queue
// 消息队列结构struct msg_form { long mtype; char mtext;};
// 联合体,用于semctl初始化union semun{ int val; /for SETVAL/ struct semid_ds buf; unsigned short *array;};
// P操作:// 若信号量值为1,获取资源并将信号量值-1 // 若信号量值为0,进程挂起等待int sem_p(int sem_id){ struct sembuf sbuf; sbuf.sem_num = 0; /序号/ sbuf.sem_op = -1; /P操作/ sbuf.sem_flg = SEM_UNDO;
if(semop(sem_id, &sbuf, 1) == -1) { perror("P operation Error"); return -1; } return 0;}
// V操作:// 释放资源并将信号量值+1// 如果有进程正在挂起等待,则唤醒它们int sem_v(int sem_id){ struct sembuf sbuf; sbuf.sem_num = 0; /序号/ sbuf.sem_op = 1; /V操作/ sbuf.sem_flg = SEM_UNDO;
if(semop(sem_id, &sbuf, 1) == -1) { perror("V operation Error"); return -1; } return 0;}
int main(){ key_t key; int shmid, semid, msqid; char shm; struct msg_form msg; int flag = 1; /while循环条件/
// 获取key值 if((key = ftok(".", 'z')) < 0) { perror("ftok error"); exit(1); }
// 获取共享内存 if((shmid = shmget(key, 1024, 0)) == -1) { perror("shmget error"); exit(1); }
// 连接共享内存 shm = (char*)shmat(shmid, 0, 0); if((int)shm == -1) { perror("Attach Shared Memory Error"); exit(1); }
// 创建消息队列 if ((msqid = msgget(key, 0)) == -1) { perror("msgget error"); exit(1); }
// 获取信号量 if((semid = semget(key, 0, 0)) == -1) { perror("semget error"); exit(1); } // 写数据 printf("\\n"); printf("* IPC \\n"); printf(" Input r to send data to server. \\n"); printf(" Input q to quit. \\n"); printf("\\n"); while(flag) { char c; printf("Please input command: "); scanf("%c", &c); switch(c) { case 'r': printf("Data to send: "); sem_p(semid); /访问资源/ scanf("%s", shm); sem_v(semid); /释放资源/ /清空标准输入缓冲区/ while((c=getchar())!='\\n' && c!=EOF); msg.mtype = 888; msg.mtext = 'r'; /发送消息通知服务器读数据/ msgsnd(msqid, &msg, sizeof(msg.mtext), 0); break; case 'q': msg.mtype = 888; msg.mtext = 'q'; msgsnd(msqid, &msg, sizeof(msg.mtext), 0); flag = 0; break; default: printf("Wrong input!\\n"); /清空标准输入缓冲区*/ while((c=getchar())!='\\n' && c!=EOF); } }
// 断开连接 shmdt(shm);
return 0;}
注意:当scanf()输入字符或字符串时,缓冲区中遗留下了\\n,所以每次输入操作后都需要清空标准输入的缓冲区。但是由于 gcc 编译器不支持fflush(stdin)(它只是标准C的扩展),所以我们使用了替代方案:
五种通讯方式总结
1.管道:速度慢,容量有限,只有父子进程能通讯
2.FIFO:任何进程间都能通讯,但速度慢
3.消息队列:容量受到系统限制,且要注意第一次读的时候,要考虑上一次没有读完数据的问题
4.信号量:不能传递复杂消息,只能用来同步
5.共享内存区:能够很容易控制容量,速度快,但要保持同步,比如一个进程在写的时候,另一个进程要注意读写的问题,相当于线程中的线程安全,当然,共享内存区同样可以用作线程间通讯,不过没这个必要,线程间本来就已经共享了同一进程内的一块内存。
  • Linux
  • IPC
    IPC
  • 进程间通信
    Linux进程如何实现共享内存通信
    这次我们来讲一下Linux进程通信中重要的通信方式:共享内存作为Linux软件开发攻城狮,
    发表于 04-26 17:14 710次阅读
    Linux进程通信方式-管道
    Linux进程通信方式-管道分享到: 本文关键字: linux 管道
    发表于 08-29 15:29
    Linux进程通信
    华清远见嵌入式linux学习资料《Linux进程通信》,通过前面的学习,读者已经知道了进程
    发表于 09-04 10:07
    哪些方式可以实现Linux系统下的进程通信
    哪些方式可以实现Linux系统下的进程通信进程与线程有哪些不同之处呢?
    发表于 12-24 06:38
    进程通信Linux进程通信概述
    人们现在广泛使用的手机等方式。本章就是讲述如何建立这些不同的通话方式,就像人们有多种通信方式一样。 Linux下的
    发表于 10-18 16:21 0次下载
    Linux进程通信方式——管道
    管道是Linux进程通信的一方式,它把一个程序的输出直接连接到另一个程序的输入。
    发表于 06-01 09:13 1475次阅读
    <b class='flag-5'>Linux</b><b class='flag-5'>进程</b><b class='flag-5'>间</b><b class='flag-5'>通信</b><b class='flag-5'>方式</b>——管道
    Linux进程通信方法之管道
    上文中我们介绍进程通信的方法之一:信号,本文将继续介绍另一
    的头像 发表于 05-14 15:47 2018次阅读
    <b class='flag-5'>Linux</b><b class='flag-5'>进程</b><b class='flag-5'>间</b><b class='flag-5'>通信</b>方法之管道
    Linux进程通信方式介绍 1
    进程通信(IPC,InterProcess Communication)是指在不同进程之间传播或交换信息。IPC的方式通常有管道(包括无名
    的头像 发表于 02-15 10:18 1472次阅读
    <b class='flag-5'>Linux</b><b class='flag-5'>进程</b><b class='flag-5'>间</b>的<b class='flag-5'>五</b><b class='flag-5'>种</b><b class='flag-5'>通信</b><b class='flag-5'>方式</b><b class='flag-5'>介绍</b> 1
    Linux进程通信方式介绍 2
    的头像 发表于 02-15 10:19 591次阅读
    <b class='flag-5'>Linux</b><b class='flag-5'>进程</b><b class='flag-5'>间</b>的<b class='flag-5'>五</b><b class='flag-5'>种</b><b class='flag-5'>通信</b><b class='flag-5'>方式</b><b class='flag-5'>介绍</b> 2
    Linux进程通信方式介绍 3
    的头像 发表于 02-15 10:19 542次阅读
    Linux进程通信方式介绍 4
    的头像 发表于 02-15 10:19 626次阅读
    Linux进程通信方式介绍 5
    的头像 发表于 02-15 10:20 625次阅读
    常见的进程通信方式
    进程通信 如果两个进程,想要知道对方在干嘛,或者进行协调运行,就需要进程
    的头像 发表于 10-08 15:48 1389次阅读
    常见的<b class='flag-5'>进程</b><b class='flag-5'>间</b><b class='flag-5'>通信</b><b class='flag-5'>方式</b>
    进程通信方式总结
    进程通信(IPC): 进程通信方式有很多,这里
    的头像 发表于 11-09 09:25 808次阅读
    <b class='flag-5'>进程</b><b class='flag-5'>间</b><b class='flag-5'>通信</b><b class='flag-5'>方式</b>总结
    进程通信的消息队列介绍
    消息队列是一非常常见的进程通信方式
    的头像 发表于 04-08 17:27 339次阅读
