CubeMX配置DAC双通道输出电压和任意波形
CHANBAEK 来源:博客园-lzh666 作者:博客园-lzh666 2023-02-15 14:02 次阅读
一、相关函数
HAL_StatusTypeDef HAL_DAC_SetValue(DAC_HandleTypeDef* hdac, uint32_t Channel, uint32_t Alignment, uint32_t Data)//设置DAC输出电压值
HAL_StatusTypeDef HAL_DAC_Start(DAC_HandleTypeDef* hdac, uint32_t Channel)//使能DAC通道
uint32_t HAL_DAC_GetValue(DAC_HandleTypeDef* hdac, uint32_t Channel)//获取相应通道的输出值
HAL_StatusTypeDef HAL_DAC_Stop(DAC_HandleTypeDef* hdac, uint32_t Channel);
HAL_StatusTypeDef HAL_DAC_Start_DMA(DAC_HandleTypeDef* hdac, uint32_t Channel, uint32_t* pData, uint32_t Length, uint32_t Alignment);
HAL_StatusTypeDef HAL_DAC_Stop_DMA(DAC_HandleTypeDef* hdac, uint32_t Channel);
二、输出电压
比较简单,直接上代码
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_DAC_Init();
  MX_UART4_Init();
    HAL_DAC_SetValue(&hdac,DAC_CHANNEL_1,DAC_ALIGN_8B_R,128);
    HAL_DAC_SetValue(&hdac,DAC_CHANNEL_2,DAC_ALIGN_8B_R,255);
    HAL_DAC_Start(&hdac,DAC_CHANNEL_1);
    HAL_DAC_Start(&hdac,DAC_CHANNEL_2);
  while (1)
        printf("DAC-Channel 1 : %d\\r\\n",HAL_DAC_GetValue(&hdac,DAC_CHANNEL_1));
        printf("DAC-Channel 2 : %d\\r\\n\\n",HAL_DAC_GetValue(&hdac,DAC_CHANNEL_2));
        HAL_Delay(1000);
三、定时器触发DAC+DMA输出任意波形
(1)配置TIM6,话不多说,10ms触发一次,即100HZ。 如下图:
(2)配置DAC,比较简单,不多说,注意使能DMA:
(3)编程实现
int main(void)
        const uint16_t CH_value[32] = {    2448,2832,3186,3496,3751,3940,4057,4095,
        4057,3940,3751,3496,3186,2832,2448,2048,
        1648,1264,910,600,345,156,39,0,39,156,345,
        600,910,1264,1648,2048};
        HAL_Init();
        MX_GPIO_Init();
        MX_DMA_Init();
        MX_DAC_Init();
        MX_UART4_Init();
        MX_TIM6_Init();
        HAL_TIM_Base_Start(&htim6);
        HAL_DAC_Start_DMA(&hdac,DAC_CHANNEL_1,(uint32_t *)CH_value,32,DAC_ALIGN_12B_R);
        while (1)
                printf("DAC->Channel1 : %d\\r\\n",HAL_DAC_GetValue(&hdac,DAC_CHANNEL_1));
                HAL_Delay(10);
四、定时器触发DAC+DMA输出三波形
(1)CubeMX配置
最大三角波幅(Maximum Triangle Amplitude)为4095,即为3.3V(参考电压为3.3V)
(2)编程实现
1 void MX_DAC_Init(void)
 2 {
 3   DAC_ChannelConfTypeDef sConfig = {0};
 4
 5   /** DAC Initialization
 6   */
 7   hdac.Instance = DAC;
 8   if (HAL_DAC_Init(&hdac) != HAL_OK)
 9   {
10     Error_Handler();
11   }
12   /** DAC channel OUT1 config
13   */
14   sConfig.DAC_Trigger = DAC_TRIGGER_T6_TRGO;
15   sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_ENABLE;
16   if (HAL_DAC_ConfigChannel(&hdac, &sConfig, DAC_CHANNEL_1) != HAL_OK)
17   {
18     Error_Handler();
19   }
20   /** DAC channel OUT2 config
21   */
22   if (HAL_DAC_ConfigChannel(&hdac, &sConfig, DAC_CHANNEL_2) != HAL_OK)
23   {
24     Error_Handler();
25   }
26   /** Configure Triangle wave generation on DAC OUT2
27   */
28   if (HAL_DACEx_TriangleWaveGenerate(&hdac, DAC_CHANNEL_2, DAC_TRIANGLEAMPLITUDE_4095) != HAL_OK)
29   {
30     Error_Handler();
31   }
32
33 }
34
35
36
37 int main(void)
38 {
39   /* USER CODE BEGIN 1 */
40     const uint16_t CH_value[32] = {    2448,2832,3186,3496,3751,3940,4057,4095,
41        4057,3940,3751,3496,3186,2832,2448,2048,
42        1648,1264,910,600,345,156,39,0,39,156,345,
43        600,910,1264,1648,2048};
44   /* USER CODE END 1 */
45
46
47   /* MCU Configuration--------------------------------------------------------*/
48
49   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
50   HAL_Init();
51
52   /* USER CODE BEGIN Init */
53
54   /* USER CODE END Init */
55
56   /* Configure the system clock */
57   SystemClock_Config();
58
59   /* USER CODE BEGIN SysInit */
60
61   /* USER CODE END SysInit */
62
63   /* Initialize all configured peripherals */
64   MX_GPIO_Init();
65   MX_DMA_Init();
66   MX_DAC_Init();
67   MX_UART4_Init();
68   MX_TIM6_Init();
69   /* USER CODE BEGIN 2 */
70     HAL_TIM_Base_Start(&htim6);
71     HAL_DAC_Start_DMA(&hdac,DAC_CHANNEL_1,(uint32_t *)CH_value,32,DAC_ALIGN_12B_R);
72     HAL_DAC_Start(&hdac,DAC_CHANNEL_2);
73   /* USER CODE END 2 */
74
75   /* Infinite loop */
76   /* USER CODE BEGIN WHILE */
77   while (1)
78   {
79     /* USER CODE END WHILE */
80         printf("DAC Channel 1 ------> %d\\r\\n",HAL_DAC_GetValue(&hdac,DAC_CHANNEL_1));
81         printf("DAC Channel 2 ------> %d\\r\\n\\n",HAL_DAC_GetValue(&hdac,DAC_CHANNEL_2));
82         HAL_Delay(10);
83     /* USER CODE BEGIN 3 */
84   }
85   /* USER CODE END 3 */
86 }
  • dac
    dac
  • 输出电压
  • 函数
  • dma
    dma
  • 任意波形
    使用DAC的软件可配置16位双通道单极性双极性电压输出
    软件可配置16位双通道单极性/双极性电压输出,采用DAC,16位,2CH DAC进行仪表测量
    发表于 06-25 11:22
    STM32单片机基础20——使用DAC输出任意指定电压 相关资料推荐
    【STM32Cube_20】使用DAC输出任意指定电压值tags: STM32CubeMX DACcategories: STM32CubeMX
    发表于 07-01 06:45
    如何使用STM32CubeMX配置STM32L431RCT6的DAC外设输出任意指定电压值?
    发表于 10-13 09:13
    RIGOL DG4000系列双通道 函数/任意波形发生器性能特点
    。DG4000可以输出16次谐波,真实模拟谐波信号,并且两个通道均能输出,互不干扰。  六. 7英寸高清屏。为了给工程师提供更好的使用体验,DG4000系列 双通道 函数/
    发表于 01-05 14:11
    MFG-2220HM双通道任意波形信号发生器的性能特点及应用
    MFG-2220HM双通道任意波形信号发生器,包括了CH1与CH2为两个最高频率为200MHz的等性能双通道AFG(任意
    的头像 发表于 12-31 16:47 3451次阅读
    AN-1198: 利用AD5722R DAC提供软件可配置的12位、双通道、单极性/双极性电压输出
    发表于 03-21 17:08 9次下载
    AN-1198: 利用AD5722R <b class='flag-5'>DAC</b>提供软件可<b class='flag-5'>配置</b>的12位、<b class='flag-5'>双通道</b>、单极性/双极性<b class='flag-5'>电压</b><b class='flag-5'>输出</b>
    AN-1197:使用AD5732R DAC的软件可配置14位双通道单极/双极电压输出
    发表于 05-07 19:50 12次下载
    AN-1197:使用AD5732R <b class='flag-5'>DAC</b>的软件可<b class='flag-5'>配置</b>14位<b class='flag-5'>双通道</b>单极/双极<b class='flag-5'>电压</b><b class='flag-5'>输出</b>
    UG-973:AD5322 12位双通道电压输出DAC评估板
    发表于 05-12 20:51 4次下载
    UG-973:AD5322 12位<b class='flag-5'>双通道</b><b class='flag-5'>电压</b><b class='flag-5'>输出</b><b class='flag-5'>DAC</b>评估板
    UG-979:AD5338R 10位双通道电压输出DAC评估板
    发表于 05-13 09:44 9次下载
    UG-979:AD5338R 10位<b class='flag-5'>双通道</b><b class='flag-5'>电压</b><b class='flag-5'>输出</b><b class='flag-5'>DAC</b>评估板
    : 2707806886date: 2019-07-31 10:48:56本篇详细的记录了如何使用STM32CubeMX配置STM32L431RCT6的DAC外设,输出任意指定
    发表于 11-19 09:36 57次下载
    STM32单片机基础20——使用<b class='flag-5'>DAC</b><b class='flag-5'>输出任意</b>指定<b class='flag-5'>电压</b>
    任意波形发生器如何输出电压
    任意波形发生器如何输出电压任意波形发生器是一种能够产生各种形状、频率和振幅的
    的头像 发表于 12-21 14:13 775次阅读
    任意波形发生器如何输出电压
    需求。本文将详细阐述任意波形发生器如何输出电压的过程,包括其工作原理、主要组件、输出控制以及影响输出
    的头像 发表于 05-15 15:38 787次阅读
    DAC53xAxW具有I2C或SPI的10位三通道双通道电压输出和电流输出智能DAC数据表
    电子发烧友网站提供《DAC53xAxW具有I2C或SPI的10位三通道双通道电压输出和电流输出
    发表于 07-12 09:42 0次下载
    <b class='flag-5'>DAC</b>53xAxW具有I2C或SPI的10位三<b class='flag-5'>通道</b>和<b class='flag-5'>双通道</b><b class='flag-5'>电压</b><b class='flag-5'>输出</b>和电流<b class='flag-5'>输出</b>智能<b class='flag-5'>DAC</b>数据表
    DAC82002 16位、低毛刺脉冲、双通道电压输出、非缓冲DAC数据表
    电子发烧友网站提供《DAC82002 16位、低毛刺脉冲、双通道电压输出、非缓冲DAC数据表.pdf》资料免费下载
    发表于 07-15 10:07 0次下载
    <b class='flag-5'>DAC</b>82002 16位、低毛刺脉冲、<b class='flag-5'>双通道</b><b class='flag-5'>电压</b><b class='flag-5'>输出</b>、非缓冲<b class='flag-5'>DAC</b>数据表
    DAC8552双通道电压输出数模转换器(DAC)数据表
    电子发烧友网站提供《DAC8552双通道电压输出数模转换器(DAC)数据表.pdf》资料免费下载
    发表于 07-26 09:15 1次下载
    <b class='flag-5'>DAC</b>8552<b class='flag-5'>双通道</b>、<b class='flag-5'>电压</b><b class='flag-5'>输出</b>数模转换器(<b class='flag-5'>DAC</b>)数据表
