CM4 Industrial是一款基于 Raspberry Pi / 树莓派 Compute Module 4,由EDATEC面向工业应用设计的嵌入式计算机设计的工业嵌入式计算机。系统可以根据不同的应用配置成1GB/2GB/4GB/8GB 的 RAM 和8GB/16GB/32GB 的 EMMC,支持 SD 卡启动。
CM4 Industrial
SPECIFICATIONS
分类 | 特点 |
处理器 |
Broadcom BCM2711 quad-core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz H.265 (HEVC) (up to 4Kp60 decode), H.264 (up to 1080p60 decode, 1080p30 encode) OpenGL ES 3.1, Vulkan 1.0 |
内存 | 1GB / 2GB / 4GB / 8GB LPDDR4-3200 SDRAM |
储存 |
Onboard 0GB / 8GB / 16GB / 32GB eMMC 1x microSD Card Slot for system boot when choosing 0GB(CM4 Lite) eMMC Onboard 32Mbits / 4MBytes SPI Flash |
显示 |
1x standard HDMI Out (Type A) 1x FPC HDMI Touch Display 1x FPC DSI Touch Display |
摄像头 | 1x FPC CSI, Support Raspberry Pi Official 5M & 8M Cameras |
有线接口 |
1x Gig-Ethernet (10/100/1000M), Support PoE (with Raspberry Pi PoE HAT) 1x Fast-Ethernet (10/100M) 2x USB 2.0 Type-A 1x USB micro-B for eMMC Flashing (Inside the case) |
无线 |
Optional 2.4 GHz, 5.0 GHz IEEE 802.11 b/g/n/ac wireless and Bluetooth 5.0, BLE with external antenna Optional 4G LTE with optional GPS support, 1x Standard-SIM card slot, external antenna |
工业接口 |
2x RS485, 6-pin Terminal Block 1x RS232, 3-pin Terminal Block 3x 12-bits ADC Channels, 4-pin Terminal Block 2x isolated DI, Support Dry / Wet Contact 1x SPDT Relay, 6-pin Terminal Block 1x RTC with CR1220backup 1x adjustable speed fan control, 3-pin wafer connector 1x Buzzer |
扩展接口 |
1x mini-PCIe slot with 1-lane PCIe and 1x USB 2.0, Support 4G Module 1x standard Raspberry Pi 40-PIN GPIO 1x Serial(TTL), 4-pin DIP connector 2x USB 2.0, 4-pin DIP connector 1x non-isolated IO, 2-pin DIP connector |
电源输入 |
8 ~ 36VDC* DC Jack or optional 2-pin Terminal Block |
指示灯 |
1x Power Indicator with Red LED 1x Status Indicator with Green LED 1x 4G network indicator with Blue LED (Inside the case) |
按键 |
1x System Reset Button 1x User Button |
工作温度 | -25~ 50°C |
操作湿度 | 10% - 60% |
外壳 | Metal Case, 2 Antenna Holes |
尺寸 | 147(L) x 119(W) x 28(H) mm |
安装方式 |
DIN-mount Wall-mount |
操作系统 |
Pre-installed with 32-bit Raspberry Pi OS with Desktop in eMMC(if choosing eMMC variants) Compatible with Origin Raspberry Pi OS, support 32-bit and 64-bit OS, support Lite and Desktop versions Support BSP online install / upgrade with APT tool |
INFORMATION
- 它提供多种工业通讯接口和功能如多路 RS232,RS485,多路高精度 ADC,隔离 IO 输入,继电器控制,电池备份的实时时钟,告警蜂鸣器。它也提供了强大的通讯能力,1路带PoE功能的千兆以太网接口,1路10/100M网口,4G/LTE模块,经过认证的 2.4/5.8G 双频 WiFi 和蓝牙,支持外置天线。
- CM4 Industrial可以支持一路官方 8 百万像素的摄像头,一路DSI 显示接口和一路HDMI的排线接口。其他特征包括板载32Mb串行Flash用于储存系统数据,8~36V*宽范围供电,重要的接口都做了 ESD 保护。
- 系统提供非常强的扩展能力,Mini-PCIe的座子提供PCIe 1x Gen2接口扩展,除支持标准的40针扩展接口外,还提供 2 路 4 针 USB 接口用于机壳内部扩展,1路TTL电平的RS232 接口等,以充分利用其强大的通信功能来满足工业场景中的各种要求。
举报投诉
嵌入式
5057文章
18964浏览量
301816 -
工业计算机
101浏览量
16121 -
物联网
2900文章
44029浏览量
370028 -
工控机
10文章
1668浏览量
50386 -
树莓派
116文章
1687浏览量
105448
什么是工业计算机(IPC)?
工业电脑也称为IPC,其组件专门设计用于工业工作环境。因此,工业计算机特别坚固,基于强大的处理器,可以根据相应的应用进行单独调整。工业计算机的典型方面:耐恶劣环境(包括灰尘、水、溅水、
工业计算机的功能和特点
在数字化和自动化的浪潮中,工业计算机以其独特的功能和强大的计算能力,逐渐在工业领域中崭露头角。本文将对工业计算机进行详细介绍,包括其定义、功能、特点以及在不同领域的应用,旨在为读者提供
工业计算机与普通计算机的区别
在信息化和自动化日益发展的今天,计算机已经成为了我们日常生活和工作中不可或缺的工具。然而,在计算机领域中,工业计算机和普通计算机虽然都具备基本的计算
无风扇工业计算机有哪些优势?
无风扇工业计算机有哪些优势? 无风扇工业计算机是一种针对特殊工业环境设计的计算机系统,相比传统的风扇散热系统,它具备许多独特的优势和特点。
无风扇工业计算机有哪些优势?
在工业计算领域,无风扇系统因其独特的设计和众多优势而获得了巨大的关注。与依靠风扇进行冷却的传统计算机不同,无风扇工业计算机经过精心设计,无需移动部件即可散热。在这篇文章中,我们将探讨无
