通过卷积神经网络实现MNIST数据集分类
jf_78858299 来源:算法与编程之美 作者:编程之美 2023-03-02 09:38 次阅读
问题
对比单个全连接网络,在卷积神经网络层的加持下,初始时,整个神经网络模型的性能是否会更好。
方法
模型设计
两层卷积神经网络(包含池化层),一层全连接网络。
  1. 选择 5 x 5 的卷积核,输入通道为 1,输出通道为 10:
    此时图像矩阵经过 5 x 5 的卷积核后会小两圈,也就是4个数位,变成 24 x 24,输出通道为10;
  2. 选择 2 x 2 的最大池化层:
    此时图像大小缩短一半,变成 12 x 12,通道数不变;
  3. 再次经过5 x 5的卷积核,输入通道为 10,输出通道为 20:
    此时图像再小两圈,变成 8*8,输出通道为20;
  4. 再次经过2 x 2的最大池化层:
    此时图像大小缩短一半,变成 4 x 4,通道数不变;
  5. 最后将图像整型变换成向量,输入到全连接层中:
    输入一共有 4 x 4 x 20 = 320个元素,输出为 10.
代码
准备数据集
准备数据集
batch_size = 64
transform = transforms.Compose([
transforms.ToTensor(),
transforms.Normalize((0.1307,), (0.3081,))
train_dataset = datasets.MNIST(root='data’,
train=True,
                          download=True,
                          transform=transform)
train_loader = DataLoader(train_dataset,
shuffle=True,
                     batch_size=batch_size)
test_dataset = datasets.MNIST(root='data',
train=False,
                         download=True,
test_loader = DataLoader(test_dataset,
shuffle=False,
建立模型
class Net(torch.nn.Module):
def init (self):
super(Net, self).__init__()
   self.conv1 = torch.nn.Conv2d(1, 10, kernel_size=5)
   self.conv2 = torch.nn.Conv2d(10, 20, kernel_size=5)
   self.pooling = torch.nn.MaxPool2d(2)
   self.fc = torch.nn.Linear(320, 10)
def forward(self, x):
batch_size = x.size(0)
   x = F.relu(self.pooling(self.conv1(x)))
   x = F.relu(self.pooling(self.conv2(x)))
   x = x.view(batch_size, -1)
   x = self.fc(x)
   return x
model = Net()
device = torch.device("cuda:0" if torch.cuda.is_available() else "cpu")
model.to(device)
构造损失函数+优化器
criterion = torch.nn.CrossEntropyLoss()
optimizer = optim.SGD(model.parameters(), lr=0.01, momentum=0.5)
训练+测试
def train(epoch):
running_loss = 0.0
for batch_idx, data in enumerate(train_loader, 0):
inputs, target = data
   inputs,target=inputs.to(device),target.to(device)
   optimizer.zero_grad()
   outputs = model(inputs)
   loss = criterion(outputs, target)
   loss.backward()
   optimizer.step()
   running_loss += loss.item()
   if batch_idx % 300 == 299:
       print('[%d,%.5d] loss:%.3f' % (epoch + 1, batch_idx + 1, running_loss / 2000))
       running_loss = 0.0
def test():
correct=0
total=0
with torch.no_grad():
for data in test_loader:
       inputs,target=data
       outputs=model(inputs)
       _,predicted=torch.max(outputs.data,dim=1)
       total+=target.size(0)
       correct+=(predicted==target).sum().item()
print('Accuracy on test set:%d %% [%d%d]' %(100*correct/total,correct,total))
if name ==' main ':
for epoch in range(10):
train(epoch)
   test()
运行结果
(1)batch_size:64,训练次数:10
(2)batch_size:128,训练次数:10
(3)batch_size:128,训练次数:10
结语
对比单个全连接网络,在卷积神经网络层的加持下,初始时,整个神经网络模型的性能显著提升,准确率最低为96%。在batch_size:64,训练次数:100情况下,准确率达到99%。下一阶在平均池化,3*3卷积核,以及不同通道数的情况下,探索对模型性能的影响。
  • 代码
  • 数据集
  • 卷积神经网络
    基于赛灵思FPGA的卷积神经网络实现设计
    FPGA 上实现卷积神经网络 (CNN)。CNN 是一类深度神经网络,在处理大规模图像识别任务以及与机器学习类似的其他问题方面已大获成功。在当前案例中,针对在 FPGA 上
    发表于 06-19 07:24
    卷积神经网络如何使用
    卷积神经网络(CNN)究竟是什么,鉴于神经网络在工程上经历了曲折的历史,您为什么还会在意它呢? 对于这些非常中肯的问题,我们似乎可以给出相对简明的答案。
    发表于 07-17 07:21
    卷积神经网络一维卷积的处理过程
    以前的神经网络几乎都是部署在云端(服务器上),设备端采集到数据通过网络发送给服务器做inference(推理),结果再通过网络返回给设备端。
    发表于 12-23 06:16
    卷积神经网络模型发展及应用
    的过程中存在梯度消失的问题[23],神经网络再 次慢慢淡出人们的视线。1998 年 LeCun 发明了 LeNet-5,并在 Mnist 数据 达到 98%以上的识别准确率,形成影响
    发表于 08-02 10:39
    卷积神经网络简介:什么是机器学习?
    的理想卷积神经网络与其他类型的网络之间的主要区别在于它们处理数据的方式。通过过滤,将连续检查
    发表于 02-23 20:11
    卷积神经网络的应用 卷积神经网络通常用来处理什么
    神经网络卷积神经网络广泛用于图像识别、自然语言处理、视频处理等方面。本文将对卷积神经网络的应用进行详尽、详实、细致的介绍,以及
    的头像 发表于 08-21 16:41 5115次阅读
    卷积神经网络的基本原理 卷积神经网络发展 卷积神经网络三大特点
    中最重要的神经网络之一。它是一种由多个卷积层和池化层(也可称为下采样层)组成的神经网络。CNN 的基本思想是以图像为输入,通过网络
    的头像 发表于 08-21 16:49 2672次阅读
    卷积神经网络层级结构 卷积神经网络卷积层讲解
    分类、目标检测、人脸识别等。卷积神经网络的核心是卷积层和池化层,它们构成了网络的主干,实现了对
    的头像 发表于 08-21 16:49 9150次阅读
    卷积神经网络的介绍 什么是卷积神经网络算法
    卷积神经网络的介绍 什么是卷积神经网络算法 卷积神经网络涉及的关键技术
    的头像 发表于 08-21 16:49 1993次阅读
    卷积神经网络和深度神经网络的优缺点 卷积神经网络和深度神经网络的区别
    深度神经网络是一种基于神经网络的机器学习算法,其主要特点是由多层神经元构成,可以根据数据自动调整神经元之间的权重,从而
    发表于 08-21 17:07 4300次阅读
    cnn卷积神经网络算法 cnn卷积神经网络模型
    cnn卷积神经网络算法 cnn卷积神经网络模型 卷积神经网络(CNN)是一种特殊的
    的头像 发表于 08-21 17:15 2254次阅读
    卷积神经网络的原理与实现
    核心思想是通过卷积操作提取输入数据的特征。与传统的神经网络不同,卷积神经网络具有参数共享和局部连
    的头像 发表于 07-02 16:47 779次阅读
    卷积神经网络训练的是什么
    、训练过程以及应用场景。 1. 卷积神经网络的基本概念 1.1 卷积神经网络的定义 卷积神经网络
    的头像 发表于 07-03 09:15 576次阅读
    cnn卷积神经网络分类有哪些
    卷积神经网络概述 卷积神经网络(Convolutional Neural Network,简称CNN)是一种深度学习模型,由多层卷积层和池
    的头像 发表于 07-03 09:28 817次阅读
    卷积神经网络分类方法有哪些
    ,包括基本原理、常见架构、优化策略、应用场景等。 1. 卷积神经网络的基本原理 卷积神经网络是一种前馈神经网络,其核心思想是
    的头像 发表于 07-03 09:40 594次阅读
