python日常记账本源代码,基于PySide6(Qt for Python 6)的账本,界面简洁、功能强大,支持保存文件、快速查询、绘制图表等,是平时记账的不错选择。账目查询、账本编辑、添加/删除、撤销/重做、统计数据、生成图表。
main.py
import sys
from bisect import insort_right
from functools import partial
from os.path import basename
from webbrowser import open_new_tab
from PySide6.QtWidgets import *
from PySide6.QtCore import Slot, QDate
from PySide6.QtGui import QStandardItem, QStandardItemModel
from api import ApiError, openFile, query, saveFile
from dlgAdd import dlgAdd
from dlgCharts import dlgCharts
from dlgSettings import dlgSettings
from ui_dlgHelp import Ui_Dialog as Ui_dlgHelp
from ui_MainWindow import Ui_MainWindow
# Version info
VERSION = '1.2.1'
CHANNEL = 'stable'
BUILD_DATE = '2022-08-25'
FULL_VERSION = f'{VERSION}-{CHANNEL} ({BUILD_DATE}) on {sys.platform}'
app = QApplication(sys.argv)
class AccountBookMainWindow(QMainWindow):
version_str = '账本 ' + VERSION
unsaved_tip = '*'
SUPPORTED_FILTERS = '账本文件(*.abf);;文本文件(*.txt);;所有文件(*.*)'
def __init__(self, parent=None):
# Initialize window
super().__init__(parent)
self.ui = Ui_MainWindow()
self.ui.setupUi(self)
self.setWindowTitle('账本 ' + VERSION)
self.labStatus = QLabel(self)
self.ui.statusBar.addWidget(self.labStatus)
# Initialize table
self.model = QStandardItemModel(0, 4, self)
self.model.setHorizontalHeaderLabels(['日期', '事项', '金额', '备注'])
self.ui.table.setModel(self.model)
self.ui.table.horizontalHeader().setSectionResizeMode(QHeaderView.Stretch)
self.__data = []
self.on_actFile_New_triggered()
self.ui.actEdit_Remove.setEnabled(False)
# Connect slots
self.ui.table.selectionModel().selectionChanged.connect(self.__selectionChanged)
self.model.itemChanged.connect(self.__itemChanged)
def __updateTable(self, data):
self.model.itemChanged.disconnect(self.__itemChanged)
self.model.setRowCount(len(data))
for row in range(len(data)):
for col in range(len(data[row])):
self.model.setItem(row, col, QStandardItem(data[row][col]))
def __openFile(self, filename):
try:
self.__data = openFile(filename)
except IOError:
QMessageBox.critical(self, '错误', '文件打开失败。请稍后再试。')
except ApiError:
QMessageBox.critical(self, '错误', '文件格式错误。请检查文件完整性。')
except Exception as e:
QMessageBox.critical(self, '错误', '未知错误:' + str(e.with_traceback()))
else:
self.ui.searchEdit.clear()
self.__key = ''
self.__updateTable(self.__data)
self.labStatus.setText(filename)
self.setWindowTitle(self.version_str)
self.__filename = filename
def __saveFile(self, filename):
try:
saveFile(filename, self.__data)
except IOError:
QMessageBox.critical(self, '错误', '文件保存错误。请稍后再试。')
else:
self.labStatus.setText('保存成功:' + filename)
@Slot()
def on_actFile_New_triggered(self):
self.__filename = self.__key = ''
self.setWindowTitle(self.unsaved_tip + self.version_str)
self.labStatus.setText('新文件')
self.model.setRowCount(0)
self.__data.clear()
@Slot()
def on_actFile_Open_triggered(self):
filename, _ = QFileDialog.getOpenFileName(self, '打开', filter=self.SUPPORTED_FILTERS)
if filename:
self.__openFile(filename)
@Slot()
def on_actFile_Save_triggered(self):
if self.__filename:
self.__saveFile(self.__filename)
else:
filename, _ = QFileDialog.getSaveFileName(self, '保存', filter=self.SUPPORTED_FILTERS)
if filename:
self.__saveFile(filename)
@Slot()
def on_actFile_SaveAs_triggered(self):
filename, _ = QFileDialog.getSaveFileName(self, '另存为', filter=self.SUPPORTED_FILTERS)
if filename:
@Slot()
def on_actFile_Settings_triggered(self):
dlgSettings(self).exec()
@Slot()
def on_actHelp_About_triggered(self):
dialog = QDialog(self)
ui = Ui_dlgHelp()
ui.setupUi(dialog)
for link in (ui.githubLink, ui.giteeLink, ui.licenseLink, ui.readmeLink):
link.clicked.connect(partial(open_new_tab, link.description()))
ui.labVersion.setText('版本号:' + FULL_VERSION)
ui.btnUpdate.clicked.connect(partial(open_new_tab, 'https://github.com/GoodCoder666/AccountBook/releases'))
dialog.exec()
@Slot()
def on_actHelp_AboutQt_triggered(self):
QMessageBox.aboutQt(self, '关于Qt')
@Slot()
def on_actEdit_Add_triggered(self):
dialog = dlgAdd(self)
if dialog.exec() == QDialog.Accepted:
row = dialog.getRow()
insort_right(self.__data, row)
self.__updateTable(query(self.__data, self.__key))
@Slot()
def on_actEdit_Remove_triggered(self):
rows = list(set(map(lambda idx: idx.row(), self.ui.table.selectedIndexes())))
for row in rows:
self.__data.remove([self.model.item(row, col).text() for col in range(self.model.columnCount())])
self.model.removeRows(rows[0], len(rows))
def __selectionChanged(self):
self.ui.actEdit_Remove.setEnabled(self.ui.table.selectionModel().hasSelection())
def __itemChanged(self, item: QStandardItem):
i, j, new = item.row(), item.column(), item.text()
if (old := self.__data[i][j]) == new: return
if j == 0 and not QDate.fromString(new, 'yyyy/MM/dd').isValid():
QMessageBox.critical(self, '错误', '日期格式错误。')
item.setText(old)
return
row = self.__data.pop(i)
row[j] = new
@Slot()
def on_searchEdit_textChanged(self):
self.__key = self.ui.searchEdit.text()
@Slot()
def on_actStat_Show_triggered(self):
if self.__data:
dlgCharts(self.__data, self).exec()
else:
QMessageBox.information(self, '提示', '请添加数据以使用统计功能。')
def closeEvent(self, event):
if not self.windowTitle().startswith(self.unsaved_tip): return
filename = basename(self.__filename) if self.__filename else '新文件'
messageBox = QMessageBox(
parent=self, icon=QMessageBox.Warning, windowTitle='提示',
text=f'是否要保存对 {filename} 的更改?', informativeText='如果不保存,你的更改将丢失。',
standardButtons=QMessageBox.Save | QMessageBox.Discard | QMessageBox.Cancel
messageBox.setButtonText(QMessageBox.Save, '保存')
messageBox.setButtonText(QMessageBox.Discard, '不保存')
messageBox.setButtonText(QMessageBox.Cancel, '取消')
reply = messageBox.exec()
if reply == QMessageBox.Save:
self.on_actFile_Save_triggered()
event.accept()
elif reply == QMessageBox.Discard:
event.accept()
else:
event.ignore()
def dragEnterEvent(self, event):
event.accept()
def dropEvent(self, event):
self.__openFile(event.mimeData().text()[8:]) # [8:] is to get rid of 'file:///'
mainform = AccountBookMainWindow()
mainform.show()
sys.exit(app.exec())
完整程序下载地址:
https://download.csdn.net/download/weixin_42756970/86845889
举报投诉
文件
1文章
573浏览量
24918 -
源代码
96文章
2947浏览量
67157 -
python
56文章
4812浏览量
85255
选手SHOW|确认过眼神,是我最想要的记账APP!
。不仅如此,圈子账本还考虑到日常记账习惯,开发出了圈子功能,让商业伙伴、家庭成员、结伴出行的小伙伴都可以在同一账本记账。不仅拉近了彼此之间的
发表于 07-02 11:48
uCOS-II-V280是当前UCosII最新版本源代码
/*********************************************************************************************************** &n
发表于 02-24 14:24
•0次下载
区块高度和记账本之间有什么关联
区块链就像是一个记账本,而区块就像是这个记账本里面的一页页记账纸,区块高度就是记账纸的页码,当同时出现两个相同页码时就会发生分叉。
发表于 10-15 14:09
•613次阅读
区块高度与记账本页码之间的关系分析
区块高度顾名思义就是区块的高度,准确地说是连接在区块链上的块数。因此想要明白什么是区块高度,我们得首先搞明白什么是区块链。如果说区块链是记账本的话,那么一个区块就像是记账本的每一页一样。
发表于 10-16 10:20
•694次阅读
20个解决日常问题的Python代码片段!
在本文中,将分享20 个 Python 代码片段,以帮助你应对日常编程挑战。你可能已经知道其中一些片段,但有些其他片段对你来说可能是新的。赶紧使用这些有用的 Python
