前文:
kubernetes:集群部署
kubernetes:应用部署与访问
部署后的视图为:
在此基础上,本文研究flannel网络的数据流视图。
一、flannel网络的数据流转是怎样的?
(一)node1节点:
1、查询node1节点详细信息,flannel的Backend类型为vxlan。
root@master: kubectl describe node node1
Roles: node
Labels: beta.kubernetes.io/arch=amd64
beta.kubernetes.io/os=linux
kubernetes.io/hostname=node1
node-role.kubernetes.io/node=
Annotations: flannel.alpha.coreos.com/backend-data: {"VNI":1,"VtepMAC":"2a:95:ed:10:e4:56"}
flannel.alpha.coreos.com/backend-type: vxlan
flannel.alpha.coreos.com/kube-subnet-manager: true
flannel.alpha.coreos.com/public-ip: 30.0.1.160
kubeadm.alpha.kubernetes.io/cri-socket: /var/run/dockershim.sock
node.alpha.kubernetes.io/ttl: 0
volumes.kubernetes.io/controller-managed-attach-detach: true
2、查询node节点信息,node1部署httpd-app、httpd-test两个POD,node2同样部署httpd-app、httpd-test另外两个POD。
root@k8s:~# kubectl get pods -o wide
NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES
httpd-app-675b65488d-6kgk6 1/1 Running 0 2d5h 10.244.2.2 node2
httpd-app-675b65488d-9w69v 1/1 Running 0 2d5h 10.244.1.2 node1
httpd-test-fd769fcb7-nbqsn 1/1 Running 0 32h 10.244.2.3 node2
httpd-test-fd769fcb7-nnm99 1/1 Running 0 32h 10.244.1.3 node1
3、进入node1节点httpd-app-675b65488d-9w69v,执行ip addr,查询端口信息。
初次执行ip addr命令提示ip not found,需要安装iproute2。
root@k8s:~# kubectl exec -it httpd-app-675b65488d-9w69v /bin/sh
kubectl exec [POD] [COMMAND] is DEPRECATED and will be removed in a future version. Use kubectl exec [POD] -- [COMMAND] instead.
# ip addr
/bin/sh: 6: ip: not found
# apt-get install iproute2
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
libatm1 libbpf0 libbsd0 libcap2 libcap2-bin libelf1 libmd0 libmnl0 libpam-cap libxtables12
Suggested packages:
iproute2-doc
The following NEW packages will be installed:
iproute2 libatm1 libbpf0 libbsd0 libcap2 libcap2-bin libelf1 libmd0 libmnl0 libpam-cap libxtables12
0 upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 1530 kB of archives.
After this operation, 4960 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://deb.debian.org/debian bullseye/main amd64 libelf1 amd64 0.183-1 [165 kB]
Get:2 http://deb.debian.org/debian bullseye/main amd64 libbpf0 amd64 1:0.3-2 [98.3 kB]
Get:3 http://deb.debian.org/debian bullseye/main amd64 libmd0 amd64 1.0.3-3 [28.0 kB]
Get:4 http://deb.debian.org/debian bullseye/main amd64 libbsd0 amd64 0.11.3-1 [108 kB]
Get:5 http://deb.debian.org/debian bullseye/main amd64 libcap2 amd64 1:2.44-1 [23.6 kB]
Get:6 http://deb.debian.org/debian bullseye/main amd64 libmnl0 amd64 1.0.4-3 [12.5 kB]
Get:7 http://deb.debian.org/debian bullseye/main amd64 libxtables12 amd64 1.8.7-1 [45.1 kB]
Get:8 http://deb.debian.org/debian bullseye/main amd64 libcap2-bin amd64 1:2.44-1 [32.6 kB]
Get:9 http://deb.debian.org/debian bullseye/main amd64 iproute2 amd64 5.10.0-4 [930 kB]
Get:10 http://deb.debian.org/debian bullseye/main amd64 libatm1 amd64 1:2.5.1-4 [71.3 kB]
Get:11 http://deb.debian.org/debian bullseye/main amd64 libpam-cap amd64 1:2.44-1 [15.4 kB]
Fetched 1530 kB in 1min 2s (24.8 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package libelf1:amd64.
(Reading database ... 6834 files and directories currently installed.)
Preparing to unpack .../00-libelf1_0.183-1_amd64.deb ...
Unpacking libelf1:amd64 (0.183-1) ...
Selecting previously unselected package libbpf0:amd64.
Preparing to unpack .../01-libbpf0_1%3a0.3-2_amd64.deb ...
Unpacking libbpf0:amd64 (1:0.3-2) ...
Selecting previously unselected package libmd0:amd64.
Preparing to unpack .../02-libmd0_1.0.3-3_amd64.deb ...
Unpacking libmd0:amd64 (1.0.3-3) ...
Selecting previously unselected package libbsd0:amd64.
Preparing to unpack .../03-libbsd0_0.11.3-1_amd64.deb ...
Unpacking libbsd0:amd64 (0.11.3-1) ...
Selecting previously unselected package libcap2:amd64.
Preparing to unpack .../04-libcap2_1%3a2.44-1_amd64.deb ...
Unpacking libcap2:amd64 (1:2.44-1) ...
Selecting previously unselected package libmnl0:amd64.
Preparing to unpack .../05-libmnl0_1.0.4-3_amd64.deb ...
Unpacking libmnl0:amd64 (1.0.4-3) ...
Selecting previously unselected package libxtables12:amd64.
Preparing to unpack .../06-libxtables12_1.8.7-1_amd64.deb ...
Unpacking libxtables12:amd64 (1.8.7-1) ...
Selecting previously unselected package libcap2-bin.
Preparing to unpack .../07-libcap2-bin_1%3a2.44-1_amd64.deb ...
Unpacking libcap2-bin (1:2.44-1) ...
Selecting previously unselected package iproute2.
Preparing to unpack .../08-iproute2_5.10.0-4_amd64.deb ...
Unpacking iproute2 (5.10.0-4) ...
Selecting previously unselected package libatm1:amd64.
Preparing to unpack .../09-libatm1_1%3a2.5.1-4_amd64.deb ...
Unpacking libatm1:amd64 (1:2.5.1-4) ...
Selecting previously unselected package libpam-cap:amd64.
Preparing to unpack .../10-libpam-cap_1%3a2.44-1_amd64.deb ...
Unpacking libpam-cap:amd64 (1:2.44-1) ...
Setting up libatm1:amd64 (1:2.5.1-4) ...
Setting up libcap2:amd64 (1:2.44-1) ...
Setting up libcap2-bin (1:2.44-1) ...
Setting up libmnl0:amd64 (1.0.4-3) ...
Setting up libxtables12:amd64 (1.8.7-1) ...
Setting up libmd0:amd64 (1.0.3-3) ...
Setting up libbsd0:amd64 (0.11.3-1) ...
Setting up libelf1:amd64 (0.183-1) ...
Setting up libpam-cap:amd64 (1:2.44-1) ...
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 78.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (Can't locate Term/ReadLine.pm in @INC (you may need to install the Term::ReadLine module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.32.1 /usr/local/share/perl/5.32.1 /usr/lib/x86_64-linux-gnu/perl5/5.32 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl-base /usr/lib/x86_64-linux-gnu/perl/5.32 /usr/share/perl/5.32 /usr/local/lib/site_perl) at /usr/share/perl5/Debconf/FrontEnd/Readline.pm line 7.)
debconf: falling back to frontend: Teletype
Setting up libbpf0:amd64 (1:0.3-2) ...
Setting up iproute2 (5.10.0-4) ...
Processing triggers for libc-bin (2.31-13+deb11u2) ...
# ip addr
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
3: eth0@if6: mtu 1400 qdisc noqueue state UP group default
link/ether 4a:1f:b9:9d:30:75 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.244.1.2/24 brd 10.244.1.255 scope global eth0
# ip route
default via 10.244.1.1 dev eth0
10.244.0.0/16 via 10.244.1.1 dev eth0
10.244.1.0/24 dev eth0 proto kernel scope link src 10.244.1.2
10.244.1.2的数据包从eth0出来,eth0为Veth设备,对端为@if6,也就是宿主机对应的6: veth76d1fce3@if3,这两者组成veth对。
4、进入宿主机,执行ip addr进行查看:
root@k8s:# ip addr
inet6 ::1/128 scope host
2: ens3: mtu 1450 qdisc fq_codel state UP group default qlen 1000
link/ether fa:16:3e:69:98:f3 brd ff:ff:ff:ff:ff:ff
inet 30.0.1.160/24 brd 30.0.1.255 scope global dynamic ens3
valid_lft 19286sec preferred_lft 19286sec
inet6 fe80::f816:3eff:fe69:98f3/64 scope link
3: docker0: mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:62:9b:ec:f4 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
4: flannel.1: mtu 1400 qdisc noqueue state UNKNOWN group default
link/ether 2a:95:ed:10:e4:56 brd ff:ff:ff:ff:ff:ff
inet 10.244.1.0/32 brd 10.244.1.0 scope global flannel.1
inet6 fe80::2895:edff:fe10:e456/64 scope link
5: cni0: mtu 1400 qdisc noqueue state UP group default qlen 1000
link/ether 36:a5:21:90:7c:9a brd ff:ff:ff:ff:ff:ff
inet 10.244.1.1/24 brd 10.244.1.255 scope global cni0
inet6 fe80::34a5:21ff:fe90:7c9a/64 scope link
6: veth76d1fce3@if3: mtu 1400 qdisc noqueue master cni0 state UP group default
link/ether 16:ae:4d:3a:e9:d8 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::14ae:4dff:fe3a:e9d8/64 scope link
7: veth16e5e638@if3: mtu 1400 qdisc noqueue master cni0 state UP group default
link/ether f6:93:97:52:2e:5a brd ff:ff:ff:ff:ff:ff link-netnsid 1
inet6 fe80::f493:97ff:fe52:2e5a/64 scope link
宿主机对应的6为veth76d1fce3。
或者,通过工具ethtool查询。如没安装,则执行apt-get install ethtool:
# ethtool -S eth0
/bin/sh: 27: ethtool: not found
# apt-get install ethtool
ethtool
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 182 kB of archives.
After this operation, 611 kB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bullseye/main amd64 ethtool amd64 1:5.9-1 [182 kB]
Fetched 182 kB in 1s (142 kB/s)
Selecting previously unselected package ethtool.
(Reading database ... 7124 files and directories currently installed.)
Preparing to unpack .../ethtool_1%3a5.9-1_amd64.deb ...
Unpacking ethtool (1:5.9-1) ...
Setting up ethtool (1:5.9-1) ...
# ethtool -S eth0
NIC statistics:
peer_ifindex: 6
5、veth设备veth76d1fce3在网桥cni0上,数据包便流转到cni0。
root@k8s:~# brctl show
bridge namebridge idSTP enabledinterfaces
cni08000.36a521907c9anoveth16e5e638
veth76d1fce3
docker08000.0242629becf4no
6、cni0的数据包将走到网关10.244.1.0
root@k8s:~# ifconfig
cni0: flags=4163 mtu 1400
inet 10.244.1.1 netmask 255.255.255.0 broadcast 10.244.1.255
inet6 fe80::34a5:21ff:fe90:7c9a prefixlen 64 scopeid 0x20
ether 36:a5:21:90:7c:9a txqueuelen 1000 (Ethernet)
RX packets 5683 bytes 328382 (328.3 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 6677 bytes 10746482 (10.7 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
flannel.1: flags=4163 mtu 1400
inet 10.244.1.0 netmask 255.255.255.255 broadcast 10.244.1.0
inet6 fe80::2895:edff:fe10:e456 prefixlen 64 scopeid 0x20
ether 2a:95:ed:10:e4:56 txqueuelen 0 (Ethernet)
RX packets 116 bytes 11090 (11.0 KB)
TX packets 101 bytes 9963 (9.9 KB)
TX errors 0 dropped 91 overruns 0 carrier 0 collisions 0
根据路由匹配规则,目的地址为10.244.2.2(假定ping操作)的数据包将会交由flannel.1设备处理。
root@k8s:# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 30.0.1.1 0.0.0.0 UG 100 0 0 ens3
10.244.0.0 10.244.0.0 255.255.255.0 UG 0 0 0 flannel.1
10.244.1.0 0.0.0.0 255.255.255.0 U 0 0 0 cni0
10.244.2.0 10.244.2.0 255.255.255.0 UG 0 0 0 flannel.1
30.0.1.0 0.0.0.0 255.255.255.0 U 0 0 0 ens3
169.254.169.254 30.0.1.1 255.255.255.255 UGH 100 0 0 ens3
172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0
而flannel.1为VTEP设备。
root@k8s:~# ip -d link show flannel.1
4: flannel.1: mtu 1400 qdisc noqueue state UNKNOWN mode DEFAULT group default
link/ether 2a:95:ed:10:e4:56 brd ff:ff:ff:ff:ff:ff promiscuity 0
vxlan id 1 local 30.0.1.160 dev ens3 srcport 0 0 dstport 8472 nolearning ttl inherit ageing 300 udpcsum noudp6zerocsumtx noudp6zerocsumrx addrgenmode eui64 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
(二)node2节点
1、查询node2节点的网络设备信息:ens3为宿主机的eth端口,cni0为网桥,flannel.1为VTEP设备。
root@k8s:/# ip addr
link/ether fa:16:3e:eb:3a:5e brd ff:ff:ff:ff:ff:ff
inet 30.0.1.47/24 brd 30.0.1.255 scope global dynamic ens3
valid_lft 61438sec preferred_lft 61438sec
inet6 fe80::f816:3eff:feeb:3a5e/64 scope link
link/ether 02:42:9c:0c:bb:08 brd ff:ff:ff:ff:ff:ff
link/ether 72:c8:ad:5f:87:07 brd ff:ff:ff:ff:ff:ff
inet 10.244.2.0/32 brd 10.244.2.0 scope global flannel.1
inet6 fe80::70c8:adff:fe5f:8707/64 scope link
link/ether de:fb:ba:bd:46:44 brd ff:ff:ff:ff:ff:ff
inet 10.244.2.1/24 brd 10.244.2.255 scope global cni0
inet6 fe80::dcfb:baff:febd:4644/64 scope link
6: veth79a7513f@if3: mtu 1400 qdisc noqueue master cni0 state UP group default
link/ether de:88:ba:a5:77:cb brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::dc88:baff:fea5:77cb/64 scope link
7: vethd0184a65@if3: mtu 1400 qdisc noqueue master cni0 state UP group default
link/ether 5a:6f:a9:bc:09:27 brd ff:ff:ff:ff:ff:ff link-netnsid 1
inet6 fe80::586f:a9ff:febc:927/64 scope link
root@k8s:/#
2、通过vxlan隧道,flannel.1会接收到来自node1节点的数据包,根据目的IP地址是10.244.2.2,进一步转发到cni0。
root@k8s:/# ip route
default via 30.0.1.1 dev ens3 proto dhcp src 30.0.1.47 metric 100
10.244.0.0/24 via 10.244.0.0 dev flannel.1 onlink
10.244.1.0/24 via 10.244.1.0 dev flannel.1 onlink
10.244.2.0/24 dev cni0 proto kernel scope link src 10.244.2.1
30.0.1.0/24 dev ens3 proto kernel scope link src 30.0.1.47
169.254.169.254 via 30.0.1.1 dev ens3 proto dhcp src 30.0.1.47 metric 100
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
3、cni0的端口设备为veth79a7513f、vethd0184a65。
root@k8s:/# brctl show cni0
bridge name bridge idSTP enabled interfaces
cni08000.defbbabd4644 no veth79a7513f
vethd0184a65
4、进入到httpd-app-675b65488d-6kgk6 pod中,查找veth设备对为veth79a7513f -- eth0@if6。
root@k8s:~# kubectl exec -it httpd-app-675b65488d-6kgk6 /bin/sh
# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
3: eth0@if6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1400 qdisc noqueue state UP group default
link/ether 0e:da:e9:4e:f0:bf brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.244.2.2/24 brd 10.244.2.255 scope global eth0
通过node1节点和node2节点的分析,则可得到数据流转图为:
二、网络抓包分析数据流
在node1节点httpd-app(10.244.1.2) ping node2节点httpd-app(10.244.2.2)。
通过在node1节点的pod路由追踪traceroute发现其链路为:
# traceroute 10.244.2.2
traceroute to 10.244.2.2 (10.244.2.2), 30 hops max, 60 byte packets
1 10.244.1.1 (10.244.1.1) 0.163 ms 0.025 ms 0.017 ms
2 10.244.2.0 (10.244.2.0) 1.269 ms 1.185 ms 1.097 ms
3 10-244-2-2.httpd-app.default.svc.cluster.local (10.244.2.2) 1.409 ms 1.357 ms 1.303 ms
1、node1节点的抓包点放在:flannel.1、ens3:
root@k8s:/# tcpdump -n -vv -i flannel.1 -w /var/tmp/n1-flannel.cap
root@k8s:/# tcpdump -n -vv -i ens3 -w /var/tmp/n1-ens3.cap
Node1--flannel.1
Node1--ens3
2、node2节点的抓包点放在:flannel.1、ens3:
root@k8s:/# tcpdump -n -vv -i flannel.1 -w /var/tmp/n2-flannel.cap
root@k8s:/# tcpdump -n -vv -i ens3 -w /var/tmp/n2-ens3.cap
Node2--flannel.1
Node2--ens3
通过flannel.1设备上抓的数据包来看,vxlan包没有在flannel.1获取到,而在ens3上是vxlan包的。vxlan解封包应该是在flanneld上进行的。
节点
220浏览量
24546 -
node
23浏览量
5986 -
VxLAN
24浏览量
3879
Kubernetes 网络模型如何实现常见网络任务
Kubernetes的Device Plugin设计解读
K8s 从懵圈到熟练 – 集群网络详解
在Kubernetes上运行Kubernetes
![在<b class='flag-5'>Kubernetes</b>上运行<b class='flag-5'>Kubernetes</b>](https://file.elecfans.com/web2/M00/49/EE/pYYBAGKhvHiAO8-iAAAmwMj0d8g546.png)
Kubernetes网络隔离NetworkPolicy实验
Kubernetes网络模型介绍以及如何实现常见网络任务
Kubernetes网络模型的基础知识
在Kubernetes集群发生网络异常时如何排查
跟踪Kubernetes的网络流量路径
Kubernetes中的网络模型
各种网络组件在 Kubernetes 集群中是如何交互的
![各种<b class='flag-5'>网络</b>组件在 <b class='flag-5'>Kubernetes</b> 集群中是如何交互的](https://file1.elecfans.com/web2/M00/88/8B/wKgaomRsG7WARog6AAAcsZxqjWw389.png)
探讨Kubernetes中的网络模型(各种网络模型分析)
![探讨<b class='flag-5'>Kubernetes</b>中的<b class='flag-5'>网络</b>模型(各种<b class='flag-5'>网络</b>模型分析)](https://file1.elecfans.com/web2/M00/95/29/wKgZomTm4JeAW7_IAAAn4ui8l64483.png)
