华为路由器是怎样通过三层交换机实现全网互通及访问外网的
网络技术干货圈 来源:CSDN 2023-03-06 09:31 次阅读
实验拓扑
拓扑分析
Access交换机配置直接可以当作二层交换机,只需要划分vlan10、vlan20两个vlan即可。
SW2 g0/0/22 不需要配IP地址,配置成trunk类型。并且创建vlan10 vlan20 ,分别给这两个vlan配置虚接口IP:Vlanif10 192.168.10.254 24,Vlanif20 192.168.20.254 24
SW2 g0/0/24 不需要配IP地址,只能把G0/0/24加入到vlan99,vlan99配置IP地址接口类型Access,同样需要给vlan99配置虚接口:Vlanif99 192.168.99.1,用于和路由器(R1)的g0/0/0通讯。
配置步骤
PC配置IP、子掩码、网关
SW1上二层交换机上划分VLAN,并把相应的PC接口加入
SW1、SW2之间的两个端口配置Trunk
SW2上面配置创建VLAN10/20/99,配置VTP,并把24口加入到vlan99,最后加一条静态路由指向网关。
R1配置接口信息,添加静态路由
R2配置接口信息,添加静态路由
SW1 Access接入交换机配置
Access交换机我们可以当他是二层交换机
Thedeviceisrunning!
sys
Entersystemview,returnuserviewwithCtrl+Z.
[Huawei]sysAccess
[Access]undoinfo-centerenable#关闭消息提示,这个很烦人
Info:Informationcenterisdisabled.
[Access]vlanbatch1020
Info:Thisoperationmaytakeafewseconds.Pleasewaitforamoment...done.
[Access]intg0/0/1
[Access-GigabitEthernet0/0/1]
[Access-GigabitEthernet0/0/1]portlink-typeaccess
[Access-GigabitEthernet0/0/1]portdefaultvlan10
[Access-GigabitEthernet0/0/1]intg0/0/2
[Access-GigabitEthernet0/0/2]portlink-typeaccess
[Access-GigabitEthernet0/0/2]portdefaultvlan20
[Access-GigabitEthernet0/0/2]q
[Access]intg0/0/22
[Access-GigabitEthernet0/0/22]portlink-typetrunk#配置22为trunk
[Access-GigabitEthernet0/0/22]porttrunkallow-passvlan1020#允许vlan10和20通过
[Access-GigabitEthernet0/0/22]q
[Access]Userinterfacecon0isavailable
SW2三层交换机的配置
Thedeviceisrunning!
sys
[Huawei]syssw2
[sw2]
[sw2]undoinfo-centerenable#关闭消息提示
[sw2]
[sw2]vlanbatch1020
[sw2]intg0/0/22
[sw2-GigabitEthernet0/0/22]portlink-typetrunk
[sw2-GigabitEthernet0/0/22]porttrallvlan1020
[sw2-GigabitEthernet0/0/22]porttrunkallow-passvlan1020
[sw2-GigabitEthernet0/0/22]q
[sw2]interfaceVlanif10#进入vlan10
[sw2-Vlanif10]ipadd192.168.10.25424#给vlan10虚接口配置IP192.168.10.254
[sw2-Vlanif10]q
[sw2]interfaceVlanif20
[sw2-Vlanif20]ipadd192.168.20.25424#给vlan20虚接口配置IP192.168.20.254
[sw2-Vlanif20]q
[sw2]vlan99#创建vlan99
[sw2-vlan99]q
[sw2]intg0/0/24
[sw2-GigabitEthernet0/0/24]portlink-typeaccess#g0/0/24需要配成access 来源:网络技术干货圈
[sw2-GigabitEthernet0/0/24]portdefaultvlan99#g0/0/24加入vlan99
[sw2-GigabitEthernet0/0/24]q
[sw2]interfaceVlanif99
[sw2-Vlanif99]ipadd192.168.99.124#给Vlan99虚接口配置IP192.168.99.1
[sw2-Vlanif99]q
[sw2]iproute-static0.0.0.00.0.0.0192.168.99.2#加入静态路由只想网关
PleasePressENTER.
R1路由器配置
Thedeviceisrunning!
sys
[Huawei]sysR1
[R1]undoinfo-centerenable
[R1]intg0/0/0
[R1-GigabitEthernet0/0/0]ipadd192.168.99.224
[R1-GigabitEthernet0/0/0]q
[R1]iproute-static192.168.10.024192.168.99.1#加入静态路由
[R1]iproute-static192.168.20.024192.168.99.1#加入静态路由
[R1]iproute-static192.168.30.02410.10.30.2#加入静态路由
[R1]displayiprouting-table#查看路由表
RouteFlags:R-relay,D-downloadtofib
RoutingTables:Public
Destinations:13Routes:13
Destination/MaskProtoPreCostFlagsNextHopInterface
10.10.30.0/24Direct00D10.10.30.1GigabitEthernet0/0/1
10.10.30.1/32Direct00D127.0.0.1GigabitEthernet0/0/1
10.10.30.255/32Direct00D127.0.0.1GigabitEthernet0/0/1
127.0.0.0/8Direct00D127.0.0.1InLoopBack0
127.0.0.1/32Direct00D127.0.0.1InLoopBack0
127.255.255.255/32Direct00D127.0.0.1InLoopBack0
`192.168.10.0/24`Static600RD192.168.99.1GigabitEthernet0/0/0
`192.168.20.0/24`Static600RD192.168.99.1GigabitEthernet0/0/0
`192.168.30.0/24`Static600RD10.10.30.2GigabitEthernet0/0/1
#上面这3条是我们加的
192.168.99.0/24Direct00D192.168.99.2GigabitEthernet0/0/0
192.168.99.2/32Direct00D127.0.0.1GigabitEthernet0/0/0
192.168.99.255/32Direct00D127.0.0.1GigabitEthernet0/0/0
255.255.255.255/32Direct00D127.0.0.1InLoopBack0
[R1]
R2路由器配置
sys
[Huawei]sysR2
[R2]
[R2]intg0/0/0
[R2-GigabitEthernet0/0/0]ipadd10.10.30.224
[R2-GigabitEthernet0/0/0]q
[R2]iproute-static0.0.0.00.0.0.010.10.30.1
[R2]
[R2]intg0/0/1
[R2-GigabitEthernet0/0/1]ipadd192.168.30.25424
验证结果
用PC1ping PC3
PC>ping192.168.30.1
Ping192.168.30.1:32databytes,PressCtrl_Ctobreak
Requesttimeout!
From192.168.30.1:bytes=32seq=2ttl=125time=63ms
From192.168.30.1:bytes=32seq=3ttl=125time=47ms
From192.168.30.1:bytes=32seq=4ttl=125time=62ms
From192.168.30.1:bytes=32seq=5ttl=125time=47ms
---192.168.30.1pingstatistics---
5packet(s)transmitted
4packet(s)received
20.00%packetloss
round-tripmin/avg/max=0/54/63ms
用PC2ping PC3
PC>ping192.168.30.1
From192.168.30.1:bytes=32seq=1ttl=125time=62ms
From192.168.30.1:bytes=32seq=2ttl=125time=47ms
From192.168.30.1:bytes=32seq=3ttl=125time=62ms
From192.168.30.1:bytes=32seq=4ttl=125time=47ms
From192.168.30.1:bytes=32seq=5ttl=125time=63ms
5packet(s)received
0.00%packetloss
round-tripmin/avg/max=47/56/63ms
PC>
审核编辑:刘清
  • 交换机
  • 路由器
  • VLAN技术
  • VTP
    VTP
原文标题:华为路由器:通过三层交换机实现全网互通及访问外网
文章出处:【微信号:网络技术干货圈,微信公众号:网络技术干货圈】欢迎添加关注!文章转载请注明出处。
    三层交换机工作原理
    “192.168.1.1”的计算机想与IP地址为“10.1.1.2”的计算机通信,因为它们不在同一子网里,必须通过路由器路由才能实现通信。 三层交换
    发表于 06-10 12:26
    交换机路由器
    网内的终端之间不能相互通信,增强了对网络内数据的访问控制。 交换机路由器是性能和功能的矛盾体,交换机
    发表于 01-08 17:42
    路由器交换机的区别
    相当于交换端口,路由器用于WAN-WAN之间的连接,可以解决异性网络之间转发分组,作用于网络;而交换机一般用于LAN-WAN的连接,交换机
    发表于 03-17 11:58
    三层交换机路由器的主要区别
    一、三层交换机路由器的主要区别 之所以有人搞不清三层交换机路由器之间的区别,最根本就是
    发表于 08-01 10:37 3346次阅读
    三层交换机路由器的比较
    三层交换机路由器的比较 为了适应网络应用深化带来的挑战,网络在规模和速度方向都在急剧发展,局域网的速度
    发表于 08-01 10:38 822次阅读
    三层交换机路由器和hub的比较分析
    关于三层交换机路由器,目前各个领域都应用的很广泛,包括hub(集线器),下面就对这者的区别进行详细的分析。之所以有人搞不清三层
    发表于 01-30 17:23 2315次阅读
    路由器三层交换机怎么实现端口聚合
    路由器间的端口聚合是三层端口的困绑,要求交换机的逻辑通道工作在三层模式下,使用no switchport 关闭二通道。并设置IP地址。
    发表于 12-05 16:28 1.9w次阅读
    <b class='flag-5'>路由器</b>与<b class='flag-5'>三层</b><b class='flag-5'>交换机</b>怎么<b class='flag-5'>实现</b>端口聚合
    普通路由器和二、三层交换机的不同
    交换机用于小型的局域网络,路由器工作在OSI模型的第三层---网络操作,三层
    发表于 02-21 14:21 2540次阅读
    普通<b class='flag-5'>路由器</b>和二、<b class='flag-5'>三层</b><b class='flag-5'>交换机</b>的不同
    三层交换机在企业组网中的应用
    根据此表直接从二通过而不是再次路由,从而消除了路由器进行路由选择而造成网络的延迟,提高了数据包转发的效率。另外,
    发表于 03-06 10:03 4382次阅读
    <b class='flag-5'>三层</b><b class='flag-5'>交换机</b>在企业组网中的应用
    三层交换机路由器转发速率快的原因
    我们都知道二交换机工作的数据链路层,依靠mac地址来进行数据通信的,而路由器是工作在网络,依靠ip地址来通信的,为了说明三层
    的头像 发表于 04-11 16:04 9427次阅读
    <b class='flag-5'>三层</b><b class='flag-5'>交换机</b>比<b class='flag-5'>路由器</b>转发速率快的原因
    三层交换机路由器的区别
    三层交换机在对第一个数据流进行路由后,它将会产生一个MAC地址与IP地址的映射表,当同样的数据流再次通过时,将根据此表直接从二
    的头像 发表于 05-18 15:10 4809次阅读
    华为实验:三层交换机路由器互联
    华为实验:三层交换机路由器互联
    的头像 发表于 01-05 09:35 3135次阅读
    深入解读路由器交换机三层交换机的区别
    随着以太网交换机的不断发展,现在的交换机提高了性能,其中虚拟网络和三层交换是最突出的。在三层交换
    的头像 发表于 09-29 17:36 1893次阅读
    深入解读<b class='flag-5'>路由器</b>、<b class='flag-5'>交换机</b>、<b class='flag-5'>三层</b><b class='flag-5'>交换机</b>的区别
    路由器三层交换机有什么区别?
    路由器三层交换机的基本概念。 路由器是一种能够在多个网络之间转发数据包的设备。它可以将数据包从源网络发送到目标网络,通过查找
    的头像 发表于 12-27 14:09 1079次阅读
    交换机三层交换机路由器,哪个才是王者?
    交换机三层交换机路由器,哪个才是王者? 二交换机
    的头像 发表于 02-04 11:03 1012次阅读
